View Full Version : Acura Integra
- b20 overheating issues
- Fuse issue??
- Trunk Key Entry Problem
- ep seats in a dc?
- B17 engine worth buying? Please Read
- B18a1/ B16a Tranny
- Motor Swap Tomorow Searched But Cant Find Definate Answer
- keeping the crank from moving on an auto b18a1
- b18A1 starter
- radiator fan not working
- IAT wire connection
- temp still keeps going up....weird
- **OBD2 GSR To OBD1 Integra Questions**
- can u use eg rear hub on a 99 integra?
- Apexi N1 coilovers, good or bad?
- changing motor mounts..!!!
- tail light value
- gsr trans question
- 80mph at 3K
- Who can Identifying My "Dc2" cuz i Can't
- can anyone help me
- what kind of welder to use when replacing floor panels and quarters??
- brake lights not working need help
- what causes the maintence light to keep flashing?
- carbon fiber hatch on 99 LS
- GSR base w/ b16 head
- GSR Trans oil change.
- sputtering and bogging
- 96 integra overheating problem..
- my first teg
- how to show af on my s300
- aftermarket cupholders
- DC2 factory cd player removal
- LS Throttle Cable Issue!
- need help!
- why doesn't my jdm itr wing fit on my usdm 99 trunk???
- Major electrical probblem?
- can u make a wrx turbo work for a b18 or any honda motor?
- I have a ls and I am missing some of my cam caps can I get some off another ls??
- My integra won't start! Please Help.
- Need write up for pulling GSR Head ?!?!
- Noob To H-T
- Looking to change things up
- Join the Honda-tech facebook page
- b18b1 swap. I need help
- 92 Integra GSR with B18c
- Timing Belt snapped while driving, but something's not right.. pics inside, 56K die
- dc2 gsr cluster into 91da9
- 2000 ls wont start when is warm
- wheel shakes bad !!
- p0420.. searched..posted.. need help desperately!!
- same mount?
- I'm new and my teggy too
- Back left corner still squeaking
- Acura: and there awesome starters
- Brakes?
- help with jdm headlights
- Blue Smoke
- immobiliser deactivization in gsr ecu
- tuning ls
- Help diagnose my problem. b18
- slight rod knock
- ITR in GSR
- vtec solenoid question
- need photoshop done!!
- AEM Sri question!
- removing of powersteering system?
- What clutch assemblies fit 94-01 Integras??
- Replace IACV valve?
- here we go again!
- Got my ITR swap running!
- will dc motor mounts fit a DA
- How many different RMF header for B series
- p08 s300 v. p28
- Failed smog TWICE! Need help ASAP!
- Fuel pressure rise rate low...
- Need help buying valve steam seals online on www.AcuraOEMParts.com....
- PCV System
- Water in the trunk.
- miracle x bar knockoff for a da teg
- Integra transmission
- jdm GSR engine swap into 01 GSR ??'s
- Car got broken into, thieves stole VTEC Controller.
- b18b1 knock
- best clutch for the money
- Bushings, Linkage, or something else???
- oil seal replaced still leaks
- What motors will swap into ls 90 integra?
- DIY Ignition switch cleaning
- Locking the rear hatch
- !2 Problems Need Help!
- guage cluster bulbs 91 integra
- brake light wont turn off
- Sticky Brakes
- obx twin loop questions
- Question about OEM badges
- need help with my axle
- ground control coilovers question
- 98 ls
- GSR Starts really bad now after replacing fuel line from filter to fuel rail, advice?
- Low rpm hesitation
- i ran in to a shift linkage problem ASAP
- 93 gsr cranks but wont fire =(
- blox velocity stack
- 95 integra transmission questions NEED HELP
- What ar ethe torque specs for.....
- 92 GS with JDM B18C (Type R) and Chipped USDM P28 ECU, throwing codes..
- Need Answer for Ignition Problem ASAP!
- Distributor cap
- Oil in intake, clogged PCV?
- Tcm Wireing
- Engine gets cooler when I drive. WHY?!?!?!
- how rare is the DB2
- 00 Front Bumper Fitment
- 95 and 98-01 fuel level sending units different...
- Figuring out what kind of tranny???
- Dc4 head questions...
- intermediate shaft?
- si-vtec lip mounting issue.
- Removing Spoiler - ITR GSR
- ? about Type R cluster C/f face??
- A/C problems... Please help
- my 1997 integra GSR is STOLEN!
- will it fit my dc?
- Jdm gsr misfires and battery keeps dying when it sits
- SKUNK 2 STAGE 2 PRO CAM COMPLICATION?
- Need engine upgrades ADVICE!
- 1.8 gsr cams in a 1.7 gsr worth the cam swap
- LS to GSR wiring
- CTR Pulley belt size
- rear panel replacement again
- stolen Integra in Riverside
- Potentially blown motor questions
- Over heating..
- integra rear valance pics
- Im buying a gsr motor, what all do i need to make it work in an ls shell?
- how do i open the hood when there is no wire
- power steering foaming
- GSR compression test results
- sputter and bogging problem
- Welcome to my B18A1 Swap Fiasco
- I need a head a B16 or B18
- Seats interchangable??
- throttle position sensor problem....
- Clack sound when reversing?
- Project .:SickTricks:. Ground Up Build. Another one in the Saving.
- Zviator Thread
- 90 teg wont start
- Why is my new stage 3 racing clutch and lighter flywheel not grabbing on my 2000 acur
- cambering question
- 91 coupe with b16 and lsd tranny
- Why does my clutch feel so...loose?
- GSR crank vs. ITR crank
- what could cause this wiring issue
- Oil light on and wont turn off. 01 GSR
- bumper conversion question
- check engine light problem
- Have an ITR what do?
- putting a/c back into a car
- Gt3 rotas tire size?? help
- quick question about short shifters.
- removing ABS....whats the part number for the brake lines??
- b18c1 gas mileage problem. is this normal?
- Bad Gas Mileage/Burning Oil Please Help!
- New to the forum
- B18c1 oil stick tube loose
- headgasket questions
- 98 Integra fixing driver side mirror
- Type R Cluster Help!
- Does 95 civic manual steering rack fit in a 95 Integra?
- Just got car, haven't received plates yet
- ls mesh rims authentic oem?
- need help asap
- stripped acorn nut
- E85 vs. premium gas
- GSR-Skunk2 manifold install-coolant passage ?
- 91 integra ignition wiring
- doing valve seals on 91 Integra?
- Replica Hytech Header flange hangs TOO LOW! anyone else have this issue?
- unkown filter under intake manifold
- getting ready to finish itr swap
- 1999 GSR Poorman's Type R Dyno
- 3g integra mirrors "fitment question"
- rear panel leaking, wtf here
- alternator
- Need Some B18B specs
- JDM swap help
- 91 integra engine??
- Replace Fuel hose from filter to rail now leaking, looking for advice
- clean engine bay
- Bad Timing Belt Job????
- cooling fan help
- 91 Integra with a 95 motor swap
- Help Front Bumper Problems!!
- Weird issues with b17
- My integra has problems starting please help me
- Ls idle help please
- 98 GSR CEL on.
- OBD1 and OBD2 Gsr Engine Harness difference
- brake pedal return spring
- B18B1 & Tranny Rebuild/Swap
- probably a thread already im sorry, misifre issues need help please
- Will 97 gsr rack and pinion fit into 95 eg?
- Teg Build
- how do you convert obd1 90 integra??
- 1994 integra ABS problems help
- cams and pistons
- rado antenna problems
- 94 ls over heating "help please"
- Looking for a throw out bearing pin
- School me on Integras
- Car has a few problems
- :: Swapping FROM ITR 5lug to LS 4lug
- Just picked up a gsr
- p75-8 head questions.!!! help..
- the difference between jdm vs usdm gsr intake manifolds
- Making my jdm b16a smog legal
- STOLEN but FOUND jasper green DA
- Slave Cylinder
- Full hydro conversion on da9
- Wont shift ! please help anyone
- b18b1 motor mount pulled away from the block
- 4 puck or 6 puck clutch
- 95 LS new build, idle issues
- My teg throwing Code 22??? anyone?
- One Last Thing...Clutch Pedal Loose
- Turbo Integra Problems, Help please
- F1 racng Clutch Adivce Needed?
- radiator fan
- rhd da6 xsi, anyone???????
- Temperature keeps going up and down...very weird
- NEED b20vtec Check engine help...
- My engine is shaking..
- 2000 black gsr??? should i buy?
- Need help! Gauges do not work
- Poll: What Clutch For My LS
- Throttle position sensor???
- what means code 9 ecu
- b16a vtec issues
- Noise when car is in gear
- '94 4dr Driver Side Window Won't Stay Up
- 94 Integra b20 rough idle
- integra replaced starter but still wont start
- 92 Integra issues. Timing belt+ cam gears timed, etc..
- Milled head, decked head
- whats my car worth?
- should it still prime???
- Ls Vtec
- helppp please, engine problems
- dizzy problem??
