View Full Version : Acura Integra
- need a little help!!
- install map bypass "missing link" not working?
- what this screw on the fuel rail and what does it do
- wat tires to use on 16x8 15 offset wheels?
- Better or worse gas mileage? Need answers!!!
- 2000 Integra GS Power Issues (Not Electrical)
- 92 DA automatic tranny problem
- Holes from emblems?
- Vtec solenoid gasket is going bad all the time???
- Can different grade oil cause engine to bog
- s 80 trans
- ctr piston tune
- Battery relocation diagram inside questions
- jdm gsr question
- Spoon N1 Axleback~ People who have.. Chime IN!
- b17a VSS?
- car wont start
- Integra Auto Trans Shift help
- bad catalyst convertor?
- head gasket for gsr???
- need inspiration, what's your favorite DA front lip?
- Engine turns over but doesn't start
- ITR pieces in a non type r
- Shift Problem Looked around can't find any answers..
- 96 ITR 4x114.3 aka Big 4 Swap Questions
- GSR coilover swap question
- dose the jdm dc2 hood fit DA9
- Password JDM Whale Penis Intake Install Question
- 98 integra build help
- Integra DC and DA fitment and questions..
- k2motor.com header for 100 bucks...
- car turns over slow and wont start
- Wierd Teg problem, can anyone help?
- replacing a snapped rod in my gsr...
- Weird Sound from Rear right axle/brakes?
- rocker question
- JVT Try-Y Headers??
- Integra Cat and 02 sensor problems
- Tokico Blue Shock Dilemma and Integra DA Noise
- checking codes
- rpm gauge jumping
- ABS help
- Leather seat problem
- Very strange problem...noise that I feel in the rev of the Engine
- Lookin for a new baby
- Oil pan question... Deep and Shallow pans.
- Integra Main Relay
- Hook up your Integra
- Ls Vtec or GSR swap?
- Seriously WTF ANOTHER ITR POPS UP!!! Sadly a 97 :(
- Compatible trailing arms with 94' Integra?
- CEL16 - I cannot solve this!!
- First GSR build oil leaking out badly(Video)
- Sportmax 501
- Need some comments on 94 Integra Automatic Transmission
- car willnt start, need advice!
- ?'s for a 95 integra
- anyone running OBD1 and a test pipe? o2 CEL...
- fitting a itr axle-back exhaust
- gsr smokes when off throttle
- GSR throttle cable on ls
- Transmission help!!!!!!!
- The saddest week ever, my integra :(.... help me with the insurance company.
- b series dizzy
- DA Project
- front window defroster
- Car bogs intermittingly
- [Help] New Car and I don't know anything.
- harness question
- front license plate mount
- wheel bearing interchange??
- my 1990 da9 integra
- can somebody help me find a lowering springs topic
- Numbers On Rods
- h22 in 2000 integra
- power steering pump issue
- Bout to Buy this 98 Integra if the deal is right so help me out please!
- 1990 integra HELP!
- ASR Rear-Subframe Broke (well kinda)! anyone have this issue?
- need headlamp
- Something I did to my Integra to day was....
- Apexi WS2
- Cometic head gasket leaking
- GSR oil filter adapter?
- "isabelle" k-swap/ or boosted lsv
- 98-01 foglights on 94-97 integra
- I Just Need HELP
- how much axle movement is to much?
- ID this part please
- Question about starter
- 96 gsr swap hesitating and bogging down badly
- How do i find out if a motor is hot?
- Difference between 97 and 99 front end ???
- CEL code 4
- 1998 integra whistle noise
- jdm B16 question
- 93 integra hub problem!!
- RHD ?
- idle or timing
- Water Outlet Cover for 90-93 Integra LS Motor
- HELP Going 91 to a 93 front bumper
- da integra lip
- Da ignition cylinder question
- how to take out spare tire
- new to site
- db8 rear view mirror
- Need This Bushing X-tractor.
- How to drop 87 teg?
- tein high tech bump stops?
- koni shocks
- wheel question already searched
- Need suspension options!!!
- Will p72 rods work in a b18b1
- Really unsure now...
- Engine Rstore AMETECH Additive(does it work?)
- Strange teg swap
- Swapping integra Dash/VIN Question
- axle problem?
- starting problem!!! HELP!!!
- advance ignition diagnosing, lil help?
- ..p72 ecu..missing J1 jumper..HELP!
- 94+ Integra 4 door: condensation on the inside windows when parked in cold?
- about sitting for extended time.
- '01 GSR - No VTEC, No CEL, 45k miles, AEM V2 intake
- Another My Car Burns Oil Thread
- engine running very low
- How does Geico determine the price of a totaled car?
- B18C1 KING Rod Bearings-Pros and Cons
- PR4 engine harness obd0 or obd1?
- wiring problem....
- car die while idling HELP! :(
- 1998 gsr was stolen LA, CA
- 87 Integra engine rebuild?
- delete
- power steering pump question
- Omni power Clutch master Cylinder Better then stock?
- Integra Cam Seals
- helpp da wont start
- How do i replace my Throwout bearing?
- DA Parts 4 Sale
- Hi I'm new. Help with my car
- Help please !!!!
- my defroster is STUPID slow
- High idle integra gsr
- Ls tranny
- 96 integra weird problem
- Fuel Pump Replacement on 93 Integra
- 95 gsr relines at 7k?? Help!!
- Best value for money LS mods and a few q's
- steering wheel question
- b18b1 general header install question
- Got a problem. Car won't start! Took out distrib put it back in and now wont start!
- rear end rattling
- Car not starting. Starter perhaps?
- Replaced rear window, now defroster not working
- DC5-R muffler on DC2 GSR
- Header Issues
- 1999 integra hatch fit on 1994?
- Need a 95 gsr engine wiring diagram!!!
- quiet exhausts?
- any shops around springfield misouri/417
- ***Official: Las Vegas Meet***
- Stock Springs
- crank pulley stuck on shaft
- Are either of these lips made in urethane
- high hydrocarbon
- ??oil catch can or breather for b18c1???
- Need a new cat on my integra
- gsr obd1 head to obd2 block?
- 90 Acura Integra SwaP?
- Daily Driver Gold DB :)
- Wingless Plugs
- 97 integra gas guage problem
- ITR 5 Stud conversion questions, suspension
- Rear Wheel Sensor
- T-belt snaped, how do I tell if a also bent a valve?
- GSR motor Build question
- automatic integra
- DA boggs down at idle.
- Problem with my DA tranny
- Need help, compression lost in cylinder 2 and 3
- Rattling/buzzing short shifter.Not heatshield.
- ..Need help with my 95 integra gsr..
- To those who have their teg lowered
- Battery won't hold charge
- 94 gsr brakes seem lik slipping
- 94 Integra LS Timing
- 91 DA Hatch supports/ shocks
- Motor sitting for some time still good?
- gsr builds
- (acura integra)need help car wont go past 6k
- b series headers??
- Teg wont shift
- Cable Transmision- Clutch pedal drops to the floor
- Emblem removal help
- Steering rack removal issues
- DA Integra Manual Seat Belt Conversion/Jdm Seat
- GSR Ticking after instaling ITR replica cam
- Where to find a Air duct for USDM front ends
- lower radiator hose cool? rest of system seems fine
- 92 integra problems need help
- question to anyone who has re built a ys1
- db1 A/C Problem
- gears go in with out pressing clutch (brand new clutch)
- starting large build. need help along the way
- Help, trans problem, missing key bolt
- b18 ls starting issues
- bad starter?
- lsvtec conversion need advice please respond
- *STOLEN* 4-door Integra SAN DIEGO CA
- jdm gsr swapped into dc2 not starting
- b20 obd2 into 93 4 door integra ?
- Need some opinions
- ITR/SIR-G Front..
- help.. no electrical power.. possible short.
- js racing in take
- I might have a switched rod how can you tell
- might of had my rods switched can you find out
- Stock fender height from ground, question.
- My tranny goin out? loud pop(DA9 help)
- WORKSMEISTER SI REPLICAS
- ls vtec obd2.. p73 ecu throwing knock sensor please help!!!!
- HMOTORS b18
- Exhaust Leak
- help SRS, CEL, ABS Lights do not come on
- Vin where on engine?
- Power window does not work .. JDM RHD
- Help: GSR timing
- Need help!!!! on my rebuild LS
- Boosted Integra
- Engine Opinions.....
- Low Idle Issue
- 94-01 integra skunk2 shock on a DA
- injectors ?
- Jg Edelbrock manifold to my setup! Inputs?
- E-Brake locked up on rear passenger side!
- hey guys what da motor oil fiter number for jdmb20b
- 90 teggy help
- Comptech Icebox problem
- car turns over but doesnt start
- Sputtering and lagging when engine is cold
- 94 LS won't start
- Need help guys please read its about my timing.....
- GM Friction Modified vs non
- Just painted my VC
- Clutch pedal goes to floor
- WHICH HEAD SHOULD I USE FOR LS/VTEC?
- DA 1 PIECE HEADLIGHTS
- DB1 WINDOW
- WOULD A DA6 EXHAUST FIT??
