View Full Version : Acura Integra
- Why is my car dying on me?
- how far do i tighten????
- 2nd update on car, still no fix, please read and HELP, losing faith!
- Bog, Hesitation, CEL..... HELP!
- AFC Hack
- anyone know how to remove the rear wiper?
- =Engine Mount Questions? Clunk/knocking sound
- Anyone hear this sound?
- Comptech/Koni Coilovers
- 11 + CR and slight Bore on GSR...use MSD ??
- AEM or Axxis Ultimate?
- custom or cat back
- cams shafts.
- ES Motor Mount Questions........
- My 94-97 Integra Front End Conversion
- will 205/50/15's fit my 94 gsr wheels?
- What Snap-on tool for valve adjustment?
- trannys with VIN plates all of them or R's only??
- never thought the day would come...
- crx w/ B17a....vtec problems!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- Integra LS AUTO turbo questions...comments?
- Raybrig Headlight Bulbs - yes or no? Integra 1-piece lights.
- have you guys had many teg's stolen in the Detroit area???
- LS auto tranny help
- Looking for Black rear panel!!!!
- asking for smog help
- How Do I Know
- Stiff Axel..Replace grease?
- How high can I rev....
- ok guys, i need ur uber observation skills .. !
- new rotors and pads
- Getting Sick On My Apexi N1 Exhaust what Exhaust has a deeper tone to it.
- 91 Integra Valve Adjustment
- f'd up gsr motor
- Where to find stock GSR and Type R radiators
- Gutted stock air box - or - generic intake? DA preferred, but all welcome.
- Install Questions -- Civic Fluidyne Radiator Swap
- manual conversion
- water=kabooom
- weight difference between dc jdm/honda jdm header?
- WTF: Honda Suspension bolts
- ITR Midpipe question......
- clutch
- Aluminum Flywheels...
- b20 in my integra
- Anyone here from TEXAS? got ripped off.
- Possibly Getting Herbed by Wheel Max
- 94-97 Front bumepr removal
- Crashed my integra today, have a few questions...
- Autometer gauges install help Please... A/F and VOLTS
- question..
- RS*R header ?!?!?
- there is a hole in my b-pipe, quick exhaust question
- Where can a buy an old school RSR exhaust for my 94 rs
- Spark Plug Wires
- SMSP is the man!
- radiator fan switch
- Names of Performance shops in Oregon
- Contest for Free Decals and Discounts
- HID help, bulb base is different
- apex ws exhaust rattling
- Stolen: 98 white Integra, Baltimore, MD
- need the pin outs for...
- I had a good month
- Help me tune my cam gears!!!
- Suggestions...
- tire size?
- what constitutes low pros?
- Good place to do Port and Polish in VA area??
- 87-93 Integra owners...does your car do this?
- Post a pic of OEM GSR fuel filter! Need to compare to my Cx, thanks!
- maybe stall, maybe something wrong
- Koni Shocks?
- mounting VIS cf lip on JDM front end (DC2)
- 90-93 integra gauge cluster wiring diagram?!?!
- How to fix the exhaust raddling?
- HKS Questions
- i have a 92 ls integra, changing the head to type-r would make it run faster?
- Persistent headlight problem
- do the distributer caps interchange between obd1 and obd2 tegs?
- SRD seat installation
- p28 ecu pinout
- Dyno'd the beeotch!! Finally..
- Radio Removal - Search no work
- 2l GSR build update...
- Caught a theif breaking into my 95 GSR and "beat him up" real good
- argh! what should i do??
- my integra boggs, i use to be turbo
- Brake Pads
- Those of you with Re-Painted OEM front lips. *PICS*
- Does anybody has this setup??
- What would you do with this......
- !!! Exhaust Question On pAinting a Exhuast !!! Hi-temp paint!
- HELP!!! Anybody Have a 1990 Integra RS Vacuum Diagram or Blow-Up Diagram???
- ITR Front conversion with standard Radiator support?
- quick question on 5zigen exhaust, anyone that has one could answer in 2 minutes..
- please answer this question about aem fuel rail!!! please
- off topic: how to search for integra stuff on ebay
- Taking off superglue...
- bsq or beaks??
- New track times.
- possible starter problem??
- H22 swap
- Prolbmes with RS*R cat back system.
- WHich is faster
- just bought a gsr, dont have much to spend...heres my goals, how can i get to them???
- MD Thieves Die
- motor weight?
- hit 9500 rpm!
- itr shocks into gsr..questions about install
- Need Help removing Power Steering Pulley
- blown headgasket symptoms?
- I think my car might die (95 GSR 80K miles)
- Struts vs. Sway Bars
- Wiring for resistor box
- difference between auto and manual motors????
- Greddy EVO-HKS Super Dragger-Skunk 2
- abs is on and my car is dead
- Still need help with PR4 wiring instructions for S-AFC
- Send me a Link please
- How come i can not post in for sale forum?
- MC on 90 Teg 4 door
- How to: Adjust ebrake?
- Does code 47 exist?
- JDMSKINS Install on suspinsion 56k jump off a building
- Smog/Other Help from CA/NV Residents
- Cant jump the ecu
- website request for da's?
- GSR Plate System. Please HELP!
- B18b water pumps
- Those with gsr's and 14" wheels
- April 19th Honda-Acura Meet in Holyoke,MA
- Rear Lower Tie Bar? ----- DIY or NOT ?
- LSD for Si transin a GSR 4 door?
- help with tires and rims
- 99 Integra GS specs
- integra ls with si pistons
- Okay desperately need a good body shop in phoenix/glendale/peoria AZ area
- Shock Absorber Recommendations for H&R OE Sport?
- OBD1 or OBD0
- gas gauge isnt working?!
- motor help??
- fuel pressure regulator
- 18" rims on an Integra? - Help!
- Something is wrong???????? Plug wires?????Help Please!!!!!
- Axis Rims
- what size tires should i get for my rims?
- need knock sensor
- Good price on Comptech Header
- Will DC JDM 4-1 header bolt right up to B18C1 head?
- cooling problems (rant + advice needed)
- Headers..ANy power
- IS there a diffrence between...a 95 gsr and a 98..gsr
- Whistling noise from intake
- What's the Best Radiator (C&R/Fluidyne/Koyo/PWR) and Best Prices?
- screw firestone tires...
- What can i expect from this combo
- Msd??
- New to the Acura/Honda scene
- any1 got the link for the
- Regular Maintenance for higher mileage engines?
- SAFC wiring for 92 RS
- 98 up vehicles cannot change cats???
- will this work??
- Next Mod...need advice
- Part Number for JDM Power folding mirror relay
- Air modification valve?
- P28 + B18C1 ??? HELP!!!
- obd2 ecu, how do i find out what code its throwing?
- Gear Ratios on a 99GSR tranny?
- Power steering fluid on 95 LSS Integra?
- E-Brake light on
- Toggle switch? Power cut-off? Help!!!
- Compression test #'s
- Screwed up frpnt end this morning !!
- update on hydrolock!!!
- Help ! Fluid above clutch pedal whats the fix
- How to mount catch can
- Where the Fook'd my post go
- ABS bracket in way of Lower tie bar install....
- Can you use the 98+ headlights with a 94 bumper?
- What could this be??
- good big brake kit
- Can I use my seatbelts with after market buckets?
- whats the difference in the AEM pulleys and unorthodox???
- HIDs do me dry
- how much does your dc-2 weigh?
- HELP...spring install.
- Got my GReddy Air Fuel Guage. EGT temp question
- Carbing Products?
- does the brand of intake really matter?
- 2.25 Magnaflow Oval - Resonator or No Resonator?
- Exhaust rattling
- d16a1 question
- best header for stock b17a
- RS-R exhaust rattle?
- 95 LS cams?
- Strange squeak
- different sizes on apexi n1
- Location for OEM Acura CD changer?
- OEM lip install ?
- clutch problems
- antenna wont go down? did a search.....no results
- Ignition Help
- compression test, think I Am doing it wrong
- Clutch pedal sticky, sometimes wont come all the way back up
- ANY NICE people in SoCAL?
- Apexi REV/SPEED METER - Anyone use this before?
- Clutch Lifespan?
- S-AFC wiring instructions for 90 teg
- Compcams....any good???
- OK take it From thE toP...
- clanking transmission...
- Safe redline for stock b18a???
- the teggie is finally coming around!!
- S2000 Antenna on a G2?
- Exhaust?
- im buying a dry kit from a buddy...he says i need new jets???...help me...
- removing rubber strips in rear wheel wells?
- JDM frontend lighting question
- what is the ECU number for 94 and 95 LS?
- ----Where do these wires go to?----
- 1.5 Drop Help
- help with glow gauges
- opening integra hood
- Xenon Lights..
- Beaks and BSQ kit and lower tie bar
- Installed H & R Race and back didn't lower ! HELP !
- Options for autoX/Blown Shocks?
- Knocking noise coming from underneath of car?
- Last Post Of Mine About JDM ITR Tranny On My LS
- help power door locks not working
- how do i install my new skunk 2 short shifter????
- Well the VA theives got another one
- Winner of Honda-tech sponsered E-town event!
- Need Tech Help: Car is SHOT
- Is it possible.......
- S2000 antena
- Exhuast help
- gsr stock rim question
- Buy My header!!!!!!!! PLease GREddy! 4-2-1
- TELL ME WHY! Oh why *Exhasut question here *
- Type R final drive
- got my high flow installed, question
- Is it ok to run stock airbox without the restrictor?
- will volk or daiyama lugs fit k1s?
- Dyno Day results: neo1z puttin' it down (& then mine)
- Dyno results
- Will Comptech ITR exhaust fit 94 GSR?
- 95 gsr axle same as 99 ls axle?
