View Full Version : Acura Integra
- GSR Crank or LS rods
- Integra Speakers
- 98+ Integra Headlights Needed!!!!
- another dumb question
- ls vtec
- Suspension For a gsr
- leaking oil pan gasket - little washers missing?
- anyone using an auto ecu for a manual?
- higher mileage=bad thing?
- Thinking about getting a GS
- Just replaced clutch and pedal is very, very soft...
- rim suggestion
- Just got my GSR tranny in my B20 LS!
- tell me why....
- strange brake behavior
- quick shifting question
- Ls/vtec smog legal?
- Help with transaction of a used car
- Turning Rotors when having brakes done?
- pulled the motor! lots of pics!! :)
- New to the board....WA state...just wanted to say hi!
- DA Carpet
- engine problem
- 91 integra rear seats.....
- LS Vtec. Best place to get the stuff?
- Cold water dripping on my feet?
- whats the difference between YS1 and S1 transmissions?
- Yes again, another rear window wiper removal question.
- aaarrrrgggg. Can't get the tranny back on...
- I broke a damn lug nut stud!
- Resurface flywheel location Socal
- ???Shifter linkage question???
- I broke my pcv valve!!!!
- stock '94 GSR wheels
- Brothers, 5 years from now....
- Mugen Rear Tower Bar Install
- Hi, I'm new
- remanufactured calipers?
- bad oil pump? vtec not working. please help
- 5 lug conversion
- should i take out my ac?
- boring a b18a
- I NEED A CARFAX ASAP!!!
- need help quick
- brake failure
- gsr head on stock ls?
- Spoon replica mirrors
- What are the negatives on relocating the ballast on the jdm oem itr headlight?
- how long do aem HP brake pads last?
- Check Engine light
- Brothers, i need some help
- Suzuki Esteem (Speedlines) wheels. Would they fit on Integra? Where to find/buy?
- Valve Cover Help
- 11:1 compression on a stock P72 ECU?
- Any 86-89 boys here? Where are you guys?
- B20b turbo>>>2nd GEn teggy
- AUTO TEGs...is there a seperate ecu to control autotranny??
- p72 in a 92 gsr
- Integra GSR weird electrical problem
- which route should i go 4 a project car
- 01 Integra Check Engine Light
- 94-97 Integra Mirror (glass itself) different from 98-01 Mirror?
- integra: price paid, year, mileage it had, model (rs, ls gs, gsr.)
- plz help **g2 question for friend**
- Cost of changing transmission?
- CEL back on
- what the hell is wrong with my motor mount!
- any point in purchasing CAM GEARS w/o I/E cams @ the moment?
- 202whp all motor gsr vs a stock v6 auto 2002 mustang?
- Question about headers
- (WTB) I need a obd2 harness, and also a obd1 ecu (integra GS-R)
- What size tire to get?
- Differences in 95' gsr block and 96' gsr block?
- Decisions...Decisions... maybe b18c5/jdmb18c? or k20?
- Integra Engine Swap GSR or H22?
- DOES ANYBODY HAVE A GSR TRANNY?! I MUST HAVE!!
- Can we buy white door protectors?
- want a car?? i need one manual tranny??
- WTB!
- B18c5 bare longblock in gsr questions
- 99 integra CEL
- ITR 5 lug conversion
- Some questions about 2nd-gen GS-R.
- Problems adjusting headlights
- How low should I go? coilovers
- throwing code 22 VTEC pressure valve, whats that mean?
- Clutch/Shifter feeling rough and "grindy"?
- Good h4h bulb for da one peices?
- advanced timing and now car hesitates? why?
- Hondata dyno of my LS all motor Teg
- whats wrong
- pics
- My new Upgrades finally came!!!
- help- new integra is hiding a fuse from me
- 94 LS - First time on the strip... any pointers
- SMOG TEST = FAIL (please help)
- Tranny Grinding...
- Best Handling Suspension Setup (springs, shocks/struts, camber kit)
- type r lip
- torque specs for exhaust manifold?
- damn!! $200-$250 to cover the 4 holes from taking off my wing?
- HELP: taking off the shift boot panel to real the dust boost with the shifter
- Could Koni Yellows for 96-00 civic fit a 2000 integra?
- 94up interga caliper
- chipped pr4 ecu anyone?
- What is the thickness of a stock P72 head?
- bad brakes (master cylinder?)
- USDM ITR front and rear end
- 4500 vtec????
- LS/Vtecs and Strokers....
- New Girl
- JDM GSR?? or boost the old LS??
- What do you guys thinkg about trading integs?
- slicks
- jdm b16 auto tranny direct swap into my auto 94 LS?
- rsx exhaust on an ls?
- Restoration of Carbon Fiber Hood
- good cheap drop springs
- Oil Pump Oil Seal Installation?????
- Who Wants OEM SIDE SKIRTS FOR THERE TEG 100% OEM brand new
- whats in a rebuild engine?
- Weird, car died after hard braking???
- Brake Rotor Screws - are they necessary?
- Intake Manifold Question...
- 2nd gen integra ls shell n motor 4 sale
- Brakes or something clicking
- does the 90-93 integra use hydro or cable transmission?
- QUESTION: LS/Vtec what's a good shifting point? Redline?
- PasswordJDM?
- GSR swap into 95 LS- how to?!
- hazard lights don't work...
- Hot/Cold lever broke
- DOES ANYBODY HAVE A JDM GSR (b18c1) ENGINE FOR SALE?! I NEED IT BAD!!
- How much do you think this Integra GSR is worth?
- need help identifying gsr cams
- wtb stock cat for ls in bay area
- car has been bogging, need help.
- stupid question + pics.
- Puffing white smoke, and ideas?
- going straight to HOT!!
- need carfax Please!
- idle probs wit my gsr
- Best intake manifold for an Ls/vtec conversion????
- ls vtec question
- anyone know whats wrong with my headlights?
- cv boots?
- Lowering suspension unsafe?
- 2.5 Header Collector Gasket **help**
- Just how quiet/loud is the RS*R ExMag exhaust?
- LS / VTEC?
- window tint
- Need JDM Front End?
- Which clutch for JDM YS1 cable trans?
- ecu question
- Dual Gauge A-pillar pod Q
- e brake tension
- New interior on my gsr
- brakes are working weird
- dowel pin removal
- clicking noise
- Tanabe RM loudness!
- JDM ITR conversion w/headlights???
- AC questions... Please lend me your expertese
- K20 engine swap
- SAD DAY, RIP to my Buddy's GSR.................
- a/c compressor compatibility - B-series
- Can i bypass knock sensor on 94 GSR?
- tranny problems
- made a JDM ITR cluster the ghetto way.. posted for your enjoyment
- tein ss
- 94 integra HELP!
- Alrite guys, its another HID ???
- header of choice low-mid range pooWAA
- 94-7 inner fender wall on a 98+ ?
- How can you tell if the ecu is junk?
- speedometer not working!
- Air Conditioning will not turn on
- tell me what i need for lsvtec turbo
- Need Help - Installing a Greddy Oil Cooler in 98 Integra
- Rear wiper removal. Part #'s !!
- mugen style muffler?
- preparing for a show
- 92 GSR ARMREST
- ls or gsr distributer for a lsvtec swap
- 94 Radiator Support
- F_cking Continental Acura dealer!!
- Going to get car painted, need help
- New to Honda-tech
- Aem Fuel Rail **i cant figure this out..please helP**
- Brake Bleeding HELP
- radiator-barn
- integra for sale
- Interior change
- Car doesnt start
- Where can I get these brake pads for a good price?
- fast blinkers
- soft clutch pedal??
- Hesitating at Low RPM's, after 3000 RPM's, runs okay...
- where to clover green pearl spraycans?
- What engines can fit in my 90 Itegra LS???
- engine/tranny combo
- 1994-00 Integra LS take a B18C?
- help and opinion!
- Help with Tranny for GSR
- has anyone tryed the carquest reman axles?
- new muffler gsr
- WRECK MY DB8 Need some advice?
- airbag replacement
- NEW GSR
- Good Setup?
- painting ITR lip yourself
- Got a problem with my 92 GSR
- FINALLY!!
- weird leaking problem!!!
- What is needed to get the trailing arm off an integra?
- Something is stopped up.....but what is it?
- New Teggy Owner!!!
- Did the 96 LS model ever come with 15 inch wheels.....
- PR4 ecu diagram?
- Replacing front hub.......NEED HELP!!!
- pcv valve on 90 integra
- ne one in the NY area know good junkyards?
- 98-01 amber bumper lenses?
- Car/Motor surges.. Plz help
- how much u think i could get for these LS seats?
- does tar help or hurt?
- Air Horns?
- First Integra!!!
- New INTEGRA owner!!
- Which tranny?
- GReddy/GREX strut bar for DA
- intake question
- low idle
- how can you make your car ALMOST un-jackable?
- Cable Tranny Adjustment....
- Value of Integras going up?
- HELP!!! - Looking for shop for a B18C swap in a 95 INTEGRA SE - Orange County CA
- jdm itr cams vs. ctr cams
- b18c bottom / b16 head
- code 15...Distributor keeps deing
- maintenance light coming on
- maintenance question
- HELP!!!trimming suspension bumpers?
- 94-01 turn signal brackets....
- exhaust rattle is killing me!
- ANYONE WITH BLACK GSR LEATHER SEATS
- extreme front bumper trade
- Timing problems I think, anyone know the answer?
- universal fit carsound
- size of comptech sport for ls.
