View Full Version : Acura Integra
- driver side axle/blown boot
- what is this?
- back pressure!
- hey guys
- does anyone have any experience with the new AEM intakes???
- o my god!!!!!!!!!!!!!!
- going turbo
- making my steering stiffer
- for ne1 that has installed the safc in middle of install, help!!!!!!!!
- tire size question
- timming belt question?
- did a search. nothing.... step by step changing shocks and springs
- b18c1 into a 2nd gen Teg
- breather filters?
- My white 4 door!
- what goes into a gsr swap???
- Question and comment on 96 GSR rims....
- hard time starting car.....
- Need intake advice
- Torque Sequence/Specs...
- Finally crossing over to the teg forum
- mufflers: noise vs performance
- A left and right strut?
- my results on my compression test
- Hate Misshifting!
- oem itr shift knob
- limited budget newbie...
- rear strut bars
- ahh, new springs and fixed the camber kit
- ls horse #
- ac compressor clutch relay
- compression test
- Worst day of my life
- BETTER TIMES!!! 1/8 mile stock gsr with short ram
- Help...won't go into 1st, 2nd, or Reverse
- need help buying headers??????
- Taillights problem!! Help!
- comp ratio to hp ???
- Will this Tranny Fit into my car With no Modification??????
- I have a 00 LS I need to buy an ECU and i need help
- my car got stolen and found stripped what should I get
- anyone know the thread for the 9006 conversion?
- I need help choseing a chip for my 00 LS
- KOS Headers! 4HP better than Spoon??
- Help, my back seat is broken!!!!!!!!!!!!!!!!!!
- ACT HDSS clutch question
- Good Tires?
- koni yellows and H&R springs
- How much could I get for my motor?
- What suspension will fit on my GS-R?
- My car got stolen. :(
- power door locks
- any integras with the tein s tech springs??
- jdm conversion$$$
- catback piping
- anyone who has ordered from NOPI?
- Eibach Pro Kit Spring - Color ???
- VTEC x-over for GSR with CTR cams?
- vafc?
- are doesnt start sometime!!!
- Overheating, Any suggestions?
- How's the Apex'i Dunk exhaust? Any good?
- Cat Back Exhaust
- all motor buildup...got new parts :)
- DA Suspension setups.....
- Knock Sensor Question
- What is wrong with my car!!!!!!!!!!!!!!!!!
- supercharge???
- GReddy SP exhaust SUCKS super FAT donkey BALLZ!!!!!
- JDM E Brake Cover ?
- JDM JON`s integra
- did a compression test...now car wont start!!!!!!!!!!!!!!
- going to the 1/8 mile track again, hopefully i can beat 10.4
- tranny help
- 92 GSR IM vs. ITR honed IM
- Jackson Supercharge 86000mi B18C1 safe??
- Have to drop gas tank for walbro install????????????????????????????????????
- installing fender
- Car is misfiring help?
- HELP!!! Car wont go into gear!?!?!?!
- engine mounts are starting to go
- need advice... im a NEWBIE at all this positive replys only please!
- leaNeed help
- VAFC max power gain on a stock gsr setup
- apexi vafc
- how does your car run
- whats a good 12v power source on ignition to wire fan into, in engine bay?
- rear window wiper
- HELP!!! My Passenger side window stopped working
- 92-95 Civic CX steering rack
- would taking out one of the fan affect anything?
- Fav. online parts store
- Comptech Race Header.............
- Weird sound
- ok, i tried searching already....NEED help with Integra dash harness!!
- blown shocks....
- Creaking and Ticking coming from the rear, new shock/strut time?
- clutch arm moves.....clutch doesnt disengage...wtf?
- $500 fora header
- smoke comming out my tail.pad pcv valve= running rich
- integra plug gap???
- Is this clutch ok???
- HELP! Stripped flange nut while changing fuel filter? What to do?
- conversion harness
- what axles to use on 1990 RS with b16a swap?
- airbags?
- Tried to search, no luck, how to turn off the maint required light
- Ive slipped into the 7th circle of hell (skunk2 manni)
- Car died today at idle... what should I do?
- I need to know what things the LS-guys have done to build the all motor cars.
- Anyone live in AZ (in glendale or close to it) rec a repair shop?
- Auto tranny on 94 ls.
- damn lol, sick mpg
- N1 or Greddy EVO?
- Type 1 Racing
- Todays my Birthday!
- What the hell is a tuner lug nut
- Matching side marker and parking light/turn signal?
- where can i get a comptech 4-2-1 header cheap
- Need some mod ideas
- Newbie Nitrous Question
- ****SKUNK2 Goodies Inside my GSR!!!!!! need advice!!!****
- Horror Struck My Integra At The Track Today What To Do (Long Story)
- just installed my jdm foglights....need help!!
- chipping an ecu???
- rim repair shop in socal
- Quick 9005 conversion question
- wut type r cam gears do anything??
- My Right-Door Window
- Anyone thought of how to box in a CAI?
- Car Accident Question with my SSBP
- Can't post Topics
- Jackson Supercharger!!!
- Just got my 98+ tails and i have a quick question
- Did Valve adjustment, now car doesn't seem to pull as hard
- imoblizer in the ECU
- Increasing MPG by removing reverse fuse..wtf?
- I got screwed! story inside..
- Any One Got Pic of Blue Integra??????
- ebay catback system...check this link, is this a good deal??
- '95 & '96 taillights..
- Low Profile Tires
- i need help quick!
- driver side window wont go down
- lightest / best carbon hood?
- Where is the cheapest place to get H&R?
- Power Steering Removal......
- 98 gsr, only headers right now...how long till 13's???
- Theives in NOVA found
- Oil in my Intake Manifold?
- ITR b-pipe on GSR, quick question?
- which is higher?
- Clutch problem... :(
- Skunk 2 or TEIN?
- Brake Shield Scraping
- another 1201aeromotive satisfied customer
- Dead alalrm battery???
- How's the health of my motor?
- OBDI intake manifold on and OBDII car
- 17x7.5 Wheels will the rub?
- Oil pressure guage
- Can I install OEM integra GSR shocks and springs into this HONDA?
- Tein S. Tech springs on stock shocks
- Price for A/C compressor
- Question On Treadwear
- do I have factory driver side window glass?
- G3 Integra Helms Manual online?
- anyone ordered from....
- clear corners on a 98 teg?
- 2.5" header to 2.36" exhaust?
- Integra OEM interior
- nitrous install
- How long do koni yellows ussually last?
- maintence light flashing 10x -help??
- 1/4 @ Infineon Raceway
- good combo?
- Why do my hoses keep breaking!?!?!
- HID's fit on 94integra with ABS???
- Anyone been following the K20 swap for 3rd Gen Tegs
- Tools needed to install koni shocks
- running rich effect fuel economy?
- Anyone have a step by step guide to installing DSM Injectors on a GSR??
- neuspeed race springs, what shocks?
- ATTN: 94-95 GSR with oil cooler!!!
- ITR rear section vs. universal Apexi N1
- directional numbers
- Update on my GSR after tuneup
- Tire Size for 16" rims
- Quick Brake Question
- Headlight Housing
- Creaking noise from clutch pedal?
- Drove thru a curve too fast and slammed into the concrete median.
- How much does a B18 block weight??
- What hose is this? 98 GSR motor! 2 pics of the hose inside!
- Hondata im gasket
- Pix of mounting suco oil catch can in dc2?
- i'm selling my teg cuz i hate getting uplled over
- gauge cluster/wiring guru i need some help!!!??
- who makes a better 4-2-1 header??comptech or dc sports
- lost power all low end and high end???apex ws catback
- eibach pro kit drop??
- where to get front and rear bumpers for a white 98 4dr integra....
- LS Vtec update...
- Fuel pressure and stock injector size
- What is Special Edition?
- Skidplate for JDM DC 4-1 Header
- where to buy tools?
- need camber kit...?
- Which clutch?
- Y2 1st to 5th gears in a Y80?
- cleaning rotors
- Filling tranny with fluid question
- GSR to LS door bezel?
- spring/shock question
- LS Vtec? Good or Bad?!?
- Water pump question
- Need one spring H&R
- Diffrence between a ls/vtec and gsr motor (b18c1)
- Neuspeed Strut Bar
- tire weight?
- I need someone to check their helms manual real quick...
- Carsound cats... Places to get them
- GSR engine information needed
- 90-93 Integra With B16A1s?
- FS Obd2 to Obd1 Jumper Harness
- helms ?
- does fake neuspeed 4 point strut bar exist?
- custom door panels
- Is this seat worth 800 bucks?
- please post pics of 3rd generation teg lips-cant decide!
- adjustable cam gears?
- Your successful custom ls turbo kits
- Skunk2 Cam setup problem!!!!!
- Apexi N1 exhaust on GSR, opinions on sound
- h22 in a gsr?
- pic request:Neuspeed race with 15's
- oil squirters?
- Fuel filter change
- New Overheating Problem :*(.............again but opposite
- Pics request-Rota slipstreams preferably or other rota wheels
- Valve Adjustment? Covered under warrenty?
- Compression test happyness
- aem bypass valve?
- HELP! I need a Diagram of the 94+ GSR Fuse Box(underhood)!!!!!!!!!!!!!!!!!!
- DC JDM 4-1 with JDM 2.25" cat, plus other small problem
- honda itr 4dr?
- si spoiler on g3
- specs on a '93 gsr??
- Got crap gas for the first time
- Two ram air kits
