View Full Version : Acura Integra
- Cucso Front lower tie bar + JDM ITR 4-1 header = Fitment problems
- new need info?
- ball joints and tie rod ends
- Integgy Needs Fuel
- Any good Michigan shop to help with LS/VTEC conversion. Or anyone in MI to help?
- Help installing body kit
- Need help picking new tires
- CEL 22
- cheapest hid kit
- what is the best security device..
- I need a good site for a b18c-r swap
- theft attempt or not?
- OEM rear valences
- best heads for a b18a1
- head really hot.
- Anyone in Orange County willing to help me take my car back to stock?
- How much for RSX seats?
- Attempted Theft on teggy
- A/f gauge question
- Integra pulls to the left when accelerating
- vafc tuning w/o dyno
- how to get cam gears off
- 91 integra b16 with GSR heads???
- 95 gsr aem cam gears...never owned...need advice
- radiator cap?
- thorttle body spacer
- advice: b18b or b20
- help with fans
- LS to GSR motor swap, whats needed?
- Overheat? Then fine, Odd OverHeating problem.
- 95 integra gsr electrical problem
- Anyone have Omni Power full suspension in their car yet?
- Clutch problem! Something I've never seen before!
- Main't Required?
- Will a 98-01 ITR bumper fit on a 95 LS without issue?
- how to get power from a 93 GS on a budget
- Need some brake assistance, seized caliper? slider bolts? MC?
- will a 92 teg door fit a 91 teg?
- oil inside my radiator??? help ??
- What can be done.
- Install V-AFC controller
- how to?
- larger throttle body + modified intake mani?
- Fuel FIlter
- Theft Attempt at the Mall...=0
- Dropping the tranny, can't get it out....90 ls
- when doin lsvtec how many dowel pins do you need?
- quick question
- Rainwater inside your car???
- engine shuts off
- just got alignment and I got a printout, what do these number mean? explain please.
- My a/c wont work if the radio is on at the same time, whats the prob????
- valve cover breather question?
- Turbonator
- symptoms of blown head gasket?
- spoon cluster
- Exhaust Burble
- Please help. Identifying if block is legit
- check this out!
- Fuel Pressure Question? Experts?
- RSR Exhaust
- weather affecting gas mileage?
- Skunk2 intake manifold problem i think
- quit ??? what should i do?
- My harness wont connect to my injectors
- turbo LS (B16 HEAD) --- worth the work or no
- Numbers doesnt seems nice to me !!! DYNO DAY !
- Gunmetal ITR rim look alike?
- vafc2 BIG BUG
- Dented oil pan - Effecting vtec, wheres pickup tube?
- Does anybody know where to get rubber floor mats for 94-01 integra????
- 225 tires question???
- Anyone know the size of the AEM carbon black one piece rotor kit?
- Stumped on speed sensor...need some help
- wheel shake!!!!
- Question about Cams
- stage 2 clutch ??
- b20 head on a b18 block??
- exhaust header.. how much performance gain?
- G3 0-60mile time??
- buddy club spec 3 vs skunk2 stage2s
- Cold air intake=future problems?
- Integra 92 axles
- got a CEL code 41need help
- Timing the Distributor to Adv need some advices + tips
- HELP ME!!! I NEED IT!!
- 90-93 teg interior
- 99'Integra Axle
- tuning tips for 90-93LS
- 97 GSR w/ 160k miles
- Please help with MES Connector
- Need Help on greddy e-manage ASAP!!!
- b16 intake manifold on LS motor
- golden eagle block guard question
- Shit... how do i fix this suspension i f'd up?
- any one in austin
- oops..!! rear lower tie-bar install ABORT.. HELP!! S.O.S.
- Press Release: Hasport will release the Automatic to Manual transmission mount..
- whats up...forced induction gurus please help me out
- brake upgrades for cheap (oem)
- for all the ricers out there
- Having trouble with the idle on a 90 Integra GS
- rocketmotorsports valvetrain
- LS TRANNY ON B16 ??????
- question
- Mixing 10w30 with Honda MTF ok?
- Oil filter.
- Pro/Cons to removing front fender liner?
- what's the difference between hydeo and cable transmission?
- 99 GSR
- Where did you mount your aftermarket gauges?
- Installing i/h/e etc.
- Can anyone suggest a good setup for my ipod in the teg
- Know of Any JUNK YARD FOR IMPORTS IN THE BAY AREA?
- Which Tranny for my GSR?
- Fuel presssure??????For the experts
- ES LCA Bushing Part number?
- Fellow so cal integra owner.... meet tonight @ 6pm Irvine: tapioca express....
- 96 JDM ITR Cluster
- help on an integra?
- removing shift linkage
- b18a1 rebuild or junk?
- help!!! swaped integra type r into 95 gsr wont start??
- ECU problem??????
- 92 Teg VTEC Problem
- help squelling noise
- help!!!
- tranny hole
- any one want to try and meet up today or tomorrow
- igniter
- How much hp without the ac belt?
- Valve cover bolt studs
- how can I get the most power out of a b18 for cheap?
- Need Greddy EVO2 info.
- Trying to put a price on my GSR
- tdc...should i try to fix this?
- jdm license plate
- What happened to my tires? (Pics inside)
- *Official* post your track times, and include mods & other info.
- rear camber trick...what kind of washers?
- I know everyone asks this...(Transmission prob.)
- Slight grinding noise with slight throttle in 1st and 2nd
- alternative to hondata
- Looking for Honda-Tech members in the Lawrence , Kansas area ???
- Q's about strut tower bar and lower tie bar
- need help
- fake jdm itr?
- Crank pulley bolt of, now how the heck do I pull the damn pulley off?
- i wanna know were i can buy honda mtf for my integra
- Catalytic converter help with my jdm header?
- Leaking!
- Drain tube on the driver's side?
- need help on wiring a PA sensor on my 91 integra
- B17 and B18 exhaust header
- Toda Spec B cams on gsr
- my stolen integra - stripped parts recovered
- HID's on a 92 integra???
- Help with alignment ?'s!!!!!!!!!
- canadian integra backseat
- how much is a coil
- I NEED HELP..my brake lights won't turn off
- Is the GSR considered a sports car in insurance?
- adding skunk2 struts and tein springs on 01 gsr
- Need recommendations....
- stock bars on 01 gsr
- wut transmission fluid my car takes like wut side 10w 30 something like tht for my integra
- shifter bushings question
- AEM V2 CAI vs Injen Racing Division CAI
- i need some help here plzzzzzzzzzzzzzzzzzzzzzzz
- wut u guys think of ROYAL PURPLE SYNCHROMAX MANUAL TRANSMISSION FLUID
- car sound?
- Can anyone confirm that this header will fit a 94 gsr?? About to buy please help...
- Car won't Start
- front and rear strut bars on and the cai
- igition chip
- Can someone identify this motor and year of Integra?
- New Honda Engines ???
- Integra Horsepower?
- NEED HELP! A/F gauge not reading...Which Wire??
- Rims on an Integra
- Will a JDM ITR exhaust be a direct bolt-on with no modification on a 95 LS?
- what year did OBDII START IN THE INTEGRAS?
- Factory Integra Foglight Lens
- Any one know where to fix rims
- turbo = better gas mileage
- Newbie: Got simple questions about mods and maintenance
- aftermarket ITR front lip
- Car problems on my DA
- 1995 GSR Injector resistance ??
- GS-R Head on LS?
- Newbie here ... be gentle
- cam storage
- How Do You Install Stock GSR Front Lower Control Arms??? Anyone know how???
- What size (mm) are '96 GS-R axle nuts?
- Finding replacement Clutch Master and Slave cylinders
- 98 valve cover on 94 integra?
- will lighter Flywheel help the car?
- AC acting strange!
- engine help
- vss problem need help
- need info on '90 tegs please help a noob(to tegs)
- GSR not going into gear
- Engine Misfire 1 2 3
- I need to find.....
- Which type of Turbo for a L.S Integra
- Water pump question?
- obd2b cel
- how many teg's does it take?
- nightmare
- ITR parts on non type r tegs
- How far back does your seat lean?
- Quick question for those who have installed Tein SS
- Update on my integra after accident.
- Anyone know where I can get a authentic, used, JDM 4-1 Header?
- torque spec's
- and there was once a DA...
- 01 cel ?
- Do these miata rims fit integras?
- Do you have to use a different IAC when putting a ITR Head on a GSR Block?
- windshield wipers dont work
- abs light is on, that means..... ...?
- new rs-r catback, do I need gaskets?
- eeek...idle problem!
- need help with mugen rear bar
- Having trouble keeping my car charged? help!!!
- tires?
- Turbo Timer on an N/A car... :)
- clutch problem
- valvespring queston?
- Where to find ITR tranny? Info?
- HELP!! Skunk2 coilover height adjustment....
- valve adjustment for gsr
- factory cd player code, how many digits?
- Where is the main relay located?
- what's the differance in the b16 heads?
- HERE'S A QUESTION FOR THE SMART ONES.
- Any Snow Chain / Tire Chain recommendations?
- I need to know the specs on a D16A1, somebody help!
- 94-97 and 98-01 front bumpers?
- carsound car.. o2 sensor's
- b18 swap question
- portflow inners with gsr outers and stock retainers
- Air/fuel guage ok?
- Stock B Pipe - Are LS/GSR interchangeable?
- tranny is hard to put in Reverse and sometimes 1st, whats wrong?
- *****ATTENTION EVERYONE, THERE IS NO FREE INTEGRA TYPE R*****
- hard to install an alternator?
- how do i take off stripped screws?
- battery dead or alternator finally went kaput?
- What exactly happens during a lean missfire?
