View Full Version : Acura Integra
- CTR cams...whats needed
- brake master cylinder install
- Do you scrape/Do you think I'll scrape
- For the GSR fans -
- eclipse vs. integra
- Anyone ever done this to their shift boot...
- Has anyone got their ABS to work with ITR brake swap?
- what do you guys think?
- how to ship integra front bumper??
- Usefulness Of Torsion Bars?
- DC header for LS ---> SI ?
- I found a way to get the integra front lip...
- AEM short ram
- Annoying sound coming from the ECU
- Skunk2 or JG victor X????
- Question about skunk2 cams.. not a repeated topic...
- Integra all motor non vtec into the 14's at altitude
- squeaking coming from transmisson
- Fuel managemant systems
- Bad gas mileage?
- DC Header for 2001 GS-R
- Spring and Shocks
- DC Sports header 4-2-1 on 2001 GS-R
- fuelfilter Q?
- schneider cams
- Would a OEM Honda JDM 98+ ITR 4-1 fit a 95 LS?
- Any way to protect bottom of header??
- best tire size for 17" on tegs
- Rota's on a white teg..
- 60' times
- Need Majpr Help W/ My Apexi SAFC
- I need some 90-93 Integra Axles!!!!
- NEED: Model numbers of KYB AGX struts for a 2001 GSR
- What are the torque specs for GSR spark plugs?
- Squeaky clutch
- I hereby swear to tell the truth, and nothing but the truth, so help me God.
- carbon stuff
- Open Fuel lines dangerous?
- my integra died
- Water in Exhaust/Muffler?
- im looking for a teg body
- need some instruction puttin the front lip on? help?!
- tire pressure
- why does my spare tire area get wet?
- if anyone needs walbro 255lph high pressure pumps let us know
- using lifting ramps on tegs
- 94 GSR FS.....
- JDM Header Collector Flange
- For you TEG owners......LOOK!
- camber and suspension ?'s
- new tires
- New clutch is in
- 94 integra GS-R speakers
- 90 Integra need help
- Color help on 'tegs
- need some info on a 1996 SE
- jdm VIN question.
- Which jack
- H&R OE springs
- check this out
- Opinions on what to do next..
- Need shocks for a smoother ride
- Headlight compatibility question !!! 2001 into a 94 ???
- about to buy new rims, what do you think...
- JDM Center Console
- ITR Exhaust Question
- Full rebuild or new car?
- Anyone here using "MSD 2 Step Module"?
- New Yorkers Meet Saturday!!!!
- I need a front drivers hub for a 94 Teg Ls?
- Tranny mount Integra pic request
- Are there any advantages to an NA motor by shotpeening
- Might need a new motor!
- Mugen Sway Bar...
- voltage help
- Help Please....Problem starting the car
- Need help deciding on struts
- is 160k too much on a 94 ls
- Pro's and Cons about buying a USED ITR rear sway bar...
- Kinda OT: Just bought an orbital buffer...
- GSR 4th gear shift??
- what to expect
- What turbo set up?
- Have u ever install Skunk2 manifold on Gsr's???
- Type R ecu on Gs-r???
- HELMS manual, where is ecu pinout?
- 94 to 98+ conversion
- Overheated Brake Pads... Ugh, 2 days in a row!
- thottle bodies
- gsr 1/4mile times?
- Tire size..
- meet in md!!!
- Type R suspenison Vs GS-R suspension
- Type R catback Vs GS-R . . check it out
- B18c5 swap
- Is there any hope for building up an LS?
- help Me Vtec not kicking in!!!
- Hey everyone just bought new car? need an opinion
- maintence light blinked 11 times
- Crower 403 Install
- Can somone post the pictures of the pcv valve location on 94gsr
- distributor sub-assembly on '88 gsr
- Help! Help! Does a 98-01 integra hood fit 94-97 integras?
- spark plugs for gsr
- Hesitation at 1500-2000 RPM..what could it be?
- Bolt on Lower Control Arms
- Pictures of my Integra
- Any tips on putting goodridge lines on?
- DPR vs. Portflow - who's better for headwork?
- Q's about sidemouldings
- PVC valve ..problem when attempted to replace
- How do you remove the ROTOR BUTTON??
- Pic Req:Red Tegs with CF hood
- Turbo kit for sale - Who wants boost??? and who wants it now??...
- Greddy Evo for trade...
- Side markers.....
- I'm new here :)
- Roll call... anyone in here from MN???
- Need Bore & stroke measures
- 95 TO 2000 FRONT END
- OT: TOO MANY I did the ITR swaybar mod posts!
- b16a2 with a gsr head
- i hate thieves!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- Just installed ITR rear sway with BSQ kit...
- mysterious CEL 73 on GSR
- Floppy Steering On Highway?
- anyone with hondata for all motor car?!
- Does anyone have the NX direct port nitrous kit? w/a skunk2 man. ???
- CARFAX Please...
- ok, too loud..wasted $$$$
- Steering wheel tilts a little to the right when break sometimes
- How high can my gsr rev if...
- **ASAP** Integra Models:
- hit and run
- why do my new brakes grind? :(
- Any tips for installing DC headers into a 2000 GSR?
- Wheel lug torque specs?
- Swapping A-pipe, cold or hot?
- Ok to not have the top of the fuel injectors?
- What size are corner bulbs for the tailights on a 2001 SE?
- suspension question
- i got a MAJOR prob with turbo setup with oil press
- when you drag.....
- Stock fuel PSI in a b18b?
- exhaust problem
- taillight question
- Question About JDM Integra XSi Tranny
- how much HP can gsr fuel system handle?
- WooHoo just got my BSQ Type R sway bar mount kit and just wanted to say "thanks Bret"
- B18C1/GSR headgaskets, valveseals, rings... how long are they good for?
- cutting out the middle bar on a 94-97
- Those of u with ACT clutch..i need help
- 99 gsr vs. eclipse GSX
- what are ur favorite integra sites?
- pics of my Gs-R...
- Turbo??
- K.O.S Header - Read inside
- General questions
- Want a built GSR engine? Got a Stock GSR engine?? Inquire within......
- Seat Weights??????????????
- Anybody ever get a ticket for a Fuel Pressure Regulator?
- Photoshop people, i need your help.
- GReddy Type S BOV and VTec
- Why rear right side suspension harsh?
- Does anyone have pics or info on a 94-97 oem integra front lip?
- Benifits Of An Apexi SAFC
- Everyone with a JDM front end, Help....
- Torque specs?
- B18B question
- replacing the t-belt
- Need help with tegs
- Tranny woes..
- Thermal Research exhaust?
- How Would a jackson blower lose boost?
- Bay Area Dyno meet video. 8/31/02
- Bushings-Suspension-Brakes?
- Type R 97 REAR Spoiler & front lip Wanted
- Attn:G2Integrity
- JG EDELBROCK TB performance?
- Moisture in rear tailights....
- Rs-r springs with koni yellows?
- Akimoto intakes
- which should i get?
- Urgent: How To Disassemble Taillights
- erm, re-accuring oxygen code
- Brake Question....Need Opinions
- it it bad to cruise at 4000RPM+ for a long time?
- My GSR has no power!! Help....
- NEED HELP!!!! (having problem removing axel)
- suspension setups
- tranny gearing sugestions
- AEM short ram performs WORSE than my generic short ram?!?!
- ABS light
- LS fuel pump replacement
- Fuel Pump Cut Off Switch?
- noise coming from my trany
- Low fuel light/fuel guage
- Can anyone vouch for drumsy
- how to remove fuse to kill engine?
- 403's without adjustable cam gears?
- H&R Springs???
- what is the max boost recommended for a stock 95 b18b...?
- Anyone find where to get the OEM front lip yet...
- what is the cheapest/most reliable way to get ~200hp out of a 94-95b18b?
- anyone use Potenza RE-010's on the track?
- Looking for a good winter tire...
- help... help... help.... gas guage / engine temperature gauge please please read
- antenna install
- difference between 90-93 and 94-01 teg trannys?
- whats the weight on the gsr blade rims??
- Pics Of Dc2 with Spoons?
- DC 4-1 or 4-2-1 for 97 GSR?
- Can I run Crower 403's without tuning them?
- Please Read Need Help
- Please name some good all season 195/55-15 tires.
- Putting on CAI, need a lil help.
- Need some help, please! Clunking noise after ITR exhaust install.
- Oh S#@&
- GS-R factory spoiler question
- neutral at high speeds
- all i want is 14's
- Wow, jdm FEEL'S body kit on eBay.
- Radiator, need help asap!
- Will 13 lenso slick wheels fit on my gsr?
- anyone got specs?
- Brake light problem.
- Flowmaster for Integra?
- DC 4-2-1 or 4-1 for a B20b motor
- What would you do??
- Lug Nuts: Skunk2 vs McGard SplineDrive vs Daiyama
- CEL Help!!
- how many miles do u you get on a FULL gas tank?
- LS/Vtec,..yes i know, AGAIN.
- cams, pistons question
- Tire Talk
- How fast would this be?
- GS-R/ Si
- Fitting Sideskirts
- ITR cams/pistons
- do 95 ls's come in silver as a stock color?
- Parts numbers needed for rear suspension ?????
- How to fix the hatch rattle
- supercharging a LS worth it?
- Hondata Question
- Wiring experts need help PLEASE!!
- Suspension between GSR and Type-R
- Toronto people......
- Whats the best type of front strut bar? (how it mounts)
- AVATAR?? how to make it better
- where to find a type r lip!
