View Full Version : Acura Integra
- O.G. 16 inch 100 spoke's DA9?
- 97 itr head/ b17a1 block
- converting a 90 to power locks info?
- Questions over aftermarket injectors
- need help asap integra starts then dies
- how to paint my wheels please help
- CTR Tranny/Shift Linkage problem
- RPM going crazy (video)
- ITR front caliper install onto 94 LS
- 97 GSR Computer Problem
- 91 jdm headlight help?!
- motor quest swap jdm/usdm
- will gsr timing belt + water pump fit an LS?
- thinking about some new shocks
- help with my dc please..
- ls vs. gsr shifter
- My shift knob gets warn and it's not because of the sun...
- Smoke coming out of oil fill cap
- quik obd/engine question
- 2dr carpet to 4 dr ??
- totally puzzled
- weather stripping
- cant pass 1gear
- Auto Dizzy on Manual car?
- any advice for my gsr??
- OBX camshafts
- Wheel bearing about to give up the ghost.
- obd2 ls valve cover
- Need help removing tps sensor
- Help Identify the Characteristics of this issue.
- oil recommendation
- Starter problem 93 DA
- need help on what i need ?????
- Bleeding clutch fluid
- 2dr vs 4dr window regulator
- Integra LS
- sputters under 1200rpm
- Need help with smog??
- y80 tranny any good
- Acura integra gsr
- cant find oem rear lip
- Where can I buy OEM replica pistons
- Suspension set up
- 99 integra conversion to type-r?
- fake visors
- exhaust heat shield
- gsr turbo problems
- B18b1 into a Da
- 94 teggy cooling and ac fans
- WTB/WTT... looking for parts (Chicago, west suburbs)
- P30 ecu help!
- 94 LS: tein s-tech, H&R race, Neuspeed race, Eibach sportline, or Progress springs
- Replaced inition control module. Car now feels weak at 2k-3k.
- How much should I sell old springs for?
- hook up iacv?
- new here got my first integra
- Putting on door panel?
- Trouble Shooting plz help...
- soo confused..
- Helpp! Car shaking!!
- Please help! Car wont start!!
- Pic Request: DA with BBS RM or RS
- what is this sensor????
- Vafc2 help
- Car title says "FOR EXPORT ONLY"
- Compression PSI results
- Harness Bar Questions/Answers
- 99-00 civic front end on 94-97 integra
- new harness isntalled(problems)
- what kind of trany is this..?
- 90 integra gs overheating problem NEED HELP
- ???...H22 in 95 teggy...options?
- '93 b18a jumped time
- side skirt "name?"
- Got an Integra with b16/gsr with front bumper
- Integra's Rock!
- ..::: HELP! Car won't start :::..
- car almost turns off when i come to a stop
- Building GSR for 40lbs of boost (Makin parts list)
- Necessary for sealant on spark plug tube + gasket?
- Comp Test
- Rim help
- injectors and fuel pump stuck on??
- How big exhaust?
- 2000 integra rear bumper
- DA seats in DC2
- Skunk2 Intake Manifold hose help
- Shaking when braking =/
- B18b1 idle high to low problem
- Fogged up headlights. Kind of a DIY
- OBD1 and OBD2 GSR Head differences
- lots of movement on drivers front rotor
- my car wont go over 4k rpm noise? video inside
- Vtec oil pressure switch bypass?
- Fuel gauge staying on empty
- flywheel question
- Help please. my Integra shut off on me.
- expected 1/4 mile time?
- integra b20 swap
- 94 integra ls wont start at all
- Sportmax 002 (0 offset)
- Car shuts down after 5 minutes of driving???
- Where to get new DC2 headliner board?
- Lowering Problems
- Low Idle Problem?????
- evap vacuum question
- cracked/burnt valves?
- 2nd 3rd grinding w/ popout
- Finally! JDM ITR FRONTEND!
- slammed suspension issue on 92 GSR
- B18a questions
- Dohc vtec decal?
- cleaned iacv now have overheating problem
- how much would you pay for my engine
- 91 integra axle keeps popping out?
- Looking for a Performance Clutch for my Integra any Suggestions?
- Infinity Kappa 6x9's In Front Doors
- Issues With Map Sensor Voltage
- Cheapest engine i could dump in my teg??
- lowering my teg
- Problems After Installing Clutch!!!
- GSR Water pump dowel pinp
- what would YOU do?
- help finding fuse box diagram for da
- Linkage fell off tranny.....
- lifters????
- my integra wont go over 2600rpms need help
- ac compressor install
- Help tail/cluster light fuse keeps blowing
- Painting DA Interior Fabrics?
- horrible gas milage. Ls teg
- Stuck sunroof. HELPPPP
- i need idea wheel paint white in integra gray
- Integra Carpet?
- 1997 integra auto to manual swap?
- oil and water temps
- Integrabot
- 94 LS boosted issues..
- would it fit??
- $5500 good price for 01' GSR?
- My LS VTEC Motor Build
- differance between 2 dr gsr exhaust vs 4dr
- trunk leak?!
- Integra Smoking??
- GSR IM brace bar and heater bypass pipe ?
- integra taillights?
- need to find obd2a to obd2b jumper harness
- Help: 94-97 to 98-01 ABS swap for my DC2
- help! who has done the 94-97 to 98-01 abs swap
- 90-91 & 92-93 clutch & pressure plate question
- Weight specific ? Carbon hood/hatch and FAL windows
- Who has HID's with a USDM front
- Does anyone know what size bolt this is?
- iac/ coolent question
- obd0 teg motor ( dizzy problem )
- Car wont start... Battery, starter, fuses, etc. are good.
- DB8 Rear Options...
- GREDDY SE EXHAUST On GSR??? good or what??? or any suggestion !
- gsr 5 speed, jerky
- gas mileage?
- Acura Integra LS 1990 Expansion valve
- adfasd
- quick help please type r head......
- how do take out IM studs ? ? ?
- how to polish the stock muffler out???
- 2.5 or 63mm exhaust options
- itr rear spoiler - Where?
- 1989 engine swap
- No spark from all distributor cables 94 DB8
- Fuel System Trouble code
- Rough lower idle with headlights on
- da out with old motor in with new
- Wtb 94 integra lower control arm
- making a weird noise around 80mph
- 1990 integra ls many problems please help
- 94 gsr ?
- can i rule out head gasket?
- JDM Red H key
- 25mm itr sway bar oem bushing
- LS tranny throwout bearing fork came off, can I get this on with trans in?
- hid replacement bulbs
- k20a2
- is it safe to run high octane on a b18?
- Anyone in ft. Carson Carson colorado
- Timing belt, 92 Integra
- 94-97 type r lip?
- need help with headers
- headers question
- how do i remove dipstick tube on dc
- Hiro spoiler/front end
- ICBMotorsport.com??
- Overheating issue
- Red Bucket Seats
- Computer/electrical failure traced to remote starter
- Jdm Front end???
- lsd
- b20 throttle body replacement
- How To Repair Halo Projectors?
- harness issues
- integra fuel and ignition problem
- Gsr cluster in a 95 integra LS spec.????
- Driverside door doesnt open from inside 92 DA
- Crappy throttle response after timing belt change?
- Need help with relays
- ABS Problems
- GSR Booster ??
- :::..A/C Service - Southern CA..::: Who do you trust?
- dc2/dc4 fuel gauge accuracy
- symptoms of a bad TPS
- New Exhaust Setup
- clutch/flywheel help
- flywheel tq specs
- Coolant/ dealer question for 91 DA
- JDM GSR Gaskets HLP
- fuel supply system
- Should the motor die when you unplug the iacv?
- LS and GSR cases the same? scychros?
- Oil on Spark Plugs
- Palm Desert Teg Owners
- No oil in car when running?
- Turbo or V-tec?
- type r axle back
- new here
- Clutch Master Cylinder issues--
- head gasket help
- Engine shifting rough
- how to check a turbo
- xtra connections from harness
- Timing belt + water pump + ?
- Can I fit Civic parts on a Integra?
- Built GSR MAP sensor issues.
- Integra DA and Dc brake differences
- Turbo kit selection
- where is the da love?=[
- Header Selection
- DA Integra side moldings (please help)
- Need help!!** tps issues ! oposit reading......
- GSR wont start
- front end shakes makes laggy noise? b20 swap
- 94-97 si-vtec bumper lense
- Rough start up idle... CEL
- 92 gsr problem
- 95 Integra LS Weight Reduction
- Transmission JACK--to Drop Engine
- Throttle cable bracket in integra with b16 swap
- Maybe a stupid question... but.
- ABS Function
- 2nd gen bumper duct
- swaping power for non power steering
