View Full Version : Acura Integra
- b20 rough idle?
- Cp pistons and Manley Rods
- What type of cams are these?
- a/c system recharge problem
- Timing belt/waterpump kit brand
- DA: lights, cd player, dash lights, clock, cigarette lighter not working
- b18b1 no throttle response, revs slowly
- Strange Part?
- check engine light on after changing timing belt and water pump
- 1995 GSR Exhaust Replacement
- will TYPE R LSD fit a GSR transmission
- need some input
- new motor or rebuild
- sunroof question
- 92 integra sedan lapbelt won't retract back in
- quick question
- question-built itr block
- Main relay???
- Integra Oil pan
- Need help on what OBD my harness is (rhd harness)
- harness tuck help dc2
- Running lean Integra
- How to ID a ls/b20 crank.
- gsr blades center cap question
- Is this good deal for 96 gsr?
- A/C compressor question
- Trailer hitch with pics
- JDM One Piece Headlights Questions.
- Pic Request - SSBP with Gold Wheels
- 92 integra reservoir and radiator problem please help
- GSR TRANNY HELP!?
- 1996 Integra DB8 Air Conditioning problem, need advice.
- integra rain visors/guards
- Need new spark plugs and wires??!!
- weird starting problems
- radiator overflow tank comp.
- GSR crank shaft/ b16a cam shaft?
- Question on camshafts
- GSR Swap
- Integra stolen last night
- Electrical Issues - Power Draining
- Quick build question???!
- lost???japanese writing on integra head?
- problem after installing my A/F ratio gauge
- Help with a B series tranny
- Cam shaft rail bolts
- Wot above 4k the tach cuts off and no vtec?
- engine start switch
- Poor Man Type R Piston ring help
- CAR OVERHEATING. Please help if you can.
- Will a EG cat fit my DC?
- Oil Consumption Study, Integra with 300+k Miles
- This problem is driving me effing nuts!!!.....
- Gauges don't work
- ((Gsr Secondary butterflies open)) Good idea???
- PROJECT: Free Integra aka DirtyDA
- DA9 tranny ground!!!
- Help me adjust the window on my DB7?
- transmission/clutch problems
- Going to the track today. Simple e85 question???
- question about a lsd half shaft??
- Rocker arm assembly P30 Head
- skunk2 coil help
- skunk2 spring help
- how do you plug aebs coolant port?
- A/C question
- Anyone one else trouble starting after fuel filter replacement?
- Ls Built? Internals?
- How to take out the rotor
- bad gas mileage in integra and bogging down.
- Engine losing power
- What is this?
- da9 leak
- 93 DA9 Problem with brake light
- B20B idle surge!!!
- NEED HELP WITH CRANKSHAft positioning please!!!
- 96 gsr eats lot of gas?like 120 miles full tank
- axle porblems
- Car wont start after swap fuel pump wont prime
- integra brakes?
- Blackout Or Stock JDM
- b16a2, Tune?
- LS turbo spark plug gap anyone know
- G3 Trailer Wiring
- Oil Pan
- 94 teggy LS (fuel)help
- parking/gauge lights trouble, please help
- Grinding sounds under semi-hard / hard acceleration
- HELP! GSR No Spark!
- timing belt torn, help me
- Quick Question
- vss senser help
- B18C1 Rebuild, what to do?
- integra sir-g emblem?
- Skunk2 mega Power RR 3inch Piping
- b18a1 w/ gsr piston,crank,rods?
- notchy shifter after clutch install
- 1990 DA build build help and suggestions
- B20 Swap
- Took my 97 teg out to the strip...hit a 14.357 :)
- 99 GS-R Harness Question.
- is a 96 integra gs an obd1 or 2
- *problems wit my 2g integra* dosent turn on
- Need help for my B18c1
- JDM Integra Type R Cluster Into 96 Integra GSR, Help
- Spark Lugs Problem HELP HELP
- Looking at getting a 92 integra, should I go for it?
- B18a1 Starting issue
- 92 integra water in MY TRUNK
- Water leaking in the trunk????
- CA State Ref Ticket
- problem with Da motor mounts
- changed timing belt. now no start HELP!!
- crankshaft wont lock down?
- GSR SWAP "power steering bracket"
- 95 teggy keeps getting oil on plugs an electro
- car is running when coming to a stop it drops idle and turns off
- CA Smog tougher or smog mistake? pics
- tune or no tune?
- E-brake wont hold
- project can o' worms: chunk of cylinder wall chipped?
- help identify gasket / seal ... DA
- Lower control arm bushings
- HELP, Ls Vtec Problem
- Noise in 1996 Integra
- Throttle Position Sensor repair. Another thing you may want to check.
- CEL 74, Random misfire cyl 4 causes????
- oil flow schematic
- Is it ok for rocker arms be loose like this?
- 99 auto to standard w/94 tranny?help
- Help with integra injectors
- ABS Delete prop valve question...
- Weird Coolant Leak!
- Trying to cut my springs
- 97 integra won't start unless I rig it
- h22 into integra
- comp clutch question
- B18 intake manifold
- NOOB QUESTION: My 2 front speakers arent working in my integra
- Best Exhaust Manifold-no expense spared
- 1991 acura integra gs auto trouble help me
- throwing code 22 in my 94 integra swap
- I failed CA SMOG today =[
- oil and coolant leak?
- Replacing 3rd Brake Light
- JDM One Piece Headlights Bulb Type
- A little Guidance please
- 95 GSR SMOG FAIL
- lower control arm question
- My 95 red integra gsr before and after pics..
- 95 GSR starting problems HELP!!! PLEASE!
- polish my intake?
- just picked up 92 DA this week.
- figured out why my car wouldnt start but??
- ANYONE have feedback about JDM Engine Depot in NJ?
- 2D Integra sunroof question.
- JDM to USDM?
- Crank Pully Bolt.
- what tire???
- car wont start
- need da service manual pdf
- Prelude 5 lug on Integras?
- speedometer help
- speedometer help
- Rpm surge with throttle steady.
- Teg burning oil/gas
- HELP with my GSR-T build
- Maryland Emissions Q
- 90 integra ls ac fan wont turn on...
- Samco Intake
- wheel color opinions needed for NHBP teg
- Swapping antennas
- JDM front end conversion question
- password jdm intake
- Integra is overheating
- O2 sensors help. Simple question!
- function and form lca
- bad motor mount?
- PCV flow question
- o2 sensor problem
- cable flywheel fit hydro tranny?
- help w/ possible motor swaps in my 96 teggy
- Brake lights won't work
- questions about injectors?
- Bad Mileage
- Blowby???
- No turn signals but hazards work!!!
- What injectors for Stock Motor B18c1 10Psi
- 93LS w/94 GSR needs tuning
- Clicking Noise and High Pitch Coming From Tranny, PLZ HELP!!
- Cusco 6PT for EG in a DC??
- Gas Problem!! Help!
- Potential problems with Auto to Manual swap?
- How many o2 sensors does a 95 GSR have?
- Squeling Noise Please Help?
- A/C question
- LST vs. JDM GSR vs. GSR-T
- cannot turn key
- integra fusebox under the hood question
- 91 integra w/b18b surging idle 24mpg?
- ac problem
- 95 GS-R: Hesitation / Bog During Acceleration
- GPS security system
- Quick question regarding Cam seals on B18b1 head!!
- My Exhaust Got Quiter???
- 94 Teggy help & short story.
- HELPPPP!!! Car won't start
- Quick relay question?
- 1997 Gsr Motor Questions
- b-series clutch kit/fly wheel
- Auto locks on my 98 LS
- My Integra Has No Power from 1-5000rpms? Help Needed
- engine wont start when its cold out
- where to buy wings west lip?
- My Integra
- having problems with my power windows door locks and folding mirrors please help...
- NEW build 3 questions
- Brake MC Upgrade ?
- Need help Re-wiring my headlights and bumper lights help ASAP!!
- Rear shock rattling (I think)
- Putting a turbo on a '91 integra
- shattered driver side rear window.
- need help
- LS header bolt on to a gsr head
- tired of bumpy ride plz help
- question about OEM Parts
- my pics of the teg =]
- 92 GSR the idle goes up and down help me fix it
- Milled head and new head gasket still leaking
- GSR swap or LS/vtec?
- Car Axle {HELP!}
- changing PCV on GSR?
- ls vtec
- DA in need of help
- 98 GSR wont start
- clutch or tranny problem?
- catch can
- wats better a b16 head or gsr head for my b18 ls
- alignment?
- auto to manual question
- branded headers vs ebay headers
- HELP: bolt removal advice needed (not lca)
- Black Box (pcv) HELP!
- Broke rear strut bolt. HELP!!!
- OBD2 LS Valve Cover on OBD1 Head
- Hood wont pop HELP
- Cleaning up the engine bay...
- help with my car engine
- 2000 gsr build, MINI photoshoot, gt powered, itr front
