View Full Version : Acura Integra
- Compensator Adjustment?
- CAMSHAFTS 91 integra
- Lsv or gsr,?
- Heater wont work
- 98 Integra Oil Filters
- Gsr will not start
- B20 swap
- 3 PIN oval plug obd2 B-series alt?
- How much will this cost me? (GSR head)
- Acura Integra b20b turbo won't run after mechanic work
- Integra hatch dash light always on?
- Need help Guys for my DB1
- Acura integra smog
- hardwiring my tail lights 92 da
- Sharing a much easier way to clock your suspension bushings.
- 99 GSR
- I need a Good DA9 Mechanic in L.A.? I'm Keeping It!
- B18 / LS Intake manifolds all the same??
- CEL stays on, fuel pump doesn't prime
- b18c1
- Coolant spill left side of engine
- Carbon Build up on exhaust valves
- 2 questions ! Help me!
- Need Help On My B18C1 OEM Rebuild
- 94 db8 fuel pump problems
- 1995 Acura Integra RS
- Trouble finding the right JDM GSR throttle body gasket.
- ECU code 71 need advice
- Uh-oh, rear toe-in.
- What Should I do With My Integra? (DA9)
- Integra Tach and Interior Lights having problem, Halp please.
- Oil pan for b18c
- Abs sensors the same across civic/integra?
- 97 Acura Integra LS gaskets
- 94 rs - outer parking lights not working
- OMG, 2000 DVP Gsr!!
- gsr part info...
- Vtec conversion
- car doesn't start when cold?
- 1990 Acura Integra GS - Should I fix or sell
- CEL code 1 and other ecu issues..(EM section won't help :<)
- Integra gen3 pas. Side axle stuck
- Help! Wtf is this noise/squeal/groan?
- Help with diagnosing oil issues
- 2000 gsr
- should i buy this or not?
- help for parts
- 94 Integra, b18b1 auto to manual conversion mount question
- Removing front support
- Front And rear window wiper issues
- Running lights dont work, but Brake lights do.
- LCD Alternative to Gauge Pods Project, Need Opinions!
- k swap shifter box help
- DA9 universal parts
- 97 integra ls (power window,wipers) issues
- Vtec Help!
- CRX GSR NA Build
- Crazy electrical issue
- Pressurized Radiator Hose.
- Halfshaft
- 91 b18b1
- Need help cant find this clip/retainer
- Idle control components, and their potential for failure
- shiiiiiiiiiiit...
- Water Leak in Trunk (Yes i've searched)
- Recaros for 650 worth it?
- Which is the best of these headers
- Gold Top in mine?
- Gsr hard to start while cold
- 01 GSR idle
- 98 LS Integra Cross member questions
- Should i replace the rear main seal?
- Is this normal for a throw out bearing?
- B18B1 help. 40,000 miles on the motor
- Engine is out, what shall I do?
- Trunk Supports: one of these things is not like the other
- Performance Shops in DC?: 2000 Integra LS
- 90 G2 Acura Integra Code 4 won't clear
- Windage tray hardware?
- Mixing clutch components, exedy w/ fuji
- Very troubling symptoms after a top end rebuild/head gasket/resurface
- Pressure plate bolt..size?
- h22 in a da9
- Just need some headlight clarification
- 95 Acura Integra Engine Harness
- Please help! Gas line is leaking badly! What are my options?
- 90-93 teg front lower control arm diy?
- Brake booster delete? good or bad idea?
- ITR trunk wall brace.
- What is going on with my door locks???
- Installing transmission
- Driver side door locks when handle lifed to open door
- Kumho Ecsta 4X II
- 92 acura integra problem
- 92 Integra GSi hatch, car cranks normal but no fire.
- So long Integra GS-R, Hello G37s
- Aftermarket Suspension Parts Advice: '92 GS-R
- Integra Runs super rich
- 92 integra cuts out
- OBD1 teggy time
- Da struts on Db springs
- gsr head
- 92 integra repeatedly turning off
- Can I use gsr rods and b16 pctx pistons in a ls-vtec if I turbo it
- Oil Temp Gauge install
- integras with 17x9s
- New owner of a 99 Integra ls
- 92 integra computer questions
- help me!!!!
- Took off Intake Camshaft cant get camgear TDC align GSR
- Fan switch size.
- Anyone got a integra on rota GT3's?
- Help with an exhaust build
- Ok, it has to be a swap.
- Acura integra part swap
- About brakes
- ITR replica spoiler with brake light on GS-R
- Cam Advice?
- 98-01 OEM Hardware for mud guards
- Would you buy this for $1,500?
- I need help with a problem.
- Key on 3rd/on position but trys cranking by itself
- Help! Crankshaft position sensor problem
- Gen 2 Integra Glovebox
- PF Mirror questions
- 94 LS DB7 build
- DIY Wire Harness
- engine help
- power steering with no fluid, okay or not?
- Random misfires after head gasket replacement
- All Motor VS Turbo
- Rhd da8 4 door harness in coupe
- 94 integra wiretuck help
- help
- help! can someone answer this for me?
- Hiro spoiler
- Gsr intake questions
- can someone answer this for me ??
- Possible head gasket leak?
- Tach cuts out when vtec hits??
- 97 Integra gs shift issue
- 00 integra no start help.
- 1995 Integra Daily/Future All-Motor Build
- PR4 to a P75
- Distributor going bad?
- 95 Integra door swap
- Possible rebuild
- GSR Valvetrain Questions
- Morning Starting Issues!!
- Maintenance on B18A1
- GSR Swap Low HP Numbers, No Vtec or some other issue?
- Sorry to ask a dumb question?
- 1992 integra taillights dont work.
- NEED HELP. Won't start
- 94 ls 93k miles
- need help to timing d16a3
- 94-99 B18C1 exhaust manifold on B18B1
- First post! Cluster/Climate lights not working...
- Smoking problem need help.
- Junk2 coilovers revisited
- Hondata CEL 11
- Fail start, no fuel.
- No cylinder compression.
- 2000 gsr multi cylinder missfire
- valve adjustment
- Rear exhaust heat shield HELP!
- What fits a da9
- Beater to Bearable RS Teg Restoration
- How do you adjust 92 Acura Integra clutch?
- Noisy b18c1
- Burning oil smell, what can cause it?
- Where is that cable going?
- What do you think of these spark plugs?
- 1991 acura integra ls hatch
- What brand of distributor?
- PCV/positive crank ventilation
- Clutch...?
- WANT TO BOOT MY b18c ! HELP ?!
- 96 civic ex with b18b1 motor issue need help
- Fuel pump not priming
- Hks exhaust
- First Car Problems
- JdmB18c W/B 16 Head
- K series axle stuck inside my GSR tranny help.
- Help/suggestion on my ITR project
- super tech
- going after market cams (gsr b18c1)
- 91 integra auto to manual conversion
- Weird issue
- 91 integra ALB ( anti lock brakes ) Help
- Vtec wiring
- Wire worx s2000 wireharness
- White smoke.
- Trying to boost my 1990 acura integra b18a1 engine
- Which motor setup would benefit me more?
- Oil line and can needed on b18c5
- GSR crank but doesn't start
- Jumps and cutting out b20v
- idle air control valve, PLEASE HELP!
- Gsr rebuild
- Best option for my integra
- eBay radiators
- manual ac to automatic ac
- Radiator leak?
- Anyone done the rear bumper cut on their 90-93 integra?
- Burning oil help!
- DA all clear tail lights
- Vibration from Flywheel or Axles??
- 89 Integra / D16A1 -- Weirdest Code 9 Ever
- b18b1 forged build
- My transmission went out
- GSR not starting after rebuild
- Need some help
- Ac delete
- Da9 JDM headlights
- Bad ECU but not, so hopefully this helps someone in the future.
- Bad ecu? 92 integra
- [B18C] TPS/Connector Issue Error Code 7
- Stolen! 1991 White 3-door Integra LS from San Bruno, CA 9/17/2015
- Swapped intake manifold car stuck in limp mode HELP!!!
- "What's it worth" mini/itr set up
- Aftermarket exhaust
- Need bolt torques for installing new idler pulley
- 95 Couple Hood Issue
- vetc rpm
- b20b swap bogging
- o2 sensor question.
- Timing help!
- What's this bracket for?
- Hard starting when cold - My problem solved
- 2nd gen integra coupe front end on 2nd gen sedan?
- broken dizzy - parts swap?
- Has anyone used these wheels?
- No air comes out in any setting!
- changed ignition and now car will not start
- o2 sensor cel on
- Bad fan switch?
- Trans shift fork spring and ball??
- Alternator
- 98 Integra getting too much fuel
- B20 Won't rev up after engine wash
- !!HELP!! OBD2 GSR Swap into 00 OBD2 LS Non-V
- Treaded water tube on side of head. b18c1
- Idle drops too slow between gear changes?
- Weird idle
- ls turbo bogging problem
- AC not blowing cold
- Auto Trans Faults
- 95 Integra Radiator fan not working wires not connected to anything but the Fan.
