View Full Version : Acura Integra
- Tire questions and poll.
- Is it hard to swap front end from 96 integra to 93 integra?
- apexi integra pic????
- How do mags test the braking distance for a car???
- Doing the exhaust right the first time...
- Pics of my new Integra...finally
- DIY Rear Lower Tie Bar
- lifting teg
- How much hp will A aftermarket pulleys push out to the wheels?
- bent valves?
- springs - coilovers?
- Idle Problem, HELP!
- Oil pan gasket....help
- Attn: VA.......Anyone ever done a timing belt and water pump install?
- sup were can i get cheap racing mounts
- integra running 13s all motor?
- tegs w/o Abs
- another "how to jack up your car" thread: regarding problems with Harbor Freight aluminum flo
- ECU Codes / b16 head decoding
- 91 integra Projector harness problem!
- what is the cheapest way to finish turbo my gsr all the way ?
- Mysterious Car Shutting Off problem
- 1991 Integra: Need Advice on Making an Offer
- motor mount/torque mounts??
- where can I tap into ignition wire on a 94 Integra?
- Project Update: Stage 1
- 2nd gen headlights ???
- How much is this car worth?
- b-pipe?????
- Can anybody w/ an OBD2b GSR look at this really quick?! I need some help really quick.
- Does changing to ITR 5-bolts conversion affects the track width?
- Power Fall off problem!
- Power steering belt, 2 different part numbers?
- specs of GSR cams
- acura to honda engine swap
- haha this is funny
- 94-97 & 98-01 Integra Body ....................
- Integra vs 4age
- installed valve springs/retainers/cams today
- TORQUE specs!!! cam caps
- comptech value.
- tires!!! where to get them and cheap online??
- rattling exhaust?
- noise after 2750 rpm...
- exhaust size on 90-93 tegs?
- messed up tranny
- Help!! suspension question
- new to GSR's
- engine clean up
- WORK RIMS??
- Look, and we wonder why we see so many " stolen tegs"
- Need help tuning my 96' Acura Integra GSR (4 door)
- P30's in a GSR ? ? ?
- I wish people would quit jackin Integras
- another car goooone AZ
- INTEGRAS WITH A TURBO HURRY!!!!
- exoust on my 96 integra
- how hard is it to install energy suspension motor mount inserts on my 96 integra
- Black 4 door GSR... WTFFF??
- Does the new AEM v2 perform that much better?
- My GSR is gettin an LSD
- Throttle Cable ? GSR
- Fastest Tegra...
- gas gauge on cluster not working? help please
- need help on an LS/vtec swap.
- ive searched pls help idle problem 90 integra
- Swapping a comeplete B16A obdII swap into a 97 integra gsr, what do i need to accomplish it???????
- Having problems accelerating with AC ON
- knowledgable people please help....need some opinions
- stolen teg SALT LAKE CITY
- Stolen Integra GSR in SF Bay Area!
- 94 ls - died on me, need help
- How many hp to expect?
- What size (large or small) kind (brand oil filter) and why???
- Tranny Fluid Change Interval
- What do you think about this website
- Need rear camber kit?
- car doesnt run right
- Reseting ECU question. (emissions)
- Clutch Problem ... slipping???
- OEM gsr spoiler fit on a del sol??
- alignments
- why is reverse so ruff sometime in the 94 ls danm
- Should I keep my B18A1?
- CD2 engine detailer
- Quick question
- Team Dynamics Pro Race 1 wheels, need pics on car. Experience
- Crower Intake Valves and Stock Headlights
- any sites selling skunk 2 stage 1 cams for cheap??
- 1990 2nd gen integra starting problem
- prelude injectors??
- help! need to replace exhaust fast!
- should i swap my lsdb20bgsrhead from a 3gee teg to a 1995 civic hatchback eg??
- Pulleys
- Carbon Fiber Canards For a Cwest JDM Front??
- Where is the alternator fuse?
- pic request...... apex ws on 2 door
- First Post: Read throught every thread on VAFC II and need Clarification.
- I need to talk to a moderator.
- i need advice on driving
- ls/vtec
- Removing Rust on Rotor
- ne one in the washington area
- what head is this?
- JUST INSTALLED AEM INTAKE on 91 RS. Weird Hose Pops Out
- 2 door integra side skirt
- Skunk2 exhaust sound and performance
- Need knowledge well.... HELP
- Greddy Electronic Gauges
- I am looking for a good place to buy a set of hids...
- Detail info on gsr 97, where?????????
- i want to make my valve cover like new how ould i have it bllack again help plz
- Anyone use those crazy looking H-Braces for the lower front on a dc chassis?
- 90-93 coilovers vs 94-01
- Gauge cluster
- Need an ignition wiring diagram ASAP.....
- Brakesss going weird help plz..it's emergency
- What do you guys use to Get stubborn Brake Dust off your rims?
- brake pad question
- hey sup guys i hope i dont bother i wanna know can i put an 99-00 SI tranny in my 94 ls
- Open Header??
- Need help please, Transmission Problem
- ITR tranny w/4.7 final drive
- Which performs and sounds better on 2000 GSR?
- Ls/Vtec
- i mean timiing belt!!!!
- selling my gsr integra
- Need help installing water pump asap!!!!!!!
- car idles high
- Anyone in Central Eastern Ohio that can help me?
- Integra ECU Plug
- OBX Resonated Test pipe fitment
- bumper lights
- oil burning question
- FI Integra 94
- high end? short ram or cold air?
- Need Help Dont Know Whats Wrong!
- gsr ignitor
- good or bad for boost?
- is the GSR cat bigger than the LS?
- intercooler piping
- slight hesitation when quick shifting
- Having Gas Problems with 95 GSR
- Clutch Help
- please help just installed my AEM V2 for a GSR
- need help with oil leak on ls/vtec
- Andy's Autosport California Type R Body Kit Lighting Question?
- AUTOMETER tach question
- diameter of exhaust piping
- chiped p28
- Electronic problem
- will a stock cat fit with my aftermarket exhaust?
- Brakes for my GS-R
- Wrapping an SMSP Header - searched
- turbo ls or Gsr turbo
- my foglights!!
- 94 ls need help wiring
- 94 ls need help
- Car wouldn't start, smell of gas....now runs good?? Whats the problem??
- Question for an Integra
- GSR vs ITR B pipe
- Looking for GSR head
- 1989 Integra LS question on heating/cooling system
- wuz up jdmer's
- a/c help!!!
- Resevoir Covers??
- overheating
- gen2 integra vs. gen3 integra
- cel code problem
- AEBS intake manifold for the GSR
- Where the hell do I put a power chip?
- Comptech filter required for Icebox?
- puddle under car
- LS tranny case
- STOLEN INTEGRA LI NY
- Wilwood 13in. Brakes
- need parts and questions answered h22 swapin 90-93 integra
- new stuff help here plz reply my stuff wich one is a good exhuast invidia,skunk2,ESPELIR plz hurry
- check out my CAR (with pics, 56k friendly)
- Car Stutters When I accelerate
- S2000 in a DA. BEEN DONE BEFORE?
- oil light stays on????
- 4dr oem kit
- who's down to meet?
- so cal meets
- brake kits
- hid kit for my db8? Phillips ? xexon? who has it on there 94-01 integras ? need advice
- water pump
- Immobilizer Question!! HELP
- optima bat. questions
- where can i get these side skirts?
- Does anyone have soundclip of 2000GSR with N1 apexi exhaust system?
- Resistance limit for OEM NGK wires
- who git an ESPELIR EXHAUST
- Tranny problem?
- Alternator problem???
- Comptech H/I/E
- Coolant drains quickly
- Exhaust dump AFTER the cat and resonator...
- resistor box question
- Not getting a spark
- Here Comes The Annoying Newb Questions...SORRY!
- Parking Brake F-ed up?
- Maintence Required Light Blinking on startup 63500 miles.
- side lip 4 da
- do i need shocks for lowering springs?
- different strokes for different folks???
- Help with turbo LS setup
- Draining the Cooling system
- Catalytic converter problem....
- Anyone in CT please check this out!!!
- Anyone identify this plug, and/or answer harness question?
- Clicking noise...can anyone help!
- bled brakes
- sensor on #1 runner of ls intake manifold??
- anyone have a oem underside hood pic?
- trailing arm bushing
- DA Filler Panel, will this fit?
- racing
- shifter question
- 1998 Integra GSR Security Question
- What would u reccomend?
- I wanna swap my ls intake manifold to a stock gsr manifold
- Help Me how to identify a B17a Crank?
- B20 Vtec Integra whats it run?
- Supercharger
- odd barke noise (already searched)
- Starting Problem
- helms help plz
- Yet another smog failure
- CLOCK IS REALLY DIM? CAN HARDLY SEE THE TIME?
- Help Me Find Wheels For My DC2
- DO NOT BUY DC SPORTS
- b18c1 with OS ITR Pistons pass smog?
- b18c1 transplant (nissan 200sx)?
- A few Pic...
- code 43...need help!
- Look at picture ----need correct part #s for grommets and screws 4 integra bumper
- Question for experienced motor-swappers ... logistics?
- kinda stupid question....
- my senior project: rebuilding a b16
- What's the most stock-looking exhaust that still makes some power?
- Where can i order a new 1-2gear Synchro Online?
- Dash lights cutting out on me
- Oil Change interval?? Every 3000 miles?
- Apex WS pics....thanks to those who posted
- Will a 2001 OEM stereo fit into a 1995???
- All DC2 dash the same??
- Spoon shift knob
