View Full Version : Acura Integra
- Where to buy an SIR-G lip?
- Where to buy OEM Honda Fluids?
- post pictures of flat black integras
- so my car wont start..
- Type-R exhaust on GSR?
- thinking of switching from dc5 to teg and going boost, few questions please help!!!
- oil is burning
- Squealing noise on 1993 Integra
- Thoughts on my Zex nitrous management mount location/bracket?
- My new teg gsr
- which da tail light is better?
- vtec wiring
- gsr tranny
- HELP.... FI E/M fues keeps on blowing....PLEASE HELP
- Is this an apexi N1 , it just arrived but im confused by the size...
- Parts required for VALVE ADJUSTMENT??
- Cam gears or Fuel Rail??
- My Integra and plans
- 92 ls head same as a 94 ls head?
- please..need advice
- HOW DO I GET THIS BOLT OUT w/pictures
- distributor makes noise?
- will a 94-01 integra header fit a da?
- whats the differents between gsr shifter...
- Buzzing sound on start up
- GSR BLADES!
- How difficult woiuld it be to...
- What are these swap application and trim
- Price for rebuilding engine
- b18a1 throttle body Help need some Info ???
- Panel below taillights?
- cams too agressive for gsr w/ just type r pistons??
- help with integra please!!!
- Autocross Video from sunday...
- brakes mushy after tranny install
- New.....
- LS and GSR ignition Coil/ ignitor the same?
- LS Tranny Question? Problem?
- HELP!!! FI E/M fuse keeps on blowing....
- usdm foglight switch...where to buy from?
- replacing lca + coilover kits
- Fuel Line?
- 96 GSR gauges off
- will a aem v2 intake form a gsr fit my ls
- transmission help
- weirdest idle problem yet......
- b20z2 valve lash?
- How To Adjust My CF Hood
- 90-91 oil pressure sensor, anyone have a pic of it??
- Need some assistance please
- Instructions please!!
- NRG Quick release steering wheel & hub adapter on a DA help!!!
- Damn signal and hazard
- burning oil
- About to start 5 speed swap, some questions
- Where to buy GSR/B16 synchro kits
- LS/VTEC...?
- oil problem???
- seatbelt
- Question about antenna...
- Can you blow the coil by...
- my locks, my window, my neck and my back...
- qustion bout dc parts into a da
- Requesting CarFAX
- just got a 1993 integra shell
- Anyone ever heard of these valve seals
- Strut bars
- b20 swap questions? 95 dc4
- 1 MORE QUESTION ABOUT MY 87mm BORE PROBLEM
- Turbo LS Question?? PLEASE HELP
- Squealing noise while turning... Help please.
- '00 Type-R hatch on '97 GSR ((Problem))
- couple of my dilemmas
- Pics of my ls turbo
- Car is sluggish and hesitate from 1-2500 rpm all gears?!?!?
- what should i do first?
- Someone pls help!
- Automatic Tranny Q
- tranny fluid
- buying a junkyard car
- quarter glass.. install price?
- skunk 2 or ground control
- Mounting ITR Replica Lip.
- 97 GSR A/C clutch woes
- abs light on HELP!!!!
- CF hood question
- Black Acura emblems..
- replacement antenna for shaved one...
- whats the average going rate for a 92 GSR?
- question for ppl who know anything about brakes
- gapping spark plugs
- Short Shifters
- Fuel Systems and Fuel Filters
- Need opinions from you guys on a 96 gsr type-r replica
- head warped?
- suspension opinion
- 95 integra ecu from a ls automatic be swap to 99 integra manuel just ecu?
- will a da cat fit on a eg hatch.
- is this a good deal?
- what is a good price for a 98+ front end?
- wastegate vacuum line
- help regarding rebuild kits gsr
- horrible vibration at idle??
- my car revs and then drops revs then drops
- b18b cranks but wont start
- rebuild before turbo or no?
- cd player grounded out??
- Need Db1 visors. HELP!!
- How to take apart 94-01 Integra Tail Lights
- AC AUTOTECHNIC fuel rail fitting size needed....
- Just installed DA dizzy on 95 DC car cranks 1 time
- do i really need a new hg
- Fluids
- Bulb sizes for Turn signal
- 94 integra alarm
- clutch problem in my civic
- 1997 gsr a/c problem
- my timing belt got jammed up when i was driving it what can happen??
- Which Obd is this??
- OBX Individual Throttle Body
- Sloppy start + slow loss in antifreeze (detail intensive)
- Unorthodox Street Pulleys
- JDM harness on a usdm
- rebuilding engine
- Diff between GSR and Type-R
- valve specs...?
- HELP Morning problems???
- 1990 Integra Max. Offset?
- confused..need help pls.
- Quick Sensor Question.
- WHERE TO GET A HALF CORE RADIATOR???
- Lowering Springs problem
- gsr exhaust question !!
- gsr DD shifting
- my dc4's phases...pics inside yo!
- non srs cluster in an srs car?
- Downpipe for a DA
- Fluid problem!!!!!!!!!!!
- Integra idle problem
- Help- Integra Dash Removal
- 94-97 front type r lip question
- where to buy 4 door roof spoiler
- Top gasket gasket?
- darton sleeved 84mm b18c, p72 head w/ gsr cams, peakboost kit.....Start up NO OIL PRESSURE HELP!
- Oil pressure sender
- crappy startup?
- Shifter Bushing
- Distributor side oil leak
- Forced Induction Spark plug gap
- 1995 Integra RS Problems
- Gsr Cluster #???
- Rear window hatch
- ground control 98 integra
- Overheating issue??...
- N1 Exhaust good with Turbo?
- my new teg
- tuning questions
- what to do...head wise????
- Spoon Torque Dampner HELP!!!
- so basically i have no muffler??? WTF
- Lightning Motorsports
- b16 swap on a OBD0 DA
- more power from my ls ???
- bossting my car (step by step)
- idle help!!!
- Car won't start: need help asap
- Engine swap
- How high should cutoff be?
- Parking Light Wire for Alarm
- itr/sir-g head light question
- transmission choices (searched)
- GSR wire harness
- ZEX nitrous kit on gsr
- ITR lsv swap with p28 s300 help
- My defroster button pops/sticks out. Any way to fix this?????
- Switching to a One Butterfly Intake Manifold..
- How long has your alternator lasted?
- I just retrofit my after market headlights but my right is brighter , why?
- ctr piston in b18c
- Turbo help
- Have you ever seen this ?????
- WTB: 98+ Integra Front Bumper
- Starter Relay Location HELP!!! **Searched**
- Fuel cut off switch
- Intake Manifold for Integra RS?
- 92-93 integra block
- Acura Intregra won't start....
- ABS Light On
- Dangling wires.. Passenger side.
- DA distributor into DC
- buddyclub spec III
- How to change out a throw out bearing
- Difference between F&F Type 1 and Type 2 for Integra
- camber kit or alignment?
- cant take rotor off of distributor
- B16 Worth
- Hyperblinking: Help: Already Know To Replace Bulbs
- Dizzy Distributor Rotor Rubbing against cap? suggestions?
- decisions decisions
- 98 ITR lip ?
- Will these coilovers fit?
- What kind of mileage do you guys get on built motors? (N/A)
- Help Viper Alarm, starter kill can't get it to work!
- gsr swap 99% done and not starting
- 9006 in the high beam for DRL
- HOW DO I TAKE OUT THE SUNROOF?
- DA8 Auto Mod
- rattling noise at 3k rpm
- ls vs. d16vtec
- k20 talk
- rust GRRR! help with a question
- Type LS/R Build
- B-Series vs. Integra Alternator Differences?
- 1998 Acura Cl 2.3
- 90-93 da armrest??
- built ls thread lost??
- 1998 Acura Cl 2.3 manual transmision
- rsx skunk2 coilovers...
- Gsr radiator the same as 92-95 civic radiator?
- Firing order for my Integra?
- Rear End Swaying
- '90 Teg build help?
- Partial throttle?...
- DC2 Integra - BULB SIZES! All of Them. - Need Assistance....
- Should i buy this integra?
- skunk 2 or blox intake manifold?
- How to put on CF Spoon lip?
- problem with my rota wheels
- 90-93 steering wheel hub adapter ?????
- Want to boost my car
- 1991 Integra cannot find timing marks
- pictures of lowered cars (3 inches)
- integra db8 rear door swap
- RIM HELP!!!!
- how do you turn off the mat req light?
- itr gauge cluser
- Recent bought 94LS - Lots of questions - Vibration, Audio, Steering, Temp Gauge, Idle
- is there a way to tell a vtec dizzy from a nonvtec dizzy
- calling out Aznricer13 and pinkdelslow...
- jdm type r lip,skirts. Anyone have pics?suggestions?
- Hood Pins On A Integra 94+
- car dies when it gets hot
- will a apexi n1 catback from a 98 integra ls fit a 94 ls
- Need help With my Da!
- Header Help????
- trade Carbon fiber for performance?
- pics for fuse box 97 gsr
- Bulb sizes for coner lights....94 Integra
- ABS problems
- Steering Rack swaps
