View Full Version : Acura Integra
- oulThrowing code 67 ... Catalyst problem
- My car got broken into...
- what would you think about a b16?
- Torque Spec. Starter 95 GSR
- Anyone run smaller LS cams? Crane #12 vs Crower 62402?
- How much for OBD2 - OBD1
- EXAUST QUESTION
- Just got a clutch installed
- Need suggestions about rims.
- All are OB2->OBD1 harnesses made equal ?
- break promblem need help
- diy icebox vs aem
- which carsound cat do I need? (which series)
- LS=obd1/2/ver.2?
- Spoon springs install and review LOTS OF PICS
- How to tell the Difference between an Auto and 5speed motor??
- itr intake air box and intake arm in ls?
- Spoon Springs/ AGX install LOTS OF PICS and review!
- Ground Control Coilovers 400/500 Spring Rates
- Would Bigger catalytic converter gain horsepower for 96 gsr?
- what kind of turbo for a G2 LS?
- Swap Parts
- Injectors
- Removing the GSR head? post your stories within
- tein lowering springs any good
- how to on jdm front end conversions
- problemmm
- Radiator/Cooling fan question!?
- G2 Sprung a leak?!!
- what time is it?
- hesitating after car warms up
- Type r cams
- Question on Getting Rid of A/C
- Front Wheel Wobble
- Skunk2 Short Shifter install! HELP ME!!! emergency!
- F-up teg. help
- 99 gsr cluster into 01 itr?
- cam gear setting for LS
- engine mount
- WTF?! B18C3?!!!!
- i need some opioions
- 94-97 itr carbon fiber lip , i want one , where to buy ??
- buying a torque wrench, need help
- ITR wing fitment on GSR... sigh, what to do?
- G3 4-dr interior...
- nuespeed race springs
- where can i get these
- Spoon Mirrors?
- What refrigerant is used in a 95 GSR?
- Motor Sources......are these two the same?
- BFG G-forces on stock 15x6 GSR rims
- Someone stole My Acura Center Caps Last night!!!!
- Gap Question
- Anyone know the weight of the stock ls rims?
- Anybody have this setup?
- are ls autos split differential?
- i need to know stock throttle body sizes (LS/GSR/ITR)
- How to replace rod bearings?
- muffler power question?
- 1st to 2nd gear not engaging smoothly...
- should i buy this? need help quick!!!!!
- big problem with the teg
- Trunk Won't Open HELP!
- Need CarFax
- 2001 Integra Ls Exhaust
- Take out 2nd O2 sensor?
- white smoke from 3rd cylinder?
- hahahah gsr turbo only 168hp and 168 torque!!wtf??
- GAUGE BEZEL POD
- turnsignals
- 3rd gear grinding..?
- gsr 1/4 mile
- rev grind
- what do you think of my car?
- widest tires on 16x7 rims
- I convetrted my short ram into a cold air intake today
- anyone HELP me PLEASE!!!!!!
- New Valve Springs with Type R Cams?
- Got kinda scared today with my fuel pump
- Failed emissions question: What would cause a high NOx reading?
- ATTN: exactvox.. I hear you can get type r spoilers, please reply with info, thanks....
- Wierd noise with Cruise Control
- HELP!! Need real answers on b18c swap into my 90 teg
- I finally gave in to the HID Gods.
- Header Bracket on engine block necessary?
- tranny woes. grinding not syncros.
- Clutch net kevlar solid disc
- gsr cams lift & duration
- Are all 02 Sensors the same?? I really need help!
- Teg Owners in Austin, TX
- that dam water leak
- how fast do you take ur teg?
- side molding dent, ERRR!!!
- short ram intake on 95 RS
- Lowering Spring Install
- Cooling Fan question!?
- Need Help Chosing Springs
- ls/vtec starter problem
- what tools to take out a ECU in integra
- Skunk2 GSR manifold.. Keep the AIB CANISTER?
- installing type r head on gsr
- Removing crap off windows
- gsr 1/4 mile times!
- Short shifter messing up syncros?
- Question about startup whine?
- Insurance rates
- 380whp Prices
- basic question
- my teg clicks when it starts?
- Yet anther Automatic to Manual question.
- b18c Engine Questions
- what is harder..turbo or sc install?
- gsr vacuum diagram
- 94integ question
- guess that tick part 2
- building the gsr
- ANY HT members in the San Jose, CA area that willlet me borrow a 2001 LS valve cover for 1 wk?
- Integra non v-tec cams
- do skunk2 for 94-01 fit 92 gsr??
- just did the diy amber turn signals.....
- heater hose diameter for a 90-91 integ
- Wierd Interior Color Question
- Stupid question but...
- my new ram air system
- time for new brake pads, oem or aftermarket?
- problem with bumper light signals
- installed my n1.. pipe is hanging extremely low
- What pistons to use for a LS motor? P30?
- manual swap list
- 98 4 door swaps
- idle problems
- engine mods
- quick question....
- 92-93 Ls Vaccum diagram.
- brake rotors . . . question.
- dash lights won't work
- AXIS se7en MOD.. what do you think?
- 95 integra headlights adjustment help.....
- need to rebuild tranny?!
- Come share in my misery (bent a Volk)
- f/s (PICS inside) 98 limited GSR interior EXTREMELY rare!! OEM!!
- the correct level to fill the clutch reservior to
- Review: Kumho 712 vs. Yoko es100
- anyone know the thread size for the oil pan drain plug bolt for a 94 integra?
- Help with removing the front sway bar
- Greddy EVO Exhaust
- Strong metallic smell from engine bay?
- rotor replacment charge
- Help with removal of pedal assembly
- help me please! any advice would do!
- main relay not as easy to get to as manual says.... confused
- quick valve adjustment question
- im new, have a few rookie questions!!
- Need some paint prepping tips! HELP!
- pics of where you installed your gauges?
- clutch install in Orange County
- water pump for b18a
- swaping ecu's any problems
- ughh, cars SUCK!!! HELP!!!
- where to buy cv's for teg??
- R1 Racing sports Coilovers
- JDM Type R shocks and springs on a GSR?
- Towing a Jetski with an Integra
- A short throw shifter discussion...
- PS Removal Kit Ready
- 89 ntegra?
- Need 1 Acura Cap
- Effectiveness of Struts
- greddy 2.25 421 or jdm oem 4-1 2.5 header??
- Help wit LS valve spring
- Rear Wiper Plug - Need Part Number
- anyone has work done at LuckyRacing aka MaxHaRacing (MHR)?
- N00b valve adjustment question.
- Anyone replace the rear trailing arm bushings 94+ Teg?
- Question about octane for high compression?
- Stock side skirts
- Help Neuspeed Front Strut Bar won't fit
- A/C / Radiator fan / Condensor fan problem
- dry oil filter?
- ctr pistons in gsr
- Losing reverse?
- rear section exhausts
- Mounting and Balancing
- Keyless Entry and Alarm
- An AEM CAI question that hasn't been asked???
- A/C
- Using Cruise Control button to power fogs
- AXXIS Ultimates for 98 GSR
- ok ls owners..how often do you take it to redline?
- starter problem?? or something else
- Swaping aftmkt suspension from 96-00 civic
- GSR owners with VAFC's....
- Ram air effect? - Integra gsr
- Need to replace head...what to do?
- want to check abs code, but no service tool
- What i need to go from 94-97 integ to 98-01 integra conversion
- 97 gsr wheels
- How do I become a real memeber instead of "Trial"?
- jdm itr five lug question
- nasty, slimy, green coolant
- how do i wire up my secondary butterfly on my gsr swap
- G2 LS cams
- S2K Antenna Conversion
- Passing CA smog with JDM ITR 4-1 header?
- Made some progress on my GS-R today (rear drum brake conversion)
- 94 integ
- Does rota make 16" subzero's in gold?
- coolant level
- Springs for a '00 GSR
- ok.. putting itr suspension on gsr... w itr rear lca's.. do I need anything else for sway?
- SSR Competitions Crap?
- Da guru's . . . Brake Question
- Help with NOS Kit Question
- kicks outta 5th?
- Fitting a JDM ITR Header
- weight of LS wheels
- GSR motor bogging down...need help...?
- More weight better for top end???
- Question about brakes...
- The story of my teg and it's demise.
- Best Big Brake Kit?
- '99 LS & '99 GSR Gauge Cluster Plug-n-Play Interchangable?
- Autozone Brake Rotors
- 1989 Integra?
- Do you guys feel a difference when you remove your p/s, a/c and advance your timing?
- how much should an auto tranny rebuild be?
- need gauges.. which are better and where did yall put em? thanks
- stock gsr wheels or rota slipstreams?
- syncros and lsd for gsr?
- Anybody using R1 coilovers on their integra?
- CEL #43 on a 90 integra
- Quick question about my gsr..
- Mis-shifted
- Buying new/used radiator support need some help!
- Little Black box?
- OEM JDM 4-1 Header or Comptech Header?
- How much are.... worth?
- decide whether to lower or not: eibach prokit
- Comptech icebox for the GSR and ITR is the same, right?
- How much does YOUR integra weigh???
- Unknown Tool in Tool Kit - Allen Wrench?
- oil sensor Questions
- can't use IM feature ! why !!
- auto swap to 5spd or 6spd?
- please help before i DESTROY my car!
- How Does Vtec Really Work
- ls vs. vtec
- ITR complete rear sway setup
- YS1 or S1?
- broke the hell out of my axle
