View Full Version : Acura Integra
- basic gsr build
- which alternator?
- GSR and Snow
- Hydrolocked gsr motor
- Water leak
- Blew my motor need advice.
- What is ls mesh center cap size and part number?
- B18C shortblock question
- Integra B20VTEC power problem
- no money mo' problems..
- Noob question of the night. What front lip is this?
- gsr bogs down on exceleration tried everything!!!
- Opinions for New Car?
- Someone with a 96-99 GSR need a favor please!!
- Looks like oil in my coolant
- Sanata Came Early This Year! Yay! OEM Parts!
- Random Vibrating
- i need a clear answer! throughout bearing, released bearing, or isb????
- cluster led lights
- fuel injectors
- b18c1 stock rebuild with USDM ITR pistons, need help with compression ratio/build
- clank when i let the car down from the jack
- Need to buy a clutch i dont know which one though any suggestions?
- Need help with fixing electrical problems
- DC windshields
- repair on motor
- tech and speedo guages going crazy
- 97 Integra LS HID bulb size???
- Replacing Water pipe O-ring
- Recleared my Fat Fives
- 1999 b18c1 complete short block- dropped valve
- What is a good B series clutch/flywheel kit?
- Exhaust Question
- Integra LS Sedan or Honda Civic CX Coupe?? Help!!!
- My New 94 Integra!
- What is the website caled were you chek for stolen parts with vin #..?
- Electrical Load Detector (ELD) BYPASS
- GSR Head Rebuild advice
- problem with cluster
- 2000 dc p/s and a/c swap into db
- b1 cams in my 91ls
- Difference between ITR 4dr and regular 4dr shell
- My Project/DD integra motor blew???
- DC Rear Seat Plastic Middle?
- 99 GSR swap into 94 LS Wiring Issues
- im dumb, 2 stroke in my ls-r
- Whats a good exhaust for a Integra Gsr
- GSR rear seats into DA
- cruise control problem
- horn not working in dc integra
- 92 DA won't start
- 1993 Integra's value IYO?
- Did i Just waste $5,000?
- integra wont fire up.
- Integra GSR rpm loss
- b20 b
- test pipe vs. high flow cat
- Exedy stage 1 vs 2
- tuck fuse box
- 2000 acura integra kill switch
- Looking for jdm front CF spoon lip??
- header help
- 92 integra ls/gs/gsr ?????
- Stock Camber for GS-R
- Not the main relay... aparently. Help? ANYONE?
- INTEGRA clutch question
- Notorious Honda "No Spark" issues-Help?
- 94 Integra w/ Salvage title, worth buying?
- My gsr was vandalized.
- transmission noise?
- 2000 Acura integra Throttle issues and Speedo problems
- This is driving me crazy! Can't find the lowering suspension thread, HELP!
- Broken jdm headlight
- What are the symptoms of bent valves?
- Tis da season for heater blower issues!
- obd-0 to 0bd-1 conversion harness b18A1 A/T to b16A M/T
- need answer
- Sealing Headlights
- 97 jdm front integra
- moved distributor while changing o ring
- @@ __SKUNK2 MegaPower exhaust system (integra) __ @@
- OBDII P75 & OBDI P75 CONNECTIONS
- 98 GSR O2 sensor question
- Mil-spec-ish harness in the works for H22 integra (PICS)
- Jus purchased a 95 gsr
- Integra Mileage Dip in Winter
- Need Help Now! 95 LS No Start Condition
- may be a stupid question, but here it goes, itr pistons in b18c1
- Car won't re-start when warm, not the main relay
- After a long drive, car won't start. Have to wait 5 to 10 min until it starts
- Slow starting...
- 1.8 v-tech head on a 1.6 block
- spoon strut bars any good?
- DC header on DA?
- 1995 Integra gsr.. Clutch gone bad.. I think!?
- 99 GSR, Coil pack?
- 1990 intega no power to anything?????
- 94 Integra won't start
- intermediate shaft replacement 98 GSR
- Electrical Help Needed...
- valve covers
- da integra fs 1000 obo
- Need so help, I have a blinking oil light in my 92 ls integra
- compression test results
- 97 integra body part help
- Help! Cold running throttle issues
- hard to shift into first/second gear at a stop.
- 94 GSR With B20Z Timing Question
- 1990 B18, 92 transmission
- Can't set ignition timing. Cam timing OK.
- 1995 Integra RS ECU Wiring Harness Question..
- B18C1 rebuild/stock refresh
- 92 acura Integra
- My steering column is not centered, NOT the steering wheel, but the whole column HELP
- blower motor
- B17 GS-R turbo build
- ABS Removal Help
- 95 Teg M light and beeping when key is on II
- integra blowing heat on one vent only help!!!
- question about headers
- HELP!!!!..trouble starting my teg..
- Bringing the Window Down
- Will Tein S Tech springs and 17" wheels rub?
- B20Z Headers + Intake manifold
- Slight knock after "rebuild"
- Titanium or not ?? Retainer Question.
- 1994 ls starts, runs than dies off.
- DA6 Driverside Seatbelt!!!!
- 36mm itr wheel stud replacement
- Real jdm sidemarkers
- PLZ HELP!!!!! wrong camshafts.. look
- 98 Acura Integra GS
- crankshaft sprocket stuck..how to remove it??
- 94 integra gs-r no spark
- b18c1 2.0 plans to turbo
- Weird oil leak- 1996 DB8
- coil problems
- new ecu bad idle??
- 2 door sunroof fit on a sedan?
- fixing cam timing on a jdm b18c (gs-r)
- Piston bore help! b18c1
- My first Swap
- Mugen Strut Bar?
- need help on integra mount?
- code 54 wont go away
- 90 integra wont run
- question about eg schocks on a dc
- B18, etc. CAD model
- Da b16 runs in limp mode
- quick transmission question
- Motor Smoking question.
- itr im + gsr head ?
- b20z DA misfire?
- Different tire sizes front vs rear?
- identifying a tranny??
- Exhaust... wonder size?
- 1995 DB8, Bogging randomly (low rpm's)
- eg hatch/jdm b16a swap Transmission and manual steering problems
- CARB legal Type r or GSR Catback exhaust **searched**
- bucket seats with stock DA seat belts (did research)
- wont go past 5k
- white foamy residue on inside on of vc. loss of coolant
- Your opinions on these headlights
- Hytech replica headers regular or big tube?
- Headers
- tuning to run ngk iridium plugs?
- new problem--vibration when coming off gas at low rpm VIDEO
- Kinda OT: Where can you buy Import Tshirts and Sweaters etc?
- 2001 satin silver GSR's..how rare are they?
- Need Help Rebuilding DA axles
- Need help with B18C in 92 Integra chassis.
- 91 ls non vtec wont rev past 3 grand
- ob1 gsr vacuum leaks idle problems
- obd2 to obd1 wiring problems. code 22&14??
- Si vtec corners Integra
- valve guides
- 95 gsr ringing sound out of the motor?
- Recommend a rear wheel hub/bearing?
- idle problem
- chirping into 2nd gear
- Front seal oil leak
- OBD2b IAB Problem *Searched alot*
- help...auto starter on 5 speed
- 96 integra starting issue
- 96 type r cluster into 99 gsr?
- Injector and Engine Manage (turbo to nonturbo)
- Head gasket leak new motor
- timing belt cover
- Wtb da6 headlights
- 91 ls not runnig right
- 95 integra ls gotta fuel leaning out problem
- Brand of Lower Ball Joint - Wow Lots to choose from
- Driver Door Lock Problem
- Tiny Coolant Leak Question
- DB2 Main Relay in DA9?
- 88 teg fuel pump wire. power
- tom motorsports coilovers?
- vtec problem
- delete side moldings
- Noise on rear suspension
- New Car - Old Member
- 93 teggy 4-1 header install
- Ls motor
- Whistling Sound Accelerating at the beginning of 2nd and 3rd gear?
- Car is having weird starting problems?
- B20Z in my DC, swap to LS cams or keep CRV cams??
- oil leak questions
- New to the forum-Introducing myself and car:)
- oil leak exhaust manifold
- Integra Air Filter Sizes
- Quick Question
- 98+ Integra steering wheel on a 94-97?? Searched
- JDM H22A idling high video
- Dc2 Integra recently stolen, started up, now get no gas, Need some help guys
- Theft attempt, chunk of key stuck
- Glad to be alive :)
- Question on ls block prep for vtec
- NEED help!!! piece of dipstick broke off into engine.. b18b1
- Swapping carpet in my 91 ls
- Help with fusebox relocation
- SMSP email?
- Cut Spring question
- How much will it cost to port my B20 head ?
- 0b2a GSR Swap Into 93 SI wont Rev. Above 3000 RPM???.. HELP!!!!
- CEL Code 22 B18b non-vtec?
- Repetitive tie rod end failure...
- question about hole/crack in headers?
- calling all ebay booster
- can i change upper rad support on a 92 integra gs
- 95 Integra GSR: SMOG FAIL!?
- What is this Called?
- 2001 gs and 1995 gsr
- Stabilizer Bar
- 90-93 integra RTA spherical bearings
- oil light comes on randomly, oil level is fine.
- Spark Plugs
- HELP-Tranny Issues
- shifter doesn't move side to side, only goes into 3rd and 4th
- 91 integra power steering leak
- Car won't start help!
- 92 integra B20z ???
- Honda/Acura Fuel Injector Stock Flow Rates CC
- 91 ls integra problem
- I need help!
- 91 Integra LS Issue
- 2nd Gen Teg, idle/temp issue
- oem optional dc2 lip kit
- Wrong plugs no start??help
- rear seats wont fold down
- my integra 92 shut off runnings
