View Full Version : Acura Integra
- 90 teg.....is there a itr tranny that will bolt up!!!!!!!
- lowered cars clear vehicle lift in shops?
- SI or GSR wheels??
- Valve adjusting/tuning??
- ctr or itr cams for b18c1's
- Got a new JDM part today (pic inside).
- Check Engine Light "ADAPTER"! How to. . .
- Any Apex'i N1 testimonials??
- Newbie here
- Profiling Stolen Cars
- how to take off interior door panel
- Type of Grease for CV boot ?
- Teg is being repaired
- oem kit installation
- What type of self service can you do yourself instead of paying hundreds at the dealership?
- help with short shifter install
- GSR brakes to Legend, or type R brakes on G3 teg
- Passenger door???
- Silver with Black!
- Engine mods to 89 Integra??
- for all the texas people
- What does white mean? Please read <<<<<<<<<<<<<<<<&
- 01 GSR JDM Header/Carsound Cat/Apex'i N1 NEED HELP!!!
- Where can I fix rims...
- For the modified Integra's out there ... we need your help.
- gs/itr for sale see my ad here
- Woohoo~ i finally put on my brembo blanks!
- actually weight of teg
- How much does B18A Teg motor Weigh
- Axles
- Hondata now has AUTOTUNE
- I became a statistic tonight.... :(
- ordering parts
- question on cam gears and cams
- Help with LS/VTEC!!! Please!
- aem v2
- GSR intake manifold
- DA hydro tranny conversion?
- Vacuum diagram for DA teg???
- Which exhaust is better?
- any1 oil their sunroof
- Trunk carpeting
- where to dyno in minnesota?
- PIC request ..... PLUM colored DC's w/ rotas
- JDM HID ABS Will It Fit With No Problems?
- Anyone know where i can get a dyno?
- Will 2nd generation integra front brake pads fit on a 98 civic dx?
- AEM Intake question!!!!
- performance motor mounts not enr sus
- 91-93 Fog light harness
- Cam gears?
- ANTI-theft ideas
- Anyone in the BAY AREA want to help me?!?!
- Is there a way to Reupholster my armrest??? anyone ever done it ????
- LS transmission differences?
- tires wearing out on the inside..camber or alignment
- oem kits tomorrow
- whats the name of that ecu?
- gas stabilizers
- HKS Circle Earth Grounding Kit
- Code 92???
- Need some help from guys that are familiar with the B18B heater core hose routing
- Just finished DIY Trunk Bar
- Ima get me an integra....newbie
- What causes the drive belts to squeal?
- Lowering springs I need help?
- Code 92 purge flow???
- ABS light came on today
- Looking from good rims, Help!
- plug for wing holes on the hatch?
- compression test?! what should the compression be?
- oem bodykit installation
- which type clutch to use for street/strip?
- DIY cpillar bar
- Problems: Rough starts...
- eclipse injectors
- j's racing intake
- Stock injectors
- Water is collecting in the trunk!
- Air/fuel Meter
- cheap loud exhaust..slowin me down?
- Anyone total a car, then buy it back from insurance company...?
- integra dash in eg ?
- oem front lip install
- N00b Question about Launching
- Red Climate Control?
- haha AEN intake
- Those with Rc injectors with 96 and up tegs.. do you need clips?
- can anyone help me out with a carfax??
- Flushing the engine with MTF?
- Bootin LSs, what was your 1/4 mile time?
- How much to get my rear emblems and my wing shaved off, and repainted??? Anyone done it here???
- B17A1.. boost or NA??
- Radiator hose or what?????????
- please...i need your help
- What is the redline on a 01 LS integra??
- again...skunk2 adjustable upper control arms.
- best springs for a heavy trunk? just got my ma audio box. shit is heavy.
- Crower cams know to break?
- Where can I buy this body kit???
- ecu question
- how easy is it to build up a b18b in your garage?
- 94 LS P74 ECU pinout
- Adjustable Upper Control Arms - Need your opinions and input
- need to roll fenders?
- Just installed my comptech exhaust. [pic]
- light bulbs and rubbing alcohol?
- bottom of my header is sorta bent...
- is sleeving needed for forged pistons in GSR block?
- mad stupid common sense question about wheels and tires. need quick answer
- who here know the best deal on fiber image stuff?
- My Compression Test Results
- Bumping NOISE..Help!!!
- My car is back together! THANKS H T members
- Type R Sway Bar Rubbing Brake Lines
- Type R Sway Bar Runnbing Brake Lines
- Has anyone Fixed a CODE 43 on a DA?
- someone hit my car
- whats up with Diabloautosports.com
- translucent film?
- Heated seats in a teg?
- Post pics of your suspension set-up...
- Will ls springs fit on a gsr?
- I'am thinking about getting an integra!!
- Mounting MSD Ignition on 2001GS
- Squeaky Ride
- been a member for 2 months
- Watching ABC7 (LA) news this morning, silver integra totalled after street racing and driver dead
- Is this a good tool set to get? If not where can I get one
- Post your favorite links for the G3 Integra
- Bouncing Rev Counter..
- Race Tracks
- price on piston installation
- 98 ls won't start, need help quick...
- 225 tires on a 2nd gen?
- itr cams on a gsr
- starter or battery?
- Teg gets rear ended hit an run AND another teg gets totalled street racing all in one night....
- sparks?????
- What's wrong with my locks?
- Honda Electronic Parts Catalogue CD 1982-2002
- looking for photos of vis carbon fiber lip installed
- Need help with wiring...
- how to stop clock dimmer?
- Post pictures of your gauge pods...
- exedy clutch
- Where can I buy
- ATTN: all lightened flywheel owners...
- Wanted p75 chipped ecu non-vtec!!!!!!!!!!!
- Anyone with a JDM VIS CF HOOD?
- identify this exhaust for me pls
- new clutch=not starting?????
- place in socal for rollbar custom fabrication.
- 2.25' Exhaust,Ok for ls/vtec with i/h/e?
- where can i purchase inexpensive oem oil filters
- HELP!?!?!?!?
- loose shifter
- door panel question
- ARGHHH car stalled again!!!!!!! whats wrong!
- Ripped my passenger side fender lining
- Dyno #'s for JRSCDC2 & a GSR. . . . .
- ticket
- P72 ECU wiring question
- which exhaust to get..hmmm
- Should I upgrade to Comptech sway/tie bar ?
- do i need to change my front sway?
- WTB::98+ integra front end
- A Glaring Concern: SoCal AAA HID Article from Westways Magazine
- S80, LS or GS-R tranny?
- Newer and faster cars...
- Torque specs 4 Oil Pan bolts
- Stock plug heat range (NGK)
- can some1 give me a carfax check???
- '95 JDM Integra 1.8vtec (Si/SiR) => 16" or 17" wheels?
- Haunted Teg...
- how much for 94-97 4dr GSR?
- Quick HELP!! Air/Fuel Ration Gauge install
- New Car Gaget
- Where is Sunny Styling?
- Neuspeed SofSport
- Equal rate front and rear springs
- JDM H.I.D. type-r front
- What should my NEXT mod be?!!?!?
- 98+ OEM fog lights
- KYB AGX with ITR springs worth it?
- just broke my valve cover bolts and
- how to break spotweld nut for ITR sway?
- Anyone running the Fluidyne Radiator in their Integra??
- WTB integra Door and JDM driver side FENDER HELP!!!!
- Where to VAFC?
- spoon 70mm tb on GSR w/ CAI, headers, catback, pulleys, ignition; THAT's IT
- Can anyone give a review of GSR Bilsteins?
- oil filter?
- will a catback system for gsr fit on a ls?
- Just put on JDM 4-1...
- AEM tru pulley belt question
- Misfiring after changing spark plugs and wires...
- 90 gs......tranny bad.....time to swap tranny
- What seats come in the JDM Integra?
- What is this????
- 90-93 teg have same rail size as 94-up teg for front seats?
- Water in Headlights/Taillights
- obd0 injectors
- do you have GSR cams laying around?
- B17A cams vs B18C1 cams...
- Would it be more worth it to buy the gude head package or.....
- GSR block
- is it ok to use ctr or itr cams just on the intake side?
- is there a difference between these?
- $1500 to spend on B18b???? LSvtec or turbo?
- GSR rods w/ Type R pistons
- tires/rims matching..
- Got my fastbrake kit with legend calipers
- zc swap in crx
- Tuning After Mods
- 95 Sedan Auto Thinking Zex
- Mechanics???
- GC provided spring rate for integras
- GB for HID's with the recommeded distributor from Phillips in the UK
- YO WTF (please help)
- Coilovers for 97 Teg
- need help with 92 integra
- straigt pipe or not?
- DA Integra Steering Column help...GRrr..R
- b18b with nitrous
- wat fluid to put in LSD tranny?
- Best upgrade caliper for the money
- need some advice on putting seats in
- Beaks users... install instructions requested
- Strut Tower Bars......
- muffler is rattling
- What should I do next??? (GSR)
- clutchmaster stage 1
- my dc2 is having problems
- :::need help on motor swap:::
- anybody got Wings West W-type kit
- Where is the factory alarm located?
- Spoon Spark Plugs
- My alarm's crapping out
- Mugen Twin Loop exhaust or Skunk2 exhaust
- What are good Sway bars for 01 LS integra??
- Freedom Design strut bar
- Ls/Vtec
- antenna
- wierd dipstick reading? need some help
- How big is the greddy sp's piping?
- Look what I can do...
- Need help please (woodruff key, crankshaft key way?)
- rust in lug nuts
- transmission problem....
