View Full Version : Acura Integra
- how do i adjust my clutch?
- carbon fiber lip and parts various sizes
- ...What psi should my tires be at??
- gsr hub pull
- GSR integra muffler noise?
- trustworthy hondata tuner
- Waiting sucks!
- Just sold my integra... :wtc: *longread*
- all b series the same
- need help finding a jdm front clip
- Strange Question, sorry
- Is it possible to convert 98 gsr 4-lug wheel set to 5-lug ?
- 5Zigen Super 6 wheels
- im guessing the clutch is gone?
- Muffler Question
- Cant remove spindle nut
- Airconditioning problem..take out or leave in?
- Rota Subzero's 16"s 205/45 or 17"s 215/40???? PLEASE COMMENT!
- Gas milage on my LS... I get about 300 or so...
- DA & DC brakes
- trouble starting motor
- crazy antitheft systems
- ground problems??? 91 da
- Anyone put a hydro trans in a DA?
- What type of tires do you use? GSR models.
- 93 ls with type r head ?'
- what mounts for a turbo DA 92 teg?
- 14" or 15" steel rims
- HKS Super Dragger or Invidia?
- FS: 90 -01 Acura Integras LOWER REAR CONTROL ARMS- 90-93 Jdm Acura Integra Cluster
- beaks instructions
- wiper plug #.. searched.. came up with
- AEBS intake manifold
- emergency: got alittle oil in the tube seal, used carb cleaner things got bad
- Type R Lip?
- I dont know what kind bulbs does my integra use.
- quick question
- jdm hid good price and help?
- Think'n of picking up a GSR have some Specific questions
- GSR INTAKE
- LS VTEC help
- Ball Bearing, is it worth the money?
- Rear coilovers in the front?
- Tranny Mounts
- For Those who have played with CATS...(Catalytic Convertor)
- Integra Sir-g lip
- looking for carbon mirrors for 94 gsr
- WTF, damn you!!! You worsthless scum!!!!!!
- Who makes higher compression pistons for D16A1 (86-89 teg)?
- ITR bodykit
- STOLEN?????????????
- Rota Battle Pics
- dented oil pan
- Seats.....
- DA brakes
- Anyone know where i can get some real HIDs for my teg
- vtec conversions?
- Need Turbo Help
- has this happened to any of you?
- engine oil question
- how many cc are stock fuel injectors
- Headlight Aim?
- 2000 LS fuel injector - Is it compatible with DA's?
- NEED HELP ASAP
- Bought Tires, Need Opinions.
- WTB: suspension, springs or coil overs for DC in So cal area
- Car sounds funny at 3500-4000 rpm's
- obd 1 or obd 2 gsr
- power steering fluid
- h22 type s swap into my teg
- 0-60 mph with integra engine 5.9s
- Are 94 and 95 oxygen sensors the same as 96+??
- does anyone in here have gt3's on their milano red dc2?
- SAFC2: Tuning how to.. anyone?
- My new toys check this out !!!!!
- Vacuum Line For Cruise Control
- Bad Clutch?
- Car Died driving
- want a DA, not a DC
- quick spring / shock combo question
- Power steering problem? Feels like i lost PS.
- Axles for 91 integra
- Question on GS-R idling
- 92-93 integra gsr production numbers?
- Hey I Dont Know What kind of Bulbs My Integra's Head lights uses.
- parting out the blacura
- How to put on suspension.
- Those with Caspers 02 Simulator
- Is this for real??....is the world going crazy???..haha check out this picture!!!
- WTB: JDM ITR FRONT BUMPER FOR DB8???perfer black but others okay.:SOCAL:.
- WTB: anybody got a LS, gs-r or itr tranny they would like to sell for a decent price?.:SOCAL:.
- 96-00 Civic coilovers on an integra?
- Need help! no spark, and no car, make jose, something, something...
- cel 67 came on today.
- Clutch Squeak/Whine!!!
- p.28 wid gsr butterfly
- type r swap?
- fan wont turn off, drains the battery
- integra headliner
- which Tie and sway??
- Swapped in stock B18B into Integra, now occasional bogging??
- 96+ b18b have Crank Sensors?
- spoon sports filter question
- catalytic converter
- Anyone have 2000 GsR ECU Pin Out?
- B18C head oil leak
- Which integra is hotter?
- Rear wiper delete...."How to"
- Apexi SAFCII
- dented gsr oil pan
- Smoke in High RPM's??
- pulled 3 codes today.
- integra 94-97 door visors
- Energy Susp Master kit for integra
- compression test ?
- squeaky clutch
- Interchangeable headers?
- wondering if integra is the way to go?
- Where too get crank bearings and rod bearings?
- i'm new and have a few questions....
- dsm muffler on integras?
- ALL MOTOR OR TURBO MY CAR
- Will a 98 APC Short Shifter fit my 94
- Tanabe USA looking for new contacts
- 94 mirrors in DA?
- CTR cam question(searched)
- Link to online Acura Integra manual
- 91 integra w/b16 NEED HELP
- Thinking about carsound high flow cat... found a ton on ebay for cheap... are these real? FREE SHIP
- ABS Problem?
- B20
- LSD costs?
- Tokico Coilovers or Illumina plus GC Combo??? HELP
- B18C3 Specs
- JDM Front Clip
- who dyno tunes in nc or sc?
- It's Done.
- Will a stock gsr head hold on?
- Head Question...
- spark tester - what setting?
- Have a VIN, what model Integra?
- Corner Signal Light Question
- LS trans gears/diff
- Cable tranny code ?
- need help!
- What is this ecu looking thing?
- Need help putting on 5 lug.
- HID wiring harness...is this correct ?
- Best place to buy JDM engine and cluster or entire fornt clip?
- Manual Door to Power Door swap???
- Need Help On Deciding
- shift knob question
- clutch cable bracket does anyone have one?
- anyone using exospeed parts?
- Integra Weight Reduction
- Bad throttle response / hesitation on 92 LS
- Exhaust Question
- Ethyl alcohol + gas = hurt engine?
- Check engine ligh and ABS are OFF ??
- New to the forum
- 97 acura integra ls
- CAM SEAL
- what would need to be done to make this work?
- Energy Suspension Tie Rod Bushing
- Check out these bad mamma jammas.
- Engine will not start after swap
- what rear seats from other hondas/acuras will fit in a 90-93 integra?
- DA6 Facelift (B16A2) 4-wire O2 sensor woes
- buidling an integra auto tranny
- type r shocks?
- two questions
- B20 swap
- HELP!!! KEY PROBLEM
- I need help putting on my 5 lug.
- Cams in GSR
- what does a 93 LS top out at?
- DC4 horn problem
- Anyone in orange county wanting to help install a turbo?
- Damn My Interior light..PLZ help
- Integra type r jdm lip kit?
- GSR Intake Manifold ..... What is this for ?
- to all da guys!
- tranny pops out of 5th gear
- Greddy gauge problem. Please Help!
- Radiator Fan Switch
- i`m sellin my 92 GSR :(
- Lookin for some doors ANY HELP???
- Anyone know what bolts are needed for type r lip?
- First Break-in for a 1 week old. 98 GSR Sedan. Stupid Thieves.
- Tranny (5th and Reverse)
- Car Fax Request
- Vortech?????
- Tow hooks, how did you mount them?
- Newbie to honda-tech
- Integra Targa Top???
- 95 gsr
- H&R Race w/ Koni reds
- Advantage and Disadvantage of going B20
- My integra cranks but it wont turn on!!!!!!!
- Check this VIN please!
- H&R sport springs for sale HID hella 10,000k
- Preferred Axles??
- Suspension Setup Question
- LS Cat v. ITR Cat..
- integra gsr price
- built ls turbo vs ls\v turbo
- hondata s200 w/ boost, ok for N/A?
- obd1 to obd2 dizzy wiring
- Sound/Video Clip Apex'i World Sport exhaust
- To Gut or not to Gut??
- B18c1 for trade (GSR)plus MORE
- 01 GSR Exhaust
- Help wanted: no more ventilation in 90 integra
- Radiator Fan Stays On
- weird noise, rattle, squeak, and a bit of clicking coming from car, help?
- Parts List for Timing Belt, Water Pump, and Valve Adjustment job
- Will a 18 Racing hart D6000 with 215-35-18 fit my stock 98 gsr?
- part #'s for radiator hoses....Civic radiator
- Should I get a Camber Kit or not?
- Rear Camber-Kit Install
- NEED HELP......what color wires on the steering column activate low beam headlights ??
- Compression on a GSR
- Ecu question
- PRICES OF B-SERIES
- b20/Vtec in a 96 Integra, ECU options
- How do i put on 5 lug?
- Question about VTEC?
- Is this damage fixable? Should I jump on this deal?
- crx pins-what are the B10 & B12 pins?
- ATI Procharger...
- car sputtering/struggling off the line
- automatic tranny rebuild
- special pads for slotted rotors???
- Front bumper modification
- Barometric question.
- Honda Bearings..... i have a Q, help!
- speedometer problem
- Which cams for my ls
- tranny fluid change
- Can you name these sensors for me please ??
- Price Quote On My Teg Thinking Of Selling
- jdm conversion help
- grinds 3rd
- Question about GSR Title
- how to clean rust of cam...... searched no result
- Will an intake fit?
- FS or WTT: Shifter bushing
- How reliable is Ravelco? Just want to know.
- A good all motor b18c1 buildup
