View Full Version : Acura Integra
- weird alarm quesiton please help. alarm junkies read!
- K&N filter
- 4-pt harness install
- rusted.. stripped... o2 sensor... any idea's how to get it off!?
- Witch OEM B series cams are better???
- TB: Surf Rack
- Cold engine RPMs - not higher than idle
- What is up with this lip on my oil pan? Pic inside
- over heating problem ...help ASAP
- 90-93 integra engine to a 95 integra ls
- Timing Belt
- Thieves need to Die.....
- WTF!!!!
- My car keeps turning off, I need help!!!
- Exedy Flywheel VS. ACT Flywheel
- vafc2
- rota auto xs
- Lost motion ass. question.
- this is tooo weird...
- suspension set up help, (unsuccesfully searched)
- OE thermostat vs Aftermarket - All equal or not ???
- new oil pump needed?
- right koyo radiator for my gsr
- bad clutch cable = squeeking clutch pedal ???
- Idle drops when using power window..
- DA side markers
- Adjust Ignition Timing w/o Timing light????
- The weirdest thing ever
- Pros & Cons of doing a h22 swap
- is this turbo kit?
- What are the pros and cons on a CF hood or hatch, IDK which to choose from
- GSR stalling issue
- B20 Integra, spits and sputters....
- ps removal kit???
- Short cluch pedal movement?? Help?
- What size wheels should I get
- "Maintenance Required" light help
- I'm getting new wheel studs and I have a ?
- 95 gs-r integra. wanna turbo it(new project)
- New wheel studs and
- Should I....
- rear suspension issues
- b18c in a dc5??
- headers to close to oil pan??
- Clutch Cable (Searched)
- how to tell oem from aftermarket???
- Head unit install
- *HELP COILOVERS*
- troubleshoot wipers
- Blinkers not working right after Steering wheel install
- Difference between a distributor off of a 96 and an 00?
- Babied, Mint 2000 GS-R Available
- quick header question.
- Offset of OEM wheels
- Firestone Broke Ma GSR
- problem with 3rd gear!
- gsr never at normal operating temp...
- hey i have a 95 gsr and speedo is not working???
- misshift, engine gone?
- rings? Help
- help! car wont start!
- shaving my head question
- missed a shift for the first time
- The usual Honda motor burning 1 Quart per Oil Change issue...
- help me identify this part on a gsr engine (picture inside)
- 93 Engine cutting out HELP!
- 96 integra gsr times?
- friend selling cams
- Aftermarket HID's for JDM front???????
- integra w/ s2000 engine swap?
- Are there any decent "Venom Style" Intakes for the B18A/B,B20.
- HELP!
- D16A1?? Free
- Heat problem need some help
- Seached, My car won't start but will crank. Need help ASAP
- cant get lug nuts off....suggestions please
- JDM ITR Steering wheel install problem. Weird Obstacle.
- question about cable to hydro conversion
- 1991 Acura Integra GS clutch problems - NEED ADVICE!
- ECU question for my 92 Integra
- clutch making wierd sounds PLEASE HELP!!!
- HOW MUCH IS THE AUTO TO MANUAL CONVERSION THANKS
- how much to resurface from head? replace valve guides?
- LS CEL Flashing and running poorly.
- OBD1 PR4 Jumper Question...
- Skunk2 camber kit problem.
- DIY -- Obd1 to Obd2 Distributor Conversion Harness
- code 9
- ACURA SEATBELT WARRANTY
- eyes say gsr, ears say sooby?
- Blades or LS Mesh?
- catalitic convertor noise
- Electric Motor
- ITR 23MM Swaybar, JDM ITR LCA's, And ASR problem...........HELP
- who's teggy is this
- gsr 4door what to do
- is it bad not to get an alignment right after changing suspension ?
- ahhhh more coolant trouble!
- type r steering wheel help on my LS
- How is the valve condition
- What the hell
- My Clogged cat ?
- Touchup Paint
- air intake
- spoon stickers
- NEED HELP ON DECIDING TIRES!!!!!!!!!!!!!!!!!!!!!
- HELP PLEASE!? Keyless Entry Remote Programming 1999 Integra gs-R
- Anyone know the name of the specific black leather interior color code for 1994 GSR coupe
- 1995 gsr needs saving
- Dash
- CAR STOLEN IN MN
- EJ8 seats in db7
- integra gsr 99 alarm
- Axles are breaking nonstop, NEED HELP
- steallys wont fit on my integ
- Anti Theft
- Cold outside n teggy won't start
- Anyone know a place to put jdm front on in San Jose, CA
- OBD1 ECU pin out questions..
- b18b head question... erg blockoff?
- integra ls possible thermostat issue help please
- how do i get off of restricted user?
- Norcal- where did you rent your springs compressors for lowering springs ?
- Are B16 and ITR retainers all the same?
- b18a1 t-belt
- 1992 Acura Integra GS-R with RS*R ExMag Exhaust VIDEO/SOUND CLIPS!!! ENJOY!!!
- Tire problem
- dc header to stock cat/exhaust...
- quick question
- Distributor Rotor - gsr and itr = same??
- Gauge pod
- How to disable my integra?
- 95 GSR JDM Climate Control Question
- idel problem
- h22
- dinan chip
- ls, gsr, b16, dohc vtec cam gears all the same?
- ls vtec power?
- MOUNTS
- TB gasket...
- ?s about should i get these gaskets & studs
- 1992 Integra
- where the eff is the IAT SENSOR???
- itr crank and gsr crank
- Fidanza Flywheel
- cam gears needed for turbo kit install?
- just changed clutch
- Will a catback from a DC2 2dr fit a DA9 2dr?
- Powersteering pump question.
- UGR FULL COILOVERS
- crankshaft seal issues
- exhaust and header brand question
- ACURA INTEGRA 97-98 RECALL !!!!!
- low idle
- Strange noise
- How To: JDM ITR SRS Steering Wheel Install
- what suspension setups are you running
- Please help me to identify the oil leak
- Timing belt question
- Is this car a good deal?? '96 SE w/ 68000
- Civic radiator in Integra Question
- usdm type r cluster in 94 gsr
- 3rd and 4th gear grind
- Integra LS Rev Limiter
- ok ive looked a good bit but not 100% on it
- thinking about selling the teg..not sure how much to ask..help me price this pos
- dyno services in bay area
- how much whp from jdm b18c(gsr)?
- AN Steel Braided Fuel Line fitting for a 95 gsr?
- Where to find service history
- 92 gsr
- Clutch problems
- 92-93 injectors in 90 DA. Resistor?
- high temp paint? Do i even need to paint the calipers
- k20a... anyone have it? i need suggesttions
- Exedy on Ebay
- Radio Help!!!
- What size exhaust pipeing?
- Header questions..
- Car is surging...
- GSR Crankshaft Girdle in an LS?
- My seat got stuck!!! Won't slide back.
- Cleaned my ICAV, now car runs like crap
- LS engines Questions?????????
- cleaning type r seats
- 91 integra RS with JDM XSI b16 Motor- Wont fire UP.. WTF is up?
- 96 integra misfiring 1 and 3
- need to know the stock bore?
- ls/vtec or ls/turbo?
- VTEC controller`
- Good place to install H.I.D. Ballast (Pics Please)
- Wires came loose from connector:::What kind of glue to you recommend? Other suggestions?
- Leak From header to downpipe question
- trunk dent
- Replacing the front windshield
- code 83.
- exhaust system question?
- Thermal R&D Exhaust 91 Integra
- JDM b18c5 itr to 96LS? need advice from some vets...
- Elbow for greddy td05-18g
- Modacar or Nipponpower.com
- Will DC headers i had for my 00 fit on my 96 stock exhaust?
- I need help with installing the ballasts for my New HID kit
- Goodbye everyone - 99' Integra: Sandrine RIP 1/6/07
- 98 Integra LS parts for sale B18B, B18A
- Something weird happened.
- Head gasket choices???
- question about o2 sensor
- exhaust resonator help!!!!
- which cams to go with?
- how rare? super sonic dc?
- Need Advise
- Distributor Cap & Rotor problems 91 Integra LS
- HELP! 93 tegg
- What is the name of this piece?
- JDM kit
- speedo question
- **HELP** Car Keeps cranking but wont turn over and start
- ABS Code 8 2 CPU comparison
- how much should i sell for?
- Humming Sound
- stock B18B quater mile time...
- integra burning oil and ignition problems
- 'B18 or B20???????
- CAMBER KIT HELP
- Ground Control Help on how to know how to lower and raise.
- Car door is making noise? WTH!!!
- car is running like sh*t...
- calling out supercharged LS!
- Different IM worth it, stock motor
- OFFSET? (SHOW and EXPLAIN PLEASE)
- mirror question
- My 91' beast just died need some help
- noob ass question...
- Rebuilding a b18c1
- What to set 2step launch at?
- What is my b18b1 swap worth?
- OEM camshaft recognition???
- Honda engine bearings......OEM versus ACL?
- S.D. / Orange County Honda Engine Builders
- 1990 Integra question
- easiest way to antena....
- gsr head bolts.......1 time use???
- squeeky suspension noises??
- major problem with headers
- pic request please
- Lowering Car
- turn signal plug..
- Solid CEL (searched)
- TURBO KIT FOR SALE
