View Full Version : Acura Integra
- $90 to ship a differential?
- Dif between Dot 3 & Dot 4
- painting the inside floorboard..any suggestions?
- PLEASE HELP Need Torque specs: Cam Holders?
- Which Lower Sway bar do I get?
- its been a while but still I need help.
- headers
- head !!!!!
- Helm manual question
- which head gasket should I use for ls-vtec?
- Help tapping ecu o2 sensor on P72
- b16a timing belt the same as a GSR?
- Anyone done business?
- need help with a dc sports header
- two quick ?
- Both doors scrape my side skirts!!!
- Blacked out light housings any body done that
- SuspensionKit Price check
- mysterious ringing sound
- will a rt cat fit?
- Help! Hit in fender and door wont open...
- 90-93 jdm b16a swap questions
- ass kicking
- Type R or not?
- Will 92-95 civic suspension fit on a 00 teg???
- rear bumper question
- (help) JDM climate control???
- Timing Advance, no CRAP, just FACTS
- MD/DC/VA - Anyone missing a Black Teg?
- What Tires is everyone running?
- vid of my car. check it out
- 3rd gear grindage
- Where did you mount your....
- Who's running CTR pistons in an LS block?
- Sway Bar / Coilovers - Where Do I Buy?
- Hub center rings
- looking for a DIY for ground kit??
- UR Pulleys
- SKUNK2 and KONI red
- the right way in installation/reassembly of suspension
- Skunk2 coilover or stock gsr springs?
- vtec controllers?
- wanted:94 ls ecu diagram
- How hard is to take out the whole dash out of an integra??
- JDM conversion
- difference in ITR cams with years???
- cam gear tunning on a stock gsr motor!
- Intake Question
- where can i get a JDM Integra Type R pedal set?
- RC Injectors
- Custom Piping?
- Help Serious Question...
- should i keep these pistons???
- Too stiff?
- what does it sound like the problem is...
- cut ignition wire?
- kyb agx or koni yellows for daily driving?
- removed p/s
- crap broke my oil pan!!!!!!!! sumoe help me out with this...
- What SHould I Do?
- Heres my list of goodies Im about to buy...
- Racing Seats?
- I have a question about alternator!
- Poll - Testpipe v. Catalytic
- B18C with CTR Pistons
- Maintenance required light on
- ebay CAI... im pleased.. write up.
- 14" LS wheels fit GSR?
- im gonna make a really smart move
- 99 Integra Black leather seats.
- clanking sound in rear suspension
- stripped stud...is the shop screwing me?
- What are good budget shocks/struts to run with ITR springs?
- resettin ecu
- what's the max psi the fuel pump can be used at?
- How many times can an Integra bumper be repainted?
- missing 1-2 shift => smoke
- Will a Skunk2 IM give the same or more HP increase as a CAI?
- How much Horsepower & Torque does a 94 integ have
- Intake Manafolds
- Changing Steering Wheel hub
- vtec contoller in an LS ?
- installing dc 4-1 header
- gsr tech ?
- gsr jrsc vs turbo
- Other Factory Wheels We Can Use- Guide
- is it straight to run AEM tru power pulley set with an unorthodox racing crank pulley
- ls throttle body...
- what kind of milege do u get with P28 chipped ecu?
- 95/96 gsr comparison q's?
- noise!!
- whats a rebuilt title?
- 91 Integra suspension set up
- clutch.....
- Curb damage?
- Help: tranny!
- What to do with '97 GSR
- Whats the difference between the 94-97 catback exhaust and a '00 catback?
- Setup question
- Just starting out
- Installing the JDM ITR cluster
- 98 type R ECU
- building a b18b need some input
- bill gude race package
- itr 22 and 23mm rear sways
- Cleaning ABS Sensor.
- ITR Cluster in GS-R?
- shock bolts
- fan switch
- So I did some data logging these past few days (CAI factual #'s)
- Intermediate shaft
- Major Problem
- another skunk2 coilover question
- Another Problem in the v-tech department
- Technical gurus needed here
- Acura w/ 135,000 miles
- Where can I buy a B18C1 Cylinder Head?
- wheres that post
- does anyone make amber bumper lights for a 92 teg?
- Special lugnuts
- part number for 94-01 head gasket?
- Another CEL code question!
- Can I bypass a OBD-2 knock sensor?
- b16 fuel injectors
- B17A owner's help out a 1st gen B16
- cheap cold air intake system
- Man This Movie Is Going to Suck...
- noise from 3k-4k rpms
- Anyone using Fujitsubo Power Getter exhaust?
- Help! I hope I didn't get ripped off, did I get GSR cams? pix inside
- B18B Throttle Response: Part > Full?
- electrical problems help!!!
- RE730's???
- LS Vtec
- ? about sensors
- WS axel-backs?
- se stock air box
- Integra vs. Prelude
- is a b16a oil pan the same as a b18b oil pan?
- How much would My AC system go for??
- B18A Block Fit W/ b18b Head??
- is it worth it for Skunk2 intake manifold for a Type R
- What seats to get for my 94 integra
- leather seats in 4dr
- Comptech vs H&R Sport springs
- Transmission life
- Valvetrain adjustment..how easy it is?
- whats the most embarrasing car youv'e been spanked by (embarrasing)
- Problem after VAFC Install........
- 95 4-door, bad rear camber.
- which springs lower the ride the most??????
- is it worth it?
- white smoke at idle and sometimes start up...
- clutch and car acting weird
- Greddy Evo sound certificate/ 50 state legal
- ES kit + doing brakes...Can I remove the Caliper?
- Where can I buy a B17A1?
- got enough water in my headlight to keep a gold fish in there. Help how do you remove the head light
- ever get this sound?
- Just buying a GSR
- Apexi N1
- Heat shield on Cat is rattling...how do i fix it?
- cooling fan/condenser fan problem
- new car
- Does anyone have 95 ls teg w/ CAI and AEM tru-pulley horsepower results.
- CEL Code?
- steering wheel question..?
- o2 simulator
- Acura wheel locks
- Skunk2 Intake Manifold
- How much to replace valve seals.
- integra parts car?
- Just bought '92 Integra - have some questions
- I found a GSR I may buy got some questions.
- Clutch Question
- noises after getting an alignment
- safc sensor settings help
- safe rev limit for Skunk2 head
- Tyre pressure for street and track?
- Does your DA get too hot inside?
- header help
- integra type r super grip timing belt
- help Mods, I've fallen and can't get up hehe
- Second Gen support
- Ok to burn a little oil?
- Haha, sorta stupid question!
- p72 question
- whats better mugen or spoon
- Hood problem on 3rd Gen Integra.
- Help needed on Engine sputtering
- Rear deck lid
- n00b here
- Question for All Turboed Integra's or Civic living in NJ.
- aftermarket civic springs on integra
- fan switch
- how much is it to have a motor rebuilt by a shop?
- whats wrong with my 92 teg? whenever i start it dies.
- taking a wing off a 2nd gen, and putting it on a wingless?
- the gizzer is bout to hit 76k miles...maitenance question
- Lame question: Which company's ITR wing for GSR with stock holes
- suspension setup....second time around
- all motor LS information?
- What would you recommend for patching up trunk holes after removal of ITR wing?
- Does this really do anything?
- How to tell if I'm buying gsr cams
- Need help weird rattle in engine bay!!!!
- Smog check??
- changing oil tomarrow...... a few questions for ya
- Anyone got information on these Optional equipment rims???
- Mysterious Oil Burning, tried everything
- already searched.......DASH REMOVAL
- Where to get a 98-01 REAR bumper?
- Need help!!!
- need help....nothing to do w/ integras
- resetting ECU
- passenger side window sluggish?
- gsr dyno
- 92-93 GS motor
- support bar for 4dr integs
- quick seat question
- Milling the head?
- stolen cars / how you protect them.
- LS/VTEC Build quick question
- n98' tailights on a 96'..will it fit?
- Help! Some nebie quistions (real newb)
- GSR Highway RPM and speed
- Need Help Locating Radiator Fan Relay
- Need help removing rear bumper
- Weird tranny problem
- newbie questions
- Goodyear Gatorback belts?
- Anyone have access to a GSR Helms electrical manual?
- Apexi N1 Cat Back Exhaust
- needed! 94-01 integra gs-r stock intake box..
- what windshield wipers are you using??
- What trim lines were available for 2000 Integras..
- Why is my tranny doing this?
- VFAC install
- difference in seats?
- B18A valve clearance whats spec? need tonight
- will this work?? need answers bout swaping motor parts..
- After thought on a failed timing belt replacement
- my friends open header teg
- Camber Kit ??
- vtec valve cover
- B18A/B valvetrain, who makes parts?
- Owned by a fuse and Arturbo!!
- how to prepare for turbo
- What year and model of the stock integra wheels were the lightest for the 3rd Gen?
- Please Read: Should I replace my timing belt???
