View Full Version : Acura Integra
- DB7 DB8 OEM optional accessories?
- Hondata boost option??
- Cruising with Zawn
- Fender Liner Identification
- Rear "bumper clips"
- 93 GS-R
- EXHAUST
- -3 AN bradied line for brakes
- brake pedal goes soft
- 92 turbo gsr engine harness question
- is it possible on a 92 teg.
- Volk Magnesium Blue paint code or closest code to the color
- Squeeking when car turns off and at idle
- ASR Brace with ITR LCA's?
- B20B smoggable in a Integra??
- Bleeding ABS..how do I refill module
- ZC Trans question
- Will a 2001 integra GSR/Type R rack and pinion fit on a 1994 integra GSR?
- Hydro Tranny Advise
- How do I know what motor I have?
- Coilover opinions
- Need advice for road racing build
- Rumors.
- easiest wasy to remove.
- Seat belt issue
- obd0 conversion
- 95 GSR no start possible injectors
- 94 integra-which fuse controls the wiper blades
- Can EK civic shocks somwhow fit Integra DA9 ?
- Battery light doesn't turn on
- ABS removal
- Opinions on flywheel ring gear condition
- Front sway bar endlinks...Energy, Prothane, or HardRace?
- 94 LS integra eating up radiator fluid
- b20 help
- Brake lights won't turn off
- need help finding this part. it's part of the seat rail
- D16 A1 new board member intro
- My turbo da build...
- 92 ls valve cover.
- OBD2B-OBD1 still necessary if i tune on crome?
- Carbon fiber hood, who has them?
- alternator will not charge. battery light does not come on
- my 1994 LS type R project jdm front turbo
- car wont start
- Best exhaust resonator?
- 1992 Acura integra auto to manual.
- just got a couple grand...
- Lowering 2000 GS-R
- o2?
- H2B engine help
- integra 13sec all motor ls vtec possible?
- 1992 integra turn signal problems, helpp
- b20 cyl1,3,4getfuel cyl 2 no fuel! need help HT
- Putting a obdII motor in my 95 integra
- How to fix GS-R leather seats
- what is this tranny? ysk2 drc94 p80?
- Ignition switch issue..
- GSR intake mani question
- just picked up a 95 Integra and its...
- Car running like hell. HELP?!?!?!
- does anyone know where i can buy greedy evo 2 or greedy tic exhaust for my 94 integra
- best lowered "functional" stance
- cam management?
- b20/gsr hydrolic tranny - what starter is needed?
- B17A1 swap lags at 5000rpm Please help.
- Not another starter relay question
- 94 integra ls no start
- MY TEGS FROM UTAH
- can someone tell me the name of this WING please
- Oem v. Buddy club head gasket
- Hood not closing and Battery
- Help: Intake cam HARD to rotate, causing t-belt to slip.
- screw size help
- Help on my suspension build PLEASE!!!!!!!!!
- Radiator question (pix)
- Got a sexy boosted sedan and need suspension
- removing headliner from da9?
- 94 Teg shut off, oil in spark plugs
- Havent drove my integra for a year.
- tire size help
- b20b swap da9 , help
- 96' Integra, Stall out around 4-4.5k
- 2000 LS license plate lights not working?? Help!
- Wheel width
- where do these vacuum lines lead to?
- ?Stock LS to GSR swap Question?
- Spoon N1 Gen. 2 fitment
- New member!!!
- Where to get DC Sports 4-1 Ceramic header cheap?
- oil pressure source
- Question buying integra ls??
- HELP
- Installing arp head studs without removing head question
- need help on 94 integra
- Exhaust question
- re-upholstering 2000 integra door panels
- 96 Gsr what is this line? Causing High idle?
- Car rides bouncy after front Camber Kit install
- any thread made for da vaccum line deleting?
- 1992 Integra Value
- I want to turbo my integra gsr @ 5lbs boost
- real rough night...my tire almost fell off...
- Spring/Shock install help
- Jdm front end headlight wiring
- it was a sad, sad day for my DB2
- DA Suggestions
- 2.2L all motor build
- Backup Lights not Working
- Clock on dashboard stuck at time.
- Main relay starting to go out?
- my 1996 gs-r
- Changed timing belt, now valve noise.
- Increasing mpg in 92 gsr
- 1990 LS idle problem / starting then dying
- clutch pedal spring ..removed (pics inside)
- Transmission code help!
- Any one read Japanese?
- da vs dc which is best?
- 93 integra 4door gs check engine light code 8
- Wheel/Tire?
- obd0-obd1 motor swap question
- Electrical Problems.
- NO OIL PRESSURE! GSR PLEASE HELP
- Power Steering Question
- Alternatives to skunk cams
- Fried ECU
- 99 GSR DB8. need info please!!!
- O2 sensor code
- My JDM conversion build thread (The resurrection of the Chili pepper)
- h22 into 94 integra?
- Swap question
- No start issue. Possible Main Relay?
- DA&DC2 12vConstant, ign1&ign2 Same on both cars?
- Driving without a heater blower?
- STUMPED AS FAWWK. cranks. spark. fuel. no start. wtf. 94 teg ls.
- DC2 Cranks over with spark but no gas???
- need help with buddy club lca set up
- Sunroof problem
- idle issue HELP
- Second opinions wanted. Bogs on throttle @idle+. Leaning towards fuel
- Tranny question
- Changing high mileage MTF?
- Help with 96 integra smoking
- Is $450 a Good price for tranny and installation!?!
- 90 teg n/a build question
- B18B1 Mini Rebuild
- valve cover bolt question
- squeaking noise in the engine bay on the driver side
- clutch issues
- Evap Purge Solenoid plug / JDM Motor question
- Trans rebuild
- OBD1 DA Integra wiring haness connectors
- 92 DA b16 having electrical problems dd.. Any input
- 02 sensor delete?(kindof)
- Am I crazy for paying this for a DA Integra?
- Oem body Parts online?
- I think the fuel pump is out - Denso replacement?
- Oil Pressue sensor
- anyone with a dc coupe
- mechanical guru required, identifying this noise
- VSS nipples
- putting my integra together
- replace seats on 90 teg GS
- best throwout bearing for 600 hp b18a with gsr cable trans
- b17 gsr worth?
- Mounts and brackets !Help!
- My 01 LS build thread
- 93' b18b1 mods
- Does IAB effect vtec
- EG to 97 Integra Ignition / Column
- help identifying sensor?
- rear brake prob on 1990 Integra GS
- nkow any good race shops?
- my speedo not working
- Spark Plug O ring replacement
- B16 obd0 head questions
- Hose size
- Traction bar install problem
- 1994 gsr w/ ls swap won't go past 3.5k. Help!
- bought 3.307" pistons and rings and rods so what do i bore my b18b engine too?
- Took off Seat belt and cant put it back on no more on Integra
- 01 LS Misfires and Valve Taps
- My Teggy Won't Warmy Uppy.
- 90 integra gs TPS red wire no voltage?
- my fan only works sometimes?
- $$ value question
- 91 teg RS acting weird yo.
- b18c1 rear wheel application
- 1995 GSR Slow Build
- 168 bulb for side marker falls out
- gsr block problem
- vtec
- vtec
- R.I.P
- 94 Integra Frame Damage
- Changing Brake Booster
- So the previous owner ripped out the ac/heat system
- trailing arm help!
- 'programmers
- Extra Plug on OBD1 harness.. please help.
- Intercooler mounting
- ls non vtec. type R/gs-r cams
- Acceleration Hestitation and idle fluctuates
- 13.1 compression ls?
- b18b1 do i need Cylinder Sleeves on it
- Bad idle
- help pulling off db8 weather strip
- How much hp does a jdm b18b have!
- ls/v
- buddy club p1 lcas with ? end links?
- help
- Alignment off after new wheel bearings. Stumped.
- Problem With My 98 Integra
- LS issue
- k powerd teggy
- Wiring Harness
- DA9 Wont start with key but will with alarm, help please
- GSR ticking noise help
- main girdle
- Gsr block guard question
- NGK Spark Plug Thread Stuck on Head *Help*
- idle purging up and down on da
- DA heater bulbs
- LS VTEC HELP!!!!!!
- How to remove automatic shifter?
- LS VTEC SLIGHTLY OFF TIMING.
- DA exhaust
- sleeper DD zex DA teg.....
- Car won't crank
- LS skunk 2 manifold on B20: Should I use the LS or B20 Throttle Body?
- idle rev
- DA Throttle Body on ITR Manifold?
- b18b tps problem
- Blue Tinted Side Mirror Glass
- 2000 integra door harness broken ??
- Rebuilt GSR burning oil
- b18 level oil pipe
- Budget B18b1 build
- LS Sunroof question....
- The dont disable your IAB's thread. High fiber dyno sheet inside!
- Buddy club spec 2 question
- post piks of ur recent mods to ur integra
- Uneven ride height
- My 1992 Integra GS-R ECU / ECM died. This is what happened.
- Which mount is this?
- NNR suspension
- raceland and rokker coilover feedback
- Can someone please measure B series linkage they have laying around?
