View Full Version : Acura Integra
- what can i do
- GSR Transmition is whining on 1 and 2 what to do?
- turbo ls/vtec help
- RHD DC2 Conversion Questions!
- streetimports jdm replica header?
- What are these?
- Check engine light!!!
- RSX rear brakes
- does a coupe wing fit a sedan? 94-01
- New member =]
- 95 gsr
- New Guy
- In need of a paintjob.
- GSR problems
- rebuilding 94 gsr motor question about oil pump
- Where to start
- Where to start with GSR???
- What is the proper name for it???
- Integra gsr oil leak
- LSVTEC OBDII-OBDI: Failed Inspection
- Prelude calipers on an integra?
- Detaching rear hatch seal (pics)
- Roof liner question? Need to know if RS/TYPE R will bolt up to LS, GSR, or GS
- UKDM FRONT BUMPER
- wheels for integra full exhaust
- EDM FRONT BUMPER
- WHAT CAN CAUSE TIMING TO RETARD WHEN CAR IS DRIVEN....
- jdm gsr RUNS LIKE CRAP @ operating temp.
- where to buy mugen replica front bumper for dc2?
- STOLEN INTEGRA LAST NIGHT DALLAS AREA
- ECU cod 15 on 1991 integra
- What exhaust should I get?? I cant decide...
- 95 integra ... wow
- Easy hp
- Just picked up a theft recover'd 99 Ls
- High RPM at High MPH. Also running rich.
- need injectors, fuel pump?
- Denso or Showa?
- 94 integra rotors fit on a 91 da?
- Help me figure out suspension issue...have symptoms available...
- Check Out Custom PCV System I Made Yesterday-Anything Wrong?
- ys1 tranny
- Where to get DA/DB1 "INTEGRA" decal?
- walbro fuel pump installation
- drop zone suspension
- Predict my LS-Vtec numbers....
- Plugging in wiring harnss ==HELP!!==
- Identify this clutch kit?
- What up, Sort of new here..
- would these rails work with jdm itr recaros?
- I think engine problem
- HOLY SHYT 1969 Morris Mini Cooper.....LS/VTEC!!!!!!
- WANTED: GREEN LUG NUTS!
- G35 exhaust??
- db skunk 2
- Buddy Club Spec II ?????
- 95 gsr pressure plate used on 92 ls cable tranny, problems?
- Not sure about timing/cam gears/dizzy
- changing piping
- WHITE SMOKE IN HEAD BUT NOT COMING OUT OF EXHAUST...
- ? for my 4 door integra
- dc2 power folding mirror switch
- turbo manifold for my gsr any good?? or just ebay junk?
- No start
- turbo setup? what do i need?
- stock integra. need help
- please help me out ls rods/ type r pistons in gsr block?
- installing exedy stage 1 clutch
- Integra springs on a civic?
- dc2 third brake light help ((help<----))
- BRILLIANT BRAD PIT (INTEGRA COMMERCIAL)
- itr shift linkage fit on a da?
- High Temp Grease?
- Need advice on what seat bracket to get.
- main bearings
- 3piece spoiler
- 98 B18B1
- manual steering rack options
- Engine blew up what was the problem ? need help please
- alternator or battery?
- skunk2 silencer
- itr optional side skirt??
- DB8 Window Visor
- who makes an angled catback exhaust?
- san diego cali 99 gsr stolen
- Whining noise near driver's side when accelerating?
- 96 gsr cluster into 98 gs help
- blox vs itr sway bar?!?
- the Turbonator
- 1990 DA RS B18A1 Help!!
- Turbo a motor with stroker kit?
- DC4 HID retrofit?
- what clutch is good to use
- WTK:GSR gearbox
- timing question
- STOLEN CHICAGO - 1999 Acura Integra GSR Red, VIN JH4DC2#######2416, IL PLATE 5287412
- Just installed SpFab (spoolinperformance) chromoly traction bar!
- Looking for cams for my gsr, dont kno which to get need some suggestions???
- **HELP** 1995 Acura Integra motor swap
- PR3 (b16) ecu in '91 Integra with LS-vtec?
- B-series tranny speed sesnor please HELP !!!
- weird clutch, just started tonight, pedal adj?
- Think this is worth keeping/fixing??
- correct spot for side markers
- DIY JDM DC FRONT CHANGING TO WHOLE JDM RADIATOR SUPPORT
- Theft recovery - what do I do with the car now?! eBay? Salvage Yard? Ideas???
- how hard is it to replace rear caliper 94 ls
- unlimitedjdm.com
- tranny quesion?
- Car sometimes wobbles left and right on freeway?
- ls vtec
- B18b short block weight
- how can i?
- b 16 tranny help...
- jdm da cluster
- Pic Request! (b18a1 rear main seal)
- car hesitates,running rich
- gsr turbo, using blox manifold, will it clear, help!!!
- turbo vacuum line help
- can u put a 97 gsr radiator in a 94 ls
- Buying Locks? Ignition, Drivers, Passengers, and Trunk - W/ Key.
- my cars jacked up!!
- Replacing my CV.
- how do you think this muffler is?
- radiator question
- my car got loud after accident???
- compression test results
- Loss of power...a little different than most people's bogging problems...bogs only under load and in
- new member to honda-tech
- do obd0 distributors work on obd1 engines? B18B
- exhaust ratting!!
- Used car problems Tranny HELP??
- workin on now... where is the fan switch on obd0?
- Need help and some ideas.
- timing problem
- Fuse Help
- heat/cooling issue???
- Tri-Y header question??? b- series
- oil pan
- whats that thing called?
- 94 teg has trouble starting :(
- car bogs when engine warms up
- wheel offset
- Stater Issue - help me before my fiance kills me!
- CDM GSR Cluster into USDM Teg?
- What is this pipe called?
- Car Died While Driving. Battery Dead, Unable to Jump
- Help! Stripped head bolts or studs and need to remove Chrome Valve Cover
- Who else makes a cat-back system for a 4dr GS-R besides Apex'i?
- 92 GS, JDM B20B, JDM S1 tranny, JDM P08 ECU chipped to run JDM B20B, throwing code 26 and running ri
- car overheating sometimes pls help
- cruise control start button
- To much tranny oil?
- GSR/LS exhaust question
- redlined and wasnt able to shift
- Need some help! Apexi or Greddy Exhaust???
- turbo question
- ksport coilovers?
- 96 obd2a gsr throttle body on 92 DA
- quick ls/vtec question
- Anti seize on brake fitting threads?
- Jackson Racing Charged GSR OBD2 Tuning Options
- Powering a headlight?
- Clicking sound, starter solenoid?
- bottome shield
- Timing Belt and Waterpump replacement
- interesting question i have for the integra sedan owners
- Quick Question...
- So some woman just hit my car
- best suspension??
- whats this white thing callwhats this called
- what is this vacuum solenoid??
- bottom shield got meeded up
- what is the best way to remove header bolts without breaking them
- 1996 gsr for sale
- how to put springs and retainers in a ls head???
- Quick Gsr Intake Question..
- im new here, just want to show my da
- DIY: 11.1" rear disc upgrade for Integras with stock 9.4" rear discs
- Which manual transmission fluid do you prefer?
- OEM cam spec help!!
- ***Need help identifying a few parts***
- Problem with Throttle
- Bad coil or distributor?
- dous anyone sell carbonfiber roofs anymore???...
- Transmission Question
- NEED HELP! my DA has trouble going into to Park. (auto)
- cold air intakes
- IS THIS OKAY FOR TURBO?
- What kind of lip is this?
- Your thoughts on this
- 95 GSR automatic transmission
- sunroof stuck
- tranny problem
- 1.5 drop???
- wheel bearings,,, please help
- A/C diode?
- Quarter panel
- 92 intera gsr running rich
- tunning B18c
- dc2 bumper lights not working?
- should i do ls/vtec or go on with turbo?
- any1 know how much...?
- pic request. skunk2 Springs on DC
- JDM Dc5 RSX momo steering wheel
- How much should i sell my...
- da 90-91 yellow fogs help???
- Swapping pinout on jumper harness???
- soft clutch..bled it....made it softer..
- gas fuel petrol meter lights up
- customize fenders
- Question about buying my 94 ls
- B17 & B16 help...firing order? fuel delivery? help
- Help with sandblasted valvecover
- rear caliper seized need help
- TPS sensor issue on a gsr?
- Tranny Problem
- waterpump,hesitation
- DA integra suspension
- how can i put jdm dc5 recaro in my 92 da
- Ecu questions Smog Check?
- NEED TRANSMISSION HELP!
- 94 ebs problem and dying
- Help!!
- 98-01 Acura Integra 4 Door Windows Question
- TIRE QUUESTION!!!???HLP
- cable to hydro conversion mount question
- 16" Rota Auto X fit under ITR caliper on LS? +42 offset.
- does anyone have instructions to install factory alarm?????
- S2k antenna for a Teg
- Coolant Leak Location? * Pictures Inside Please Help!
- ******************FOR SALE BEUTIFUL INTEGRA SHELL**************
- Advantages of GSR over Ls/Rs besides VTEC???
- How do you know when your clutch is failing?
- Picking up a GSR
- Built/Turbo H22 into teg (SEARCHED!)
- B18B1 question
- ingalls torque damper
- NEED to find an answer...
- b16 in dc2
- 89 integra swap
- integra tail light problems................
- New to the integras
- 94 Integra LS cranks but wont start
- Ecu Question?
- DA parts interchanable with EF's?
- cant read cel!!
- Fog light problem. DA & electrical experts please!
- car dies
