- Car died
- how much can i sell a b18b1 head??? and gsr front disc conversion?
- db1 fan problem
- good body to build on?
- da9 oil light help!!!!!
- Trying to replace lug bolts 92 integra
- parts microfiche
- GSR Damaged Valve, Crank OK???
- B20vtec...??
- Bad window motor or bad switch?
- Another dumba$$ move, old timing belt broke
- All motor Integra GS-R Build questions
- Ingalls camber lube question.
- Will b16 gear set fit in a gsr tranny with out no problems...?
- help with my auto to manual swap wiring car wont sart
- Computer ob1 block 3600 rmp
- over heating issue
- Clutch Pinrod Locknut
- Manual Dizzy on Auto Car?
- Good build?
- 96 Teg new rebuilt motor throwing Code 45 and Code 54 help
- window motor help
- a lil help with this clutch ?
- F20b motor mounts?
- clutch catching at the very top
- Acura Integra starting problem
- cam gear timing help
- Question about Engine setup
- Best Cams for All Motor B18C1 daily driven???
- help with 93 integra ecu!!!
- Starting my b18c5 w/s4c swap in my 1994 4door a/ integra.. have some questions!
- Got a quick question about civic/integra mounts
- heat pouring into my 98 integra GS and extremly hot shifter.
- Boost lines?
- signal lights keep falling out?
- Main fuel relay problem?
- b20 redline at 7k rpm?
- noisy window when rolled down
- new water outlet's dont have bleed ports?
- 17x ? and offest questions for a '94 GS-R
- my da is to hot!
- B18B1 beef up
- H22A?
- Type R Head on GSR Block Compression Help!
- ac vent blocked ... ?
- jdm gsr crank and gsr crank
- do i need to tune?
- rear driver side door wont open
- fast turn signal how do I stop it?
- Rotora FC4 fit integra>
- ef motor mounts?
- sunroof problems
- GSR IAT Senser CEL code10?!
- Knocking Noise:(!
- suspension
- 90 DA won't start.searched lol help!
- type r swaped integra having trouble starting
- Integra JDM Front conversion shops in NY/NJ/CT area?
- high/fluctuating idle... just cleaned FITV
- 94 GS-R rattling cats?
- car bogging out
- Will a D.A. coil over fit my DC ?
- 90 integra b18a1 to b20b questions
- ls v tec without main gridle
- How do I figure out bearing size?
- 1990 b18a1 engine problems
- DC2 UKDM / EDM tai lights, where to buy?
- my 94 integra
- stripped oil bolt
- Shifting Problems
- My '94 Integra Won't Pass 80 Mph
- Please help! Manifold and turbo fitment question! <(PICS INSIDE)>
- find head gasket
- Very low RPM idle
- Cliamte Control wiring issues!
- Will a integra 99-00 coupe door fit 96 Coupe?
- Drivetrain issues, stumped.
- new car dont know where to start
- fuel problem?
- GSR Timing Belt & Water Pump
- 96 integra & 99 civic Si trailing arm bushing
- Color Codes
- Where to find intermediate shaft for 97 4dr AT LS?
- vtec conversion
- HELP!!! Failed smog!!!
- Interior leaks in rain
- car hesitate
- maintenance required light on
- Flywheel upgrading
- Just picked up a 95 LS M/T
- Bogging Down DA
- help plz
- Price range
- What to remove paint from valve cover/paint to use?
- A/C fuse keeps blowing??
- b series cable to hydro question?
- Ac compressor question?
- 96 integra factory alarm
- Fake Mugen bumper and sides - DC2
- Driveablility Issue...
- Ls vtec won't crack vtec, any ideas y???
- DC1 zx how to change the engine from Carb to intjectors
- Battery choices? 91 DA
- b20-b20v-ls-lsv?
- Shaking in the front!!!
- h22 or b18
- Roll cage color opinion
- splatter paint strut bars
- Complete n00b needs help with new muffler
- rims to toss on my dc2 teggy
- Aem pulley kit for integra
- jdm fog light switch
- Seized LCA bolts in LCA bushing sleeve; now what?
- F20B swap in 94 integra...In progress...help!
- Engine Overheating Problem
- 95 4 door have a issue with power windows
- Smoking @ High RPMs...?
- Adequate Injector Size for current and future setup
- 91 acura integra Need Help!
- JDM Engine Question
- questions about compres
- code 9 >.<
- high wattage headlights???
- 99 gsr stolen from LA/CA
- No oil reading on dipstick of freshly rebuilt motor
- Rear brake caliper piston?
- Help diagnose this noise--2000 LS
- 97 Integra main relay question??
- weird coolant leak
- towing a jet ski with a DA?
- HELP!! ABS light comes on after lowering car
- help on pistons for turbo
- goin ls vtec got some questions
- teg head knocking
- ECU help and opinions please
- 95 integra LS wiring problem?
- Hit a deer now horn doesn't work :/
- ecu wiring
- B18a1 Build Suggestions
- Need Help. Teg Pulls To Right. And Wobbles
- Civic Struts In An Integra
- Question about I/H/E
- I need some opinions
- Oil feed line adapter NEED HELP!!!
- moon roof cover rattle?
- RSX Trunk Lip Spoiler on Integras?!
- valve cover help
- bright headlights
- Power Windows Wiring Issue
- evap concern
- Do the 90-91 and 92-93 use the same cluster harness plugs?
- oil (possible) leaking from my exhaust?
- alarm/keyless entry remotes
- computer issue?wiring issue?motor issue?
- USDM doors in a RHD
- BC Cams for b20b
- tranny/clutch going bad need a rebuild?
- whining noise from valve cover
- clogged fuel somewhere?
- what ac bracket to use for d series compressor with ls block
- 99 si conversion to OBD1
- need part #
- C's short shift on a DC2
- corner lights will not stay....
- 1992 integra gsr vtec stall
- Help with LCA bolts
- Innovate OT-2
- clutch pedal/shift minor problem..?
- da headgasket questions
- Show me a gunmetal/gray teg with gunmetal wheels!
- 92 integra gsr won't start, need some help!
- Extension stuck in spark plug hole.. HELP!
- Misfire Under Load...
- Does a 1998 Gsr have a EGR valve
- h2b swap in 93 da
- Anyone using a power steering delete kit?
- gc coilovers question
- DC2 theft recovery window dont work
- hello im looking for a 92-93 gsr spoiler i need help finding one
- 96 Integra ls turning off when clutch is applied while rolling
- acura head
- exhaust question
- SAFC On My LS
- axle wont come out of spindle
- EGR Valve Delete need input
- my dc2
- 92-93 oem gsr front lip hardware
- whats this harness plug?
- H22 LSD Tranny Axle ?
- boosted b18 vs semi stock sti?
- My integra change over!
- 4dr exhaust question
- Can someone with experience answer these questions thanks.
- cheap mods for a 91?
- gauge pod application?
- No coolant
- Break-in transmission?
- tranny/cluth oil?
- solenoid question
- doing a swap soon have a few questions
- Any interest in parting out a '90 Integra LS 4dr??
- so i plan on getting a es tuning muffler..
- help me identify these 3 sensors for the cooling system
- Wobble I can't get rid of...
- Good price for steering wheel?
- putting an itr long block into my 99 gsr
- RHD conversion worth
- engine swap?
- Spark and Fuel, but no start
- skunk 2 shift knob owners
- 94 GSR idle problems
- Vtec solenoid bolts
- aftermarket replacement front bumper
- DC Sport Exhaust Question
- Gsr cutting out need help!!
- tranny problem
- Best ecu for swapping a gsr into a 2000 LS without immobilizer issues?
- k20a in 95 teg help!
- 99 integra cylinder 1 misfire
- apexi ws2 for my gsr
- GSR w/S2 Mani High Idle again
- skunk2 throttle body
- Random misfire need help
- ls vtec help?
- ls-vtec da running sluggish
- relocating the battery
- need suggestions on brakes
- jdm b18c what WHP on dyno?
- Gsr rear brake problems.
- no crank
- gsr motor with 120k on it...how much would u guys pay for?
- 94 teggy Ls bumper help!!
- Car wont start sometimes, starter interuptor switch?
- Whats wrong with my car?!?!
- results from a compression test
- Alignment results after new tires
- i have no spark and am at a loss. any ideas?
- knock sensor
- Header Help Please - 98 GSR
- 98-01 front bumper on 96 teg..fender swap or not?
- Shipping Rates?..help plz!
- new teg shell...auto or manual?
- what sensor is this? how can i reroute these hoses? *PIC*
- Is there any tail lights made for DB1 (4 door)
- 1994 GSR, broken oil pres sensor = no start?
- automatic transmission interchangeability?
- ls/vtec issues
- sunroof flew off
- recaro srd/speed harness questions
