View Full Version : Acura Integra
- OBD1 injectors...need quick answer
- CTR N1 Pulley belt issues
- Need- 98 Integra Driver side fender!!
- hondata gasket
- b18 build suggestions
- 91 lip fit 93 bumper?
- Tire size for Mugen mr5 15's
- Cable to hydro tranny swap
- Wanted:Someone to hook up my vtec in my eg
- Hasports 200whp axles
- CEL code #9 obd1 95 gsr
- need help for b18c1 rebuild
- ARC box in my DA
- will 1999 gsr iceman intake fit on a 95 gsr?
- Will the mugen 13" CF-48s fit a DA
- annoying squeeking noise from my 94 rs need help quick!!!!
- New parts from GReddy
- torqueless b16 in a da
- Are 93' GSR front endlinks the same at 94-01 GSR front endlinks?
- For those who have been asking about gutted cat/test pipe...(video inside).
- Hesitating after obd0-obd1 conversion
- need help quick
- switching up the tranny
- anyone in Richmond VA area?
- help do i need this part on my distr
- stage 1 to stage 2
- 90-93 DA SPRINGS fitments help me choose
- b18 or b16?
- wtb or ttt any b-series head or L.S. parts.
- im an idiot help please
- cleaner headlights????
- WTF is going ON 96 engine with 93 mounts???
- Q: i see grease everywhere on my passenger side near axle/tranny . what is it.?
- Headlights really dull. relay them maybe?
- Q: aggressive cams with a stock valvetrain
- greasing the speedo cable for my 91 DA
- JDM ITR SUSPENSION!NEED HELP AND ADVICE!!
- CAN ANYBODY HELP ME?!!!
- OEM Motor Mounts
- in need of 94+ power antenna!!
- whistle
- 1000-2000 High Idle.....this one gots me stumped!
- will my ls/vtec blow?
- replacing door on G3?
- where is the iacv...pics please
- My motor is misfiring?
- my baby got hurt...
- Starting car after 6 months
- Maintence Required Light Help!!!!!!!!!!
- Anyone scope the Turbo GSR that won $1000 on Carster?
- Need Instructions on CV boot removal.
- confused about thrust washers.
- car wont start!!
- Type - R ECU chipped?
- Rear LCA's: Are they hard to remove?
- what paint code is this
- GSR and ITR 's Ignition Wire the SAME Length???
- SUNROOF question
- burning oil, single black spark plug
- Are all 94-01 Clusters the same?, 99 GSR With Full OBD1 swap, what cluster??
- OBD I or OBD II
- questions that need answers
- Urethane Bushings
- 91 teg vs rx8....
- Loud humming noise coming from my DA!
- b16a2 tranny in a gsr
- show some pics, need to make up mind
- 90 Integra GS Oil Catch Can Installation HELP!!!
- Gsr transmission? what stamp?
- Rsr exmag bpipe bolt to itr axleback?
- switched tranny....
- body kits are falling
- exaust fitment
- how do i remove a b16 head?
- camber kits
- main bearing colors traslate to part numbers?
- Pics of my DA
- my new 94 gsr
- Hey everybody, I'm new and have a couple questions.
- My K20A2 DC2 build up! no haters or 56k!thanks
- identify a GSR harness
- B18B1 and trans traded for swap labor/lift time
- please help tranny problems............
- Q: how do i fix this bumper sag on JDM ITR front end ??!!
- leather an option in a 98 gsr?
- Q: which socket will work with this light bulb (parking/turnsignal)
- 92 Integra not getting Fuel!
- correct way to put piston rings?
- pressure switch test???
- Starting problem, starter relay? need help!
- help me integra forum!!!!!!
- need advice on shocks: teins vs. tokico
- how can i tell what tranny i got on my b18?
- need fpr fitting
- lag between 3k up till point wild vtec engages? engine lights comes on!
- IAB connection
- cam gears making noise
- what cams are these?
- 94 - 98 windows?
- Extremely high HC on my idle test (smog related)
- What to do about this stripped nut?
- What are these plugs for? *pics included*
- whats this clicking noise??
- replaced the doors on my 94 teggy.. need help... not getting power
- Switch That Will Fit?
- 98+ Foglights
- 92 DA - Squeaking whenever I turn left
- Clutch Cable?
- TYPE R HEADERS?
- irregular idle
- Will a 91 oil pan and axels off B18b work on a 94? Please help!!!
- Over-heating B18c1
- Need help installing my intake!
- 99 gsr head/skunk2
- arp rod bolts
- Tranny swap
- New shots of my '99 GS.
- Windshield wiper problem, HELP HELP!
- idle keeps dropping when i use electrical stuff
- shock collar bolt...
- LOOKING FOR A 94-95 gsr or b16 ecu
- VIN location on LS block?
- Bad Ground !! Help !!
- Is this integra worth the money?
- RSX TYPE R? integra type R verification
- Timing
- found stolen LS-needs swap
- car idling too low doesnt start unless i gas it
- fuel injectors
- slick size.
- Will JDM DB8 Type R window switches work in my 1997 DB7?
- help w/ running rich.
- Any One have a diagram of the radiator hoses help me out thank u
- cam gear or not to cam gear
- Adjusted timing on my DA, didn't change whether I jumped the harness or not?
- Question
- Cheapest place to get gsr motor?
- turbo b-series
- help with valve cover bolt
- Inspection Related...VIN Stored in ECU?
- want to know if this is possible
- Need to re-align rear hatch
- BEST DA PIC S
- front windshield wipers. too long? why they hit ??
- ls vtec... couple questions
- JDM gauge cluster install issue
- what is this cel?
- a better radio mount?
- clutch? Opinions Neded
- How to id cams?
- Help!! Electronic fuel pressure gauge
- Stock OEM ITR cd/radio player vs. aftermarket
- HELP!!! Blowing ECU fuses!
- starting problem
- Intake manifold question ?
- GSR intake manifold ???
- ECT/Fan switch problem..help please
- 1993 Integra Won't Start!!! PLEASE HELP!!!
- Dynamic Damper on Left Axle
- 90 Teg LS Tranny Swap
- GSR vs. ls/vtec turbo
- Thar she blows
- Phantom grip lsd
- what u guys think bout this suspension
- DA almost stolen
- Help throwing an engine code. Code 3 MAP sensor
- What are my best bet for shocks and a camber kit on a budget?
- CHECK IT!! My Electronic Blue Pearl DC CHECK IT!!
- 5 lug conversion
- GSR no vtec on 1 or 2 gear but can feel it on 3rd gear why?
- Running rich.....any help?
- shifting and shifter-related problems
- HONDA WON F1 GP
- help
- my 404s are in, but...
- Lets see your car!
- GSR exhaust on an LS???????????????
- exhaust quextion...
- Tires/Rim Blows up
- 96 INTEGRA SPECIAL EDITION, WHICH HEAD??
- would it be worth it?
- Decided on RS-R ExMag
- Who's got a LS/VTEC?
- Need help replacing studs!
- looking for 90-93 integra
- low compression with itr pistons in gsr
- Where do you mount your gauges?
- Skunk 2 and stock compression
- Need door lock/unlock/alarm wiring help!!!
- EXHAUST HELP
- Car won't start (sometimes)
- screeching sound on right turns after hitting 70+
- Quick Suspension question.
- Ecu Help
- 4dr integra
- Door help needed!
- port and polish ls head worth it?
- Bumper Lights
- Gotta pick up some spark plug wires. Suggestions?
- DC catback in a DA chassis??
- Fluid suggestion for ITR trans?
- JDM front Corner light bulbs wiring help.
- overheating
- Does a High flow cat make that much diffrence??
- HELP! ignition problem
- Rims 17's or 18's?
- SRS dash Light w/ aftermarket steering wheel
- S2S2 cams
- p05 Question
- ***trans rebuilt not going according to plan***need help***
- how do i set my timing?
- no reverse!! help
- milage check
- JDMshit SI-VTEC lip: Do I need to put nuts behind the screws to fasten it to the bumper?
- EGR Valve | ECU Code 80
- REAR MAIN SEAL OR DISTRIBUTOR
- Wheels?
- is 350 a good deal for rota slipstreams?
- Need some help w/ DC sports 4-1 header purchase
- Rebuilding my LS motor!
- Timing Belt
- obd1 injectors fit an obd0 car?
- exhaust fitment
- trunk issues
- fittings for oil pressure gauge
- pics of lowered gsr
- 00-01 LS question
- dampers/shocks which is GOOD?
- 4 door GS-R exhausts
- Power Steering leak!
- timing belt scraping because of cam gears?
- Brake swapping...
- Brief question, please help.
- Should I turbo my LS motor or Rebuilt it?
- LS motor has a P28 ECU?
- went to the shop today...
- gsr block with ctr pistons?
- please help
- 98 GSR and Spoon ECU
- Trunk Relay for '94 Teg
- need help locating radio fuse on 94 integra GSR
- GC/Koni Yellow adapter?
- 91DA suspension/steering help
- Chattering problem found out.. motor swap?
- alternator removal..?!
- gutted cat/test pipe
- brakes lights
- advance timing
- CRAP! stupid tokico's
