View Full Version : Acura Integra
- Damn! A screw dropped into my resonator!
- Automatic Type-R???
- Is this a good header for me
- window problem
- CARFAX NEEDED
- buying 97 GSR Help
- diff between a header for gsr and type r
- rear wiper removal question(grommet) 91 DA
- Differences between JDM and USDM Integras
- nylon seats
- Milano Red R-81 Double Check
- Help - problem with GC upper mount/AGX strut
- strut bars...
- Real quick question....
- JDM foglight hook up ?
- S2k antenna installation
- clicking noise from cam gears normal?
- new here - need advice on 93 transmission compatability
- Just got the ITR tranny in the GSR and wouldn't ya know.....
- Valves Bent??? How do I know?
- Strut Bar... Stock vs. aftermarket *TECHies only please*
- clutch trying to pull the car when fully depressed
- ECU Question ...
- should I be concerned with the stem seals in this DA???
- what's the difference between LS/RS b-pipe and GSR b-pipe?
- Finally got to the track
- how do you buy a second hand car??
- 90-93 halfshaft or 94+ halfshaft
- new clutch is jumping/hesitating = ?
- loose flywheel?!?!?!?!
- Tranny Problem..
- 93 LS Project
- 95LS A/C system = r12 or 143a??
- Need Stock 93' integra LS ECU
- How to remove water from engine? hehe
- performance disk with stock pressure plate and flywheel....
- what could i get for my gsr?
- anyon prefer stock intakes instead of performance intakes?
- cleaning air filter
- A/C - R-134A Low Side Service Port
- Brakes Problems
- d16a1 88-89 ????
- revhard tubular and cast mani
- Spedo Cable Squeaking '90 Integra 4 door
- Want to see pictures of 1992 GSR's
- p&p GSR IM
- trailing arm bushing
- Turbo GS-Rs...I need your help
- What would you keep? Stock LS with 100k Miles or Stock GSR with 140k Miles?
- Lowering Springs
- Trust Air Filter
- cluster wiring?!
- new tps questions... what about the gasket?
- B16 tranny
- GSR head Q's?
- 3G dash swap into a 2g?
- sitcker
- another 98+ conversion question... bulbs and bulb brackets compatible?
- how can I tell if I still have front bumper SRS sensors (JDM front end conversion) - help
- which head bolts ffor LS/vtec?
- ABS question
- the hatch gitters
- For those with BOTH VAFC and RSM
- GAB/ROTA WHEELS
- squeaks and rattles ahhhhhhhhhh!
- Question please help???
- compression???
- I Need Cam Help?
- m thI HATE ACURA KEYS
- block paint??
- Alignment Problem on a 98 GSR
- AC compatibility question
- i want a 98-00 front bumper on my 95 gsr...what do i need?
- del sol seats in my teg
- Anybody have a broken 94-97 driver side headlight?
- B16 tranny question on a b18c1
- calling all imports in the va area
- car starting troubles...HELP!
- Car won't start
- obd1 conversion problem
- 3rd Gear slipping?
- 95' GSR VTEC not working?
- Anyone know how to RESET Eclipse 55090 DVD player ?
- Problem with Air Horn Install.
- SAFC or Jet Chip
- project turbo 97 ls/non-vtec
- Where do you guys buy ITR sway bars
- What do you think this is worth
- HATE....COPS......
- Oil leak from drain plug, any solution?
- OEM Exhaust Question
- ITR suspension on 92LS..?
- OBD2 Alternator on OBD0 Integra
- power locks wanted
- Best Exhaust for a GSR
- Strange buzzing noise
- which headers and cat for integra ls
- breaks are going, need opinion on new setup.
- Need help with Axles - grease everywhere
- New to site please help.... JDM type R cluster swap
- Is this a good price? ( i think it is, but im asking anyway)
- My Integra Compilation Video
- question installing my rear hatch
- Did all gs-r's come with the spoiler
- Just got a white guage...it comes with 2 wires..black and red for illumination. Where do
- looking to buy
- Question about front bumper(94 GSR)
- Help on installing a new fuel filter
- SCAM
- compression ratio???
- Prepping for GSR REBUILD! Suggestions and questions?!
- For those runnin HAMP filters
- fuel mileage
- Not sure if i got ripped off or not?
- Broke all 3 lug nuts
- is this a good buy?
- to boost, or not to boost (no hating plz, thx)
- RSX feels tighter than my gsr
- z32TT owner going ls/turbo
- Idle RPMs are around 200-400???
- Transmission install problem...ok to run without dowel pins?
- valve spring install with head on, droped piece
- Autozone Shocks
- Timing belt snapped and distributor housing questions
- Wirning colour charts for 93 integra.
- How much do 97 gsr mesh rims cost?
- Anyone with a b16 in there 94-01 Tegs?
- Best place to get Hondata intake Mani Gasket?
- car troubles... please help ASAP
- LS/V-TECH-
- Type R sway bar question
- Axle question
- Black key, red key, valet key?
- Air Cond help bay area
- How much would you pay for a radiator flush?
- quick Q on ITR sway
- jdm ss 4-1 dc sports header
- running really rich?
- HELP
- Timing belt problem
- JDM Conversion ?
- integra trim level?
- taillight removal help!!!!
- MEESED UP RINGS
- Dont know what to get
- about intake tube to valve
- cant find cheap place for FERREA valves , need some ASAP
- best compression ratio with 100hp/NOS?
- did the 92-93 JDM Integra's come with amber/red taillights??
- AEM carb sticker
- help ! integ techs, SRS ABS Light Problems
- heating up bent rim?
- Help lower my 1/4 times
- Quick seat Q
- NOS Dry Kit question!! NOS jets, Nitrous Jets...
- im freakin out guys, i need help with the lowering my car
- New IMPORT TUNER magazine 159.7 WHP on a stock 98 GSR.
- Car wont start!!!
- Tanabe Exhaust...
- cruise control removal?
- What kind of Integra rims are these?
- Throw out Bearing??
- Quick question AEM SRI install....
- Question 2001 Integra Type-R front bumper cover, worth it?
- removing side airbags in RSX seats
- All integra fenders are the same?
- gone through 2 radiators in less than a year
- ebay intake and bad gas millage
- INSTALLING A FRONT CLIP
- Pin number to A/F pin to ecu??
- signal light blinking problem, help.
- Where does the Gs-r beat an ls???
- Couple quick questions\ AEM SRI install
- Any cause for concern?
- power windows failed
- Troubleshooting distributor...help
- si head vs. gsr
- Exhaust
- Coil-Overs
- Cold Air intake
- Need help on deciding which chip to go with for my gsr!!
- do i really need to disable SRS>?
- idle drops and goes to normal?
- jdm cluster problems
- Building a kteller exhaust system
- BOSCH Spark Plug Wires / help
- Piston and rod combo
- gsr trans 96
- is it me or do tegs warp rotors fast?
- Stock All Season tires
- Coolant leak
- what trannys will work
- b20 CRV timing belt and b18b1 timing belt same part number?
- HHHHEEELLLPPPP REAR SEAT BELTS????
- Reverse not working ?!?!
- SRS LIGHT/ ABS LIGHT - Help Please.
- Opinions needed. Q's about my RS.
- Abandoning project da-t
- wheather or not to get vtec gsr or ls
- How long?
- bruin muffler or exhaust
- Please Help 90' LS
- heim endlink help
- KTELLER Exaust ?
- Ticking NOISE
- question on idle control valve (IACV) install on '94 teg
- After 4 years it finally happened to me!!!
- Stuck Caliper: Caused bad braking
- Anybody use a willem eprom burner, post here, I need help please.
- Still having trouble finding vented hoods...
- I'm Back in The Game
- need alt. belt part number
- surprisingly good tires
- Who got the best price for your used 2nd gen integra?
- ODB0 - Benefits?
- bad bad noise
- Manual window's dc2?
- Quick Question
- ys1 tranny in 90 gs
- Anybody have a how-to on replacing the steering rack bushings?
- Yoko AVS ES100 vs. Parada Spec-2 vs. Kumho ECSTA 712
- fields vtec controller and OBD2b....
- B18a all motor?
- 3 busted cv joints in 1 week?
- brake light does't work HELP
- I need help!!!!!!!!!!!!!!
- Swapped coil & ignitor, still no spark HELP ME
- Shifter movement
- Can civic HX rims fit on a 95 ls integra? i heard it might rub!?!
- Where to get the bolts for muffler
- OEM mufflers that bolt up to 94 RS?
- Pics of crashed car (3 weeks ago)
- !!!! dont do what i did and order a tranny from a DEALER !!!!
- seattle / vancouver area teggies!
- JDM Floor Mats
- Hard startup when warm ? NEED HELP
- how long does it take to be an offical member of HT?
- D16Y8 into 1G teg
- Viper 320HV
- people with jdm 4-1 header in gsr
- HELP! Steering/Suspension help needed...BADLY
- Exhaust fitment (2 door - 4 door)
- Help with starter problem!!!!!!!!!!!!!! URGENT!!!!
- clutches
- manual windows installation in SoCal OC?
- Caliper won't clear bracket, why? (five 640x480 pics inside)
- What diamter is GSR exhaust piping?
- B16 Dizzy
- spc camber and ingalls camber???
- AEBS on a LS motor?
