- gsr clutch: axle nut
- top speed 89 integra?
- MORE TURBO PROBLEMS
- jdm integra?
- Using my cruise control=bad gas mileage
- Lubricating Window Tracks
- Need some help
- Skunk 2 Lowering springs
- NEED HELP!!!!.........please help me out...
- having trouble gettin 2000 b18b motor to crank in a 93 integ
- 2000 b18b into a 93 integ
- Watch your cars, mine was stolen last night
- c clip on bitch pin??
- Cruise Control Doesnt Work
- clutch question?
- maintance
- to those members with jdm conversion. quick easy question. thanks for responding.
- turbo or all motor
- HOW MANY lbs for a s STOCK FLYWHEEl
- 92 b16 teg Intermediate shaft problems
- gsr isnt idling right, not enough air?
- dealer charge
- Speedo cable - 95 GSR
- OLD BMW wheels clear GSR brakes?
- Does Anyone Know?
- STOLEN 91 2 door Integra *phoenix AZ*
- itr cams
- need a little bit of help regarding short wire
- ******* Question: 00 Gsr E-Brake Light *******
- what sensor..?
- motor mount question
- Gsr into a Ls
- Ebay intake with K&N filter, legal or not???
- Your opinion is actually desired! Plugs for my NA build setup
- Air suspension
- idle bounces constanly
- replacing manual trans fluid
- TUNE UP
- bore size = overheating???? searched....
- b18b head on b18a block
- what manifold to use
- weight reduction actual numbers (208lbs)
- 94-97 tail lights into 98-01 jdm tail lights
- is it okay to put a jack stand a while?
- owners manual
- EVERYBODY WITH DA,s SEND ME SOME PICS OF YOUR CARS
- problem when i painting my rims.
- cant get oil pressure
- SOS Engine
- Omni Power Coilovers
- questions about open headers
- Spark Plug Wire Question
- VSS affect performance in GSR???
- distributor problems
- B18c1 into 91 Integra LS parts?
- Please Help!!!!!!!!!!!
- 2000 headlights
- YS1??
- gsr clutch/flywheel installation
- fuel problem
- not really technical but just curious if this is a good price for these two parts..
- b18c and b18c1....searched
- How much motegi ff7s?
- need a quick answer...
- USDM ITR tranny a direct drop in on a gs-r motor?
- Valve Cover Gasket Set?
- passenger airbag connections
- 89 Integra Times
- Is this harness from an Integra of any year?
- GSR warming up ?
- engine jerks when shifting at high rpm's
- Mounting Intercooler in 98+ Bumper?
- Question about B18A engine.
- Wuts the name of this color...
- j
- Bought a 90 Integra W/ Turbo B18C MAJOR PROBLEMS NEED HELP!!!!!!!!!!!!!!!!!!!!!!!!!
- Where do you put transmission fluid?
- Spring Cleaning (56K... go bake a cake)
- SHAKING when doing over 70 mph my theet are about to fall
- question about p75 ECU..
- Calling ALL DA owners!!!!!!!
- JDM Integra Steering Wheel? or No?
- Vaccum Line Problem
- brakes grinding.
- front end conversion help
- Reputable garage in SoCal
- Car not running right.
- 1st Gen Integra
- question about body kits...
- Just installed OBX c/f intake on my 90 da
- pedals
- looking for pics of clean turbo integras
- gauge bulb
- KENJI Rock's
- Anyone with a blown head gasket on a B18B?
- 93 integra swap question
- REar caliper is too tight when it goes back on!
- STOCK GSR 1/4 mile time and TERM SPEED>>>
- sparco seat hits door when closed
- CF hatch
- Engine just dead.
- hondata question
- High RPM = No heat ???
- What size is the n1? *searched*
- What is the volumetric efficiecy of a JDM GSR
- mike and ikes in the defrost
- TROUBLE WITH 89 INTEGRA
- Hard Choice: GSR or ITR swap?
- tire wear/alignment
- Integra question: Interior
- what is a good asking price ??
- oh noezz teggy dead!!!! :(
- curious question to ask for ppl who tested skunk2
- B20A3 Motor
- Hello everyone
- JDM OBD2 B18c1 Swap
- LSD: OBX vs Quife
- Integra High Beams...
- Help me decide quickly
- Header, hi flow cat converter and cat-back exhaust system
- header collector?
- Greddy evo/stock exhaust??????
- Differences in coolant hose configurations between years
- Will a OBD2 Civic Wiring Harness work with a 1996 Integra?
- SRS code list?
- question about clutch?
- Clifford Alarm Question... Car won't start up..
- DA Armrest.
- 626 area Rota group N.. mugen replicas for sale
- testing a head for bent valve
- Skunk2 ECU's???
- on the drive axle
- DC2 CF hatch
- what is this part called?
- how to tell the difference between obd1 and obd2 harness
- DC2-DC4 exhaust difference!!!!
- BURNING OIL
- What type of motor do I have????
- where could i find cams for an b18b
- Antenna won't go down?
- b18 swap trouble
- Head... which setups work best?
- b18b rev limit..
- gsr oil filter questions
- anyone using the TEIN luxury springs..??
- NSX like Integra or vice versa?
- For All the Haters..
- Gauge cluster works but none of the lighting.
- Apex'i RSM stolen!!! How to convert back to original wiring?
- GOod Deal?
- Horn doesnt work...:(
- New to honda-tech, check out the teg...
- Valve Ajustment: How to Line Up Cam Gear
- H.I.D. Conversion for my teg
- Extra Wires from swap!?!?!?
- maintenence help
- post pic of 94+ integra lowered on blades with no spoiler
- removing super glue on car?
- I am off to see the wizard! The wonderful wizard of KMS.
- clutch pedal height adjustment
- RS R racing coilovers and KYB AGX setup
- jdm front end install??
- 90-93 DA Integra H22A motor mount kit
- How many CC's GSR STOCK
- Tic Tic Tic noise in Engine
- Quick Noob Q.
- JDM front bumper cover
- Where can I buy rear valence hardware? Prefer OEM.
- Brake Pads????
- oil pan gasket
- obd1 gsr in 96 ls
- Motor mounts suck!
- Nead advice on camshaft
- Quick question about offsets
- looking for these parts
- TIMING HELP!!! WIERD SOUNDS ON LS-VTEC!!!!
- 97 integra tail light question
- shops near in florida??
- TURBOED INTEGRA PPL.......intake mani upgrade or waste of money?
- Thermostat Cost
- Best Suspension Setup for a DA9
- Gauge Cluster dont work HELP PLEASE
- small upgrades for acura integra 89
- My 1997 Integra LS/VTEC Turbo's Transformation (CONT.)
- interior light question
- Map Sensor on my obd0 LS to my GSR swap
- GSR PICS....
- Rear mount brace bolt size
- maintenance light
- help! brakes gone bad.
- removing ABS
- GB B18C HELLO H22
- exhasut...
- TURBO INTEGRA PROBLEMS
- eibach pro kit/ Kyb agx combo
- water pump
- timing belt
- Camber control arms
- b-series thermostat all the same?
- is it good to chip an ecu.
- obd0 motor into 0bd1
- help car is ticking at idle??
- post pics of your 90-93 integra aftermarket crossmembers/traction bars!
- fan dosnet come on?
- cluster light is out
- Are small pets living in my car?
- 90 91 integra header
- if a voltage regulator is faulty what syptoms would be occuring?
- 1st
- 95 Integra Stolen :(
- ECU Question!
- what a stock gsr "should" run and reaction/total time
- Rear mount, inserts, last bolt...
- bushings
- motor mounts
- Window Switch
- ***What is the highest comp. ratio for daily driver***
- DA and DC belt buckle mounted on seat the same?
- show me your muffler
- Gas and Temp Gauge not working correctly?
- Modding stock antenna to come only halfway up
- injectors ?????????
- 92 gsr abs to 90 rs non-abs HELP!
- painting wheels
- Da Hood Latch Work On Dc4??
- what color should i paint my car!
- help!!!!!
- ls vtech
- show off your ls!
- Can a JDM G3 Headlight fit a G2 teg??? HELP
- What's involved in the 100k mile service?
- Go into a crash and don't know was wrong with suspension
- cluster shift light?
- New parts
- Question about Drag Racing.
- gsr shifting problem
- Swapping in motor. Have a few final Questions. DA9
- Measurements for the trunk area
- Interior lighting...
- hey im new to this site
- obx twinloop wtb
- Motor Mounts 99 LS
- Why would an exhaust get louder?
- HELP.. CAN U TELL ME IF THIS IS A GOOD DEAL
- torn tie rod end boot
- integra front end trouble.
- Coolant Expansion Tank aka Coolant Reserve Tank
- need some help on removing drive axel nut
- noise at high revs
