View Full Version : Acura Integra
- 90-93 DA COILOVERS?
- 90 DA with idle problem
- Alternative B series tranny philosophy......Integra LS 5th gear
- Stock Springs...Which is for Fronts? Which is for Rears?
- How do you get a cam seal off?
- i would be appreciate if you guys can tell me how to install light bulbs in my 94 integ
- GSR/LS radiator
- engine questiomn?
- HELP light keeps comming on!!!!
- Pic Request: 94-01 2 door integra seats in 4 door sedan
- mechanic needed...
- 99 ls engine..Help Needed****
- bumper crack. help fix! plz
- h22 swap in dc
- 1992 Acura Integra GS, Front Bumper Gap Issue, Help Please
- Cam question
- California smog numbers. 94-95 OBD1 B18C1 DOHC Integra GSR motor
- obd1 gsr vs. ls distributor?
- Planning on selling my Integra
- CEL throwing code 43... Any experience?
- integra body parts question?!?!
- battery sucks at starting when cold.
- Help ASAP --> 96 Integra w/B20 Swap. Engine will NOT turn over.
- JDM vtec solinoids have no pressure switch... question
- Recently traded my 93 DB2 for near stock 97 DB8!
- cel light on..
- EVAP purge valve different on ODB1 and ODB2?
- removing/eliminating antenna
- what offset?
- guage cluster pinouts
- B18c1 with CTR N1 pulley what belt to use?
- :Repairing Shift Knob
- TYPE R MOTOR SWAP
- lip question?
- stock exhaust piping size?
- auto manual conversion
- True or False
- Just got into an accident last night!!!!!
- Removing The Rear Seats In My Integra
- VSS location and question
- NEW to HT how long before i can buy parts
- 88 integra fuel guage
- flashing OIL light
- Flashing old light?
- Need some wiring diagrams for clusters
- Anyone here ever use Dynomat or Sound Deaden their Integra?
- i think i moved into a bad neighborhood.....
- How HOT?
- Couple Randon Questions
- Will 96-00 civic shocks fit a 95 Integra?
- NEED HELP WITH DC WITH PA SALVAGE TITLE HELP HELP
- timing
- ls/vtec computer??
- need help routing the cold air idle control?
- What kind of power is a stock LS block capable of, all-motor? Dyno sheet + mod list.
- oil every where.
- ls vtec question...
- Interchangable EF parts to a DA. (Searched)
- bad mpg... concerned
- Will water get into CAI if splash guard in place correctly?
- AC fan harness??
- ECU codes pissing me off
- code 20 ELD i blew the fuel pump fuse and now it is on
- 95 RS w/ Greddy Turbo kit
- Can anyone recommend a good & fair priced mechanic in Orlando area?
- Problem in high rev? Error code 4, 5, and 6
- Noise from intake
- 94-97 jdm front conversion.
- rear lower seat cushion in DA?
- fuel help on a b18b boosted motor
- Taking Suggestions, What Would You Do Next? 1992 Acura Integra GS
- 90-93 Integra Front bumper (after market lip)
- would a 99 si rear lca fit a 96 integra??
- Substitute for ITR rear LCA's
- quick question regarding head bolts.
- Color Code on Stock springs
- exuast
- Are all the B serie axles the same? hydro and cable?
- 1 obnoxious buzz + 3 different mufflers= me about to go postal on my car!!!!!!!!!!!!
- what bumper is this for the jdm front???
- noise under car in the rear
- JDM ENGINES FOR SALE B18C5, H22A, B16B, ETC....
- Headlight Help!
- good full coilover suspention for a DA
- New JDM B18B, Please Help!
- LS/V TURBO SUGGESTIONS
- transmission question
- 95 gsr sedan questions
- gutting engine bay, help
- what can i get rid of?
- Is it worth spending any cash on my GSR?
- steering wheel removal DIY
- Temp gauge?
- Will my 92-95 coilovers fit on my 93 integra?(already searched)
- Confused about cooling system
- whats the difference???
- Will my 2000 gsr take a 96 JDM gsr block?
- how to visually make sure vtec is working?
- wheather stripping
- im having alot of trouble choosing what i want to do..
- b18 manifold
- JDM ITR Header
- Should I get 98 Teg LS with 90k miles for $3.8k? carfax anyone?
- Piston fireing order
- tan inteior owners
- buying a dc....one problem please help
- pilot bearing into flywheel problem
- just wondering if ittle work or not?
- Do we need an DIY A/C removal thread?
- Need help findinf white wheels for a GSR
- just a quick & stupid question...
- stock speakers
- need vacuum diagram
- cluth fluid slowly leakin.
- Fully built b seiries or k20?
- NEED TO BUY B18C ROCKERARMS BADLY
- I need 98-01 parts!
- Steering Column / Ignition Woes (wont start after new column + sitting for 3 monthes)
- CAR WONT START!!
- How does Honda make the GSR 30hp more than the LS?
- NEED b18c rockerarms
- Where to install ITR Front End Conversion and get a quality paint job in SoCal?
- neuspeed + koni yellows? any good?
- rGSR SKUNK2 IM, p73 cable?
- Where can i get a b20Z?
- this is wierd
- turbo manifold fitment
- 90-93 teg guys, can someone take a picture of the throttle cable attachment??? on pedal??
- Exhaust for my DA
- Starter Won't Crank
- CEL code 92 Evaporative emission purge problem. what to do?
- Misfire
- Engine running but car won't move (help)
- Ground Control Coilover Question...
- How to identify an ITR block
- weird noise @ ~ 1050 RPM & 2000 RPM
- new motor??
- How much money would be needed for my car to pass smog?
- Since I cant post in the MARKETPLACE... 94-01 Type R Wing For SaLe
- Which ARP Head Studs?
- DA integra brakes on a DC????
- Can someone recommend a resonated testpipe
- When turning car jerky and makes a grinding noise.
- Is this acura a good or no?
- Big question for an immediate swap porject reply at ill_s_trait559@yahoo.com
- spray paint on cf hood
- H&R or Eibach
- How not to blow a Headgasket?
- NEED a set of GSR ROCKERARMS and VALVETRAIN
- B-series Transmission Question
- B18B1 replacement
- motor swap
- Launching?
- ********VTEC CONTROLL??*********
- Simple Integra Question
- shifter bolt gets loose !
- tuning ecu
- just need to confirm, are these ITR Cams?
- any way to tell what year an ECU from from?
- B18A1 N/A
- pics some feedback if u please
- Using Gasket Maker On Head?
- Were to order a Jdm B16 with a cable tranny .. looked everywhere no luck !
- B20 injectors fit the same as B16, B18 injectors?
- pics only if u want to look
- Need to purchase rear speakers 95 Teg sedan...
- tail lights
- help on back trunk leaks please..
- intermediate shaft
- HELP...IT WON'T STAY ON!!!
- 98 hatch swap
- 15x7 +15 for
- taking a vtec head apart
- What's the story on XS Power?
- my 99blackls
- 92 check engine/no start
- bolt on, but runs the same at the track.
- Type R Spoon Style Lip???
- Rear Valence square bolt
- da9 ls/vtec start up!
- my DIY air intake setup...
- Hasport Mount Question
- aftermarket steering wheel
- B20B into 91 LS HELP
- successful OBD II motor swaps into OBD I integra?
- OBD-0 or OBD-1
- Shark II vs. MDX Atenna
- oil leak/milky residue out of downpipe leaking like crazy!!! please HELP!!!
- vtec killer cams
- gsr motor build...need suggestions
- would a saab t-25 fit a inline pro a/c manifold?
- jackshaft bearing??
- rims issue
- Registration bullshit
- timing cover question
- lightened crank pulleys
- having trouble
- Should I be able to compress rear caliper piston if...
- difference between.....
- need torque specs for head
- How do you make the JDM front w/oem hid's fit into 95 integra with abs
- Dropping back in the engine, but WhereTF is this sposed to go??
- Running too rich!!!
- Stock Gsr(dc2 hatch) or Si(ej cpupe)
- DC integra fog lights
- Question about skunk2 intake mani.
- Looking for Website to buy stock interior pieces
- What is the difference from a dc2 and dc4?
- Where can I find the ecu codes for OBD1?
- How does this fit?
- obx-r or quaife
- Got CAI......whistling noise????wth
- ********CUZTOM*********
- what kinda MSD is this? and how do i remove it and get back to STOCK?
- compression test dissapointment...
- carpet
- B18B cheap power
- Junkyard question
- turbo timer question
- Few Questions Regarding Pistons
- Help! OBD2 integra Main forewall harness to OBD1 integra
- vtec wont ingauge at high rpm
- 97 to 98+ bumper question HELP!
- i dont knw if this will work...?
- Fuel Pressure Regulator and Nitro and more Qs
- Car wont start! Help......
- Fuel Pressure Regulator + Throttle Position Sensor
- burning clutch?
- Aftermarket Fuel Pressure Regulator Question
- ecu types...
- Coolant Trouble 1999 GSR
- valve springs and retainers
- Motor philosophy
- help auto to manual swap, wont rev past 3k rpm
- Integra break down What years = DA and DC
- A few pricing questions.
- Suspension Question?
- Is this a deal or what- DC sports for 94-99 GSR on EBay?
- ls and gsr trans
- broke crank pulley
- Question bout my Acura Integra
- exhaust question
- a/c turbo manifold for integra ls???
- Outer Tie Rod Ends - mine are shot, but I have no idea what they are!
- ecu question
- high compression ls/vtec?
- FINALLY DA BILLET MOUNTS FOR DA OWNERS..!!!!
- turbo hook uppps
- Anyone try out the BFgoodrich G-Force KDW tires??
- 90 integra cant pass "NOX" Emissions...
