View Full Version : Acura Integra
- Decibel level of Tanabe Hyper Medallion?
- Some B!tches bRoke into my car and tOok my sh!t~!@!@!@
- look what i picked up (56k beware!!)
- valve spring
- Question Difference in Cams?
- fuse problem......help
- spoon replica mirrors
- Question on Halfshaft
- Wanna KEep my LS NA
- gsr cams
- tanabe sustec pro sss type 1 or tein ss
- Snap Ring Problems with Tranny
- Intake Package for top end
- transaxle/nut removal problems
- CFM rating of stock 3rd gen oem fan or fans?
- quick yes or no question about crower 403 cams...
- whats the best thing to get first ?
- suspension help
- Integra Seats
- i need a cat! Whats the best place to get a cat?
- How low??????
- Integra LS Pisotn Rod Bearings Color
- clutch/flywheel combo?
- need help with tranny, ls set up in a civic but civic guys cant help
- how do you find out the CEL codes for DA (90-91 integra)
- idle problems and misfiring
- Check Engine Light comes on only after hitting 6000rpms
- Anyone have a picture of a 16" rim over some AEM carbon black rotors?
- Buying Hankook Ventus HRII's Tommorow, any info on them?
- 93 LS halfshaft fit a 91 GS???
- JDM B18c hp???
- Machining my Block
- Help me Identify this Exhaust! Pics inside!
- RSR Ex Mag
- question about speedo..
- Tell the Difference Between LS and GSR Water Pump?
- Advanced the timign again
- H22 DC2?
- Tach, Speedo off, runs fine though.....shorted something???
- What suspension setup should I get for my Teg?
- swapping clusters with a newer teg
- GSR water pump on B18B1 .. [did a search already]....
- JDM shift knob on 98-01 GSR
- WARM AIR PROBLEM
- My car won't start, i've tried almost everything.
- which camber kit ?
- no secondaries or vtec what happened
- Replace main seals when doing a swap?
- Newcomer Says Hi to Honda-tech members
- Would CTR Rear Calipers fit on a JDM ITR 5-Lug setup?
- Short Ram Intake or Stock box w/ K&N with cold air extension?
- VALVE TRAIN
- Temperature question...
- intermediate shafts
- gsr tranny
- need injector pigtial!!
- turbo ls
- dont know if my car already has a SKUNK2 manifold?
- help! aftermarket exhaust size for DA tegz
- Anybody in South Florida with a pair of steelies I can borrow?
- gauges swao
- Whats the difference between the jdm and usdm DA?
- off topic but is H-T broken for anyone else?
- Will ITR final drive fit in LS tranny?
- Video of my Turbo Teg, before this:
- SMog questions
- Fuel gauge prob
- LS VTEC head swap on Daily Driver
- simple question guys
- New motor mounts for LS/vtec??
- have 500 to spend on suspension
- coolant leak
- Brake upgrade?
- How much could i get for my DC4?
- beaks product
- Newbi from tha other side!!!!!!!
- Wheel size question- Already Searched
- Your nitrous setup
- Re-wiring my zex kit and have a fuse question
- itr lip
- Brembo Brakes
- Hearing a wierd noise when driving.. help me.
- WHO WANTS A TYPE R
- STOLEN: HELP FIND MY CAR!!
- intercooler fitting on my 01 itr..... ?????'s
- GSR secondaries question.. have an idea but need details..
- WTB: 90-93 DA Integra LS/RS/GS DOHC fender molding!
- skunk 2 short shifter install ???
- Clutch making noise?
- Clutch question
- my LS on nuespeed race.
- Negatives of H&R Race???
- those of you with comptech springs and stock shocks....
- Whats the difference between Vtec point 1 and Vtec point 2?
- What fluid do i use?
- ClutcH
- P75 ECU help
- JRSC intercooler
- pic of the back of the cruise control switch
- What is the better header?
- Need help after Zex install, tapped wrong wire, now rev at 4,000 rpm
- J's racing intake anyone know where i can get it
- Torque sequence...Help!
- fmax turbo kit
- PAINTED FENDERS
- help with G/F's car
- How do I become a Member, and not a guest?
- brake rotor?
- Main rear seal leaking...
- 210hp
- LS VTEC?
- Question about ecu and stock engine
- PLEASE HELP,Tranny Problem
- gsr turbo on an ls
- B18B HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- b18c1 with b16 trany.. question
- jg 1001 cams on an LS
- HID JDM ITR conversion help
- Spare tire size
- Skunk2 Camber Kit
- Falken Azenis review: after 15,000 miles of use
- An odd problem with my teg
- Vtec header
- DC Header 4-2-1 $150
- ProLite or StreetLite Flywheel??
- oil pan gasket - looks like the bolts were too tight
- Suggestions please! (looking for tegs to buy)
- What Anti-Freeze/Coolant do you guys use?
- Need help on B20 Swap- ***Pics inside***
- integra dash font?
- Will i ping?
- Bad dyno runs any ideas why or is the were i should be
- b16a2 head, help please
- HELP!!!
- ls ecu/vtec
- VAFC
- PCV valve stuck
- CHECK ENGINE LIGHT FOR TPS SENSOR (THROTTLE POSITION SENSOR)
- How much slower would...
- Who's GS-R is this? (at the houston drift day event)
- question on valve cover painting
- JDM OEM Stanley Sidemarkers
- weight distribution of integras
- CTR or ITR Pistons
- JDM Sir-G header
- teg #21 on list of stolen cars
- Stock clutch on juice = death
- Any integra owners with magnaflow mufflers?
- Tranny problems, changed fluids, more problems!
- 15" Konig Reign
- CEL 41...help please
- wastegate question
- Spring rates for GSR sedan
- how much would u pay?
- IC question
- 95 GSR wheel (fat five): if you have them, ? for you
- Just installed CTR cams!
- quick question?
- Falken 512's vs hankook HRII H405
- When did the JDM switch to OBD-1?
- running lean..... any help
- mugen diff torque spec and oil
- 4th to 2nd
- What plugs to use for nitrous
- gsr cluster
- gsr cluster
- RS on the bottle??
- jdm GSR ecu VS. usdm GSR ecu
- hybrid times
- Full LS/Vtec Coversion
- Ecu codes found here!!!!!!!!!
- is it worth it
- ingall camber kits
- battery light on
- Looking for 94-01 teg with 16in azenis
- OBD II to OBD I Conversion Question On O2 Sensor For 2000 GSR?
- Help on upgrading brakes
- STOCK LS REDLINE!
- B20 Head code?
- Installing Hood Pins
- interesting article on all motor
- O2 Sensor Problems
- changed the oil, car wont start... wtf mate? 5th to 2nd gear change, eeek
- good shops selling usdm or jdm parts?
- Are these the bearings that come on a GSR or type r for lsd?
- SCCA Solo II Brake ?
- turbo gsr...how the hell does it fit?
- I know the jdm cluster works, can I swap the speedo with my usdm one?
- 9005 update
- check engine light
- HELP!!!!!!!! Insurance question.... problem!
- Maint Reqd Sign??
- vtec soleniod ground
- chip burner
- hb with gsr. f/i or n/a?
- lighting question...
- JDM B18A????
- wtb: gsr or itr crankshaft
- I need a pic that shows and names all the AC parts...
- comptech TIG header vs. jdm ITR header
- Im going to be running a test pipe.. Im now OBD1..
- intake fitment
- LS/Vtec Members what model exhaust? LS or GSR
- burning alot of gas???
- sir-g tranny
- which fuel pump? 190 or 255?
- How do I get170 - 180hp out of my Teg LS NA?
- HELP! BUMPER BEAM FOR JDM FRONT END.
- HELP! ! Brake lights turns on wen' parking lights is on
- QUICK - Oil pan gasket install QUICK
- CTR pistons + B17 = ?
- Timing Belt
- Vtec Controller ?
- what race class with a CF hood
- GM Synchromesh, clear some things up for me please?
- QuICk ?
- What's your integra setup??
- ITR springs?
- 2001 gsr cluster plug and play into 94 integra?
- 96 Integra GSR Blown Head Gasket
- valve adjustment question
- Apexi N1 or Apexi World Sport
- Tien S-Tech Vs. Eibach Sportline
- Loose ash tray mount in 01 teg
- recalibrate instrument panel 91 ls
- Increasing brake pedal sensitivity?
- VERY basic "check engine light" question
- Help me...
- LS/VTEC
- car problem, stalling sometimes
- So My Turbo GS is up and running *UPDATE* PICS:
- Changing MT oil (GSR), Can't find filler bolt? Help?
- 91 Integra LS question
- need help with ground control coilover!
- Can't get to my head unit!!!!!!!!!!!!!!!
- Help! Pass. window won't move!
- Seats
- VAFC settings?
- HUGEST TURBO EVER!!
- Has anyone ever changed their timing belt and waterpump??
- I need some info
- Distibutor Part Number For GS-R, the casting number on the dizzy, what is it???
- how to roll back or forward odometer. (for use when swaping gauges only)
- gsr/type r cluster in a LS?
- Car won't start, need help
- valve adjust specs for B18C1?
- Tail lights...
- USDM ITR headers.....is it different from gsr headers? or same size
- Unsealing sunroof
- LS VTEC???
