View Full Version : Acura Integra
- JDM B18c1 GS-R (sir-G)
- Integra Finder Help
- Car hesitates real bad when I press gas.
- side molding question
- H22a vs B18c5
- What can i transfer from my LS 2 a GSR motor?
- Brake Light Doesn't Work....
- need help installing cams
- Atomsphere Pressure CEL light? help!!
- what else do i need?
- Ecu question.
- Need a clean exhaust for a 2nd gen teg
- rear trailing arm bushings, replaceable? (kinda long)
- type r sway bar with agx..suggestions for settings?
- where to mount my vafc?
- comptech gsr filter
- Is there a such thing as reprogram the Immobilizer procedure???
- Can you use hondata s100 for an automatic integra and make good power out of it?
- Jdm ITR Conversion...what conectors to use
- Hondata question
- auto/manual axle question. yes i searched
- are ebay "OEM" front bumpers reliable?
- stock gsr 99
- spark plug gap
- how do you get the lights to stay on?
- How much did you spend doing a newer front end conversion on your 94-97 teg???
- where is the ground on the spark plug??
- Fuel tank location question
- Distributor Wiring -- GSR connector on to LS dist.
- Integra Shift Light
- 1st Gen Integra Torsion Bars for sale
- $350-400 what to buy??
- rear strut bolt broke! HELP!
- Looking for o2 Wiring Harness 95+ GSR
- Skunk2 intake manifold question
- Engine mounts
- 450cc Injectors???
- where can i buy sea foam in canada?
- 98-01 rear oem body kit install??
- Greddy Turbo Kit...will it fit?
- NO SUNROOF...?
- Price on a decent b18c1 swap??
- destroyed CV boots ????????
- Brake upgrade questions
- Super Tech oil and filters???
- 98 GSR header on 91 ls?
- tranny owned by 6-puck/slicks
- Engine Running Temp
- What is my motor
- Where do you buy your parts?
- wierd idle
- left blinker is blinking faster than right, help
- need help w/ bulbs for JDM teg headlights
- wich muffler for my TEG Sedan
- GSR to LS Exhaust fitment
- Stolen Integra Chicago
- Does a '98 LS have an EGR...
- getting rid of my GSR
- Where to find 94-97 abs type r lip?
- cams exhuast and intake vs. 6lb supercharger
- What are your rear brake pads of choice?
- valve clearances/compression
- LS / Vtec - Turbo ?
- integra front on a civic
- Anyone know where to buy the suction cup license plate holders?
- pis request for milano red integra with rnr's or group n's blk with red lip
- question about integra door panel removal to uninstall speakers
- Greddy Turbo
- Simple question
- leaky doors n sunroof
- When checking CEL codes, the check engine light turned off.
- : : : : : : Please help me...face lift from '94-'98 : : : : :
- How to make LS faster beside turbo or vtec
- help:anybody using h&r oe sports
- Integra ideling funny....air leak?
- shocks/springs/clutch
- Yea so Im starting to dislike my integra
- aem intake for $60?
- 00 ls M/C fit on a 94 ls???
- wierd scraping noise?!?
- jdm itr header ?'s
- Where can I get a Type R lip for my 92 integra?
- Fuel Rails>>>?
- Best mod for Hp
- Identifying Eibach Springs, is this a good deal?
- Installing stock suspension
- when's next H-T meet?
- JDM DC Sports 4-1 Header on a 96 GSR?
- searched... can 94-97 taillights fit on 01 integra's?
- Backfires/rumbles/pops between 3500-4000 rpm
- Help me out guys...
- type-r cams how can u tell?
- Pic Request! 90-93 integra's with JG Edelbrock manifold
- is it me or is the integra threads going slow??
- Loud noise after lowering
- Amber bumper lens for 94-97?
- HELP!! radio turn off ...car wont start...
- my 94ls žmile times
- Crashed my integra....
- GSR: ATS FINAL DRIVE
- rear wiper removal
- running crower 403's?
- Integra wont start / No Spark
- So CALI RPM Motorworks... FREE food and drinks. FUN STUFF!!
- Dealership question...
- DFW GSR theives!!!!!!!!!!
- Type R intake fit in an LS?
- skunkworks same as skunk2?
- General Tech Forum Sucks! Help Me! Brake booster idle problem? Vacuum leak?
- San Francisco BodyShop
- ebay seats
- Falken Azenis Tire question
- Pics of 94+ 4 door Integra with Prokit springs or HR OE Springs?
- Loose Handling on broken pavement
- Hondata stage 2B on Automatic 99' LS integra!!! help
- 94-2000 gsr exhaust the same?
- Noob Questions
- Neuspeed Sports Opinions
- Whats the difference
- Greddy Evo 1 or 2
- Loud knocking noise while idling. No CEL code. any idea?
- knockin noise on my gsr
- Spoon sprts sw388's
- need help quick!!!
- pr3 pistons on gs-r rods
- help, tryed installing shifter bushings @tranny side..
- e brake line?
- 87 Integra Question
- installing springs tommorow
- OBD I engine in 96+ What's different
- How to be more effective with Auto gearboxes with sport gears.
- Reliability for an LS Vtec?
- ls oil pan on gsr?
- Windshield install
- Ground Controls?
- Norcal INTEGRA meet Pictures!!
- VAFC problems
- Uneven Tire wear...need help
- Track times!
- anyone need a d16a1
- Debating on Apexi N1 or Invidia
- help with rusted bolt
- worth of my tranny
- Exhaust Gaskets
- even MORE weight reduction!!!
- 00 gsr 4x100?
- will a steering wheel hub for a 91 civic fit a 92 integ? ANYONE!
- are the 96 gs-r faster then a 01 gs-r
- shift light , with an Auto gearbox ?!?!?
- Home-depot lip
- Where to get cable transmission
- Ebay Fuel Rail
- how loud is apexin1?
- Any Powerplant option, what would you do.
- Header options
- did search but need help, going from NA to turbo
- JDM SIR-G
- Anybody seen my GSR
- code 41....o2 sensor mish mash *HELP NEEDED*
- RR Brake Problem
- CAR wont start - ECU not to triggering ignitor (measured with an oscilloscope)
- Tower Bars Diffrence?
- whats need for a mild b18b build?
- will civic coilovers fit my DB??
- rods to crank
- Spring Noise
- replacing DA seats
- changing dizzy cap and rotor...
- problems getting off oem springs
- car just blew up
- bought used springs, which one is front & rear? *pic*
- how much does a 93 gs weigh?
- ecu help quick
- Hood won't open
- Does it sound like anything is wrong with my engine?
- do i need my lower rear stock sway bar?
- OLD ladies man I swear
- Clicking coming from front left..............
- idle RPM changed!
- rubbing on my 95 gsr
- AEM OE caliper big brake kit - melted pad pics =) and some bonus pics of my teg.
- Turbo Help.
- PIc Request....h&r springs, on STOCK shocks with 17's please help
- what do you do to clean your dash?
- B16 B18 1/4 times what are you running??? (mods, times, car)
- symptoms? bad clutch?
- help w/ oil leak
- testing waters: how much could i get for my 94 gsr
- 95 GSR and need performance should i swap with a H22
- What LSD for a 94 LS?
- see if you can help me with this
- eBay Headers
- HELP! WHAT DO TO? WHICH ENGINE TO PICK?
- How do you know if your motor is in good condition?
- Wet Interior!
- Cel 16 Help
- CEL code 90
- where to get front doors from sedan
- Problems after installation of CAI*sighs*
- Bosch oil filters
- intake testing? how do u do it?
- This a good price for an ITR Lip?
- GSR dizzy on b16 head?
- what should i do, b20vtec or turbo?
- Question: will usdm bumper reinforcement bar fit on jdm integra radiator support?
- Engine Setup!!?
- Throttle Body stud size?
- anyone know the oem wheel weight?
- Sway bar question
- TSX being parted out, anything worth grabbing for my teg?
- wont 00 si main o2 sersor fit my 98 ls?
- Turbo LS build question...
- oil pressure...HELP!!!!
- auto/man convert....Just look
- GSR guys... help me with the distributor...
- My teggy pictures
- itr wing on gsr
- anyone got a type r wing for sale?
- DA guys have any experience with this setup!!!!
- bullfrog cams?
- Would this engine swap be a good choice??
- neuspeed race and AGX's?
- Can the B18C 96-97 Type R motor fit into LS properly?
- o2 sensor question
- can someone find me a pic of an integra with Si wheels?
- Just to clarify my problem..(idle/overheat)
- OIL LEAK!
- bought some used shocks, what do i need?
- OEM LCA Help
- Hesitation when pulling out from a stop.
- cloged cat causing bad gas mileage?
- installing jdm fogs on 97 ls
- shock bolt?
- wheel question/opinion
- emergency brake light
- Need some advice on which motor to put in my GSR
- Rebasing 9006 for HIDs?
- Dyno on DIY icebox.
- LCA's for a 2nd gen. Teg. (searched, still lost...)
- Clutch Master Cylinder Fluid, WHERE IS IT GOING!!!
- Wires for 99 LS
- 4-1 Header on DA Integra (searched)
- No Spark...not so sure its an ignitor...which distroscan I swap (95 gsr)
- CARFAX needed ASAP....didnt know which Forum to put it in.
- New Owner
- can't get my left side axle out and or can't break my tranny loose
- main bearing codes.......NEED HELP!!!
- ITR LOWER TIE BAR
- Where do you guys get your misc hardware?
- Any way to indentify a motor without VIN on it?
