View Full Version : Acura Integra
- best cheap cams
- help needed!!! screeching noise....not sounding too good...pleasssseeee.....
- ls vtec leaking need help
- leaking tranny fluid... but don't know where
- Need some help from you 4door integra owners...
- Side bumbermarker need help
- what to use to paint side skirts?
- emission...calling all machanics!!!!
- where to find a good muffler for a 92 teg?
- Need to know ASAP!
- color code question
- 99 acura integra gsr and jdm itr lsd!!!
- how much would it cost to get a b18c vtec + turbo kit
- panit job
- Will a B16A/B, or ITR intake manifold fit a B18B/B20 head?
- CALLING OUT ALL BOOSTED TEGS
- help me right now on my skunk2 intake mani on ls. the little extra hose next to the main hose on the
- Switching remotes??
- DA exhaust?
- PAYPAL ISSUES!
- da
- Installing a short shifter... 90-93 integra
- B20 VTEC
- 87 integra
- Oil in my coolant.
- Best motorswap for a 1993 integra gs
- New project car
- itr shifter on my ls?
- vtec controller for a lsvtec
- how to wire up a pw0 into a 90 integra???
- TB to IM - New Gasket?
- part # for OEM bump stops? difference?
- got ecu code wtf help plz
- what is better - closed deck or block guard for a lsvtec engine with 10psi?
- hp headers?
- integra DA cup holder
- Butterfly valves
- header questions
- tint
- will a trust exhaust from a 98 2dr LS fit on a 94 4dr GSR ????
- Any one know if NKK Clutches are any good?
- Know This Bolt?
- how much will a salvage title affect the value of a car?
- window molding
- MAP and TPS sensors
- does anyone have any of these parts around or know of anybody that has these
- what should i do to my new '98 integra gsr
- alternative parts to my car
- My JDM ITR Swaybar Install
- wiring problem?
- car shakes when AC is turned on
- I got it done...:)
- need help! car starts but then dies immediately.. ignition problems?? electrical??
- Help with a part I am trying to find-
- cop pulled me over because..
- EIBACH OR SKUNK?
- 90-93 integras GSR VS GS
- MOTOR DROPS
- thinking of getting a taffetta white bumper for frost white teg need help
- best settings for kyb agx / gc
- Need Help with MISFIRE!!
- CLICKING ON GSR
- TWM individual throttle bodies
- nsx brakes on teg?
- F'n Steamed!
- A quick question for you Integra guys
- What brand is OEM O2 Sensor
- bad idle on a gsr
- What turns on the a/c compressor?
- megan racing test pipe
- CONSTANT IDLE FLUCTUATION
- Energy Suspension motor mount inserts install
- Place Where I Can Get Stock Integra Interior Parts?
- pics of my skunk 2im on my 00 gsr
- Competition Strip Clutch is great, i recommend it
- valve compresser
- Rod Bearings in Milwaukee (1992 GS)
- Clutch problem need help guys :(
- springs
- Help with head gasket
- intake gsr vs civic
- overheating problems?
- lightweight flywheel killed low end power completely!!!!
- Car Stolen AGAIN!!!!
- air fuel ratio guage install gone bad, help!!!!
- Sup fellas/ladies
- rebuilding engine
- mtx rebuild kits
- just installed Clutchmaster stg. 3 and lw flywheel....
- Transmission Swap
- Hey all. New to the site.
- PLEASE SIGN THIS PETITION TO SAVE NHRA DRAGSTRIP "ENGLISHTOWN"!!!
- Do EF strut bars fit DA?
- Base Timing is off, which way do I move the belt over?
- Installed my GSR strut bar on my GS(walkthru/pics/impressions)
- I have a problem with AN Integra rs idling after changing the intake manifold
- Are '95 and '97 Automatic Trannies the same on Integras????
- Where was the integra manufactured? the US spec one
- f20b swap
- O2 sensor on cat
- rear brake question for Gen 2 ASAP!!!!
- parts needed for obd1 conversion?
- rebuilt gsr trans.... major prob
- Yokohama AVS ES100's taller than Falken Ziex 512's?
- Will not belive
- Spoon Cams
- how much oil?
- PS help on 98 dx with b18c1
- Is the integra worth it?
- PICS PLEASE
- 9 Blink Code
- Hi all!
- Missing or skipping at 1400rpm
- lots of mods but car is slow
- steering wheel install
- How do I install H I D Lights?
- Which header would you pick?
- where to buy comptec header?
- cluster light not on?
- leaked ls header?
- Lookin For Mudflops
- DA Power Door Lock Conversion
- Gsr header on a ls?
- help, I need one of these, where can I get it???
- 2nd vs 3rd. which is the better gen?
- pr3
- tell me if this turbo kit is good
- aem pulleys
- How do i become a Honda-Tech user?
- Does HONDA CIVIC SI pistons raise hp on a GSR?
- hayabusa ITB??
- bored, pics of my diy earthing sys.
- Oil cooler hoses for '00 integra sedan
- VERY PISSED.....anyone has cluster gauge bezel installed?
- obd1 / obd2 head
- Clutch suggestion for N/A + bottle fed LS..
- DA Clutch Engagement Point Adjustment
- FS: 2001 Integra Console
- 92-93 front bumper doen't fit right the 1990?? help??
- Very strange problem! NEED HELP!!!
- Helppp!!! GSR shake my...
- Motor Oil that gives HP and Torque ???
- BSQ & beaks kit difference ???
- anyone know ALL MTR TODA HATCH?
- Adjusting clutch??
- best cam for a N/A LS motor
- ? on Hid's
- apexi vtec controller help
- Found Oil??
- OBD what?
- gsr motor - forgot 1 sensor
- WTB: Skunk2 intake manifold
- Not another LOOK WHAT UPS brought me....
- Neuspeed sport springs on stock integra wheels
- Timing Belt Tensioner Rattle/Sound? Squeels with RPM climb!
- headers
- Posting...
- Best Year And Model
- custome muffler shops in Chicago
- Skunk2 or Greddy Evo2 Exhausts?
- LS vacuum line prob.
- door rails
- Rebuilding my GSR engine, need opinions on my plan...
- NYC TRI-STATE AREA PEOPLE
- g3 shift plate differences
- need help [o2 sensor]
- p13 ecu. anyone selling?
- how to mount licene plate lights.
- fast rim size question
- Thinking about getting a 2nd gen Integra, need to know what to look out for
- Top Speed?
- DA Teg power steering rack
- Integra Final ratio question...
- Running 4deg timing retard, daily driving?
- rod and main bearing questions
- s2k antenna What do you need?
- 62404's and JDM ITR exhaust question
- Quick Replies needed!! Will 24x9.2x15 drags fit my teg??
- KYB AGX rear shocks that fit a DA
- q's on Ls cams
- Black stuff out of exhaust
- 1998 ls swap into 91 da
- Just got my blades...with 2 new tires...now I need to buy 2 additional tires. Quick question...
- good place to order jdm itr 4-1 header?
- DA broken into :-(
- Need help with 02 replacement
- ICM Fried?
- Spark Plugs & Wires (B18C1)
- Flat Black
- GSR 1/4 mile times
- hid troubles in my teg... need to vent.
- Question: H23A swap into 94 Integra
- question about ls/vtec redline!!Help!!
- Vis carbon fiber hatch
- hyper grounding wires
- new forum for only va,nj,ny,pa
- Teg meetup in Chicago
- Teg meet 8-14 shcaumberg, IL
- What oil do you use on your GSR??
- tsudo exhaust???
- Suspension Setup?
- VIS CARBON FIBER HOOD
- QUESTION: For the integra owners with BENEN rear lower tie bar
- 120 mile check
- supercharger on a 95 gsr
- Couple quick questions on Oil Change....
- Integra Audio Info.
- Frustrating! "short" weekend project turned into LONG!
- greddy timing belt code help
- my new shifter, just wanted to share
- Just wanted to Clarify my guage readings...
- Let me know what you think...
- Serious help with code 73 cel!
- Speedometer went out
- Please post HIGH QUALITY Supersonic Blue Tegs
- Tranny Problem?
- People with Eibach Sportline springs...or those who can help
- I got a tranny problem :( help
- 90-93 integra cluster issue
- anybody know how to take the corner lights apart?
- 91 integra b16a starting problems
- Pics:) Help:(
- Money Back Guarantee
- Just a quick fitment question?
- ignition switch problem
- Anyone w/skunk2 coilovers or ne coilovers...........
- Shock blown twice now :(
- B20 vtec motor swap in 94 integra, what parts do i need......
- Anyone in Las Vegas with an integra???
- My baby is offically GONE (i will be in the market for a 94+ integ)
- What size exhaust should i get?
- how do you tell a difference in a ls and gsr tranny when out of car
- the search
- for the 'when to do/what to do maitnence' -chart
- DA window visors 4 sale rare item discontinnued...
- HELP need ac blower motor
- help me identify this steering wheel hub!!
- Installing HID bulbs on non-HID clip
- Best Tire Size for Stock 15" Wheels
- drag turbo is complete
- how do i strip a/c?
- Stupid moonroof won't stop shaking!
- Best Axle Back Exhuast?
- baker high performance battery question
- B17 deal?
- question abt my rpm
- i have a noob question abt ls/turbo =\
- JDMBLUEDA9,calm down its just my post up name!
- h-t dyno day august 21 wilmington delaware
- GSR in the shop
