- droppin tranny?
- Motor mount inserts
- Colorcote wax?
- mismatching tires in the front n rear
- B16 clutch on a B17???
- B18B compression? Whats a good number?
- distributor 99si head
- Price of GSR Shift Knob
- New guy here and to honda.
- H22 into GSR
- How to get to antenna wires?
- DA Crossmember
- need pic of shift linkage under shifter
- ECU Upgrade for 96 GSR
- wtk stock fuel pressure on c1
- clutch problem
- Side skirt screws
- Jdm Integra Bumper Support Question
- pulling tranny apart?
- if a block is stamped 94, is that a 95 model?
- Crazy what a difference weight makes
- just got my xsi motor, but y1 tranny?? confused!?
- are fastbrakes any good
- how to get rid of 1 of 2 o2 sensors and the tdc sensor?
- Integra radiator hoses with a del sol si radiator
- Stupid @#$&*($ POS axles!!!!
- what flywheel?
- auto tranny electronics
- Hytech Header!
- Took my 90 teg to the track....
- Gsr vs. Ls
- Windshield wipers look old...ever since i bought the car
- !!! RIMS !!!
- clutch ?
- How to wire up 97 gsr w/ 95 gsr motor? help please
- Can someone confirm this wiring pin-out for a '90 teg automatic gauge cluster...?
- Checking for vacumm leakage....where to start?
- What springs gives a DC2 EXACTLY a 1.5" drop?
- Wheel Lock Fitment Question
- Stuck Head Bolts
- Need swap info for a DA???
- what should i buy??? need help
- Integra seats into 97 civic?
- THIS IF FOR YOU GUYS WITH ACURAS/HONDAS!
- To G3 Teg owners who have replaced their taillight seals....
- Help me Pick a Tranny!
- Adjusting my comptecg sway bar. ??'s
- is RS*R exmag gt2 exhaust hang to low for my integra?!?
- Brake Problem
- Difference between 95 Gsr block and 99 Gsr Block
- Difference Between 90-93 Integras???
- black face integra reverse guages
- Water in cylinder 3 spark plug....misfire...wtf
- honda H's on front and rear of DC?
- removing heat shield?
- LS/Vtec Turbo?
- what do you guys think? good deal on 96 gsr
- Its been fun!
- cam profiles questin
- Switching fender and front bumper
- bouncy ride and noisy- hr sports/konis
- Question: Removal of paint on rims.
- Anyone which Acura dealership give discounts for being honda-tech member?
- Car dont turn over
- 2nd gear syncro
- HEY TECHS WHY ARE USING LS/VTEC?
- Misfire or clutch slip?
- Just ordered Ground Controls...
- White smoke came out!!!
- Wheel Lock...what's your recommendation?
- Can you run a 205/55/15 or 205/60/15 on the blades?
- Outerwear PreFilters
- i need tranny advice.
- um ok, cant pull ECU codes!
- exhaust shake/rattle
- can someone scan helms 94 b18b...
- 94 b18b1 wire harness diagram...
- Mixing, and confused on what to do.
- Thief on the loose!! I can't believe people would steal a $10 clear corners.
- 94 b18b1 motor obd1?
- wheels shake when braking medium hard sometimes... help!!!
- what the stock bore on a gsr or type r
- Anyone in the ARlington/Pantego/G.P./Dallas Texas area had a LS/Vtec done?
- identify tranny
- NGK spark plugs
- OBD1 Harness w/OBD2 motor?
- tried searching but.... yet another "car wont start"
- help me handle better!
- about my rear bumper..stains? or something
- New Fram Airhog filters
- Uberdata on a Non-FI engine?
- 5 lug question.
- jetta coilovers on integra?
- switched plugs what should gap be?
- STOLEN CAR
- Anyone have any idea on.....
- rear lower tie bar install question
- question
- Props to JDMshit.com
- 14 inch steelies fit gsr
- fuel pressure regulator? are all 94-01 the same?
- wheel stud
- vibrations at ~80 mph?
- need help bad (clutch master cylinder or something?) long
- which oil do i use (the best you know of)
- Valve Adjustment concerns
- How to disable antenna?
- valve seals giving problems on rebuild engine.........
- Bad Fuel Pump or Main Fuel Relay?!?
- Does anyone have any suggestions for a new fuel pump on a 92 LS Integra???
- H H H H - any engine builder/installer mark there engines w/ this - H H H H
- JDM front non-hid question... (got confused at some search results)
- where to buy Koni yellows?
- lca bolt question
- click from clutch
- Will a b16a2 a/c compressor fit onto a b18c1 block ?
- engine builder
- Carsound Cat/ Comptech Catback Check Engine Light?
- JDM steering wheel fitment?
- High Rev Motorsports
- obd2 o2 sensor help
- hks hi-power
- obd1 vtec problem...
- hondata and now my car stalls
- what cams to get for my b18c?!?!?
- water in my headlights!!!
- What clutch and flywheel for 90-91 Integra? (gonna use in B20 later)
- Is it an upgrade or a downgrade?
- AEM Filter on Matrix Piping 98 gsr
- Newbie
- turbo kit
- short ram or aem V2
- Frankenstein B16/B18
- 16s or 17s for GSR?
- Question on E-bay fuel pump
- MDX antenna
- ECU ...Vtec Problem
- couldnt afford the rest of the rim?
- ups and downs
- Buzzing at ~3200 RPM when car first starts up... Only with Aftermarket Exhaust
- tie rod question..
- Rattling noise at cold start up and low rpm's???
- b-pipe exhaust fitment question
- bouncing rev limiter
- ABS Sensor
- Time to move on
- White Guage Wiring....question?
- LS VTEC question
- 2 GSR TB's?
- B16a1 w/LSD into a 91 LS integra HELP
- AEM cam gears what side do you advace and retard and to what degree
- Will a JDM ITR 4-lug conversion fit a 4 door GSR??
- couple videos
- who knows about Different tanabe RM &SRM
- Integra PR4 OEM part number
- Good head and intake suggestion
- hub centric rings
- Anyone install a venom vcn-1000 n2o kit?
- Need help with my 98 gs-r
- new installs on the DA
- are axles supposed to be able to be pushed in
- pr3-4 is what b-series head?
- *HELP* knock sensor setting off CEL?
- Anyone has "this" lying around in there garage?
- 94-95 LS GS differences... look what I discovered....
- f**kin thieves
- cut my aem cai?
- internal speakers
- Perhaps, no boost?
- HeadLight HElp!!!!
- Hood wont close!!!
- comptech swaybar/tiebar and 2.5 kteller exhaust
- how much nitrious shots would a stock internal 93 ls take?<or safe!
- Pic request: Wings west mugen kit + slipstreams
- she will live again!!!!
- Little Vtec help please
- 01 gsr help
- swade or tweed
- what is this part? how much will it cost to fix? suspension related.
- Engine in SE teg???
- Kyb Agx Setting For Daily and Track
- I thought I've seen it all...
- need help with 1990 integra
- Brake fluid on ABS equipped
- JDM Conversion Questions
- helms help?
- Where can i get car paint
- xsi integras
- Gsr cams in D16Z6?
- How to wire a 4wire alternator OBD1 to a 3 wire OBD1 alternator?
- Skunk2 coilovers and Illumina Struts
- performance parts for gsr
- header install
- shifting?
- 98 civic GSR
- gsr and ls shift linkage?
- clanking noise at lower rpm?
- Need Help with reverse lights.
- Sparco Grip Installed
- CarFax needed!
- 90 integra gs 123k
- header selection
- Oxygen Senor (DC2) - When do you replace?
- Endyn Skunk2 manifold
- spark plugs
- Thinking out loud: Would EK side skirts fit on a DC2?
- wider tires worse handling ??
- what size azenis on my stock fat fives
- rebuild parts for cable b-series transmissions
- 1989 integra no start? help please
- trying to decide, 4 door or 2 door?
- to duel or not to duel
- short shifter install
- Help!!! Removing Integra 00 back seat
- help with pilot bearing
- 1991 gsr???? is there?
- problem trans!!
- auto transmission question
- Question about going from Heavy to Light Wheels
- carbon fiber deck lid 94 teg.
- Location of aftermarket air filter....is this safe?
- PLEASE SOMEONE HELP ME WITH THIS GSR SWAP!!!!!
- b16 tranny problems
- what does back pressure sound like?
- CLICKING SOUND
- Exhaust Systems?
- Volk Wheels
- Turbo exhaust question, please help
- clutch adjsmnt.
- catch kan problems
- problem with keys, did i get screwed over?
- HELP!! In need of side mounts, base and sliders for Recaro Pole Position bucket!
- 94 V-tec integ. gear oil & break fluid change??
- Ordering some JDM S1 Cable tranny syncros- Anybody else need some?
- 91 Integra Ignition problems
- Which Springs to use??
- fuel cut
- will a 95 LS cat fit the same as a GSR cat?
- Will my turbo off my gsr....fit
- Experiences With Different Suspension Set Ups
- 1990 Integra vs. 1990 240sx Who Would Win?
- skunk2 or edelbrock....... can't decide
- no-noise making exhaust with more flow??
- 98 integra gsr vtech not working
- JDM P73 ecu? did not pass emission?
- Bought a 96' Integra GSR!
- Ok so i think i bent a valve but not sure?
- Is this a good deal?
- cable or hydraulic tranny
- Cut door handles or switch doors????
