View Full Version : Acura Integra
- hi people
- Purge Flow
- 14" steelies
- how muchhhh would this bee???
- Need advice. Eagle Connecting Rods. Torque Specs.
- rattling sound at around 3k -3.5k rpm, what's ur suspect?
- cel 4 . map sensor ?
- How long before clutch master/slave cylinder breaks?
- JDM Front End Conversion
- Timing belt ?
- Greddy turbo or jackson supercharger for 95 RS?
- QUESTIONS ABOUT BALL JOIN PLEASE HELP
- help find me these jdm fog lights
- anybody in slc utah area work at acura dealership?
- LOOKING FOR b118 ls crankshaft
- HEAT SHEILD? YES NO?
- Ebrake & Windows
- Piece it together
- Need basemap for itb
- obd0 to obd1 wire problem
- My hood won't open!! 94 teg w/ jdm ITR front
- Having trouble removing driver side axle
- whats the difference between a msd ignition and the oem one
- tokico shocks and skunk2 coils
- Neuspeed 4-2-1 header fitment problem
- running /w too much oil for a day.. what damage could be done?
- !!! NEED HELP PLEASE!!!!
- Another newbie to H-T
- b18c1, how much???
- Starter problem??
- time for oil change...which oil filter?
- 1998 Integra OBD2A ?
- buying a gsr teg tomorrow HELP ASAP PLEASE
- early build 1994 GSR
- Turbo & Engine Questions
- its broken help
- My car keeps stalling out on me.............any suggestions?
- pic request front lip!!!
- gsr vs. type r
- b20
- intake bypass for B18
- (((92 GSR DIAGRAM)))
- JDM Integra Rsi vs. 99/00 civic si i/h/e ? Is it just me or is it really odd?
- New and Wanted to say hello
- Power Steering
- What fuel pump to get?
- rear spoiler
- Quick tranny question
- Can crower 403 LS cams pass smog ?
- Torque spec for manifold exhaust
- how can i get my crank pulley off.
- 98 Front conversion
- Keyed!!!!
- Ecu Chip!!!! Help
- ls crank into a gsr block
- 99 civic si wing fit on dc integra?
- TIRE PRESSURE
- steering rack, 96 gsr
- clutch question
- Gsr power?
- wheel bearings
- EVAP purge solenoid
- already searched. intake manifold inlet size
- DIY Request....
- part number help
- what alternator belt? b16 crank pulley on a b18c1
- LS/VTEC Turbo
- how to tell
- MSD REMOVAL HOW TO????????? just change the dizzy cap and unhook the wires and DONE??
- did all DC integra motors have VIN #'s on them?
- bored out stock im and tb vs. skunk2 im and tb
- Irratic Thermostat
- 98 gsr.. pissed off.. need advice.
- Check out my new DA website
- skunk2 IM HELP!
- Just Bought a 93 integra need help
- Auto tranny problems on 99 Teg. Hard Shifting
- Suspension Question
- What companies make 2.5 inch diameter catback exhausts?????????????????
- HELP!!! Car counds like dirtbike, running rich as hell, cant figure it out?!
- need help plz
- Why is my rpm needle jumping around like crazy?
- Whose integra is this
- Hose From Head to Air Intake
- turbo question
- Defective ARP Connecting Rod nut. HELP I'm scared to put this crap in my motor!!!
- Skunk2 shifter question
- removing abs
- which is more accurate? Helms, Haynes or chilton?
- control panel problem! HELP
- USDM & JDM DC2, DB7 & DB8 Shift Consoles
- BAD heat - did research couldnt find any answers please help
- Photo Shop my ride
- no start with (video) HELP
- sunroof
- Build or buy?
- Build-up on inside of window
- mishimot radiator with mugen cap
- ecu question?
- Dent on integra, checking options.
- Clutch Problems
- problem starting... sometimes....
- Motor mount interchangeable, btw LS and GSR?
- Aftermarket Oil Pressure Gauge Question
- Transponder Key
- Gsr head questions
- quick question
- clutch options b18a1
- electrical problems with my teg...
- 96+ Integra Front Clip
- When biulding your head?
- break in question...
- Steering Squeak
- Tranny Help!!
- Stolen DB8 integra gsr in springfield VA
- car stalls after start moving 10 seconds, wtf
- Just found come cut wires...........HELP PLEAZE.........
- what are the symptoms of a bad dizzy
- help cold outside car will not warm up
- Windshield Wiper
- Power lock and window HELP!!!!!!!!!!!!!!
- Distributor HELP
- sk2 oilfilter
- Looking for header gasket for GSR 4-2-1 header
- how can i tell what header I got?
- b18 crankshafts
- Good or bad coil overs ?
- headlight question
- honda weight specs
- 15X6JJ 45?
- quaife LSD wont fit a J spec tranny?
- Code 43, running very rich, bad gas mileage?
- pic request dc with eibach prokit
- Tranny?
- Is there an easier way to remove a nut and bolt?
- b16 in 90 integra wont idle
- totaled my teg today
- Safe to run on disabeled ABS??
- Broke Girlfriend LS integra need help fixing...PLEASE HELP HT members
- whats my gsr swap worth???
- Question about alignment! Help please!
- Easiest way to separate axle and half shaft??
- Will this High flow cat work with jdm itr headers? Urgent need to know now!
- Jdm integra bumper support
- Top Fuel Full Catback System
- 96 GSR ran lean and melted a piston, anyone ever experienced this?
- Any one ever used these pistons and rings?
- Need help JDM front
- crower stage 2 cams? are they fine for my setup?
- FINALLY!! GSR TRANNY
- Drop-Zone springs...aware
- b16 timing issue Help?
- My RIDE
- Steering Wheel Creak
- reverse lights stoped working
- 97 ls, FITV?
- new exhaust but room for improvement?
- V-tec cracks too early!
- Will 13" wheels clear GSR brakes?
- Open header....car cuts off...wont start???
- Apexi WS2 exhaust
- STOLEN ACURA INTEGRA!!! SHERMAN OAKS CA
- Help with speedometer! it's acting up...
- infant baby seats
- GSR - Soft Brake Pedal - New MC
- da with 96gsr swap
- RPM and speedometer does not match?
- GSR for 20 grand?
- MY HONDA SHOULD I TAKE..
- PIC REQUEST
- i lowered my car now my drivers side sits lower than passenger
- what wheels do i have?
- b18c shortblock components
- school me on wideband o2 sensor
- Surging Idle
- '95 GSR running too rich
- DA/DC spring on Civic
- idleling problems
- 95 GSR INTEG. NEED HELP! ANYONE WHO KNOWS B16A!!
- Driver Side Head Light Is Dead.
- Going to replace my DC header back to OEM one!
- B20B ,B20z... questions look here
- CF sunroof plug: anybody have one
- jdm fogs
- new guy here
- Skunk2 vs VENOM
- Idle Messed up
- Fog light relay
- all motor gsr
- Tranny?
- Changing Tranmission Fluid
- help project/dream car
- Emissions Question
- Friend was following behind and saw black smoke out of my muffler!??!?!
- BAD IDLE
- Heater not working properly
- Timing problem
- aftermarket springs with stock shock
- need tranny
- Integra and GSR Spoilers
- 94 integra electrical starting problem
- 98 itr vs. 06 nissan ser v spec
- DA side skirts
- Mis-shift question
- dim dash lights
- Needed!
- I searched, but I wonder if anyone else has this issue with their G3.
- What Kind of Exhaust do you have?
- Time to replace the clutch
- where can i get an ecu pin?
- i put in a jdm b16a2
- Rattling WS2 Axleback after install
- Bleeding air out after a radiator change.. help.
- searched with no luck...98-01 integra with acura tl HID's?
- SIDE SKIRTS!!!!
- Parts I painted for a fellow HT SSBP
- megan headrs???????
- Bore my throttle body?
- HELP! how do u know if a GSR engine is Legit or STOLEN??!?!?!
- Spoon Wires vs. Any other
- gsr swapped integra, turns over but wont start.
- funny fog light phenomenon...comments/ideas please
- specs on gsr
- suspension install in stockton, ca
- powersteering pump
- how much
- any idea?? HELP!!!
- CV joint and intermediate shaft issues
- High beam for G2, DA
- cc and ac removal help?
- Electric Fans Not Coming On When HOT
- OBD1 GSR INTEGRA WITH B16A, NEED HELP!!
- 00 integra oxygen sensors
- 3 Tranny Questions
- Different Final Drive gear in YS1 (LS) cable tranny
- Need Help!! ASAP
- CARDONE cv axles????
- p72 obd2 ecu??
- does anyone know anything about this...
- trying to put the engine vacuum hoses on etc....
- CEL turned off automatically?
- Kind of scared removing head/ tips?
- Car is Boggind? Don't know why plz help
- Problem with a new gsr
- db1 squad?
- Stock LS and bad mileage....
- nsx brakes on integra
- start-up problem?
- Is there a numerically higher final drive ratio available for the S1 tranny?
- parts car up for grabs
