View Full Version : Acura Integra
- CEL blinking with no jumper wire.....?????
- RWD GSR on Ebay - check it...
- Need help with windows in a DB8
- Engine kicks when decelerating.....
- What shocks/struts also fit 94+ integra's....
- Ls/Vtec
- Reset my Hondata ECU after CEL?
- **OFFICIAL 4dr DAs**
- EXAUSTS??!?!
- cams for turbo ls, or port and polish? what will make better power???
- Local Body Shop for JDM Conversion (Dallas)
- GSR irratic RPM
- 92 integra converted to type r 5 lug conversion.
- Greddy Turbo? and Unorthadox Racing crank pully
- Need help! car only runs when it wants to!
- Am I running rich?
- my car died last night... timing belt?
- Out the thieves
- Integra
- Unorthodox Racing pulleys
- one side of my car is higher?
- overheating & no heat
- hey i got a question about IM
- what kind of cams do u think???
- Strut Bar for Victor X Manifold
- installing steering rack and steering column... any tips?
- anyone knows difference b/w RS an others(no type R) upper control arm??
- anyone have a picture
- Springs and retainers??
- silver teg with group n
- ballast resistor for MSD setup?
- need help asap for sale on teins
- DA owners!!
- Foglight switch not lighting up?
- Oil Catch can question
- suspension ideas
- ecu problem
- DA Manual Seatbelt Conversion
- ecu differences
- Aluminum Oil Pan - Benifits? Exhaust question
- ENGINE IDLES AT 500rpm
- how much do you think it'll cost?
- Antanna
- 90-91 Integra Hatch removal.. HOW ?
- i need a carfax in less than 2 hours please help
- OIL DIPSTICK
- What level number should I leave on tokico shocks on stocks springs?
- Sound clip
- broken cupholders
- Headlight Adjustment
- DA auto shoulder belt problem!!!
- cam gears
- TURBO LS help: Do i need to tune if im using a "FMU" instead of F-con, Aem ems, etc
- what is a breather on a b18c1
- AEM Fuel Rail for my 91 Teg?
- Looking for an Adhesive to stick even when wet.
- Picture request
- b18a1 oil pan gasket alternatives?
- GSR valves,springs, retaners
- numbers
- Mississippi/Louisiana Area Shops?
- WTB: Corner Light, Front bumper, Pass. Front Panel
- aftermarket cams question
- Coolant seapage
- ASAP What cars had a b16 hydro tranny?
- What would be a better choice? port and polish my head, maybe my turbo, or cams?
- transmission for a 96 type R motor
- JDM conversion
- Lost Car Alarm Remote :(
- can someone help me put my stock suspension back on and ill give u my skunk2's w/tokico blues. So ca
- TIMING BELT??? Integra LS
- Twin Loop Muffler Installation Charge
- Jackson Racing Supercharger'd gsr's. whose the fastest??? 1/4 times, whp #'s,....
- which tool to use adjusment my haedlight?
- greddy evo2
- what i ended up goin with tell me what u think
- help me find a website
- where to find cams
- 9005 conversion to 9006.
- Engine delayed crank or won't crank at all.
- need a lil help my car is smoking
- where do i send my transmission for a complete rebuild
- pcm programming
- NEED HELP
- question about a b20
- Any Suggestions for modifying '94 Integra VTi-R
- Vin # on Tranny / Firewall .. need ur help plz
- Best HF Cat....that doesnt bust after a year....?
- need help choosing rims
- 1988 honda integra wont startfuel pump replaced
- Rough Shifting: Is Clutch Bad?
- My 1st gear Laggg from start to 3k?????
- help on b18c
- integra distributor
- wats the best lip for my 95 integra... >?
- How do you guys jack up your car ?
- Where to find lower part of 94-97 bumper?
- yellow highbeans??anybody??
- b18b ecu??? need sum tips
- noob sayin wuts up
- can you guys help me out... strut bar compatibility
- Where is the ignition control module on a 94 Integra LS? (searched)
- anyone have a pic of a Integra Airbag module /unit/srs???
- ABS question..JDM HID Front
- 1st Post = 1st Honda **LONG**
- tranny problems in a 90 integra RS HELP PLEASE!
- CAR WONT START****
- carbon fiber spark plug cover?
- where or what is a heat shield?
- 91 integra ls. cargo area diameters, and turn signal lighting up too fast
- Cooling problem v2
- Integra Handle Covers? Where?
- Oil Leak?
- compression test results
- 98 obd2 engine harness same as 2001
- Clutch kit
- what head bolts to use on LS vtec
- how to fix my cf hood
- Prelue injectors on Turbo LS good? yay or nay.....
- Machine shop is going crazy with my stuff...
- engine builders NC
- ALmost finished with my Roll Bar.....
- Cant get o2 sim to work
- jdm front end storage question
- need help with tranny code.
- JDM Conversion Question
- Sluggish Ls/Vtec need help
- whats the story on these new headlights for the da
- Best Way To Shave Side Molding
- Where is starter located?
- Quick Question?
- tuning a gsr
- Quick question, hopefully a quick answer...
- B16A2 into 2nd Gen problem
- CTR Cams on my Stock GSR Block?
- OEM Fog Lights 94-97 Wiring Question
- ANYONE KNOW THE FT LBS TO TIGHTEN THE OIL PRESSURE SENSOR TO?
- will DC seats bolt into DA's
- gsr throttle body on skunk2 im
- Body damage. Advice on how to fix.
- 00 JRSC Integra LS that need some serious advice!
- how to change fuel filter on 94ls integ
- just bought sk2 stg1 cams for my gsr!!
- JDM frontend installation
- what is the cheapest deal on a built motor
- EXPERT ADVICE ON RADIATORS. WILL AUSTRALIAN SPEC SHOWA FIT US SPEC SHOWA RADIATOR?
- battery
- To Change or Not to Change (Tranny Fluid)
- weird problem .. suspension/ tires related ??
- which intake for my 95 h22a swap
- Security code
- clutch installation
- Motor mount question.. *yes i somewhat searched*
- Spoon valve and spark cover???
- pedal assembly removal
- viper remote start for my teg
- RPM Idles at 1300
- HELP ME OUT
- hey every one
- mirror relay
- What's wrong with my car?
- Wiring outline
- Fog Light Switch Ampage
- --No Blower Motor--
- Map sensor issue
- SHOULD I FIND ANOTHER TRANNY FOR MY 92 INTEGRA OR GET IT REBUILD
- ALB light??
- leaking fuel
- F/S TEIN SS FOR DA 90-93 INTEGRA 6 MONTHS OLD
- spark plug cover for integra LS?
- How to do prep work for a paint job?
- ac radiater under dash
- 86-87 firing order
- help wit a carfax plz
- Damn some haters...
- Gsr for sale
- blinker lights
- should i turn down my fuel pressure
- engine flush is it safe?
- Spark Plug Wire Problems
- question about headlight bulbs
- New member says Hello!
- del sol w/ integra front end b18b1
- 1/4 on EG with b16a
- Need help ASAP please!
- new to HT, got a question...
- skunk 2 exaust pix?/
- JDM DA front bumper Q
- IM to used for b18
- EQUAL LENGHTH MENIFOLD
- hey guys, a couple of questions that have been bothering me.
- cant decide what color rims are best for my teg
- what springs to use for a h22
- HELP: are automatic axles and 5spd axles different? intermediate shaft?
- Electrical problem - PS front amber running light (dual filament) not working
- integra 94-97 headlight question
- what should i use for tuning? looking for cheap, but good. can i get help?
- Hi im new welcome me to HT
- WHat kinda Exhaust on a 98 gsr
- STOLEN TEG!! (Chicago, IL.)
- Stolen Integra in San Jose, CA
- Pic Request. Comptech sway/tie with itr LCAs. Integra DC2
- strong b1
- comp calculation diff????
- changing clutch, need to resurface the flywheel?!
- is my tach off or crome?
- prelude hub swap
- New Integra owner
- help please
- coolant leaking from intake manifold
- Problems with JDM b18C
- Will comptech sri work with stock airbox???
- how to recognize a skunk2 camshaft
- Eibach Springs
- ITR suspension on dc2
- hks hi-power for 92-93 teg
- limited budget... 2 options
- Question about sleeving and boar and hone
- Speed Sensor Question
- 16's in the front, 17's in the rear....... yay or nay?
- Anyone know the color code for the PasswordJDM DA Integra???
- 215/50 15 w/15x7 +40 offset wheel
- jdm itr cluster question.
- weight reduction
- What piston rings should I go with?
- VARY IMPORTANT NEED TO KNOW ASAP!!!!!
- Check Engine light fix?
- SO CLOSE ON GAUGE CLUSTER !!! HELP
- Do you alarm goes off when u disconnect the battery and then reconnect?
- Is Gsr 94~2001 springs stiffer than LS???
- Trouble setting timing...
- help, replaing tranny in 92 integra ls ,5 speed
- I thought this was pretty cool...
- IS my timing off? god damnit!
- Funny things..
- Head gasket problems (pics)
- wtb gsr blades phat fives or ls mesh
- ctr or sk2 stg1 for a stock motor?
- Turn on heat, burning smell starts..
- VAFC and WideBand O2
- will the password whale penis fit a da
- uberdata p75 with data logging cable
- Firing order
- Temp Gauge Problem
- 4 door wing fit a 2 door?
- 90-93 DA integra fog light bulb question
- When setting the timing...Fan need to come on?
- Look at my plug
- Turbo AWD DA Integra
- 95 Integra LS
