View Full Version : Acura Integra
- which intake? short ram or cold-air?
- power steering rack
- Cant decide on tires for 15x6.5 wheels..
- selling my rear very cheap
- ls/vtec just about to get toda cams and cam gears
- 2nd gen GSR throtle prob. need help.
- DC header
- Anyone prefer non vtec over vtec?? And why?
- h22 integra axle problems
- ideas on fixing this broken stud.... (pic)
- Clutch Master Cylinder
- Autometer guage install....
- b series fuel rail
- springs?
- what do these #'s mean on the sterring knuckles?
- ENGINE BOLTS FOR MY ENGINE STAND
- Integra VIN # help
- Major grinding..then goes away..stuck starter?
- Comptech Exhaust 98 GSR
- 94 integra rs , car does not run, need some input
- Performance Comparison Site???
- How much for a 99GSR
- Good Dealer Experience - Buchanan Jenkins, Ft Pierce FL
- Crower 62403 vs 62404 vs 62405A
- The color of my car??
- some pics from Drift Atlanta including RWD teg (56k friendly)
- teg is Sluggish after VAFC install, need help
- JG Throttle body?...need help...
- 8K everyday?
- Stock '00 LS gas mileage - is this bad?
- LSD QUESTION
- a few issues with a obd2 B16A2 into 95 LS...
- Gen2 owners.....
- Coilovers on Stock struts...
- How to S2K seats?
- Valve Springs on ITR Cam
- GE 9005 super blue
- NEW fake mugen strut bar!
- stock gsr ecu with skunk2 im
- bent rim, where can i get 1 rota!
- what tranny are y80 and s80
- PISTON RINGS - THE GAP?
- Radiator problem, need some help ...
- Tranny Code Issue. Is it a GSR or LS, YOU TELL ME.
- 95 GSR spoiler
- Ignition trouble? I think
- Driver Side Rear View Mirror
- difference in a 4-2-1 and a 4-1?
- 5 BOLT CONVERSION FOR LS
- Check Engine light came on...???
- rear brake pads help
- which cat-back for 91'
- Mileage
- top fuel rear lip?
- Failed smog, suggestions?
- HUGE PROBLEM NEED HELP!!!
- CRV Pistons
- front lip for 94 teg?
- neuspeed stainless steel brake line...are they any good?
- fellow teg owners
- sell the integra??
- questions on high octane
- need to BORROW a cut vtec valve cover for cam gear tuning help!
- AC harness question , please help =)
- Cooling fan wires burning?
- help plz
- Oil Capacity of 00 GSR !!
- what exactly open the secondaries?
- running rough and smell gas inside cabin
- GSR/ITR front sway changeover on LS
- Anyone have a carfax account?
- oil pan gasket question
- car wont start.....just put stock IM back on.
- JDM ITR front end conversion q's
- my new lss
- suspension choices!@!@
- Big Brake Problems! Need Help Quick!
- Ross 84.5mm ring gap help! Did search!!
- the jump
- tire rubbing problems w/ neuspeed race
- Lazy sunday afternoon chat
- PIAA 1400 Fog
- PCV install?
- suspension for DA9
- Exhausts Apexi or Greddy?
- I need some help finding springs with the right drop for my DA9.
- electical or mechanincal??
- OEM spark plugs pre-gapped?
- difference between a gsr and ls
- Lost remote and key, what should I do?
- DRIVE Master Cylinder Brace anyone have one?
- JDM ITR final drive in JDM YS1?
- CARB legal????
- Surging Idle?
- DC Sports Exhaust
- Suspension Questions
- Hey im new :D
- 3" or other fat exhaust vs. cops
- Are these NA dyno #'s right?
- Grinding Gears.. How to Prevent it from Happening?
- custom exhaust. use flange?
- synthetic oil not good for high mileage vehicles?
- Rocker arm Question.
- How much power loss with too large of exhaust?
- casting number question
- Teg driver needs help
- Clutch squeeking?!?
- BOLTS FOR ENGINE STAND!?!?!
- where to find 2001 four door?
- harmonic balencer ?!?!?!? help please
- Maxima HID install help?
- what looks nicer?
- reciept for cluster
- Life's Little Lessons: Clutch Edition
- usdm itr pistons for 2000 gsr
- Short ram for 88 integra???
- koni yellows/hr race noisy?
- passenger door jammed? (searched)
- Idle air control valve and Skunk2 IM
- needles fell offa gauge cluster help!!!!!
- LS VTEC
- hole in tranny, possible to fix?
- Part number for a 1996 Integra GSR IACV?
- Where'd my post go?
- a few pics of my DC4
- question? engine and head is different years. does it matter?
- tickin in engine
- check engine light..
- Can the new AEM V2 cai, fit into a 92' LS Integra(non-vtec)???
- JDM B16 swap. ECU fuse keeps blowing!!!
- Power steering
- awd integra
- Free VIN check?
- koni's and ground controls
- camber kit questions
- MSRP on 2nd gen tegs?
- HELP: TRANNY WON'T GO INTO FIRST, SECOND, FIFTH AND REVERSE GEAR
- Teg, with Js style racing intake and ABS?
- Hatch Problem--Please Help...
- Attentio Bay Area People!
- DC vs. RSR vs. Comptech
- Skunk 2 short shift problems
- laptop in the car
- E-Brake light comes on...
- Poor Mans ITR On a GSR
- New Swap....Light Clutch pedal?? Help!!
- looking for a clean LS motor
- Venom Performance Chip
- snapped wheel stud
- 85 300zx in 94 Acura Integra
- Hey guys, sold my car but never posted before so I figured Id just share my loss...
- Anyone know of any good performance shops in ct??
- What's this black thing?!
- g2 integra gutted (piX!)
- 90 RS
- Dyno Spots In Southern California?
- broke a bolt.. is this common?
- Question about an upcoming race!
- noob question bout DOHC..
- 93 honda civic jdm eg6 steering wheel
- how to identify real KMs in the car?
- let me see some stats on the 4dr gsrs out there
- Need Fuse Box Diagram (Under Dash) fora 95 Integra
- rear 98+ rear bumper inserts...
- TPS code low input.. HELP ME :)
- Hey everybody, I'm new here
- will 90-93 auto tranny fit 94 up integra?
- MY AEM BRAKES ARE FAQED!!!
- Can stock valve train be used with ctr cams?
- ITR front bushings same as GSR?
- AEM big brake problem...
- Pulled ABS code
- b&m shifter+FPR=cheap? Where did the thread go?
- O Ringing!?!?
- H&R Sport Springs
- Suspension For Sale.......
- Most disapointing moment ever: my cars goin to a mechanic.
- Header question. time sensitive!!
- Len's ITR, dog, and home lost to fire... have you guys heard about this?
- ride height with type r sus.
- any pics of dc2 without back seats
- Mods: Why am I a trial uyser, and why can't I use Instant Messaging???
- 1992 manual work for 1990 b18a1
- Online Integra manual
- JDM swap in my gsr, reving up slowly not making any power.
- OBD2 Intake Manifold Upgrade on 90-93 Integra Install Guide Needed
- After market bulbs for the OEM gsr fog lights?
- how much are side moldings?
- JDM ashtray???
- My Buildup
- Nitrous bottle heater
- what type of ecu?
- will 94 gsr seats fit in a 93 gs?
- What type of headers???
- help!!! car-resale value
- headlight adjustment
- headgasket suggestions?
- halp with ABS
- cheap carfax reports - get em while you can
- race on air ride
- j's racing
- I hate Trannies!!! HELP!!
- motor mount.. o2 sensor?? STUMPED......
- They're on! AEM big brakes at all 4 corners. Talk about stopping power...
- transmission hum and axle loose....please help
- Banding Together to Help a Member in Need
- CEL on help please!
- $3000 for a good condition 94 LS - salvage title - buy it?
- gsr..turbo pics!
- Im trying to find a turbo and yes I searched!! Please help
- tein ss or tanabe sustec pro ss type 1
- Flywheel and Clutch
- Where Can I buy GM Synchromesh Friction Modified or Redline Shockproof Online?
- My lowered integra is rubbing, cant figure out where, HELP!
- ITR .25mm overbore pistons
- auto gsr, real of non-existent
- what ecu to use?
- Steering wheel Turning/ Noise in Rotor/Axle Area??!!! Please Help me out
- any comment about the B20 engine?
- LOOKING FOR THE BEST ALL MOTOR SETUP FOR MY CAR
- Why can't I post in kills?
- My horrible experience with springs (long)
- Hello
- g2 gsr header question
- **Hey guys i need a obd1 chipped gsr ecu if anyones got one for Sale**
- 94-97 integra o2 sensor question
- Free AEM Intake!
- is amsoil worth it?
- MY CAR IS ON SIDE OF THE ROAD HELP PLEASE!!
- 9005 lowbeams
- replacing valve seals
- Anybody know the color of this car?
- Cam decision....
- leaks, leaks, and more leaks!
- 2000 gsr future setup
- Reverse gear problem
- header question
- Goddamn clinking noise.
- Well, my ECU is fried.
- lol..stupid question im sure....
- Hiding NOS Bottle
- H22 Swap
- Good Acura service shop in Austin, TX?
- Who's selling the JDM front license plate holder? for 20-25 bux???
- blown ecu fuse????????????
- Quick and simple Question
- best header/exhaust for 2nd gen integra (searched)
- Gr-2's
- Ground Control Coilover Differences
- Valve Adjustment.. when?
