View Full Version : Acura Integra
- ECU what should I go for?
- FALKEN azenis
- Clutch smoothness
- wings west rear lip question
- The $2000 question
- This forum is NOT for PIC requests.
- cyprus green integras
- How long did you OEM Clutch last?
- Good tires that come in 205/40/17 ??
- gsr ecu question
- Anyone have pictures of a leaking head on a Integra?
- quick ls question
- Part number for manual tranny bracket bolts?
- Autometer monster tach
- Does the stock radiator fan push air, or pull?
- Car is reluctant to start
- where can i get a helms manual for my car
- anybody have a review for a fastbrakes kit on a gsr?
- b16 header on b18
- Just installed a 98+ JDM LSD ITR Tranny(4.785FD) and Action Clutch in my 99GSR....
- Any feedback on the BBK 70mm Throttlebody?
- How do these come apart??? Intermediate shaft holder thingy
- Clutch pedal making a 'squeaky leather' sound.
- Suspension gurus: help help !!!!! see inside
- Help! Are these coil overs any good??
- Rotors are warped :| eeeek
- Help with Exhaust Fitment
- Where can i get a 99 integra sales brochure...
- Interchangability of wheels speed sensors?
- Stock Fuel pressure
- what would happen if i dont change my shocks?
- Need help installing throtle cable
- Maint. Required Light
- Shifting problem....
- Help me with the rear motor mount
- B18b n2o users?any problems?
- ITR header work w ls
- Is this teg worth 5k? Help please!
- Engine Noise....?????
- help?
- how bad is it to run directional tires backwards??
- Throwout Bearing + Pilot Bearing Question
- Pic(s) Request! OBD1 GSR wiring harness
- Where can I get an Acura emblem?
- Is it possible to integrate LED into the gauge cluster??
- ATTN: People who drive in the Snow
- 4dr gsr......need info
- Cant shift to third gear! what could it be?
- does tokico????
- someone tried to steal my wheels
- 9005 Conversion...
- comptech intake fitment question
- redline of 96 special edition ??
- offset keyways for crank pulley/ 94 GSR
- Car leaning out during cruising speeds
- Gram Lights 57 Pro
- where is a good site to buy rims for cheap?
- 95 Integra GSR VS. 2000 Toyota celica GTS??
- Front Bumper?
- New To turbo Scene....What do i need?
- Anyone have a Stock Gs-R dyno plot or atleast can confirm the number?
- hey i found a pic of my car on the net!
- shift linkage bolt broke on my skunk ss...help...
- has anyone done this swap
- Car feels like its been flogged after gunning it
- 5000k HID
- JDM GS-R Header
- feul pressure???
- revhard manifold
- Can anyone vouch for D1703 ???
- Hate my car
- What mod to do next
- question about my dc header
- bad brake master cylinder or brake booster?
- Ingalls Camber kit w/ H&R Sports and Koni Yellows...
- metallic scraping sound from my car??
- Does anyone know where I can get good deal on Brembo product?
- FS: Walbro Fuel Pump GSS 317
- Electric Superchargers. No, really. Seriously. -Please read and reply-
- whats the cost for installing cam gears?
- 1998 milano red GSR for sale in the NY area.............
- Do JDM door panels fit my integra coupe?
- rebuild or go v-tec???
- Getting my Valve Cover powdercoated!
- Looking for pic of 97 gsr rims
- question for painting sideskirts
- FS:94-01 GSR Skunk2 Racing Intake Manifold
- Just got my exhaust put on, but do i need to reset my ecu??
- 98 up integra conversion....other questions
- New Times @ Track
- Looking for pics of a 94-01 silver DC2 with rims friend of mine need some ideas and pic woul hlep
- built ls turbo head with sheetmetal intake manifold and 75mm TB F/S!!!!!
- ZC in 88 teg?
- which sit lower integra or del sol rails
- what is a good price for spoon cam gears?
- turbo integra questions rev hard kits
- what shit i get
- Noob question on Metric bolts/rear camber....
- Racing Hart C5 Evo's
- Help needed!!!
- four door type r???
- Do brake lines from a 98 ITR fit a 95 LS??
- fixed ticket
- HELP! Hub/lugnut/wheel question on 95 Integ
- H&R sports VS. race
- gearing?
- Replacing Cam Plug Seal (end)
- need some info on koni's
- Temporary Disassembly of Stock Intake To Boost Performance?
- Locked key inside car. Got key back....now I need an alarm. Suggestions?
- What size are the bolts that connect the cat to the exhaust?
- Blow shocks
- Qucik, how to unplug spoiler light
- Excess heat?
- Will i need a slim fan with my fluidyne and drag 3 kit?
- for those with KYB AGX/eibach pro kit or koni yellow/comptech suspension...
- KYB GR-2 shocks for my teg???
- My gsr is over heating, but why?
- AEM Brake pads
- My worst car day ever*
- help! car freaked out and started shaking and pulling left
- 5zigen exhaust diameter
- zero effect
- please help
- 13" wheels on a teg
- jg or web cams??
- those who bought carsound cats...
- clutch
- Front windshield broke !!! What to do?
- '94 GSR Block... how much is it worth?
- recommended rotors? what kind?
- Removing/ Replacing spoiler
- quick paint question
- Compression numbers........
- smallest size wheels i can put on over GSR brakes?
- JDM type R conversion for 94-01
- which is better?
- 1998 GSR for sale in the NY area....
- Question about integra 96 rims
- B16a in Integra
- help...loose LS valves
- Jic Magic
- Spec Zero (Cool New Site)
- firewall
- My Rotor Grinds... need help *PICS*
- C'mon guys! wheres the integra groupbuys at?
- ticking from back of motor?? wtf?????
- can anyone help me with some LS swap questions
- Engine oil for GSR???
- What size rims for integra? bolt patter.
- whats the best exhaust
- Your opinion on an aluminum flywheel!!
- G3 Integra coin-holder, use it?
- Burning oil
- How to remove/dissolve maple syrup?! :MAD:
- whats the best aftermarket bumper that will fit good on 98 integra
- please somebody answering my mysterious door problem
- GS-R Horsepower?
- HID info.
- How to distinguish OBD engines?
- modifications on 94 integra enigine
- cwest kit for integra... any one got pics of it ?????
- are LS/GSR intake mani interchangable?
- gsr '01 swirlies, how much?
- Anyone replaced a radiator? Good manufacturers?
- Street leagal intake?
- Street lagal intake?
- What exhaust should i go with?
- revhard or drag manifold
- White integra with HIDs by almaden on saturday night?
- are falken azenis a one dimensional tire?
- got a cai installed it, now i need recomendations
- GSR Oil Consumption and Electrical
- Front lip for JDM conversion
- Anyone with a Comptech Intake and Icebox?
- GSR all motor times
- What year Integra had the saw blade rims??
- should i get skunk2 manifold first? or cams?
- throw out bearing maybe???
- B18C5 in '94 GSR
- Where to get stock GSR valves?
- Paging Chris or any other moderator
- piston question
- o2 sensor rubbing
- 94 gsr h22a sawp what axles
- THE TIME HAS COME, bye bye gsr :( long
- Dyno Day results for me
- Anyone ever mount Hella Twin Supertone Horn Kit on their teg?
- GS-R 4-2-1 or 4-1 Headers...I already did a search..
- any one in sd wanna help with cam gear install
- pix of the old Comptech Integra DA's?
- Where to go next to improve my ET's?
- My engine builder told me....
- removing stock black side skirts???
- roll call for owings mills meet!
- my car is lagging
- removing the rear seat
- Intakes, did search - couldn't find specific info
- How to get Tranny Bolt out for Motor mount?
- MD/DC - casual meet up with Team-Integra
- is there a way to tighten a clutch? what does that mean?
- Guyz i need help
- maintenance required light on
- sunroof leaking.. anyone else got this problem.
- Lowering GSR w/o upgrading sway bar, is this okay?
- Aluminum epoxy to repair an aluminum casting
- Fairplex track (Southern Cali)...
- GTECH handling records??
- Any suggestions for Fields VTEC controller settings?
- 90-93 Integra Weight?
- 1/4 mile times in a GS-R?
- GS-R wheel horsepower?
- LS 5th gear in a YS-1?
- Auto To Manual Parts List
- Automatic tranny shifts inconsistently, but not all the time.........
- polish head?
- Installing Comptech strut tower brace...what bolts do i use????
- Rear brake pad replacement
- AEM diameter
- Need p74/75 ecu ASAP
- What is wrong with my front brakes?
- JDM cluster mileage???
- Lubricating Sunroof
- Someone please help me, i have a 92 civic hatch, go B18c1, B18c5, or b16?????????
- Removing spoiler... tape? plugs?
- cyberdyne digital speedometer help
- need to sell 18'' volks bronze te37
- WTB: radiator
- Front ITR Lip
- Suspension Techniques "Speedtech" lowering springs any good?
- what car did these seats come from?
- Screeching sound from front right wheel
- UPDATE: Yikes....there's oil on my spark plugs!!!
- for you guys that got the itr shift knob off ebay...
- SoCal guys ~~~~ What is a good exhaust shop in the Valley?
- ATTENTION: seattle, wa people!!!
- Regularly scheduled tune up
- I have 18" volk rays te37 in bronze
- my exhaust is all jacked up!!!!
- Honda Torque vs. the world
- Sideskirts in AutoX
- CTR cams...whats needed
- brake master cylinder install
- Do you scrape/Do you think I'll scrape
- For the GSR fans -
- eclipse vs. integra
- Anyone ever done this to their shift boot...
- Has anyone got their ABS to work with ITR brake swap?
- what do you guys think?
- how to ship integra front bumper??
