View Full Version : Acura Integra
- carbbbbb
- ► 1994-2001 (GEN 3) - All General information & specifications
- DA9 OWNERS IN THE BAY AREA
- if your smart?
- original engine? I think I got played =(
- Just got her
- 01 integra
- Does changing exhaust effect vtec?
- gsr b16 head timing belt problem.....
- itr exhaust vs 08 si exhaust?
- yonaka header
- vtec problem
- JDM Front End Headlight Question
- skunk 2 pro 1's question
- Type-R motor mount fits on Rs,Ls model??passanger side.
- excessive whining from abs relay
- Hard to find Part Numbers?
- LOL AT COPS, check this..
- mileage on my car might be too much
- Front and rear bumper
- new head timing question..
- car stolen... but i got it back with the engine and trans still intact!
- Hassle with seller (What is a replica ITR wing worth?)
- Black dash conversion. Problems with low and high beams.
- HELP PLZ ASAP
- 1997 Acura Integra Clutch Problems
- banjo bolt wont tighten help!
- JDM Sir-G Rear Seats?
- Radiator clogged
- obd0 b16 alternator?
- ignition problems? coil failure? hello from australia
- B18c1 Rebuild Kit
- how to make it hard to steal my car?
- da9 topic: 2.5" headers that will clear the crossmember?
- aftermarket synchros ?
- is the 5 speed ys1 strong?
- GSR with a LS motor in it. What kind of issues would this cause??
- Brake pedal getting soft when braking slowly
- ---------------keyless entry--------------------
- How rare is it to find a rear window visor?
- b18b1 in DA?????
- PANASPORTS ON A DA9?
- should i go LS VTEC
- should i go hydraulic with my 95 gsr?
- amber climate control
- part # for cw Honda caps for ITR wheels??
- DA HUB STAMP CODE!?!?!
- How to get my A/C working
- Stripped 1 of 3 bolts holding my Intermediate Shaft in........
- Engine Throws cel for vtec malfunction and random misfire on cylinder 3...Help!
- DA Avatar?
- throttle body/idle problem
- HOW-TO...92-93 bumper onto 90-91 integra da9
- Rod bearing problem??
- koni red struts
- HELP! teggys sputterin
- crossmember removal? ok or not?
- JDM b18c Automatic Cams?
- right way to burn out in a teg? (mt)
- Megan Racing M-OE Muffler
- what can be causing my doors to unlock out of no where??
- Idle Hunting - Stalls coming down from high rev
- loud noise comming from wheels?! and rubbing!
- 89 teg wont pass smog, with new cat.... ZC motor DOHC non-vtec
- Have one question? 1995 Integra B18A1?
- 0bd0 to 0bd1.... is it worth it?
- need help getting the name of a part!!
- Problem with IM and TB!!
- need help with a swap!
- brake lights stay on constantly. need to adjust pedal
- integra weather strip
- Loud Squeak coming from my DA
- recently installed new cams...looking for opinions on what else i should add
- heat shield for aftermarket headers?
- what computer/chip do i need in my DA stock b18a
- High idle when cold!!!help
- A/C compressor compatibility
- 1990-1993 Integra automatic to manual transmission conversion
- Jakeiscool Goes INTEGRA!!!!!!!!! Quick Question
- how much for a MINT 92 teg
- my car keeps getting wet inside!
- what does it mean
- Underdash/cluster/stereo wire harness question
- DA auto to hysro swap
- which is a better diffuser?
- TAN! TAN! TAN! Door Panel Insert ISSUES!!!
- E-Shift Performance in central New Jersey
- 96-00 ek9 type r lsd
- RC1000 injector questions?
- bought a 1990 integra rs
- Anyone know where i can find front and rear mud guards for a 98 DC4?
- battery / alternator problem?
- 95 4 dr integra exhaust!
- Odd sound coming from engine (b18c1)
- CAI for new IM
- Cracked valve cover
- 90-93 Integras with ABS wanting front strut bars
- DIY: DA trim / molding restoration
- b18a camshaft
- front speaker wires ?
- oem sides?
- Radiator Fan Relay and Wiring questions 90-93
- 1995 integra gsr
- new cams
- How to drop the trans DIY?
- dizzy problem????
- Front turn signals not working.
- help please: 91 DA Passenger Side Floor Leak
- b18 obd1 timing issue
- Where is G2IC? (obviously not tech-related)
- Clutch acting funny
- NO PCV VALVE, HELP??
- shark antenna
- O2 bung O2 sensor question
- type r swap in my ls......help please?
- Loud Exhaust
- Just Got An LS, Now For LS/Vtec Help Please On A Build!
- DA Integra Clutch Problem
- bumb stop cover problem/ strut problem...HELP
- Help! Axle keeps breaking
- greddy sp2 catback video clips
- Failed smog check!!! Help
- has anyone replaced their power window motor before?
- Lookin' for a writeup for the jdm antenna on the bumper
- trying to get more hp out of b16a2 going all motor
- lsd options?
- ECU doesn't have cel light or scan bar
- gsr build. help a noobie out
- block HELP!!!!
- Acura RSX Steering wheel on 96 Integra RS
- Advice for the youth who are thinking about entering the auto tech. field??
- STOLEN 2000 ACURA INTEGRA GSR, WHITE 4 DOOR, CHICAGO
- turbo my integra
- b16 or itr head?
- Wire harness troubles in black dashboard conversion
- Ignition Problem
- Tranny NUmbers
- DA JDM headlights
- jdm block usdm tranny and head?
- ANYONE know where i can find a bumper pole write up?
- advice for setup on 1990 DA
- Uh I think I have a nice problem on my hands... tranny? t/o bearing?
- Dashboard "maintence" wire harness question
- Da b16 Build
- HOW RARE IS A 93 GSR
- burns oil, go for b18c5 head?
- Stupid question??
- brake issues again....
- coilover tool???
- HELP TRANNY INSTALL
- The Real Cable to hydro conversion?
- Back Up fuse Keeps Blowing Up PLZ HELP
- cel 41 Primary Oxygen Sensor - Heater circuit malfunction
- Auto to manual conversion smog
- jdm integra headlight adjustment
- sunroof visor compatbility
- What type of Catback exhaust is good for 94 LS?
- NEED MAJOR HELP ASAP!
- Question about ctr pulley and belt?
- Built LS/VTEC starting issues
- How do yo take this off?
- yellow konis ASAP
- Cluster Light? What to do
- power pro and pro street suck
- B18 Rod options
- bad clutch or shot transmission????
- Muffler for 2.5in exhaust
- lsvtec swap....ls pistons gsr head!
- what is the name of this enkei wheel?? i need to buy 1
- integra gs-r swap problems
- fuel cutoff switch question
- Fender liners
- check engine light error..
- Limiter question
- Someone Stole the Teggie
- 05-06 RSX-S muffler bolt right up to 94+ integra's???
- 94 Jdm 5-lug integra Stolen at eibach springs...
- low compression piston Kit.....
- Brake light switch install ?
- Need Help Please!!!!!!!!
- Adjustable Springs/Coilovers
- does integra 94+ coilovers fit 90-93 struts?
- loose brake calipers??
- my new b20vtec pics and ?
- 88-91 civic taking 90-91 harness for LS-V? what do I change
- tranny filler bolt
- LS vtec
- Stolen '97 Integra LS in Cerritos
- Problem with upper control arm!!!!!
- idle problem with cool engine
- K20a2 into a DA. What parts are available?
- what ECU for LS-V in DC4
- da widebody kit?
- this integra is hot!!!!!
- input shaft bearing question.. searched.
- whats a Good Header for the money? b17a1
- shocks ranking?
- how to identify itr gsr and b16 shifters?
- spring question-? Tein S Tec
- over heating...=/
- hard shifting
- check engine light on after hit
- passwordjdm.com??
- A few problems.. fuel trim malfunction & tps codes..
- memoryfab intake questions
- B18C1 Head Re-Build HELP
- I NEED SOME HELP 87 INTEGRA OVERHEATING
- nipple on throttle body?
- weapon r headers?
- gear grinding problem....
- is it ok to increase the amp fuse?
- Integra SPOON front lip!
- 5th gear problem
- my DA bog's help me fix it, its my DD!
- fuse for speedometer? 00 gsr
- Fun Question for gsr lovers
- 1997 Acura 2.2 cl I just wanted to know????
- 96 GSR, rsx type s seats?? NEED HELP???
- ecu upgrade
- Looking for a ls head or vtec head for sale in the houston tx area
- clutch seems constantly disengaged
- Idle problem Identified, Valve on TB!!
- Newbie
- Car won't srart after driving.
- is there a difference between an obd1 gsr intake manifold compared to an obd2 one?
- Need radiator...Yonaka any good???
- air conditioner : coolish/not every cold air during day, and ice cold at night?
- Rear hub wheel bearing
- Any DB8 4 Door's with JDM ITR Exhaust?
- MY CAR WONT START!
- horrible sound
- What are signs of needing a Valve Adjustment?
- does a 92 oem lip fit on a 91 bumper iwth no mods?
- tranny swap
- js racing intake??
- WTB: Black Tweeters and Cup/Pocket Peice
- *Vote* - What Axle Brand to Buy?
- Check engine light? bad gas mileage?
- ******* Integra GS-R Tranny ?'s *******
- car is acting dumb???
- Im Swapping GSR head?
- skunk2 Cmaber kit issue!!
- ctr camshaft
- Ls vtec ?
- jdm headlights on a mugen front end??
- jdm sir-g (b18c) help!!!
- weatherstrip moldings.. paint or no ?
- Suspension squeaks over bumps
- cluster problem
- i;m afraid to even ask....head gasket diagnosing
