View Full Version : Acura Integra
- Insurance ????s
- What do you use on your 17's ? 205, 215, 225 ?
- I ordered my JDM ITR 4-1 header today!
- 11.75" and 12.2" 4 piston kit design work is complete
- Do underdrive pulleys improve steering feel?
- Stripped Tensioner bolt hole
- Exhaust questions.
- where to get my integra 3rd brake light
- wondering about integra vti-r (GSR) performance.
- arospeed CAI anygood?
- Quick Q: AEM Short Ram vs. AEM CAI
- Quick help please on tranny fluid change.....
- Over Revving Damage?
- b17a pistons
- It's just like Xmas! (pics)
- cam settings
- I REALLY NEED HELP...TRANNY/CLUTCH QUESTION
- new clutch, flywheel...how much quicker in 1/4 ??
- Tunning???
- Shaving Holes
- port and polish FAQ
- OT: Question about mother clay bar
- anyone with a 2000 GSR pleease help
- Spark plug gap
- can someone explain this dyno?
- clutch master cylinder rebuildable/repairable?
- anyone ever use meguiars x scratch ?
- steel lines
- how hard is it to change valves
- Looking for your help Integra owners!
- How much does AC and PS weigh
- Chech this out,
- How much weight will you save with a CF hood?
- type r/gsr tranny in ls
- ALL KYB AGX OWNERS......................
- White Face guages (NOT INDIGLO)
- shif light
- itr tranny
- proper way to down shift!
- proper procedure for bleeding GSR brakes?
- What CAI with skunk2 mainfold
- Which B16A
- Stolen: 96 Red GSR in Glendale CA...
- Making my custom turbo.....what little things do i need?
- Are new brake pads supposed to suck at first?
- WTF!!! CEL CAME ON
- Snythethic oil change interval?
- Typical for a GsR to eat oil burn oil after 80k?
- tire: Potenza RE950
- Difference(s) between LS and RS tegs
- Carbon Fiber hood for INtegra 2000
- spark plugs and oil
- Intermittent Starter Problem
- JDM DC ceramic heaers $275~
- Help me pick parts??
- emblem question-
- Snow Tires.. What's good and what's not...?
- HAWK HPS brake pads.
- "MAINTANENCE REQUIRED" light blinking on my 95 gsr please help
- mishifted and hit 9500+ today...
- baked on plastic on your exhaust???
- whats the stock size of the steering wheel?
- whats a good 11-12 lb flywheel
- Vortech SC is now available for 94+ GSR!!
- Just got the Helms manual....do II need the 2000 supliment?
- magnecore 8.5mm kv85 wires?
- JDM gsr engine?
- OT: Playstation games in japan?
- ECU ?
- help me out once more pls. which springs will fit my 94 4door GSR? thank u
- whats the best air filter
- Invidia RSR
- How do I disconnect the intake mani.
- Sports Compact Performance Gear 2 in Montreal, CA
- Newbie Strikes again. (Pulley's)
- Z10 radius arm kit groupbuy
- camber question
- tire question
- Best place to get JDM ITR 4-1 Header?
- oil additives
- Changing transmission oil - '95 Integra
- wuts the difference between these short shifters...??
- What kinda HP (crank) should I expect for this setup?
- All right, I'm tired of this...
- how long should a stock GS-R cat last?
- DC header.. questions
- does GSR have LSD?
- I want to get HIDs...... I get the 9006 one right?
- Alignment Problems...is something bent?
- CRVTEC peeps....mods to the VTEC head to match the 84-84.5mm bore?? How??
- Option 2 Decals
- OT: But must sell quick....DOHC VTEC ECU(s) chipped..sorry for the BW waste
- Any of you guys have this--
- Dyno results. 00 GS-R, JDM ITR 4-1, AEM CAI.... more.
- What size lugs? 12 X 1.25 or 1.50?
- So CAl event FRI night 8-12pm OCT 5
- Spoon Sports Calipers - Anyone Interested ?
- ITR clutch better than GSR?
- Its about Cam Gears and the Vtec Apexi controller
- Anyone heard anything about the new Skunk2(RSR) exhaust??
- HELP ASAP! Engine bogging down...
- Attn: Fastbrakes
- JDM 4-1 Header Install on a GS-R???????
- What does the Beaks or BSQ kit look like and whats the difference?
- Parts Needed for JDM ITR 4.785 Final Drive on GSR
- anyone else have their stock ignition coil die?
- Emblem Question.
- ITR LSD fit in LS?
- BSQ kit??
- Just got my Rota C8 and Paradas put on... (pics)
- AEM CAI good price CDN?
- Code 63
- Skunk Cams
- Torque and Horsepower RPM
- b18b valve adjustment
- finally got hood pins for my CF hood, need input
- More terrorist attacks?
- Anybody got TENZO AV-7 gunmetal on a silver teg???
- BEST intake mani, TB and header?
- What's needed to cover up spoiler holes?
- spoon engine?
- how bad is it on engine to take it to redline??
- wHiCh iS eAsIeR?
- NEED 95GS-R MOTOR
- Is it safe (theft wise) to put the S2000 IGNITION BUTTON in your car?????
- ITR, GSR.... same size rear rotor?
- opinions please: s-03 pp or michelin pilot xgtv4 + talkabout radios?? :)
- GSR rim question...
- ground controls on stock springs?
- weight???
- HELP! Is my piston messed up?
- THE best short-shifter for Integras
- How much do you think a 99 GSR would cost??? (whats a good $)
- Need torque specs for sparkplugs on gsr asap thanks
- all koni yellows height and firmness adjustable?
- anyone seen Rota Slipstreams in Silver?
- can i remove my sway bars after installin z10 radius arms?
- Exhaust question?
- FN front bumper POS...
- Exhaust question
- aem pullys, need help?
- need help with jdm type-r headlamps.
- Help! Bolt pattern & offset on G2 teg
- Need Wheel lock suggestion asap please....
- Can a muffler shop angle My n1 muffler without piping?
- Water pump install
- New Info on Spoon calipers and Integras...
- Please post black tegs with rota slipstream flat black or bronze.
- Painting side lower moldings
- Taking off side moldings and pinstripe
- Can i put an HKS bov on greddy piping?
- Pictures for website
- Getting Ecu, P30? ITR?
- Will a JDM ITR 4-1 Header fit my B18C1?
- What are lightweight rims made of ?
- Cammed LS ned premium gas?
- starting problems- Diagnosis?
- what does it take to make todas spec b work?
- Bad Wheel Bearing
- Good machine shops in Missouri?
- Sway Bars?
- Anyone have pics of a Greddy front mount?
- Owen just got a new spoon header for 795.00
- Suggest a good place in Phoenix to install Alarms
- will an ITR header (mugen) fit an LS ?
- ITR sway bar
- FI?
- Someone with a G2 shop manual, help me out.
- Hype-R :)
- Going back to stock Height and springs.
- Teg/Civic Si 11" 4 piston kits now finalized...
- Disappearing oil?
- sliding timming belt on
- Car taking a while to start????
- are the jdm headers really what they say they are?
- What size downpipe/exhaust to run with this turbo
- rice boys at URI
- acura sway bars
- 30,000 Mile Tune Up
- how do bigger wheels affect your gearing?
- What next?
- what mph should a stock LS run the 1/4 mile at?
- Skunk2 coilovers or GroundControl????which should I get??
- torque specs for valve cover
- Does my car have an EGR valve?
- What is the website for Steve Colletti's shop?
- axles..are the gsr and ls..the same diameter? thanks
- FAIL'D SMOG WITH ONLY I/H/E.... WTF
- I need a new muffler - ES any good? Suggestions?
- Integra Parts for Sale
- GSR header fitment question????
- What do you think of the H&R Coilovers?
- trans linkage bushings install
- help me out here....what can i do?!
- Sliding shims on Brake Pads?!?!?
- Did I get the wrong shocks??
- My car failed emissions....need help
- Fair price for a '99 GS-R?
- Are there other sources for OEM Acura parts besides the dealer?
- Advice from mechanics please!
- Check out my Camber Results, Do I need a camber kit?
- Carbon Fiber Hood on Silver Integra
- Local Help?
- Is that noise the exhaust or VTEC?
- Exhaust Problem????
- Valve adjustments on an LS head
- pics from new (second hand) Integra VTi-R
- My car is dead!
- Need some advice. Might buy an Integra.
- passenger side higher than driver's side?
- two ?'s RE: screws for rotors and weird idle or electrical problem
- Brembro Brakes install
- Air Fuel Meter install
- what rpm to launch at
- broken axles on integras?
- test post for pics
- Help!!! battery light is on!!!
- Remote start installed, now I am paranoid.
- What is duel valve springs? and more ?tions
- how hard to install CF hood?
- what cams
- SKUNK2 cam gears or orhadox?? and i need some information aboutt the APEXI vtec controller
- Mating a b16 intake manifold to a LS head ... Anyone..
- 17" rims with 205/50/17 tires?
- skyline vid
- Do It Yourself? Removing stock tires off stock wheels.
- I went through a new trannsmission in ONE DAY! Can Honda trannies handle high HP?
- what size jet's for this shot?
- Compression Test results:
- size of apexi ws tip?
- speed governor
- Bay Area CA Meet!
- 00 gsr with aem cai
- is thre a makeup dat for battle of the imports at route 66???
- car running weird. fields vtec controller is the cause. (related to the fields & map sensor prob)
- TIRE RUNNING FLAT!! WHAT TIRE PRESSURE???
- b18c5 into a gen 2?
- how does ur r/t effect ur 1/4 mil times???
- what next for my all motor setup
- changed out my axels and the ABS came on.
- Would i need an o2 sensor...or not? and what kinda downpipe? confused
- Will a Greddy frount mount kit fit an se?
- ? about my oem kit install
- dc 4-1 gsr vs usdm dc 4-1 itr headers
- just did my rear brakes 1000 miles ago, now squeeking
- wiring expert needed..light fuses keep on burning out
- GSR AEM CAI question
- Headlight Problem
- 5Zigen Fireball owners, how low does your piping before the axle hang?
- I AM SO FRUSTRATED ...HEADER...
