View Full Version : Acura Integra
- Please Help -Friend has B20B in 99 GS-R - Need some ECU Verification/OBD Help
- yea yea i know my car is burning oil...
- MT - Axle Differential bearing or something - any thoughts?
- Water Problem
- 94 gsr uninstall turbo now runs weird!!!
- CEL and VTEC
- knock sensor info.
- GSR Problem (Built Distributor)
- new to forum
- tranny code on my teggy
- Gates Racing Timing Belt, anyone use them before?
- Greetings, new car, new forum.
- my new integra
- LS Basemap needed ASAP
- California State Referee certification...do i have to go stock on my i/h if it has a OE #
- price check on a used stock 98 gsr catback (i am buying)
- Going Ls-Vtec
- Car started pinging, please help
- how many people Haven't gotten away not having a 3rd brake light?
- Who sells just mufflers? for 96 gsr
- centrifugal s/c on 91 DA with B16a fitment question...
- 98+ door on 94 Integra ??
- valve cover
- suspention
- 2001 jdm ls misfireing
- type-R tranny
- gsr problems
- 98 ls how many miles until death
- Hit a a bump and started leaking coolant. Help Please
- by build is ready to start am i missing anything
- B18C EK.
- SPOON CALIPERS
- Hooking up laptop to Car
- how do i put in a block guard?
- engine builder in nashville area??
- help s-afc2 not working what sencor code should i put in???
- Are you able to change the ruber inside the blox LCA
- Turbo gsr questions
- exhaust pipe question
- corrosive battery?
- quick lsv question
- Brain fart and I can't find the answer.
- removin sideskirts
- SPOON OR ROTORA CALIPERS FOR GSR
- Weird Wheel hop issue. need help!
- Do aftermarket cam shafts delete vtec?
- Insurance.
- tranny blocks my shift for 1 sec.
- GSR oil pan question p72 **Please Help**
- b16 port and polished head
- power door lock module question...compatibility??
- about to swap
- About to replace my front axles, what else should I do while their off?
- piston pin??
- car wont crank
- weight of a bare shell??????
- So CAL Area !!! Complete GSR block for sale !!
- wierd overheating problem
- rs options??
- hand brake cable (discs)
- windows slow?
- ITR Exhaust Question!
- acl thrust washer part #
- Suspension Problem
- Buddy Club Vtec Controller Wire up anyone?????
- jackson racing supercharger vs. turbo
- 02 wire?
- Need Help!
- Speedometer is reading 15mph less then it should
- differences in bumpers?
- I want to put an OBD2 LS motor into my OBD1 LS car HELP!
- b16 ecu
- Turbo
- Auto to Manual Conv. Help
- Bizarre Idle
- Half-Shaft Removal - How to pop out from intermediate shaft
- Engine Swap Help
- need help!!!
- Anyone else had this prob'?
- took off muffler.....got a question
- Anyone know how to CHANGE PISTON RINGS??
- water in my cars
- Excuse me moderators..
- needed for exhaust
- WHATS THE NAME OF THIS PART?
- CPS (Crank position sensor) code?
- Type R Seats
- JDM fron end ?
- Seat bracket installation?
- LOUD, ANNOYING SCRAPE sound from tranny. ABOVE 4 mph. and every 3-4 seconds constantly. HELP
- emisions (exhaust leak - test pipe) problems
- Bad Piston Rings
- Introduction to my New (to me) car!
- gsr skunk2 IM clearance issue with strut bar...
- No spark, no power to coil, story inside!!
- car wont start
- OBD-0 Dizzy to OBD-1 harness wiring diagram needed. Searched
- b16a-b16b?
- Stolen in Milwaukee - 1998 GSR HELP!!!!
- Tell me what short shifter this is
- b20 crv T stat same as 90 b18a?
- buddy club hg
- 94+ brakes and rotors on 92 integra?
- 94 GSR Emissions Problem - high NOx
- Cranking but not starting, plus white smoke
- Harness bar for 91 Integra?
- not staying in 5th gear
- camshaft? 2
- CTR pistons
- Oil leakage problem..help!
- Is this a good deal?
- Tenzo-R Springs with what???
- cars shakes when stepping on the gas, help!!!!!!!!!!
- question about lowering car
- Help with my 92 GS :(
- center caps for blades
- My engine build/Need a good tuner in southern PA or Northern MD
- what should i do with my gsr?
- P30 bearings for an LS Vtec?
- 99 Integra....new pics few questions
- Temperature Gauge
- sound like a good deal on this integra?
- cams
- Leaking Gas :(
- Help me decide if I should buy this car or not
- b18
- b18c1 Gurus please help my iab problem
- is it worth tuning this early into the game?
- msd 6AL and blaster coil 2 install
- gauge cluster
- please help me with this
- Side Markers Problem!!!!
- 2006 2007 civic steering wheel fit in 98 integra
- usdm to jdm
- Newbie need some help with Mods!
- coilovers on my teg
- best skunk2 cams for b18c1 and my mild build
- Need Suggestions. Want To Build Badass DA Suspension Setup
- bmw bottle cap style wheels over GSR brakes?
- integra single cam?
- Synthetic Oil
- Cypress Green Pearl & Forest Green the same color?
- smog hook up?
- Will a 91 LS teg 5th gear work in my Y80 GSR trans?
- Which hood dampers? Tein, PasswordJDM, Ingall or NRG?
- i need axle bolt torque
- PIC Request: 98+ with front bumper removed
- NEED TO FIND A GOOD LOCAL MACHINE SHOP
- whats good to use, other than a pin press to take out a spring pin from the change rod of a tranny??
- coil springs
- Different Heads
- fuel gauge off
- rims
- jdm front blinker question
- b20 vtec?
- NEWBIE NEEDS SOME HELP PLEASE!!
- Lowering my DA even more. Need some advice, and a photoshop request!
- 99 Integra parts needed ASAP
- compression readings
- electrical problem?
- Car dies when trying to put it in Gear
- Aftermarket headlamps?
- Won't Start, Backfiring, After Distributor Install
- power lost when hot
- Nardi Horn Button Problem on WB QR
- New to site
- Car stolen: Now I have electrical problems....HELP...
- someone please help!!!
- jdm front clip
- anyone using Bi-Xenon HID?
- tranny swap
- Blox/skunk 2 intake manifold question!?!?!
- Modifications
- pulley question
- distributor question 90 integra with b16a2
- skunk2 manifold application
- couple new vids of my gs not an R
- plzzz help...my gsr
- ok i need a moderator
- Burning 1qt oil/500 miles... should I be able to see this in the exhaust?
- what size throttle body?
- B18c1
- GSR stollen!!!!!
- will bigger injectors, fpr, and fuel rail help on a simple set up?
- gsr rebuild questions......
- how will a tune......hondata,crome, uberdata help my set up?
- possible starter problem?
- noob question: p30 ecu and iab's
- boosted ls with a pw0 ecu
- 186k mi LS/v-tec or new b16
- what inch piping for my exhaust?
- Replacing Alternator / 1995 LS
- Latest Mod: Heim Joint Rear Swaybar Endlinks
- help new motor problems
- help with my 98ls
- Speedometer Lighting.
- techmaking a vtech
- are hondata stage 3s good
- no oil in motor, car shutted off
- car is not pullling hard? starter problem?
- wiring for headlights
- TPS Sensor?
- recommended fuel
- DC2R Shocks/LCA Install
- Roll Cage Db1
- Would a bigger throttle body benefit my set-up ?
- Aftermarket exhaust
- is this even possible????
- 92 Integra ABS Light Help
- X-mas is around the corner
- Shock fork help?
- im trying to take off my headlights
- HOW DO YOU............
- Leak Down Tests Don't Lie - One Bad Cylinder - Options people, options
- OBD1 vs OBD0 engine harness question
- Wire Tucking HELP!!
- integra jdm front end gallery!!
- engine displacement
- internals
- civic ep3 seat in integra db
- Good header for good price?
- front left lower control arm
- HOme made turbo for my LS
- Weird Noises
- Looking for a DIY/Write up
- A'PEXi N1 162-KH10 4dr GSR. What needs to be done to fit LS?
- water leak help
- GSR vs ITR bumper
- Typr R style rear lip kit 97-01 integra
- b sereis vibration mounts questions
- valve adjusting spect 96 DC2
- lip kit for db1
- power steering cooler.
- louvered resonator?
- Transmission problems. A few of them
- Help Integra cut off driving to work.
- need help putting back spark plug wires to the distributor!
- Need an old clutch.
- plz help me
- Drag Strip 2nite...Have some ?
- Rear Wiper Removal?
- 91 DA: tranny swap attempt. first time. any pointers? precautions? MUCH APPRECIATED!
- db8 k20 question
- header $500-$600 for b18c1
- and i still cant pm or anything yaccount
- Airbag question.
- Car Bogging (searched)
- Need urgent help please (TIPS)
- had a problem when i pulled the motor
- Tein S-Tech
