Question about stock 96 Integra shocks
When you're tightening the at the upper spring perch, the shock rod will turn with it if you don't use an allen key to keep it from spinning.
yeah when your taking off/apart (loosening) the shock/spring assembly or putting it together (tightening) you use an allen key/hex key to hold the shock rod stationary while your use a combination wrench to tighten the top shock cap/top nut.. otherwise as you turn then nut/combination wrench.. the shock rod keeps spinning and it won't break loose or fully tighten since the shock rod keeps spinning...
egg_baLLa
11
Apr 6, 2008 04:10 PM
supapoopa
Jan 18, 2003 07:10 AM
