View Full Version : Acura Integra
- GSR bore?
- High Press. Power Steering Hose Question
- People With Shaved Antennas....
- calling all LS owners.........lets hear about your header....need imput!!
- Plug Cover
- pic of silver rota subzero with polished lip on teggy!
- Q: integra gsr frontal area and Cd?
- EK interior FS!!!
- who has the highest redline that actually makes power there?
- VTEC Project Update: VTEC IS FUN!!!
- Miata wheels on an Integra?
- Power Slot rotors?
- B18C head on B18B block? possible?
- Projects for the spring...
- I need help
- Shud i change my Comptech muffler b/c of my 2.5" piping
- question about the skunk2 manifold
- Input shaft bearing or throw-out bearing?
- PLS. HELP ASAP
- What to do!?
- AmsOil
- ITR Rear Strut Bar -- quick q
- Front brake recommendation 98 ls
- 90,000mi
- Thank You all very Much!
- thanks vtec4gs
- special wrench for oil filter
- Uh oh.....oil on my spark plug
- update on spueak
- engine swap on 92 ls
- Hella Supertone horns rule
- i need a 98-01 2dr Integra rear bumper????
- any one have an hp racing muffler?
- difference between skunk 2 and JG/Edelbrock intake man.
- Rebuilt Engine?
- help!!! code 73
- 88 integ ?
- Valve adjustment at 30k?
- Skunk2 Stage II cams, anyone seen these yet?
- I need a passanger side mirror for a 2001 Integra
- Tires
- Rough idle when lights are on. Any idea?
- Integra blind spot.
- best exhaust for all motor
- Cam upgrade for an higher mileage B18C1.. what should I do?
- How hard is it to install the AEM CAI?
- getting white smudges off paint and tips to help sell car for GSR
- Does anyone know the bolts/nut/gasket size needed for a Apex Dunk or other exhaust?
- dry or wet nitrous
- Dealership Clutch Install
- intake manifold difference between gsr & typeR
- any pics of 225/50/15 tires on stock 94-95 gsr blades?
- squeak when turning steering wheel
- Would the next best mod after AEM CAI for 98 GSR be an OBD1 conversion???
- Anyone with carfax? Wanna help me out?
- MD/DC/VA Area Meet tomorrow..
- Need a carfax check for a 95 Integra.
- Vibration in front end
- Top tank cracked open.
- Which one?
- ls head gasket
- reduce frame twist when cornering?
- Radiator Questin
- Exhaust Question
- wahts a code 17
- What do i do with a stock 1994 LS?
- Just did compression test
- What kind of clutch should I get?
- 99 Integra LS Intake problems!
- need help with cel
- How to install Energy Suspension Mount Inserts?
- b17a parts
- Guys with 205/50/15 tires - what PSI
- ITR head vs. GSR head...any real difference?
- Toda vs. Spoon flywheel
- Damn gas pedal!!!
- Is there a way i can identify CTR cams?
- shifter problems
- vtec light with the photon keychain lights?
- majestic honda for acura's??????
- coilover installation
- 98 GSR..good price or no?
- Distributor Problems.
- How many holes have to be drilled when installing an ITR spoiler on a GSR?????
- Car got violated :(
- Oem car cover
- Integra specs
- What do you guys think about this set up?
- $600 Later, My Teg looks a little different!! (Pics)
- Squeaking noise in the morning
- LS compression numbers. With ITR pistons.
- Fuel Rails
- Need a carfax check for 95Integra.
- 94 teg vs 2000 teg
- Would this engine still start with these compression numbers?
- Compression Test results, Input please
- Car shudders when going in reverse from a stop
- Polishing 94-95 GSR rims???????????
- 10w-30 oil = decrease gas mileage?
- where does dome light get power
- JDM GSR
- Pic after I had Comptech springs and Neuspeed-Koni's installed
- H-T Meet In East Tennessee!! Pls Read If Interested!!
- coil-over question ?
- GSR TB cable with skunk2 intake manifold, how/?
- Crashed my GSR tonight
- All people with Headers!!!
- Gauge Cluster Question
- Lowest Price Parts Store Now Online !
- Koni Yellow Perch Setting
- who has a dc jdm header on a g2 teg?
- JDM 4-1 on an LS?????????
- fuel rail stud broke
- need to know the knock sensor
- camber kit, from old springs to new coilovers
- Clutch making a loud squeaking noise now?
- Test Pipes and Check Engine (CE) light???
- Bolt Extraction Techniques!!!
- DC 4-1 or 4-2-1?
- How do u afford your mods?
- Question about Zex kit
- I want mad power!! what do I need to buy??
- is the exhaust anygood??
- Groaning steering...
- cv joint replacement costs
- Good Alignment Shops in Northern New Jersey?
- Anyone interested in JUN cams...
- Vtec conversion
- I'm new to this forum
- B18B1 (RS/LS/GS) NA Setup...Comments and Suggestions Needed.....
- PLEASE HELP!! Car constantly smells like clutch....
- Tranny ???
- cusco cam gears?
- VTEC Project Update: Almost there...
- Does your exhaust garggle when you shift?
- Big Rear Brake help balance/diving?
- Need some help
- Upgrading My Brakes
- how do you guys remove the o2 sensor?
- Car fell off jack...
- new GSR
- exhaust size.
- How bad is it to throw the e-brake on while sliding in the snow?
- Anyone know what the best after market cam to run in a LS for moderate race use
- CEL Problem after 6500?
- 95 INTEGRA question.....
- What to adjust on the Dyno?
- What brake would you choose ?
- I think I've been screwed!!!
- What size tire do u run (205+?)
- Car Fax?
- need a work OBD I ecu for my 00 gsr
- What happened here...help please.
- question about scratch removers!
- GSR Insurance?
- horsepower difference between Toda B vs. Toda C, is the upgrade worth it?
- A question about a valve train upgrade
- shipping company: from USA to Canada
- Some poor Acura employee is going to pay...Read
- once again...Integra meet..please read.
- Knocking
- Tokyo Pics
- LS catback exhaust longer or shorter than GSR's??
- Silly Question, noise at idle.
- QUICK Q, what else do i need for my skunk2 itm install?
- Skunk2 chip makes LS redline 8500rpm? is this safe?
- rear jacking point?
- Brake pad recommendations
- JDM FRONT END OWNERS!!!! Anyone want to sell their 98+Usdm Front End??
- Identifying ecu's
- Engine Parts
- happy new year
- Gauge Cluster question...help me out :P
- Part Number for 95 GSR Distributor Cap and Rotor?
- wat would u guyz reccommend for an NA teg
- Can a 96 GSR Short Shifter fit my 92 LS?Without Modifications....
- Took car to shop today, this sound expensive!!
- where to buy option/carboy magazine in sd?
- where to get skunk 2 Intake Manifold
- DEC 30th HONDA TECH or INTEGRA MEET hehehe GSP
- compression questions...
- Oil Pressure doesnt rise above 75psi
- Type r vs. GSR
- 170's Possible?
- Rear Engine mount,help
- vafc questions
- WTF!?!?
- konis with ground control
- Driver side, lower engine mount, stuck! Help!
- Axle Question?
- Import Showoof Pics???
- Tranny cooler install help...
- NJ teg meet
- will a GSR exhaust fit an LS?
- OT: www.s4-mtm.com Please show us a big picture of your avatar!!! =)
- Integra w/ 6000K HID kit...(pic)
- Ideal cams to run w/boost?
- OT: Need a carfax on 94' LS
- anybody know another way to take of crank pulley bolt wothout an air gun
- changing cv joints
- Comptech camber kit any good?
- Are Yokohama A032R's any good for drag?
- what is more comfy USDM itr seats or gsr
- im getting code 23
- AEM or Comptech
- OT: spoon sports
- H22 in teg...Wise???
- secondaries with hondata
- Does the OEM bodykit from Radley Acura come painted for $350?
- Newbie to this board
- Looking for JRSC for 99 ls anyone know of one for sale
- DAMNIT!!!! ANOTHER BROKEN BOLT!!!
- What is the best way to keep the secondaries open?
- ITR clutch setup
- Good weight for a lightened flywheel???
- !? skunk 2 exhaust dyno !?
- Help!!! Need Drivers integra Seat!! 94-01 Condition DOESNT MATTER AT ALL!!!
- 1/4 Time Question, Gsr, Type R Cams, Greddy Evo Exhaust, 10 psi on Drag 3 Turbo Kit?? 1/4 Times??? Y
- oiling sunroof
- Coilover install progress...
- $1700 worth it?!?!
- NON VTEC PLEASE HELP.... i want umph by stayin NA
- Ran into a problem when changing brake pads...............
- rotors are fried
- Evaluation of my RS
- Integra Specs
- damn its cold in IL 6F....my car is snappin...
- Good Junkyards in MD/VA/DC area?
- Just changed my coolant, I have some questions!
- Brembro cross drilled and slotted rotors for integras
- anybody with a GSR shift knob they want to sell or give me.
- B18B - Top dead center, and the distrib - questions.
- Need help with rattling noise PLEASE.
- real quick question about where to buy OEM bodykit for a good price.....
- Car not getting starter signal right away?
- A must mod for the LS
- What do guys think of my friends Integra?
- rev? problem
- MID ATLANTIC INTEGRA MEET........CHECK IT OUT!!!!!!!
- 5 Zigen Fireball Silencer?
- What is this part?
- anyone know anything about a code 45?
- still getting CEL 43... please help!
- goodbye to my teg
- Frost White and Taffeta white???
- Turbo and auto
- Top speed for an LS?
- the slut had a make over today... new cams, wheels, and brakes! details inside :)
- left tail light
- coilovers or springs and shocks?
