View Full Version : Acura Integra
- Clutch
- exhaust
- Question concerning compatibility
- b20 vtec Headbolts
- manifold question
- spun another bearing
- Have a question about raising my car!!!!!!!!!!!!!!!!!!!!!!!!
- swap question
- Going Turbo is there a big difference between gsr and ls tranny????
- Camber Kits...Skunk2 or Ingalls?
- Air supercharger
- quick question
- which turbo and manifold would be needed to keep AC in my integra
- Dc Rebuild Continued
- Strange engine noise in 99 GS-R
- Which steering knuckle is bent?
- Tuning/Adjusting SKUNK2 Camber kit, HELP PLEASE!
- Immobilizer swap?
- Type R bracket on Skunk2 Throttlebody *PIC REQUEST*
- DA wiring help needed...
- Ls wire sparkplug wire cover.
- Question about LS tranny..
- hks super drager?
- need to know the part number for these
- Simple Integar Header Question
- WTB ASAP! 94-01 GSR flywheel!!!!! PLEASE HELP
- 95 integra plus jdm b20b?
- ABS MC Fitting sizes
- HELP!! Short shifter install
- Someone who owns a DA integra need a quick favor please!
- can someone identify this plug
- idle problem
- jdm '93 integra xsi/rsi cable or hydro tranny?
- Anyone have experience with D2 suspension ???
- integra halo projectors, what to wire it to
- putting a ls head on
- abs malfunction/abs light is on help!
- changed timing belt, wont start!
- Racing Seats on the DA (fellow DA owners please advise)
- i get on it, then the temp goes up
- PLEASE HELP DIAGNOSE!!!
- problem with motor (running loud/ticking)
- symptoms of having very bad motor mounts??
- BAD WHEEL BEARING
- DC Rebuild
- swap....?? yeah or neigh....??
- need help
- megan headers
- FOG LIGHTS MELTED LIGHT HARNESS(short in wire)
- SMOG Trouble
- Need to know the difference about headers.
- 2dr and 4dr same shock?
- Broke timing belt while driving.
- fuel pressure and tps ?
- Belt Runs / No blows
- RSR EXMAG
- cleaning painted wheels
- radiator bleed valve
- VIN Locations
- Problem with Intermediate Shaft
- NOOB!
- Where can i buy the little thing that protects the engine from the bottom?????????????
- k24 for sale
- N1 exhaust available?
- FS. 1996 Usdm Acura Integra GSR front end.
- Is it safe to use 89 instead of 91 gas?
- 2001 integra gsr
- GSR and TYPE R aem intake the same??
- Tail lights
- Maintenance light??? how to get it off
- Difference between AEM short and long neck filters
- horse power will i make
- help car breaks up when i rev
- check engine codes on my ls
- stolen integra in san francisco
- need help on engine swap ideas for my 92 integra
- Stock block and head Da drag times
- Passed my smog!!!!
- Is it my alternator?
- installing sidemarkers
- Ticking sound from exhaust (Not sure about motor)
- b20 gsr/vtec swap
- Theirs something wromg with my muffler or exhaust!!!!!!!!!!!!
- Rear Bumper
- drag racing vtec vs non vtec
- installing headers
- B16 axle Q?
- Dirty Housing
- got some parts for sale.... need to sell asap!
- 2 check engine lights
- help car wont start with odb1 harness???
- accord ecu
- speakers for 90-93 integra, g2 guys help.
- cant get into reverse
- Piston?
- ATTN: URGENT>>CAR WONT START!!
- Mom's auto LS spedometer went out...
- Quick Q?? What does GS-R Mean???
- Need your help with anyone who has a stock spoiler (thats 90% of you)
- need help. in a bit of a trade dilemma
- lsvtec
- 98-01 rear bumper on 97
- quick question
- setup options ls/v gsr b16 pistons
- does any one have a hydro LS tran?
- Throttle Body Sensor
- Differences between 4 door and 2 door 3rd gen Integras?
- Oil Pump for a b20 vtec
- STOCK MOTOR.. WHAT WOULD YOU DO IF YOU WANT TO GO ALL MOTOR???
- Exhaust too loud! how to reduce noise?
- Stock running rich? 02 Bosch sensor?
- itr/sir-g headlight question
- can you help electrical problem?????????????
- DA suspension question.
- New springs on stock suspension
- Cali + Engine build + OBD2 + Smog = ?
- Caster Problems?
- b18c swap
- burning a lot of oil
- How to install AEM Short Ram Intake on DC2?
- Clutch might be going out...
- Valve Adj. Help quicky plz !!
- STOP!!! To anyone sending in a good GSR block to get sleeved....
- 5 lug??
- lsv turbo vs b18c na
- Anyone have problems scraping their mud guards?!?!
- Stock ITR CD player in GSR
- JDM_DC2SiN Project GS_R Integra
- HELP!!! speedometer isnt working!!!
- side marker help
- Any one have some blue Integra seats for sale?
- jdm 1pc headlights?
- Dc2 Taillights
- Is my cat-back exhaust still good or should i get it replaced?????????????????
- Seems like alot of idiots/wannabes on this forum...
- What is code 7
- Corner lights
- Short shifter
- where is the p/s rack on a gsr....???
- how do I open a jammed locked door?
- Exhaust systems for an 01 integra LS (no VTEC, yet)
- Does converson kits for Integra's need weld work?
- Need help on a possible spark plug wire going bad issue.
- GSR Swap
- 97 gsr how much?
- i need to know about an exhaust tip
- 4x114.3 conversion for a DA
- Both windows rattle like crazy...
- I need cooling advice/help for my DA teg
- Vibration problem at highway speeds
- Quick Question
- clutch/flywheel install
- 89 RS question
- Did Search: Where is Scanner Port for 95 GSR?
- WHICH ONE????
- head question
- Prelude injectors in Gsr
- ZC cam
- just making sure real quick on axles
- Clutch trouble!
- will dc5 5 lug fit on dc2
- need help wiring the vtec odb0 to 1 harness??any diagrams??
- starter problem?
- need help
- Thinking of new paint; post pics.
- Header questions
- Integra DC trunk removal
- which cam is which?
- Question about my alarm
- What tire size to use with 15x7 rims? 215/45/15s?
- Good choice for clutch?? I searched!!
- ive got a problem...please help a fellow tegger out....
- SHOW OFF YOUR EXHAUST!!!
- gsr vs 06 base model rsx
- need help on HP guess.
- NEED HELP REGARDING THE JDM ITR HEADER IN GSR
- PR3 ECU
- suspension what to choose?
- PR3 Spoon Ecu in 94 GSR?
- Wats the difference between ecu's???
- 1994 acura integra gsr motor transmission and ecu for sale
- skunks vs kyb agx vs tokico illumina for my 94 dc
- Question about fuel pump assembly
- exhuast question
- I need a longer clutch cable then a DA ideas?
- I Crashed....Where to get GSR Front End?....
- For people with the Skunk2 Shift Knob
- tranny fluid
- coolant leakin from oil pan **NEED HELP!!!**
- Tapping noise when coasting
- Do a 4 door Integra B-Pipe fit a 2 door Integra ?
- who is riding the new skunk coilover?
- acura cd player won't work anymore
- DA owners please come in
- 93 ls= 93 rs ???????????
- JDM itr conversion: buy parts separately or complete?????
- alternator q's
- what does a stok gsr run??
- Code 24
- Distributor part number
- parts list for swaping a b18c1 gsr into a 1992 integra
- Coilover ? that i NEED answered
- giving up the teg
- OEM headgasket kit
- Jdm Front End Help!
- champagne color DA interior color
- b18b fuel problems
- How To: DIY Del Sol Seats in 94-01 Integra
- Brake or Rotor noise?
- 94 Integra RS keeps dying
- Bay area import shops, where they go?
- Any1 Have the Maintenance Schedule+Checklist for the 3rd Gen NON-Vtec Tegs?? +TimingBelt ?
- Is this bumper repairable?
- what to do with 90 integra
- WILL A JDM ITR HEADER FIT A 95 GSR?
- what type of signal does the vss on a 95 ls put out?
- Swap questions.
- Code 7
- ECU quest
- wow i found a bad @ss website
- Engine code for 95 gsr obd1
- Help with exhaust
- ACE lip ??
- Best online teg shopping?
- type R axles?
- symptoms of a bad tranny
- possible to convert a DA to hydrolic tranny?
- Fastest All Motor DB8..........
- anyone have 1st gen parts?
- what are the b-series automatic gear ratio's
- will a si , ls , or ex muffler fit on my gsr?
- smog check needed click here
- STOLEN RED GSR 2DR CHICAGO
- HONDA"s new car
- Everyone whos had an oil light read this
- over heating...
- Temperature Gauge Fluctuation
- RHD where did u get it
- Dc2
- IVE BEEN A MEMBER FOR A YEAR AND I CANT POST ANY TOPICS OR REPLY TO NUTTIN
- lets see some reviews
- Vacuum diagram for b18b
- which oil pan for 99 gsr?
- Fuel Pump Kill Siwtch help on g2 teg
- how to take out and replace cam seal
- New to Honda-tech.com!
- a 2000 si tranny going into my integra, the si tranny is a y1 right??
- 94 Integra JDM Options??
- what air filter?
- Best aftermarket fans for GSR????
