View Full Version : Acura Integra
- So I just received my Comptech header...I have a simple question...
- Honda oil filter: 15400-P0H-305 or 15400-PT7-005 for 94Integra?
- Just in case anyone cares...
- GSR's built in Sazuka, Japan?
- Buy my Integra :)
- JDM integra '96-'97 w/ B20Z???
- Leaky Tailight
- 5 zigen exhaust diameter
- Options...
- Top speed of GSR?
- Timing ques...
- jdm 5 lug conversion on usdm tegs...problem?
- where can I get a TPS sensor
- Recommendations : Wheels Repair Shops in Tampa / St. Petesburg FL
- any experience running koni yellows and ground control?
- 91 LS Brake question
- Comptech Type-R exhaust fitment on GSR
- Which Aftermarket Tires?
- NR gauge?
- Ride height with H&R springs
- my milage is EVIL gotta see this pictures!!! 66,666 66.6
- Noise coming from wheels!!!
- Urgent: Throwing a CEL
- Question about Axle boots...
- Thoughts on buying used E/H?
- anyone have pics of what the es oval muffler looks like on integra's?
- Is the LS air intake box the same as the GSR air box??
- CANT GET INTO GEAR!!!(sometimes)
- NOS shot??
- Red/White interior for sale!!
- Pro-Kit + Yellow Settings
- Best headers/exhaust?
- Wierd popping noise after install of ITR swaybar
- p73 ecu in a 2000 gsr
- Anyone looking for a brake upgrade?
- B20b BUILD UP!!!
- springs and shocks
- Immediate off throttle problems...
- Edge Racing Rims
- Help with blown up JDM GSR motor..long
- Should we have a KC H-T meet?
- Supercharger
- Hmmm~....
- hayame muffler
- lsvtec
- Can the gauge cluster bulbs be change???
- just snapped the screw off my head!!!!!!! lol
- Gnarley Speeding Tickets
- How do I take out my Bulbs?
- TJ's adj. B series gears
- tranny swap shops?????
- Odometer Rollback
- Cams or ECU?
- B&M oil cooler?
- engine help
- Stock p28 ecu
- 92-93 stock bumpers
- So i got my new Comptech springs...
- Steak and Shake Meet Altamonte Springs, Orlando Fl August 24th 9pm
- Does anyone have a pic of an EVAP canister in their engine bay?
- Spark Plugs wires?
- worth getting the AEM CAI??
- tranny differences?
- Best Maintenance Manual?
- Newbie here, I own a 94 LS, whats up all.
- cant get rear wiper cap off
- Integra clutch 90/94
- Official times...
- Which cat-back exhausts are available for GS-R sedans?
- question (somewhat off topic)
- Type R tranny in GSR bolt on?
- Anyone here know whats required to put a 'smaller/higher' 5th gear(LS or GSR) in a USDM or JDM ITR T
- Dallas area peeps...Imsport Racing shop?
- Timing
- what is the piping diameter of a dc sports exhaust??
- Pictures of your gauge pods...
- Mechanical oil pressure guage...
- NEX Coilovers
- GSR Intake Manifold on B18B/B20?
- ????Topspeed???/
- Viper starter kill..??..
- my GSR feeling sluggish....
- Noise coming from sunroof...
- Eibach Pro Kit Springs
- just put in 9005 Silverstar conversion...
- who can get good deals on OEM honda/acura parts?
- Check Engine Light
- What pieces am I missing from the radio console? (PIC)
- JDM H23 build up possibilities
- Azenis tires Ownz!!
- urgent! need obd2 to odb1 harness pics
- Wheres the PCM reset switch?????????
- Is this fine for a new clutch for my car???
- Does the greddy 4-1 header say Greddy on it anywhere?
- Bras... Bras everywhere!!
- compression test how to??
- safc?
- Spoon Sports Radiator Stay? (modacar.com)
- To those with camber kits
- anyone lower their tegs on 1.2inches??
- OT: Anyone here from manitoba?
- Las Vegas Honda-Tech meet
- integras at aucton
- Gauge Cluster Differences?
- bennen tie bar
- Sparcos
- newbie radio swap, will it fit?
- does spark plugs
- Need Opinon on a purchase-major one.....
- rear skirt question
- Help needed: rewiring corner lamps
- Do tires help if you don't have enough power to chirp/spin them?
- ECU throwing a code - please help
- How come I can't advance to 18degrees...only 17?
- clanking noise with H&R coil install...
- 1991 Integras... What motors were available for them?
- What the best mod, dollar for dollar, put on YOUR car ?
- anyne find a 94 integra at a auction
- Best handleing mod every.... here to testify to it...
- 90 LS rear trailing arm bushungs gone bad. what are my options?
- Header Installation Tips??
- Sunroof has the jitters
- anyone have a 90-93 integra ecu?
- Front drivers hub loose? bearing (everything is tight)
- Spotted a RED Teg with....
- Coilover Question???
- who would you put $$ on?
- Need Upper Control Arm....Just crossthreaded mine
- DC JDM 4-1 fits LS?
- Sparco seat install...
- Putting a Type-R rear sway bar on a GSR
- Recently Purchased a 1994 Acura Integra GSR 4dr
- Thank you Chris for locking my thread
- Possible Ortega meet
- Eibach spring rate.
- anyone switch from Weapon*R to another coilover?
- Going to do some street racing, need some advise
- b18a1 re-builing questions?
- -2 degrees camber with H&R Sports.
- spare tire
- front sway size for canadian tegs
- Help wit selecting reverse indiglo gauges...
- Installation of Ground Control's and Koni Yellow's
- wheel spin off first w/ nos?
- which lower tie bar to get?
- vafc settings
- Does anybody have an extra bulb holder for 94-98 front repeater/turn lamp
- What are you guys running for sturts/springs need to lower car
- Quick question
- Anyone running LSVTEC with GSR head and CTR pistons?
- Best cams for a stock compression B18C1?
- spoon n1 exhaust
- Ingalls Camber kit install ??? Need help
- Ash Tray & Cig. Lighter delete?
- Frozen Front Control Arm Nuts
- Broken header bolts...what's the best extraction method?
- where is the coolent temp sensor on a b18c1?
- New suspension
- Dunno if i have a problem or not????
- Helm manual
- Compression numbers on my turbo LS.
- OBD II Nteg LS throttle body work fine on OBD I LS nteg ?
- Airbox Cover?
- VTEC Engagement Variable
- Checking for Vacuum leaks?
- Where Can i get some new front lights?
- NGK Platinum installation
- Does Tanabe make a 3'' exhuast?
- 4-2-1 headers
- ls/vtec with chipped keys
- high beam problem
- Speedyradiator.com
- which exhaust Tanabe RM or Apexi N1
- anyone have GSR ECU Wiring Diagram 97 OBD-II?
- Need emissions help
- HELP! VTEC oil pressure check engine light!!
- need help on racing tips!!!!!!!!!1
- can one buy these parts?
- New SCC Mag Hits AUG 26 ....ENTIRE DETAIL FOR A G1 TEG B-Series SWAP !!!!!.....
- What msd kit to buy for my allmotor ls/vtec???
- 94-97 ls ?
- Help!!! Is it my tranny or my clutch???
- do you think I need an alignment?
- can i swap an engine in and still keep a/c.
- Changing oil
- Question about B18C1.
- Squeaky Clutch?
- Simple.... Forged or Cast ? No huge Hp Q's here...
- itr shift knob nut...
- jack stand question...
- jg edelbrock intakemanifold GSR[link]
- When did it come out?
- Headlights... bulbs keep going out!!
- Does anyone know what this could be....
- Cost of lowering?
- Looking for rare 90-91 DA6 body kit
- itr lca's
- The best route, which one of 'em is next?
- where to find?????????
- Anyone have experience with PYR cams for B18b??
- How to start modding my engine to an ls / vtec ?????
- Nisei Week Car Sho & Carnival
- Splash guard
- Radiator replacement
- Acura Integra GSR or Acura RSX Type-S
- Belt replacement Urgent
- --->What Does This Do?
- Can a Spoon Radiator cap make my radiator leak??
- Clutch break-in over, AND...
- NEED help identifying headunit wires in '90 RS teg......damn thieves!!!
- Another Oil Changing Question....(sorry)
- What ecu do I have??
- A big thank you to all ricers and generic muffler makers
- How to bleed air out of system after installing new radiator?
- Engine Lags, at steady rpm, then kicks in... Hard to duplicate, but happens alot
- What do i use to tint my windows
- Switching from AEM CAI to a short ram - Which one to buy?
- Will a catalytic converter from a '94 teg fit on a '98?
- I lost low end with my Skunk2 manifold
- installing sedan exhaust on coupe... ideas?
- Bay Area Folks!! HELP!!
- is a 4 puck too hard for the streets?
- Have a problem with my swap
- AC compressor
- hello...im new and like integras
- lug nuts
- ECU Code 6, 7, 13
- ecu question
- 98 spec type R cams VS. 00-01 Type R cams?
- Help! Need source for new tranny in SoCal!
- MOMO hub stuck on steering colum
- What fuse to pull whle doing a compression check?
- oil, coolant, tranny oil, et. al....where do you discard it?
- Clutch, Transmission? This one is tough
- Turbos???
- where can i buy BENEN products?????
- Teg action strange. What could it be?
- need tires and want opinions
- Suspension Techniques Anti-Sway Bars ??
- oil change questions
- Spark plugs for a GS-R basically stock???
- Question about a 93 Special Edition Integra.
- What the F... just happened to my tranny?
- '96 GSR, good price?
- can you use a P28 on DOHC w/o re-chipping
- steering wheel and front driver side wheels shakes
- GSR Shift Knob
- '91 Integra stock parts
- Rims for a Road Course? (like thunderhill)
- How to run wires down A-pillar?
