View Full Version : Acura Integra
- Reputable company to get itr pistons from??
- Clutch nothing working right, really loose?
- Auto Trans Help
- Smoked a Type S by 3.5+ cars?
- Bad idle help!
- b18c1 or b16a SiR-II Auto Swap
- Looking at a GS-R Tomorrow
- I lost the car title of my car
- New project 1gen teg
- 98 LS Keyless Entry
- Black Smoke!
- Custom exhaust setup
- Just got a 95 Integra SE
- RF ABS wheel sensor.
- Door panel issues...
- integra wont let me rev higher then 45k rpm and runs like shit!!!
- Need some help, buying 4 dr GSR (95)
- need help figuring out if my RC injectors are saturated or peak&hold??
- can i make my LS transmission into LSD
- How long to change **hard** brake lines underneath car?
- Transmission rebuild
- civic transmission in an integra
- skunk2 cam gears on a b18b..?
- Starting/cruise control issues
- Car stalls out
- b18 idles rough, & swap question.
- How to post big pics on new topics
- aebs intake manifodl on gsr
- Tire Comparison - Great Ariticle
- Cant get to the Oil Pan bolts
- automatic seatbelt removal? da teggie
- Door panel inserts for two door DC , need help!!
- what should a 1998 integra rs be making to the wheels
- no vtec.
- question over resistor box.........
- Very odd problem. 1993 GSR, power loss / etc.
- squeaky noise from wheel
- Car cranks but doesnt turnover after....
- Need moonroof/windows to work for the Ladies!!!
- help with some noise
- Spoon caliper help
- Need help! Throttle cable for B18c1 In a DA integra
- in need of b18c1 block and rotating assembly NAME YOUR PRICE
- LS vs GSR
- Well a B18a valve cover fit a b20???
- Useless compression test write-up
- 96+ GSR REAR LEATHER SEATS...!! HELP!
- rear front honda emblem fit on the front?
- building my LS
- distributor question.
- leakdown test resulted in 5-10% is it bad or good?
- auto to manual change
- eg radiator into a 01 Da
- loose play in steering wheel? HELP PLEASE!
- What does it feel like when... Pease help
- First Integra....
- right side cover and oil pump seal????
- Temperture gauge/sensor problem need help/advice
- main relay not clicking
- another gsr engine build!!
- 1996 Acura Intergra GSR Cylinder Head. HLP PLZ!
- need help, advice on trade plz !!!lol
- My New Integra! Need Advice!
- runing rich, runing lean
- Zeal Function Or Skunk2 Pro-S Coilovers
- Rear window visor
- jdm 96-00 b18b pass smog or reff in CA???
- Installed cams , Want idle????
- alarm wiring ?? viper 791xv
- transmissions
- Parking Lights Fuse keeps blowing
- ls/vtec redline?
- 94 Integra - Replacing axles with aftermarket or OEM options?
- tranny case switchable
- New Dizzy, No Vtec
- head gasket problem 95 integra
- 93 integra needs catylatic converter replacment
- integra JDM front conversion
- BEEP BEEP BEEP
- ACCELERATION PROBLEM
- 91 acura backfires
- headgasket/compression test results
- Any Shops in Bay area installing clutch??
- Turn Signal doesn't work!!!
- Radiator and A/C fan doesn't work
- car ideling odd
- IAB Vacuum Line Necessary?
- Help with tranny
- wanting to go turbo
- NEED HEADER! HELP!!
- other ways 2 rest the check engine
- Cranks won't start, Any suggestion?
- shoppin for resistor box
- injectors bad?
- exhast for an 90 integra ls
- A\C gurus needed badly
- how much is my b18 worth???
- How often do you guys change your engine oil?
- Turbo Integra runs well until after boosting
- Turbo fully in and ready to get ingnition done. need some guidance.
- how much for a sleeve install??
- greaddy wastegate???
- how to hardwire vtech on b16a2 into a da integra
- VSS Problem
- Steering rack adjustment - Best thing I ever did.
- coolant leaking from bottom somewhere
- What kind of axles are these?
- 94-97 jdm fog light help
- White corrosion on exhaust valves
- Car cranks but wont start
- trans mount ?
- 90 ls automatic & 5 speed distributor are the same???
- I want a know about the BBP exhaust
- Timing Belt Issues
- Integra CEL blinks on start up ONLY
- Foam Injected Fenders??
- will a 2000 b18b1 longblock be a direct drop into a 1993 integra???
- b18 valve on b16
- Keep blowing fuses
- What are stock bore sizes and is it worth it?
- ls VTEC question
- Idle surge after cleaning IACV
- will oil pan fit please help
- Should I get this?
- What is my compression you think??
- what are the compression supposed to be on a b18b1???
- IS the GSR ys1 Tranny any good
- doing a leakdown test on a longblock what is the percentage supposed to be???
- pics of '00 integra drivers side plugs/relays
- check out my swap
- Upper Ball Joint Broke
- ITBs or Boost??
- Where to get Dc2 Jdm front end installed and other questions.
- Radiator overfill boiling, car overheating WTF???
- b20b swap on a 95 integra
- Socal Alignment Shops
- my car shudders between 1k-2k rpm's
- integra rims
- Jun cams
- 90-93 integra (DA) trailing arm bushing removal
- problems with swap
- gauge pods?
- Quick question about RPM and B18C1
- 90 integra timing marks (no faq) ?!
- Someone please help!
- What is a good autocross setup, engine, suspension wise, opinions please
- Is it worth putting a turbo on with 100kmiles on my gsr?
- lowering my '98 gsr, opinions on ride height,and brand
- trouble starting the da
- H2B swapped Integra vs Porsche 911 Carrera
- Compression question?
- Quick Release Question *Steering Wheel*
- error code P1035...help
- Another Exhaust thread...
- Quick door jamb switch question. 93 DA
- gsr tranny help
- itr muffler vs fart can
- need 2000 integra ls dash relay pics
- stock tires 195-55-15 but 205-50-15 works?
- Gas Gauge Reading Off/Hesitation During Acceleration
- FITV on obd1 GSR?
- Lets see what you guys think...
- Got a Problem(Need Info)
- Car Bogging Out! Help, PLZ?
- Idle surge please help
- switching exhaust from civic to teg
- got a real stumper for you guys...
- How to do a LS Vtech
- flasher problem
- Is this part of my car?
- 95 integra gsr valve ticking/tapping?
- Spark Plug and wire HELP
- How to hookup 90-93 ls 5 spd speedometer cable?
- helppp car being stupid
- new 94-97 front bumper
- 3rd brake light
- broken dash/circualtion control or trap help
- Lower than stock compression across the board, bad?
- OBDI B20VTEC pass OBDII emissions??
- 99 mitsuibishi eclipse oz rally for trade
- can i do a JDM engine swap in CA??
- obd1 obd2 ???motor swap help!!
- Hot coolant bubbling up through top of reservoir...?
- what hole does the ground wire connect to on the valve cover?
- spark plug firing order does any one know it?
- Issue with power antenna replacement on DA
- boggin issues after swap(b18b1)
- Hit a curb on an 97 Gsr...Need Help ASAP
- electronic air control problem
- Dizzy question
- Balance on the rear tires
- 94-97 front end on 98-01
- need help ac wont cut on !!!! da owners
- B-Pipe to Muffler Bolts
- rsx gears in b series tranny??
- o2 sensor code
- tranny problem
- turbo exaughst on a n/a teg
- Car wont run!!
- Blinker
- wat goes where on a gsr long block
- Where to get Gaskets?
- Dyno run from my basically stock 1998 4 dr GS-R with 210k miles
- Stolen GSR in Concord, NC during NASCAR event 5/15/09
- Please Help! My car wont start....
- Quick LS/Vtec question (on obd1/2)
- ? plastic injector harness holder...... nothing in search
- VIS hatch question
- injector clips
- B16a2 clutch work in a B18a?
- Replacing Piston Rings
- 93 gsr 02 sensor?
- Need Help Identifiying a part
- help URGENT firing problem and possible larger problem
- 4040 prop valve
- Will a jdm b18b intake manifold affect smog?
- unequal length header
- I'm throwing a 9... cylinder sensor
- Will a 93 integra F bumper fit on a 91 integra????
- engine harness help
- Good condition pistons?
- Cel p1359
- DA needs a new motor
- why is the carpet by the clutch pedal damp?
- help me identify this dizzy.
- cams for b18b?
- my 95 integra gsr
- weird bogg prob help honda-tech!
- New to the Integra Scene
- OBD1 Integra Question
- checkin injectors(help needed)
- Thinking about buying 97 LS w/ snapped timing belt
- a wierd question...
- cam gear advance\retard
- rear bumper??
- B18c1 '99 integra LS
- Unable to achieve lower FP's w/ AEM FPR...
- B18c Intake Manifold bolt up to b18c1 head?
- gsr rebuild with itr internals
- Question regarding replacing throwout bearing
- oil leaking from headgasket on rebuilt engine
- 94 integra ls $3000 O.B.O
- ...:: 94 Integra LS - FAILED EMISSIONS - HELP! ::...
- What is the name of this piece? (exterior)
- Burning smell from brakes/rotors
- DC2 Brake light problem.
- is my tranny bad
- ABS Delete
- braking vibration
- checkin gasket.....
