View Full Version : Acura Integra
- Weird electrical problems?
- Old to new B18B1 head swap.
- Pictures of 94-97 milano red integra with rota circuit 8's
- Rusted Trunk HELP PLEASE
- need HELP!! You know what block should I get in my 96 GSR// Please read
- OBD0 ECM questions
- Distributor Help
- What radiator?
- WTT:90-93 integra vis cf invader hood
- Best Windshield Wiper
- got a short block..need help assembling
- good exhaust for 2nd gen tegs??
- fan don't turn off prob
- Purpose of ITR LCA (I've searched)
- integra belt
- Helms Manual Book
- 1st Gear horrible hesitation DA 90 LS b18a
- your thoughts on these pistons for an all motor setup
- Today I went to see what was left of my teg that was stolen on Oct 25
- ABS light questoin..
- Aftermarket Rads, how much lighter?
- GSR/Type R/LS header
- Light bulb question.. just wanna be safe
- Integra Center console
- Texas bracket race coming soon!!
- Dec 4th Meet at Agile, Mostly Integra
- fuel pressure regulator
- I can't use my heat! PLEASE HELP!
- shipping cost of motor?
- 98 + ABS pump motor
- hondabond = permatex?
- HELP WITH ECU CONVERSION
- integra rs trans swap
- Turbo Ls + Skunk 2 Intake Mani =?
- When clutch catches - Grinding??
- gsr tranny problems
- Spacers to raise car??
- Check Engine light?
- wat would my acura do in the 1/4 mile if i do drag gen 3 turbo
- fog lamps
- Will a 93 Integra Front Bumper fit a 90 Front Integra Bumper?
- Do's and Don'ts
- need some stuff
- VAFC2 INSTALL
- *****92 integra idle surging*****
- ECU programming
- 11.0 Compression GSR rebuild Part 1
- What is LSD (not the psychadelic drug, Acid.)
- Rattle Questions
- Golden Eagle Conversion Kits help
- Will you do this
- Best place to buy a CARBON FIBER TRUNK from??
- Question about which type of oil to use.
- Quick question
- Parting out integra turbo setup
- some coolant hose help 96 gsr into a 99 ls
- LS/Vtec Vs. GSR Which to do?
- question relating to my LS tranny
- OBD1 OBD2 Teg motor swap
- Clutch grabbing height
- 87 or 91 for smog?
- Is this Real?
- Help me please!
- 95 GSR CEL Question
- Are these good?
- please help me trying to find out what kinda tranny I got
- problem with suspension
- help!! installing 1990 ls head
- Does this integra sound like a good deal?
- what do you all think of my plans for next year?
- 94-01 Integra and 92-95 Civic springs interchangeable?
- Oil Pressuse Light. Did Search Already And didnt Find The Answer
- WARNING: NOOB QUESTIONS
- buy pr3 pistons ? (94 LS)
- Interior Color Codes ????
- Integra Optional Kit
- Brake Rotors
- Integra Pulleys
- Are racing harnesses in my integra legal?
- ITR Motor, LS parts = ??
- speedomter wont work
- 3pt Strut vs. Classic 2pt
- head question... need your help
- knocking noise coming from under the hood
- abs removing
- carbon fiber sunroof
- Car won't shift - syncros? tranmission? Strange issue.
- gsr boggs when vtech kicks in....
- New Pics of My Car
- stock cams on upgraded valvesprings... help please
- Auto to 5 spd help
- QUESTION! Will a 95+ Integ springs fit a 00 Civic?
- gsr tranny???
- Just removed P/S, wheel is now dangerously hard to turn
- 400 whp build
- How long do springs take to settle?
- h22a swap
- drivability with cams and springs in but not tuned
- Where to buy?
- were can i find the hks hi power for a good low price.
- Will auto tranny starter fit on a manual tranny engine?
- 5 zigen fireball catback
- I NEED HELP!
- RS-R GT2 Exhaust system...
- Stolen
- how do i know if its a gsr tranny?
- SPARK PLUG TUBE SEAL: IN THE PROCESS NOW!!!
- Radio Code Question...I HAVE THE CODE BUT IT DOESNT WORK
- how much does a 2000 ls go for
- what is the best suspencion for 2000 integra ls?
- what engine does the civic type r have?
- cam gears, how much horse power do u get with them?
- HKS Hipower? or Greddy Evo 2? opions please
- anybody got pics of 3rd gen teg on h&r race spring or nuespeed race springs
- Air intake question
- aebs install high idle.......
- running into another problem!
- NEEDED---!!
- 14" Wheel clearance
- stage 3 clutch on stock LS
- FUSTRATED AND TIRED!!!!
- Does this sound like a fuel pump??
- retrofitting HID projector into jdm one piece for DA??
- Aem V2 trouble??
- throw out bearing??? please help
- engine work
- what to do? faulty brake master cylinder
- acura integra
- NEED HELP, gsr engine wire harness...
- power door locks on gsr
- coilovers question
- Real Quick Question
- 90-91 vs. 92-93 wiring differences for b18b 94-95 swap?
- Cam Gears
- Crap! Someone help me.
- need a carfax please
- 1/4 mile time
- HELP transmission identification... ?
- N1 Crank Pulley
- 90-93 shifter to a 94-01 integra
- ls swap near completion questions
- Should i get a VAFC with a N/A setup******* please help
- 90-93 integra window regulator compared to 94-01
- Quick anwser....ls into a gsr....
- gsr questions (blinking check engine with mileage)
- Why do I have unever drop?
- head gasket problem maybe more...
- NEED HELP!!! Wiring techs please look.
- pics of under side of dc2 tegs
- RPM's To High!!!
- what's the quarter mile times of a stock integra Automatic gs?
- stuck lca bolt
- Invidia Stainless Catback any good? any sound clips out there?
- noise question
- Couple Questions About Coilovers
- Rebuilt clutch master cylinder: are they even available?
- ticking valves?
- Carbon fiber hood
- Brake lines with Big brake kit
- Where was the thread: Viberation when accelerating
- Greddy Blue Box Install
- anyone with a 90-93 integra helms
- Civic SIR/ integra GSR front strut bar on a DA?
- You guys got any problems with HKS Hi-Power Exhaust?
- Need HELP - MotorSwap,Ecu,Etc.
- REALLY CONFUSED ABOUT CHIPPING YOUR ECU
- VTEC only works in 3rd gear
- Another CGP added today! HURRAY
- boring and sleeving
- Mudflaps?? Remove or don't?
- need to window weld motor mounts...
- Weird noise (while moving; not suspension/brake related)
- Need a vouch: Selling my car
- OIL?!?!
- Wanta Sell some wheels or an LS motor?
- will a b18b intake manifold bolt up to a gsr head??
- LSVTEC help
- Comptech front lip 98-01
- is this worth my time?
- ITR suspension question
- Uneven Brake wear
- GSR-LS Radiator, The same?
- Rear Brake Pad Change Problem
- OBD2 vs OBD2b
- Post your dyno runs here...pref boosted
- Strange Signal Light Problem!
- how to take off gsr head
- GReddy Exhaust Certificate
- Problems associated w/ no knock sensor?
- Carbon Fiber rear hatch
- ITR Tip Dimensions
- price estimate for installation
- traction bars
- List the causes of blown headgaskets....
- Piston rings.
- Lowering spring questiong*searched profusely*
- Integra LS Blows Cold Air
- Any Interest in Door Insert Coverings??
- oil is leaking
- ECU ERROR 41..HELP!
- gauge pod question
- quick question
- vss problems
- Will not come out of 5th gear
- Oxygen sensor question
- dash dosnt work
- NO A/C and I just got it fixed!
- 99 LS part needed ASAP, Help!
- Neutral Safety Switch trouble
- Thermostat Replacement!!!
- EM Racing Triangulation bars????
- Please send a Pic!
- NSX seats?
- What cams to use in B18C1?
- TRYIN TO TRADE MY 93ACURA INTEGRA FOR HONDA H/B
- 1/4 mile Question
- TEIN RA on a 97 GSR???
- 1995 B18 Intake/Head, 1991 B18 ODB0 Throttle Body -- Air intake for which year?
- B18A and a B16 Transmission
- Nice Turbo Setup will it work?
- LS/Vtec which ecu
- teg suspension
- in NEED of VTEC
- anyone with spaco seats i need help
- LS Quater mile time?
- Question about brake pedal travel/effort
- idle problems
- Type R rear lip? pics?
- how many VACUUM lines go to Intake Manifold?
- Im out... enough of Integras
- insurance question..
- What you think shes worth??
- Turbo Question Please Help.....
- ne one have rsr with straight pipe. how does it sound
- dash has gone dark!
- oil loss plz help???
- need info on 94 ls motor.
- NEED CODE FOR STOCK RADIO!!!!!!!!!!!!!
- !?!?!Killed Spark Plug Wires w/ Oil?!?!?
- JDM Front End
- Any way to modify 9007 bulbs to fit?
- pics of their tegs
- tips on removing crank pulley
- strippin Koseis K1s
- HID CONVERSTION
- 94-97 Intercooler mounting/ed pics?
- H&R sports sagging
- How do i remove my 3 piece mid wing?
- don't get it
- Do any of you guys use an Iceman cold air intake?
