View Full Version : Acura Integra
- brake pads
- 95 integra LS-13 second dreams?
- h22 or built LS turbo in my 92 teg?
- Would 92-93 integra front bumper fit on 90-91???
- Any more suspension upgrades?
- cluthc pedal switch
- GC and Koni Yellows
- buddyclub pro spec exhust question.
- hmm first thangs first
- help me make a decision
- transmissions for k20, h22
- LED Retrofit with aftermarket tails...
- Barometric Pressure Sensor
- gsr bogging/sputtering 40-50% throttle.
- Temp. control slider hard to move...
- I'm gonna try to make this as painless as possible...
- temperature rises, radiator leaks
- hoses cnnecting to the intake
- HELP! having trouble with skunk2 manifold after installing
- Search! DA sidemarker template?
- Help blew diff out of GF's GSR at track
- ITR LSD into LS Tranny--ITR first gear needed?
- Wiring short or CD player problem?
- ARC Super Induction Chamber and Airbox
- ls Vtec question
- Anyone make a custom 6speed for bseries?
- dont know what muffler or exhaust it is ...
- passing emissions
- My 1997 Integra LS/VTEC Turbo's Transformation
- radiator fluid leak?
- stock gsr tire size
- Car Sputtering!!!! HELP PLEASE!!!
- LMA Failure
- window
- FS: 94 Integra GSR B20 vtec (as fast as Type R)
- DA lowering springs
- New Member
- Where can i get the part from? Or is there away around it?
- ls distributor in b16 head?
- HELP! Exhaust leaking like crazy? Please help w/ flange gasket
- Motor help?
- what tools are need to do a drop?
- wtb 94-01 integra 4dr wings west sides skirts or rear lip (SF)
- megan 4-2-1 header
- Engine Wiring Harness Diagram for 1995 Integra GS-R
- ITR brake/suspension upgrade
- CAI getting wet.
- Salvage titles?
- CRV trans fit in Integra?
- dead v-tec !!
- sunroof leaking. how much for molding?
- NO INTAKE, SAFE??
- stock integra rs
- LS VTEC wat da heck is it and how it works hahaha newbie wit ls/vtec
- GSR door panel swap
- GS-R running rich at WOT above 6000rpms
- DA leather wrap steering wheel??
- Hid lights for 98 integra
- civic and integra trailing arms the same?
- drag kit
- Did I lower my car too much
- Type-r T1R b-pipe will fit on GSR?? let me know FAST!!!
- adjusting cam gears
- Is this a deal?
- JDM Itr cat?
- Picture request::Back of a b18b1 motor
- my integra drawing (rice warning)
- Quick question opinion
- Is there anything wrong with putting 100% water for coolant?
- yellow lights (high beam) pic request..on dc's..
- I need a carfax - please?
- I have searched. Where does the 2 hoses on the breather box go. May be a new ? but just double cheak
- loud noise occurs when hitting high rpms
- gti or gsr?
- I'm fairly new, got a quick question...
- DA Glovebox Removal help!
- is there any difference between usdm gsr and R seats
- Which Fan is the Primary fan?
- Stock B18C1 what size piping will do that job right??
- Ok, what do you guys think?
- Integra Struts
- LS Tranny or GSR??
- anybody have jdm type R front for sale?
- B18C1 oil pressure question
- Help with Oil Screw
- Problem with 'search' ?
- WTB: Integra Tail lights 99-01
- *STOLEN* car! 1998 Boosted RS
- help - how much can i get for my integra?
- where do you DA owners put your guages
- Success to install JDM DB8 type-r carbon fiber window switch no any modification
- Ball joint removal
- any one seen the latest issue of scc
- rsx-s exhaust?
- How do I go about getting my block cleeved by Benson?
- Torn steering tie-rod boot.
- my tach n speedo dont work help!
- BUMPY ride with Tein S Tech in DA.....HELP!!!!!!
- Fuel pressure regulator
- FS: Winter Rims *cheap*
- 98 GSR Tranny - WTF ?! 5th Gear VTAK?
- exhaust
- Need Help to install SKunk2 IM B18C1
- Skunk2 intake mani on my LS
- S2000 gauge cluster in a integra
- 90-91 DA bumpers interchangeable with 90-93?
- FUSES KEEP BLOWING...PLEASE HELP!!
- stripped stud?
- green loop on a Digital 6 Box
- oops. cut wires to aftermarket tach in car with the car on and running. help..
- need a major help!!!!!
- ''tuning''
- ebay intake
- need to know where is radiator fan switch
- Integra Overhauled
- removing front bumper
- dynoed my gsr.....
- 2 wires from EACV go to where?
- Can a GEN-0 B16A1 Head work with a GEN-2 B18C1 Block? What happens with the distributor?
- Best Choice?
- my gsr is traded for...
- What color is this???
- 95 ls to Gsr swap not cranking over. What to check for?
- b20vtec or b20 turbo
- Dyno of my Type-r.
- Weird clicking sound coming from my distributor??!?!?!
- ksport suspension
- hit and run..
- Header question..
- FS: 01 INTEGRA GSR DRIVER SIDE WHEEL + AIR BAG
- Rear main seal leaking.
- ??? CHANGING TIMING BELT... WHAT ELSE SHOULD I REPLACE TOO ???
- i need some help plz
- corner light wire harness?
- super charged gsr
- cv joint question
- best rim size...
- Brakes upgrade recomendation?
- OBD2 chipping... is it really this "easy"
- Problem on my skunk 2 intake mani install
- 91 Integra LS Rear pad and rotor change..help me out
- Need opinion on NA!
- Different NGK o2 sensors, anybody know the difference?
- HAHA! here ya go!
- Tranny Gurus: What 5th gears can I use in a 92 ys1 (gsr) tranny?
- Do you have vtec Yo? VIDEO!
- ABS light
- clutch pressure
- Mechanic for Brakes in Socal Burbank/Hollywood
- rankin tx
- rota torque
- 1st gen integra swap ?
- 97 GSR test pipe fit a 95 LS?
- Funny Integra video.
- oil stinks! oil breaking down from heat?
- Will these fit, PICS
- Can you feel the VTEC?
- twin turbo'd GSR
- B18a to B16b
- hi i'm new
- my DC
- Radiator comping out: replace anything else?
- b20 with b16 head swap pricing?
- Frustrated: Exhaust piping and parts, Why cant they just have a standard size? PICS, Kteller exhaus
- Throttle cable??
- does anyone make rust repair panels for a 94-01 integras.
- Tein S-Tech Springs on your DC2...
- *Selling head lights*
- motor mount help
- questions about ls/vtec
- v-tec sel
- question about ABS
- code 41?
- bad clutch or bad tranny
- JDM DA '92-'93 Integra Turn Signals
- Who do you think would win? B16A SiR II DA VS. 95 USDM prelude VTEC
- need help, swapping GSR ecu to ITR ecu
- Apexi N1 vs Spoon N1
- just got 94 integra need parts for cheap
- Built turbo teg, NEED HELP
- ABS problem please help
- I NEED HELP
- exhaust from a 92-95 EX Coupe fit a teg?
- trouble shooting 87 teg
- my friend wants to install some springs
- 5th gear grindin
- i have a silver LS 2000 should i...
- Anyone got JIC Magic lower tie bar?
- Safe to run stock injectors and fuel pump with jrsc?
- your opinions PLEASE
- Where can i purchase a Koyo radiator cap???
- Cold Start Valve Assembly
- compression low...valves bent?
- Exhaust on rear sway bar....
- rear window washer is not sparying out washer fluid
- a delimma about what to do skunk2 manifold or cf hood, p72 or p28?!?!?
- Greddy 4-2-1 header w/ O2 bung fitment on 00-01 GSR (p/n 10551011, listed as 94-99 LS)
- s2k or type-r seats for a gs-r possibe?
- *SEARCHED* 98 Teg Lip Options
- non-VTEC, 2.0L stock c/r or 1.8L w/ ITR pistons?
- need help with ecu..
- USDM ITR CLUSTER PROBLEM!!
- Buying an LS Teg
- Wont start Battery,ABS,Oil lights on HELP
- QQ: Can i use NonVtec Alternator on Vtec motors?
- CHILLLLL
- suspension ? for daily driver
- 87 integra fuel issue?
- cracked header..any suggestions on what aftermarket ones to buy?
- what is bump and PM
- Sputtering problem in 94 LS
- vtec solenoid leaking
- Need help with intermediate shaft and DSS axles
- Loud pop in my suspension yesterday...
- type r sway bar and BSQ kit question
- weird temperature problem
- just restored a 95 teg and brought her back to life.....
- Shifter
- Omni or Tien Basics..? which one would u get..
- vtec malfunction???
- bell housing transfer
- b18b clutch in a b16?
- moonroof problems
- Pics of my RHD DB1
- Axles
- civic radiator for dc teg
- IM and TB question
- Meshies For 265
- new here with 92 GS-R
- Skunk 2 manifold for GSR
- GSR Intake Manifold
- gsr manifold question
- radio err-3 code, how to get rid of?
- im new to this..i wanna find a gsr motor..
- 94 gsr best year??
- INTEGRA SECURITY
- ran a shitty time why?
- greddy
- B16 ecu for ls/vtec
- half rad?
- gsr cams question
- decisions.....decisions...
- gsr question
- rear defrost button question
- dc ceramic headers
- Clutch Issues..........................
- My old integra proj. 56k=death
- o2 sensor?
- bumper removal???
- need suggestions on what to do
