View Full Version : Acura Integra
- Where to buy a Power Steering Rack?
- quick question about cam caps
- Where to get Redline MTF?
- RHD ITR
- '98 Integra RS
- Clear taillights
- To those with del sol seats in Your G3 integra
- People's Engines
- Horrible noise, any ideas??!?
- New ABS lip - USDM ITR style
- RADIATOR PROBLEM...I already searched, jus need confirmation
- Teg interior room space?
- car wont start, no fuel spraying from injectors
- what should i do with my old motor?
- For those who did the 9006>9005 conversion...
- 3rd gear
- Best Header for GSR
- : ( broken belt, piston to valve contact, shitty idle, bad compression in #3....help
- 95 gsr it starts but then it dies (what's the problem)
- OEM cluster mi to JDM cluster km swap.... DMV question!!!
- question bout strut?
- Ls motor/ tranny blew up ........
- thermostat question
- Integra Si Vtec (UK!!!) Brake Pads?
- whats the difference between a LS and a RS
- Guess what i got..
- Spun the #3 rod bearing
- Type R Catback
- front end conversion question
- Hot and cold air not as hot or cold as I thought it was
- ElectricAL problem- please help
- Is the B20 distributor same as a B18B??
- Advan Model 5
- bad trans?
- window wiper removal...
- Can anyone do a 'how-to' on how to change the brake/gas pedal assembly?
- RS and LS
- mugen side skirts
- CF Lip for USDM integra (searched like you wouldnt believe already)
- Anyone have pictures of the hydraulic line setup?
- APEXi N1 Question
- someone congradulate me (h22)
- turbo or super charger or typer head?
- busted my rim in the snow! (being dumb)
- attention all RHD owners!!!
- Your guys opioion....
- jdm gsr cams
- carbon fiber
- Rich or lean ??? before the engine goes boom!
- jg ib, dynamic autosports, or jdm dc header?
- Just got a teg, couple questions
- anyone w/ oem style 94-97 fog lights?
- What You Guys Think
- skunk2 IM install...need help getting gasket off
- tire sizes
- sticky
- my clutch...problem.?
- anybody using these coilovers?
- 96 civic muffler on my 94 DC2?
- exhaust settup
- stock fuel pressure
- jdm 4-1 header. look genuine to you?
- UP
- who here is using a Civic SI front bar or is thinking about it?
- GSR tranny for $200 with bad synchros?
- how to get airbags out of 94 gsr
- wondering..
- Help! - question about turbo'ing or supercharging my higher mileage GS-R
- clutch acting up, is it dieing?
- 90 teg distributor: odb-1?
- question about painting my teg
- transmission question?
- Cleaning SS Header
- question about stick shift...
- body parts
- Ok got pics. But
- better steering response with lighter rims??
- Type R LSD
- color code
- carfax help
- Installing Sparco Seats
- USDM Foglight Switch Wiring - How To
- What type oF bar is this?
- DA rear shocks?
- How to tell if it's oem
- Need Help!! Injector question...
- HATE my HATCH Light
- what white is the 1998 ls? frost or tafetta?
- Question for the people that race their integra's
- Selling my LS and uninstalled turbo kit...need $$$$$
- Water pump leak?? Help me decide....
- Xsreams Integra
- CEL 1 on my teg....WTF??? help please...
- airbag removed, now the car won't start?
- ABS Light
- Integra Water Pump....how to?
- Shift Light install???
- Integra horn wiring question, switching to airhorn.
- Bumping redline and internal mods in
- Hi...I'm new...quick question for you Teggy's
- ITR Sway (with BSQ kit) appears to be wearing the rear suspension bushings out
- replacing turn signal bulb
- How much for this integra.
- thread lock
- Is this right?
- CLUTCH BOLT QUESTION
- skunk2 shifter install
- need help installing air/fuel gauge and volt meter
- Differences between LS exhaust and Gsr?
- Powder coating in the bay area?
- coilover advice
- worn piston rings?
- fake badges.........need i say more?
- Easiest way to remove the rear mount for E.S. insert installation?? LS teggy
- Can I hit 13.5's in the 1/4 with this setup? and How much power can it make??
- Automatic transmission...grinding noise :\
- STOCK TIME
- Question vocabulary.....
- apex n1 gsr?
- Does Dent King work?
- Any ones LS run this strong?
- Problem with my turbo gsr...help
- DC 4-1 or 4-2-1....which one should I get?
- maybe i'm being retarded...(about maintenance light blinking)
- Matching amber interior
- FLYWHEEL BOLT QUESTION!!!
- Cost of Turbo
- Question about MC/BB w/ 5 lug non abs dc2 RS
- how do i get rid of condensation?
- B20B Integra is bogging bad..any thoughts on that???
- Power Steering Noises (Minor) & where to buy a new steering rack...
- got a parasitic drain...
- What kind of times?
- topic titles
- what seats are these
- Sunroof sticking how do I clean tracks?
- red line for ls motor.
- integra color question
- how in the F@#K do i post pics
- 5-lug conversion
- Need a little turbo part guidance.
- adjustables or not?
- integra want to buy....help me out
- will hasport EF Bseries mount kits fit DA?
- white spots on rear hatch...wtf?
- integra injectors in cc
- Brake light didnt go off this morning
- Power Antenna is DOA.....
- I think this is hopeless
- 94+ seats question
- b16 with ls crank vs. ls/vtec
- gsr Blades Question... Are they chrome plated or not?
- installing air/fuel gauge
- what sets of a fuel code (43)?
- Intake Manifold Q's
- Anywhere to get this rare "antique"?
- What are the Specs to put a V-tec Head on an LS Block
- Quick question - re: 2nd O2 sensor CEL on 96 GSR
- Coolant leak, what is causing it??
- Need Paint Code for my 95 Milano Red GSr
- rear wheel bearing??
- Hid in a dc questions.
- leak under dash...
- 3k rpm idle
- ECU Question
- Help me take my axle out? LS teg....
- front end problems
- Ecu codes: How long is a long blink and a short blink?
- cannot downshift to 3rd
- B18C5 swapped into my GSR??
- Another Starter Problem
- GOT HIT the day before SCCA
- acura/alpine cd changer compatiable?
- Best way to ship seats? heh
- Question about turbo mani, Lovefab SST for LS
- Pics of Integra catback
- Help with axle (inner cv - tulip joint separation)...only thing stopping me from testing my new tran
- Where Can I find this intake
- driver side upper mount bushing
- WTF IS THIS? I NEED HELP FAST PLZ!!!!!!!!!!
- Guessing game: What's changed?
- i phucked up my front corner lights >__<
- hid adapter
- momentary power loss..until..
- Post pics of your Thermal R&D exhaust!
- sfc vtec feilds help
- magna flow cat back
- Rear Windshiled Wiper Blade Removal
- Its Coming!!!
- n00b q about coolant
- dsr tanny syncros
- 91 integ a/c electrical problem
- intake?
- remote start accident!
- 2 Questions about Neuspeed/Koni's
- B17 distributor firing order?
- 100W 9005/9006 bulbs....safe???
- Carbing 3pt Fitment On My Ls...
- skunk2 intake manifold installed, 2 problems
- Is there any aftermarket motor mounts for DA>?
- are cams different on an auto ls and a man. ls engine? 90-93
- JDM Integra.........pics
- just got my teg out and got a ticket! CAn yall help
- abbreviations????
- dumb tranny question
- oil presure gauge?
- Help with driver's side door switch...?
- Suspension Setup
- What do you use to pinch the brake lines ?
- Clutch problem! Help!!
- Comptech vs oem itr
- what do u guys think about the ACT 4puck???
- H&R Race do not cut bumpstops?
- Need help asap with wheel assembly, can't get it back together!
- What clutch do you have?
- cat question?
- clutch getting very squeaky and seems to be more resistance..
- quick cat question
- Trying to make a Civic Type R engine
- B18b on B18a tranny?
- !HELP! Engine's running hot...
- idol ?
- 94 GSR and 90 Integra Fly Wheels the same?
- just bought a Griffin radiator
- gsr wheel wieght
- Checking tranny fluid on a '94 GS-R
- CTR CAMS
- Cars making noises
- Integra Ls b18 stock = how much horsepower ?
- replacing or change portion of power steering rack
- Interior Removal (seats/door sills): How easy to remove?
- Skunk 2 GSR Intake Manifold Official Thread
- cat sizing question
- JDM front end ques??? did search!!!!
- coilovers
- another question
- noobie me
- HELP ASAP........intermediate shaft problem
- Insane Gas Mileage
- Redline MTL or MT-90?
- how much to uninstall my viper alarm?
- 14.8X possible?
- koni yellow/ GC coils... problem....
- jdmtheory.com? good prices! anyone deal with them??
- CF Front Lip for 98-01
- integra rack and pinion
- trial user?
- gsr header question
- strange noise... very scared
- steelies or wheels?
