View Full Version : Acura Integra
- G2 Turbo setups?
- Did I give my brother a good deal on my GSR?
- Spring Covers
- ECU code 61 thrown: Primary Oxygen Sensor
- Ls/Vtec or Turbo?
- how do i know my axles are bad?
- suspension?
- Integra with cable tranny swap 4 a hydro tranny HELLPPP
- HELLO HONDA TECH
- side moldings
- OT: Please Help
- quick yes or no question. keepin it simple
- timing help???
- B20 Stroked 2.2 Liters
- ALL red JDM 95 taillights?
- camber adjustment
- LS ALL MOTOR HELP
- Beige to Black Interior
- Wanted: 90-93 Integ
- Camber kit..
- Turbo Smoking / Please Help
- Should I buy this drag raced/ auto x'ed 2nd gen integra?
- LCA's
- Do I need to drop my gas tank?
- ITR vs GSR suspension
- what the funk
- Which gaskets to change with new cams install?
- tranny fluid
- Won't go in 3rd after not going in 4th...Just read please!
- Tranny Problem I think? HELP??
- 95 b18 with b20 head: pcv setup?
- Almost ruined my day (funny anecdote)
- Fitting a Cat Back for GSR on LS???
- anyone wanna trade a World sport for an N-1?
- Integra year 96 with ZC Engine
- help I messed up my head!
- CAMBER KIT NECESSARY?
- i'm sorta new, but not
- Had a weird situation with my spark plugs recently any damage done?
- Insurance... and opinion about buy?
- Lookin' 4 a B18A1
- cable trans to hydraulic trans conversion
- B18B
- not getting spark
- need to know the size of these bolts ....
- itr header ?
- maintenance button on 2001 GSR
- car turns over but doesnt start please help
- ABS Light went on
- GS-R a good choice?
- suspicious ebayer selling a lot of integra/civic parts from CA
- stock 98 ls running rough!!!
- fuel controllers?
- Hello all i am a new person to HONDA-TECH
- Tranny Leaking!!!!!Help
- 87-89 octane -vs- 91-93 octane
- Anyone with heat shield removed-Shifter problems!
- will ground control coilovers be good on stock shocks......for a 96 GS-R
- how to install coilovers?
- lowering issues ( stuck bolt)
- HORRIBLE shaking
- FYI: Emissions Recalled Vehicles and Salvaged Titles...
- Suggested Headers? (street legal)
- gsr block and a type r head?????
- build or swap???
- Rich on stock ecu?
- Omni Power Coilovers.....
- manit. req. light 01 integra
- Stealing my own Integra
- New Dist, Plugs,&wires, Still NO Spark?
- Type R Yellow
- where to buy skunk2 IM?
- how do i wire a 93 ls motor into a 94 si del sol.........HELP ASAP................
- in general are Integra's kind of valve noisey?
- Opinions on buying a header/cat setup: JDM 4-1+magnaflow cat *pics*
- Fluidyne, Koyo, or PWR? Is fitment easy?
- my gsr have ball bearings for differential?
- What is the ITR?
- EVAP Solenoid
- How many quarts of MTF does the G3 GSR's 5sp tranny take?
- type r conversion
- Does anyone know how to move the 94-97 ABS unit to fit the JDM HID ballast???
- Valve lash for my B20...
- Lip difference
- cheap place to order timing belt/water pump?
- i have a dilemna right now
- Radio won't take my code for some reason.. any ideas?
- g2 motor mount questions and HELP!
- Stock rev limiter? b18a obd1 pr4 ecu
- Those with ITR/JDM headers on 94-99 gsr, i have some questions........
- 98 JDM itr lsd into a 99 gsr ring gear
- LS Turbo Problem
- just got my streetlite installed
- GSR vs LS suspension
- What maintenance at 90,000miles?
- Couple of newbie stupid questions on Boosting
- need help with obd2 swap
- Chipped ECU on STOCK manifold
- need help to find turbo info
- secondary o2 sensor how to bypass.
- is this a good suspension kit? (look at the link inside)
- What the hell.....
- Very bad idle problem
- ignitor???
- can deal exhaust realy hurt your performance?
- Tranny is Fxck!!
- E.T 1/4 mile with i/h/e for ls? (SEARCHED)
- changing fuel filter need help
- weird little noise/buzz right after i turn the car on? 94 gsr
- I need an opinion...
- Set up of a supercharger/turbo
- city light on JDM NON HID headlights
- jdm gauge cluster question!!!!!...HELP!
- Both pwr windows, sunroof, wipers, wash fluid not working-90 integra
- ECU CODE 20 Electrical Load Detector?
- VTEC VS NON VTEC
- ABS problem
- how to check knock sensor?
- need help w/ skunk2 and koni yellow setup - pics included
- Integra Ignition
- LS/VTEC ECU & Harness
- Short Shifter
- cheap coilovers that work?
- Is 10w30 ok to use in transmission instead of honda mtf?
- need to find dave at sms
- right size tires for GSR hammers?
- Clutch question
- Having some trouble....................
- Please post pics of car with springs and indicate what springs you use NOT coilovers
- Shafted by input shaft bearing
- Best way to update brakes
- obd-1 gsr dizzy
- need help ls vtec head gasket is leaking
- Integra Mods (help)
- Right turn signal problem
- Droping the kar
- Looking for a good repair manual for my second gen integra.
- race on cv shaft?
- Wondering about something
- MY FIRST POSTING
- PR3's on stock ls rods
- obd2 jdm gsr swap in odb1 gsr chasis w/ chipped p28
- popping out of gear...
- Rear hatch windshield QUESTION.
- Got 92 Integra 4 door
- Need a place in CT that can do lsvtec
- where's d cheapest place online 2 order & OEM cap & rotor 4 my '96 gsr?
- cel code 13
- Will My Exhaust from a 95 Civic fit a 92-93 Integra?
- some kind of ringing.
- What does my compression results mean?
- which junkyard turbo is best for gsr?
- YS1 tranny ?
- fuel filter problem?
- how do i remove this?
- All Motor LS + Nitrous setup--opinions?
- how good are the tenzo R coil overs
- best size tires for 16" wheels
- kyb agx gas shocks and neuspeed springs?
- ABS/SRS Light came up??? WhY...i need help...
- Carbon climate control searched :(
- USDM DRL Conversion Electrical Question
- need help to determine compression ratio
- holy friggin crap, i love my new ITR sway bar!
- HELP!!! engine throwing codes
- if you have code 9 (OBD1 p72) will vtec work?
- RSX Seats Installed(lots of pics)
- cel 21
- header
- Skunk2 Intake Manifold?
- Prepping for Hondata: OBD1 Conversion, Please read.
- What rpm is best to launch at?
- where can I fin the JDM Zeal style front bumper?
- a/c r134 overcharge?
- Trunk Carpet destroyed
- AEM gsr cai + skunk2 im
- installed new gaskets but only fixed one problem
- JDM 4-1 header
- DA civic springs on integra G3
- witch fuel pump?
- 96 LS First time at track...
- JDM Conversion... Headlight Ballast fitment abs
- VTEC not working
- What are these called?
- i bought my 1st Honda... need some info
- quick question everyone!!!!
- Who makes good LSD for Integra GS-R's?
- DA Guys, need help: JDM bumper? Any different?
- integras and wheel rub?
- Car Shaking When Taking Off In First Gear..
- Quick question.
- want to sell my DA, whats it worth?
- Ok so my friends 94 teg has a p3-4 head on it.. whats that from?
- What would cause this? (Rotor turning blue...)
- components and process of an LS-vtec coversion??
- Want to take out back seats but need a way to cover up whats in the trunk
- wheel/tire question
- kW bloak Sealer
- 1/4 mile times in 2nd gen.
- OEM cap & rotor or local auto parts store brand?
- Need Help Identifying a hose
- SUGGESTIONS for B16A1 mods???
- LS TEGs.. and Vtec wiring Question..
- Smoking after VTEC?
- Wings West G5 Rear Lip
- Sideskirts w/ Jdm Front End?
- Should I second guess what Ground Control told me?
- i think i may have got a wrong brake pad?
- drag exhausts
- Compressor Engages but no Air?
- sorry if this is a repost but.. how do i..
- LSD for YS1 cable tranny???
- Ls vtec worth it?
- JDM 4-1 DC header
- 94 ls bore?
- Catback Rust
- pillow ball mounts?
- teg first visit to the track
- Remove driver airbag keep passenger airbag functional?
- I wrecked my car Today!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- aftermarket water temp gauge
- low idle & voltage readout
- Stock throttle body vs, ported on all-motor
- best method fuel tunning-rich/lean
- b16a head on a gsr block GAINS???
- NEW TO THE SITE....JUST SAYING HEY.
- G2 question about light bulbs in different area's of the car...
- how do u fix a broken eld..??
- Alternator?????
- Oil pressure quesiton
- damaged screw
- Painting the black rubber molding??
- greetings
- What Does It All Mean?
- Greddy MX
- B20B J-spec CRV motor swap
- dash and tails out.
- Will a JDM ITR FRONT sway bar fit a 94-01 Integra?
- Lug Nuts............
- Give up on the import scene?
- Teg is really sluggish, need help
- Loose gear shifter????
- someone pls install my windows
- dc2 ground controls in a DA?
- just a few questions i had
- FS: 95' Integra Airconditioning. ALL HARDWARE AND LINES!!!
- Head gasket trouble
- teg won't start?!?!
- G3 Oem Foglights?
- Which is Lighter?
