View Full Version : Acura Integra
- engine mount installation
- front jacking point
- AC recharge, all in one cans or seperate content cans?
- Dyno'd the 94 GsR today
- cooling problems
- JDM climate control
- wtf part is this on my suspension
- honda cam install
- Pics of my car
- new zex nitrous air intake filter? good bad?
- increase stopping power on integra 90
- Seats Swapping....
- wooh! cam install 95% complete
- which tire to choose
- will 94+ gsr header fit on a b17 with mods?
- My.. Teg.. is.. gone.. (STOLEN)
- Rear seat ... broken ... help!!
- Idle with AC kicking on?
- Skunk2 manifold versus JG/Edelbrock, which one is better?
- Is this normal?
- Auto shift kit?
- Drive shaft or tranny problems??
- 10w30 motor oil in Manual Trans.
- What kind of torch did you use to bend your valve adjustment wrench..
- auto w/ exhaust
- problem with door locks
- what color is my car?
- bye bye teggy
- Axle Freeplay
- Black Spoon Shift Knob - BRAND NEW
- knowedable p72 users
- exhaust leak??
- Distributor play
- car wont start
- DA integra seat belt stuck!!.. help!
- 5 lug GSR convo..RSX wheels...help
- a/c Question
- ebay camber kit for integra 90-93
- Organizing a group buy of ViS carbon fiber hoods! All makes, models, and designs.
- Plugs for Type R Spoiler on a GSR
- !!!!!cam install last leg -questions !!!!HELP!!!
- Stock 92 Integra
- Air filter decided to fall off.
- Your opinion: 2000 GS-R with 84,000 miles
- question about the skunk2 short shifter
- GSR vs ITR alignment
- opinions on stage3s vs stage2s on the street?
- Probs with radiator hose
- Can I install 90-93 Spring only on a 94 integra ?
- Damn Oil Drain plug..
- Blue smoke! quick fix or tear down?
- need quick ground-control help needed
- OT: was searching summit racing v-tech gsr hahaha
- woke up to a tire with low air
- do 89-91 civic exhausts fit 90-93 tegs?
- SUM1 HELP!!!! I THINK I BLEW MY GSR
- Need some tips before heading up to IMPORT WARS tmrw ;)
- need help!!
- car pulls from side to side
- does anyone have a g2 stock axel back or aftermarket to get rid of?
- My Car Is Idling funny..???
- Rotors warped
- Alright guys i found this e-turbo thing a little sceptical but i said what the hell!
- sonofabitch, someone tore off my OEM rear skirts
- C-West
- having major sunroof trouble!!!
- B18b cams in B18a... worth 30 bucks????
- Can anyone with a stock-height integra help me out here?
- getting a 93-95 integra gsr
- gap in cam plates
- need help got a hesitation
- need help go hesitation
- brakes failed today help me!!!!!!
- 98 master cylinder
- Recommend good street clutch for GS-R (Stage1)?
- will the h22a engine fit in a 94 integra
- 91 Teg LS vs. GS differences??
- RoD KnoCK new bearings?
- only right tire has camber wear, help
- A/C went out. What could be wrong??
- Difference between GSR rear lower sway bar and ITR sway bar?
- Crazy AC problems
- need help with headers
- just finished my installation of type-r exhaust
- Throwing code 57 on ecu?
- secondary intake runners on b18c1 (turbo application) confused?
- Those running JRSC............
- NGK Coppers spark plugs....BKR6E-11 ??
- rear OEM lip
- Problem with rear hatch lock, please help
- b18c1 w/lsd
- Emission system cleaner - dealer rip off or needed service
- Anyone with p28 and GSR tranny?
- AEM intake gone BAD.
- Toyo Proxes T1-S?
- Throaty engine tune
- Difference between stock USDM & JDM suspension
- b18 diagram?
- anyone heard of a crower cam,valve,valve spring kit.
- What Radiator Do I need?????
- adding an extra fan on the C&R radiator
- does it matter how many bolts the cam gears have?
- Cluster lights, tail lights, parking lights went out...fuse problem
- URGENT!!! cam install help #2
- dynoed my car and friends stock R today. interesting result.
- My mods & quarter mile time ..... pls. looK
- Do Koni Specific GCs sit directly on C-clip or on the washer that sits on C-clip?
- If the itr wing is functional... is the gsr for asthetics?
- ANY INTEGRA OWNERS IN NORTH CAROLINA?
- Best Oil
- Checking/Changing Tranny Fluid
- Pics of Greddy Evo and S2k Conversion
- a/c problems
- !!!!!!!!!HELP - CRANK BOLT LOOSENS [cam install]!!!!!!!!!!!!!!
- NEED HELP....
- help! i think my teg is dying!!
- all motor lsvtec
- best cat back: evo, n1, thermal, rs-r, comtech...
- b18a1 and b18b1 exhaust manifold gaskets are they the same?
- Differences between Canadian and US GSRs??
- Idle doesnt increase with screw...
- Does harbor freight still have the valve adjustment tool...
- HELP...how do u remove window from 90 integra.
- need help on conversion from a/t to 5sp.. on 90 teg.
- JDM non-srs Steering wheel question?'s
- Anybody that has carfax please help!!!
- Last year of RS?
- What plugs with 50 shot NOS?
- suspension debate (help)
- Turbo cams
- how to remove pedal assembly on 90 teg???
- driving without oil
- Late engagement after new clutch master cylinder
- Suspension: Mild Drop, Smooth Ride Combos?
- Opinion on Ebay Mod
- Opinions on Visa Tires made my Falken
- Question about my intake
- Tire help, will it fit?
- Will Type R Airbox Fit?
- I just bought my fender
- Can extreme motor heat evaporate engine fluids?
- Got skunked...
- My "virgin" track run.. disappointed
- taller tires on 1995 Integra GSR?
- ITR LMA in GSR p72 head?
- Lease is up in 3 months on my 2000 GS-R, possible to negotiate buyout???
- Lookin for a 94+ integra ls for under 5gs
- Gas Mileage on 94 GSR?
- Never driven the GS-R in extreamly hot weather.......
- what fans to use with fluidyne rad.
- I dont want to pay $300 for installation of air/fuel and fuel level guages
- poor gas mileage. what could be the problem?
- GSR rear brake piston key
- Piston to valve clearance
- Cheap way to hit 13s with GS-R motor......
- J's Racing intake w/Apex-i power filter???
- KYOKUGEN Lug Nuts: lightweight and theft deterrant locking... your thoughts?
- How reliable is this part?
- sluggish startups...
- 3 piece mid wing
- b18b1 fuel pressure ???
- Ac and Ps pump/belts, where can i get them?
- Another shock/coilover
- P72 Skunk2 manifold - which intake arm: GS-R, ITR, or doesn't matter?
- 16.82 90-LS
- how do you wire up a resistor box for DSM injectors?
- transmission changes Help.
- what about this clutch?
- Idling problems, idle control valve?
- GM Synchromesh in the Teg
- Should i trade rims
- Climate control not lighting up. Where are the bulbs?
- Gauge install problem..
- Autometer guage question (A/F)
- need advice on torqe specs
- auto to standard LS what are the diferences??
- pcv valve on 96 ls motor?
- 92 GSR Springs - 2000 GSR springs
- Valve Cover Gasket, does it cause the car to over heat?
- my a/c isnt cold..how can i diagnose the problem?
- 2000 ls gude bullfrog throttle body
- Is my new used teg haunted by a ricer?
- Falken Azenis Tire Size Poll
- Ordering Bilstein shocks need help.
- Type of Gas
- Power Antenna
- busted a stud on the head
- is this a good price for a tranny?
- 370cc's with stage 2's.. What would you set yout VAFC at?
- Rubber housing underneath CAI...
- anyone in here with stock shocks on h&r race springs
- To All With WingsWest Rear Lips????
- neuspeed race on stock shocks?
- How hard is it to recharge your air conditioning?
- How to take out door panel off a 90 integra
- I'm so bummed
- Question for all 94+ integra with sunroofs
- How do you know when your axle is gone.?
- 205/45-16 Yokohama Parada Spec-2 or Kumho ECSTA Supra 712? Experienced drivers wanted
- is this a ggod price?...
- need some help with b17 numbers
- stuff on ebay
- help me diagnose overheating problem
- Clutch Prices?
- GSR is gone.. time for a new car... Type R or LS turbo?
- Advice on clutch
- Compression Tests
- gsr and type r axles??? ASAP
- ECU Question:
- compression #s for a healthy b18b
- does any one knw the curb weight of a 92 gsr
- A Question for those using the GC/AGX combo!
- Getting shocked evertime i enter/leave car!!
- ITR header + carsound + (missing piece)
- SUSPENSION
- car is shaking
- 01 itr o2 sensors fit on 97 ls?
- Car is shakin
- Where should I go to get my engine rebuilt???
- need help, check engine light
- How to tell if these rims are real Enkei RP01's?
- Need help ASAP with brakes... stuck ?
- 94~95 waterpump $47.45, 96~01 waterpump $90.60!!!?
- Low beams and DRL running at the same time
- Exhaust question
- just got my b18a head back.....
- suspension noise
- Recommended Tire Pressure???
- Starter Problem?
- Help!! 91 integra LX. at 5500+ RPM's, engine makes weird noise.
- Is this worth $13000?
- water pump
- B18C1 Crankshaft question
- JDM GS-R or USDM GS-R motor
- Failed Smog, Please help.
- Tokico Coilovers, yae or nae?
- What is the purpose of having a breather?
- 92 EG steering wheel in DA
- Selling the bits and pieces
- Anyone have Spring springs?
- Dyno Tuning Results
- NYC: Found a Stolen Integra
- what is this part!? someone help!
- need part numbers...
- looking to turbo 1992 acura integra ls anyne know were to find manifold that allows a/c
- Will B16 header fit on B18B
- Eibach Springs
- Motor Mount Symptoms?
- why cant a jdm engine pass smog in cali
- LS/RS Integra with 130k worth? to much?
