View Full Version : Acura Integra
- NEED Help ASAP
- ls/vtec timing question
- jdm integra headlight fogging up??
- 94 integra gsr power steering flush
- Manual tranny fluid question 91GS
- foggy head light???
- Replacing battery cables...
- Electrical or Mechanical???
- gs-r manifold vs. ls
- DA carpet help real quick PLZ
- Looking at buying an Integra
- JDM headlight wiring problem
- your choice
- Part Number For valve cover gasket and sparkplug gasket
- ground control with knoi yellows
- NEED HELP PLEASE!
- H2B Gas mileage?
- Da Cupholders??
- o2 sensor problem.
- 95 integra drag strip
- B18c4(b18c1) Exhaust pipe diameter
- fog light problem in my da9 with jdm 1pc headlights
- 98 Milano Red Integra project...
- RSX type-s axle back
- i got an acura 94
- Going to buy an integra 94-95 soon. Will swapping in a newer B18B eliminate the performance advantag
- 5 lug conversion?
- A tokico shock questiom
- Anything wrong with change to 10w30 oil?
- how is a starter work?
- Type R ecu in 96 LS teg.???
- Brake pedal slowly fades to floor after replacing the alternator
- does the integra coupe rear strust bar fit the integra 4 door? integras 1994+
- driver side mount question?
- aftermarket exhaust set up.... O2 Sensor ?
- bent pulley question
- Size/thread of Intake Mani Bolts
- GSR torque specs
- 0bd1 92 dx hatch gsr swap ecu to engine wire harness
- cheap turbo kit
- hunting revs WTF?!?
- Clutch pedal hit the floor, wont return
- l/s or single cam v-techhhhhhh?
- running into problem while driving..
- 99 gs missfire help!
- How am i runnin(valves)
- gsr lean???
- help me identify this gasket?
- b18c1 heads look in here.
- bought a 4 door LS today
- integra trailing arm.
- rear brake problem need help
- Need help. Lean, rough idle,
- PUTTING 2000 LS IN MY 94 INTEGRA WIRE HARNESS QUESTION
- Problem - clutch / trans / throwout bearing??
- whine
- What to do with stripped shell
- CEL code 41
- LS VTEC ISSUES!!!!
- 96 Ls 4dr Motor Swap to ????
- catalytic converter replacement / califonia smog legal 98 ls
- I'm buying a 91 Integra
- Problems with stop leak products in Hondas?
- What causes the spark plug gap to increase?
- ABS Problem...
- I guess breaking into integras is a world wide trend
- Check engine code 22
- do i have a G2 or G3 walbro fuel pump??
- LS Rods and Crank in GSR Block
- 1992 integra died on the street
- another lame exhaust question :(
- need help fast!!!!!! 91 DA wont fire.....
- water leak in my trunk
- i didnt work (help)
- Smog Checks
- Water Temp Adapter Size? '92 Teggy
- integra conversion?
- Check engine light
- Need new radiator on GSR, recommendations and fitment issues
- where can i find knockoff ITR wheels?!?!
- Amber Alert!! missing parts
- JDM motor chugging gas??? HELP! NEED FIXED IN 5 DAYS!!!
- Infamous Distributor sound results - ticking / rattling - Dizzy
- jdm front convserion question
- i need help?!?
- Coolant not flowing - Thermostat wont open - Overheating...
- e-brake question
- couple of questions....
- Help with axle stuck on hub
- About to rebuilt for boost
- wheel clearance?
- will a Gsr header work on a b16?
- is the bumper different
- MAYDAY! TEMP GAUGE 96 RS
- !!!NEED MAJOR HELP!!! head is leaking...
- friends teg no start researched but no exact ansewers
- Tranny Question
- Dyno result and beyond
- 93 obd1 integra b16a swaping out tht motor to put obd0 b18a1
- My TEMPORARY brake line patch on my DC.
- Plug Wires ?
- Injector size for mild built turbo ls
- Motor Swap Help
- Comparing Distributors....quick question
- i just put a ls head on my car and now it's not idling y ????
- DA ABS Light
- Are there Steering upgrades ????????
- Has anyone actually tried to make your exhaust tip blue, give it a burnt tip?
- How do you remove the front bumper off a DA
- ls valve cover question
- sportmax wheels
- pcv valve
- ITR cams install on B18c1? guidelines?
- Knock Sensor on LSVTEC???Problems???
- Header and exhaust setup on a 97 GSR - opinions please!
- aftermarket rear sway end links?
- OBD1 dizzy vs. OBD2 dizzy?
- starting????
- Power steering problem on my DC
- GM Synchromesh Friction modified,, straight or mix it?
- how to determine rear main or oil pan leak?
- idle
- battery light on. NEED HELP!
- Fresh clutch install now having an odd problem
- having temperature issues with the teg
- o2 sensors interchangeable?
- need help asap tranny problem
- edelbrock performanze X intake manifold
- DC parts for sale in long beach CA
- Rear wing on integra need help
- wtb cheap carbon hatch
- motor mount
- installed tv umit back up fuse keeps popping
- what exaust is quiet but also good for alll motor lsvtech power
- **Rebuild of my 94 tegzzz**
- ls manifold on gsr head??
- help me identify this part...
- how to put in valve cover studs
- Need help removing/replacing a part
- tranny conversion in DA
- JDM INTEGRA BUMPER INSTALL HELP !!!!!
- Integra brakes interchangeable with civics?
- Yet another axle problem... NEED ANSWERS QUICK
- interior side panels?
- clock & cd player NOT working?
- Does Anyone Know WHAT TRANNY I HAVE!!!!!!!!!!!!
- crank differences?
- spoon n1 fitment problem
- OEM 1997 Type R Front Lip
- Need help with a auto to manual conversion
- fuel line problem
- white obd0 turbo teg in the phoenix, AZ area
- oem fog hid conversion?
- ABS code 18 *searched*
- Apex'i Exhaust Question/Opinion
- spudders when giving gas need help
- EG with LS swap - IDLE AND CAR DIES PROBLEM!
- engine mounts inserts (energy suspension)
- CAR STOLEN IN RESEDA, CA (1995 ACURA INTEGRA LS SE)
- I need help, they trying to total my car
- No spark
- WTK: Good WI paint shop
- b18a1 oil amount capacity?
- Does this sound like a good deal?
- idles at 1k rpm
- gsr 2 stepping?
- ls to a ls vtec?
- Synchromesh fluid...HELP!!!
- BPI velocity stack fitment issue (help)
- rattling windows
- *tein coilovers*
- Timing problem 91 Integra
- Hi honda-tech
- Couple of maintenance questions.
- secondaries not working ??
- 94 integra 5 speed VSS interchange?
- what motor in my db8?
- GSR b18C into DA integra (1993)
- sputter when floored
- LS VTEC TICKING??
- How to fix Engine Code 22?
- Gasket?
- airbags
- Nose mask fitment?
- Biggest intake tubing?
- timing belt issue....with pics.....
- seat covers
- pcv system
- what clutch to buy?
- JDM ITR LIGHTS
- My headlights are dimmer than they use to be. What kind of HID lights are good?
- ITR front sway bar
- valve adjustment results: correct?????
- Plug 4 Resistor box on 94 teg the same as 89 civic?
- Question about BPI Velocity Stack
- Skunk2 Intake Mani HELP!! (pics)
- Turbo w/ A/C
- Wedge Brackets and stock seat belt
- da fuse panel diagram needed please blower confusing me
- steering rack: driver's side ball joint adjustment possible? + fluid leak '87 integra 1.6
- I need some advice
- HELP!!FRM DA OWNERS
- b16 sir tranny in my gsr pros/cons
- h23 in integra??
- Help : Car Showing Code P1381
- Clarify this please..
- Important Question!!!!! someone please answer!!!!!!!!!!
- Looking for a little help...
- 98 stock ls exhaust
- The "new guy's" plans
- LOUD speedo cable.
- car with no title
- what motor will be faster b20 non vtec or a b16 ??????
- 94 gsr savannah, GA
- B16 head on b18?
- track?
- will 99-00 civic si rad hoses fit 94 Integra GSR?
- Crank shaft flucuation sensor
- INTAKE SETUPS
- vtec prob help
- Car feels like its losing its power
- Common integra problem??? Help!!!
- weird overheating issue on my 94 LS when stationed
- i know its been done.......
- Another turbo Integra Gsr Misfire question/comment
- Need opinion on oil pump......
- injector question
- idle question
- B18C3?? is dat JDM?
- can a gsr smoke stock ls swap eg's?
- need help - purge solenoid location and replacement
- help with silencer for my apexi n1
- Question... HKS Turbo Timer Type1 Special Edition
- Can someone tell me what this is..
- What motor is this? Please answer this fast.
- srs light
- DA integra tech help
- Motor mount question
- trial user wtf?
- Anyone have pics of their buddyclub exhausts?
- Cruis Control help...searched**
- Carbon Fiber Side Skirts
- innovative mounts
- question needs immediate response!!!
- eg6 foglight???
- 92 GS Integra seat belt dinger
- B16 oil pan fit B18??
- Motor swap F22BI in to a 95 Integra
- gsr with an upgraded ecu
- Seat help!
