View Full Version : Acura Integra
- skunk2 manifold question.....
- vtec controller or vtec solenoid?
- 2001 bumper lamp size?
- ECU......for.......Ls........?
- Running a little rich?
- exhaust mid pipe question for integras
- salvaged?
- Difference between LS and GSR fuel pumps?
- h&r sport springs
- obd1 to obd2?
- CEL 20 (ELD) - Is there an ELD sensor on obd2 Integras?
- integ tranny help
- question for you integra tech guys
- 94 stock integra l/s
- Need help with integra GSR
- what are the gear ratios for a 90 Ls cable tranny?
- 98 gsr with jackson has anyone used a crv crank
- need link for how to build an ls/vtec
- Throwing an engine light....
- Need Opinions! Help! Boosted GS-R or Boosted Type-R
- B16 or B18 Tranny?
- How to repair a stuck shifter
- fitment Q'ssss
- obd1 tranny on obd2 car
- need info on exhaust
- Build LS-VTEC - Opinions please
- searched* windshield mist motor
- skunk2 stage1 or 00-01ctr/itr cams???? for gsr
- PoMans 5lug conversion question
- 99 taillight price? Adjusting headlights?
- hondata
- Quick ECU# ?
- Turbo question
- Idle problem
- Piston Scratch (useable)?
- b16 vtec soleniod on a b18c motor?
- 215/45/16 Azenis with 1.25" Drop
- How would you pay for H&R Sports w/ Tokico Blues?
- ahh SHIIIIIT, some how my factory alarm locked my keys in my car.. help meeeee
- Clutch Problem?
- Your opinions on this Integra Type R / GS-R clutch / 8lb flywheel combo JDM...
- question about dyno tuning
- Fuel Depressurizing?
- JDM type r
- How Much for Neuspeed
- ITR brakes upgrade
- Parts and components for ITR upper mounts?
- Hasport Motor mounts DCSTK (street)
- k2o in 94-up teg ls???
- OEM clutch manufacturer?
- MSD Distributor Cap Question
- gsr rear seats
- 94+ integra rs
- Integra Injector?
- Where to Buy Fittings to Block Off Power Steering?
- Need Website
- Please help... left out 2 washers
- Anyone know where to get a carbon fiber "acura" emblem
- Recently Installed Skunk2 Manifold on GSR with Stock P72 ECU
- Turbo kit
- o2 simulator?
- looking for opinions on exhaust for LS
- ignition kill switch?
- Stolen CRX AZ!
- blown valve
- good topic h series tranny into b series engine (vice versa)
- peak series
- Difference in JDM Integra front and USDM front
- swap and smog
- will stock gsr ecu handles this?
- does the JDM 1995 DC2 SiR cluster light up amber?
- cost of OBD2 to OBD1 + wires harness + labor
- ***CALLING ALL USDM 94-01 DC'S W/ 96 ITR 4X114 WHEELS***
- installed outer tie rods now I hear a noise from suspension **help**
- quietest exahust besides stock
- Stock Ls Vtec
- cleaning a block
- were can i buy powder coating spray
- b18c1 block whats the hole in the back
- Greddy/Trust SP1 exhaust
- Car keeps poping out of 5th Gear
- any one with an hks hi power in here tht has pics an a sounds clips off how it sounds like or video
- AEM SRI Picture?
- ITB Help plz!
- carpet
- which axles are better
- Help Install Brake Rotors/Pads
- '90 LS Integra Wiring Trouble. <------
- how do i post pics?
- fuel cut off switch
- JDM ITR Integra Type R MOMO non SRS Steering Wheel - am i missing something?
- Cheap solution to gear grinding in cable transmissions
- Yet another searched ls/vtec question.
- Sweet conversion..
- Help with IACV maybe?
- Front Upper Strut Bar That Fits...
- Auto-5spd swap Parts list????????
- High Pitch beep/ringing sound at idle
- is it possible to find a 1995+ gsr for sale? for under 4k
- Do all 6 puck chatter?
- jdm fog light question for dc2
- Auto to Manual Questions
- need welding done on my car
- can we trust this?
- Need help big time?
- Help with B16a1 swap.
- need advice $4000-5000 budget
- ign. timing
- What is the piston caliper diameter?
- guaging interest... rear trailing arm replacments
- Length of Sideskirts? FAVOR NEEDED
- 2000 gsr hatch question
- JDM 94-97 amber bumper lense
- need a front end
- Car wont start after distributor cap and rotor install
- AEM cai vs. sri comparison
- Whistling noise when driving!
- integra da6
- 50 series too big on 16" wheels
- IDM INTEGRA LS continued
- GSR Drivers Side Mirror Problem Help!
- What size cat do i need to run jdm itr header on 95 gsr exhaust
- Ls Cams the same between 91-93 / 94+?
- Will This Fit?
- Clutch Chatters?
- Air Conditioning Still not cold after re-charge
- Please help find source of crazy noise
- Do 98-01 bumper lights fit in a 94-97 bumper? Help!
- engine check due to exhaust.
- B18B turbo...
- Free cookie to someone who can tell me the axleback muffler bolt size!
- just install the skunk2 manifold , iddle drop 200 rpm , temperature as well few ???
- if i get a V2 aem would i need a bypass can some one show me pics in a tegg
- Dash Swap into a DA
- detachable killswitches?
- Question about custom exhaust
- exhaust condition
- does a 94-95 jdm climate control plug up to a usdm dash?
- WTF IS WRONG WITH HT TODAY IS IT JUST ME OR YOU AS WELL?
- Can a LS distributor work on a Gsr?
- Gsr swap
- head decision
- x-tra air box on OEM intake tube
- Please Help: Problem with my 99' Integra GSR
- 92-93 tranny
- DC Sports JDM 4-1 Header Modifcations?
- Halarious!!!!!!!!!
- ITR rear sway = Night and Day
- milage question
- new motor--reuse old clutch/flywheel?
- car stumbles
- how much oil?
- suspension
- How to separate upper ball joints?
- Mugen strut question...
- Bad Idea or not....
- pros and cons having a 7.5lb flywheel on a daily driven gsr
- difference in obd1 and obdo pr4?
- what is thsi?
- Brake problem when AC is on?
- new to the speed scene
- Where do you buy parts?
- IAB open at?
- Question about Airbag
- NEED HELP WHEEL SHAKE
- Ok, so now that my car still won't start
- racing seat question??
- Clutch problem
- OBD-1 GSR IM butterflies
- What could cause incorrect fuel gauge readings?
- Need some assistance
- fluydine radiator
- torque steer
- high idle
- WTB: LS Crank
- Programming 1995 factory alarm key fob??
- ** INstalled LSD in a GSR and now the Axel won't go In anymore ** Oil leak
- How many miles after gas light comes on?
- Will a Steering hub for a EG/DC2 fit a DA
- rear brakes, which ones? does it matter
- tranny is leaking oil...
- whats the weight of ur teg?
- stereo slides in and out
- Ls hydro tranny with an aftermarket clutch kit and flywheel vs. 99-00 si tranny with stock clutch?
- rpms going crazy!
- A/C problem
- which shock to buy?
- 01 Gs-r Throttle Body for sale(stock)
- d16 into 95 integra
- tell me what think
- keep upgrading or new motor
- tachometer wiring help
- rimsandthings.com
- UP Hill
- Bought 00 GSR clean but busted motor!!!
- stock gsr shift knob?
- brake lights???
- b18a1 crank vs. b18b
- Water in engine
- Lot Of Vibrating When pulling up, help!!
- Throttle body ?
- Resurface Flywheel in New Jersey
- OEM honda valve cover
- FS:JDM ITR rear seats good condition
- GsR Header question...
- GsR Gauge Cluster question. Please help.
- cf hood / body color ( on db )
- rear brake problems, 94 2 door
- broke 4 axles in 2 weeks
- JDM TRANNY
- DIY OEM ITR trunk brace, completed w/ pics.
- $4 Sell Great Buy
- Two Quick Questions?
- What to look for when buying motor (head/block).
- GSR tranmission question
- 95 front lip
- i want clips off hks hi power sound on a integra plz an pictures
- brig MAG 8
- missing
- need a favor from gsr owners
- took car out to track today
- planned lsvtec setup.
- weird idling and sputtering
- Searched* Backfiring problems, not ur normal backfiring. Look!
- 97 Teg LS.... car just died...help please
- HELP, with buying car!!
- Help, Oil Pump...
- Teggy Help
- Speedometer wont work
- anyone else have an idm teg?
- Regular integra brake lines and ITR lines the same?
- Stripped Stud...WTF (I searched) HELP
- shift boot
- Need someone from so.cal
- Hey is this a good deal?
- Trunk Lid prob. GIVE YOUR ADVICE PLZ
- New Radiator leaking again
- Gsr 9000RPM?????
- NEED HELP B20 motor question....
- New front bumper cover?
- amp draw -- "1G" fuse under hood.
- Where do I find an Acura (Honda?) color code chart?
- intro and info request
- starter help!!
- B20 Vtec
- $ not an issue, best B18B intake w/bolt-ons
- STOLEN
- oil cooler?
- "92 GS-R
