View Full Version : Acura Integra
- b16 on LS?
- JDM front end conversion paint and installation costs?
- Weird Electric Problem...
- Comptech Axleback w/ Apexi piping-will it fit?
- Wats a Good all motor chip For a 92 integra???????
- Upper Control Arms
- Difference between ODB 1 & ODB 2 Sensors? CEL Related
- USDM vs JDM swaps & differences
- Gaskets???
- FOR SALE DC SPORTS INTAKE
- How to fix a squeaky hatch?
- OBD2 -> OBD1 ECU; wiring harness + kick panel?
- SPARK PLUG GAP FOR GSR'S
- All Worries solved, a $4.17 part fixed my disaster!! No more oil consumption..
- Cleaning old pistons
- help vtec is kicking in at 6.2k-6.5k
- Help! Keep Blowing <Tail light, instrument light, license plate light> Fuse!
- What head unit?
- picture request!! anybody have an es oval on ther dc?!?!?!?
- How the hell do you remove wrist pin
- 9004 to 9007 conversion.
- WTB: Cam Bracket for integra motor
- ::pic request:: Apexi GT Spec exhaust
- 98+ Signal Light Bracket
- ABS removal / Fuse
- where can i get ............
- P420
- Photoshoot CAR needed! Chitown area and suburbs.
- Louder ticking after adjusting the valves WTF
- How much you think i can get for my teg???
- Swapped out LS and in comes GSR *AC Question*
- 94-97 OEM ALL AMBER CORNERS
- which would you decide upon?
- Help : Air leaking noise when I turn my teg off
- ITR 5 lug on 93 Integra
- 98+ OEM lip
- Skunk2 intake manifold or stock?
- Shocks Question?
- Peel out vid...
- Skunk2 Coils: Which sleeve goes where?
- lsd ????
- suspension set up
- HELP! smoking problem
- I need a TX shop for tbelt etc.
- Integra JDM DC2 Recaro Seats
- MUGEN Spoiler!
- V-Spec Coilvoers or TEIN S-Tech
- itr shift boot
- smelling fuel...
- REALLY WEIRD AND DIFFICULT QUESTION>>NE1 ANSWER IT?
- looking for a power steering pressure hose, found 2 but dont know which one if the right one.please
- Integra Frame Dimensions
- exterior door lock not working
- Climate Control Removal 94-01 Integra
- type r lip 98-01
- About to do some maintence
- b16 swap
- What psi should i be running for my fuel?
- Weight Diff
- gsr?
- NEED AN ANSWER ABOUT VTEC CONTROLLERS
- went to the track after i thought i fixed my car
- ITR rear wheel bearing question, is it the same as a GSR wheel bearing???
- ITR Rear LCA's on a 97 GSR???
- build LS or go b16a?
- wich air/fuel gauge should i get?
- running no sidemoldings
- Head milling?
- difference between gsr and ls muffler?
- 2" Header or 2.5" Header with 2.36" exhaust piping?
- Newbie
- cable trans input shaft?
- Whats the Difference Between Stock Fuel Pressure Regulators
- C&R racing radiator with air conditioning?
- Interior
- Intake Manifold Bracket?
- what kinda cat is everyone running wit jdm 4-1
- obd0 and obd1 ecu pinouts
- engine mount tq specs!
- LS Parts
- rollin on 17's?
- 2000 Integra factory alarm?
- Phantom IACV (1509) code
- 1994 RS Overheating
- Let's Talk SECURITY
- spark plug gap
- Exhaust question
- fs----msd digital 6
- fuel pumps
- seat belts
- CAR GOT BROKEN INTO!!!
- rsx front seats
- I got a question about my tranny
- ATS first gear
- Anyone install a cargo net?
- Please help me choose an Integra...
- Need help what should i do?
- V Spec Coilovers
- tire pressure at drag strip
- Purge Control Solenoid keeps burning out. ..... Help..
- Damn CODE 90!!!
- 92 teg ls vtec setup what do u think?
- Which ECU?
- Post your DC2
- lighting help
- Suspension questions, Need help!
- how to hook up autometer oil pressure gauge
- Is ther a Diffrence
- strut bars for 91 LS
- Check engine light after exhaust install
- Need pics of EP3 seats on DC2. EP3 not RSX
- 88-91 OBD0 B16A into a 91 Integra LS OBD0 Information
- who make 2 step igniton or whatever you call it
- cold air intake question
- Installing universal radiator fan? Easy Question! Need answer.
- few ?? before i juice the teg
- After Market Catalitic Converters & CA's SMOG test help,
- WHAT IS THE BEST FUEL MANAGEMENT FOR A TURBO GS/LS INTEGRA
- how would a shop charge to install jdm sidemarkers?
- Ignition Question
- DA's - should I go ls/vtec?
- New car ideas..
- help! 1995 ls motor not starting up!
- GReedy sp2
- Is it possible..................
- has anyone sprayed on LS before?
- i want more power
- HELP!!
- what clutch setup do you think would be best LS/vtec
- hydro and cable tranny ?
- coilover kits
- LS VTEC WIRING
- parting out a 91 teg
- hey all
- question about 94-97 to 98-01 front convertion
- gettting my turbo kit for my ls tomorrow!!!!!!!!!!
- What Brand And Size ThrottleBody For Mild GSR ?
- Integra port polish?
- ??? for all DA owners!
- first time at the track with my gizzer
- LS to JDM ITR Rear Sway Bar
- Cold starting problems
- D16Z6 head & gearbox on a ZC block?
- Shaky DA
- spark plug wires
- vafc 2
- gsr engine prob
- Type r head on a GSR block
- Anyone Still Doing Free CarFax?
- 1991 Acura Integra Misfire
- i think all of my motor mounts are ripped,where can i get new ones
- My 92 Integra RS : Pics
- Pics of the new exhaust
- AEM intake rattle problem. HELP!!!!!
- WTB:power steering pressure line
- help - failed smog test; ignition timing defective, N.O. = 568 when the max should be 467
- JDM Conversion?
- white or black GSR?
- Battery or Alternator?
- HELP ME!!!!
- gsr A/C uninstall
- B18C A/C COMPRESSOR
- super light DA E swap
- balljoint clunk
- Will After Market LS Engine Parts Fit In A GSR?
- b18 tans
- Difference between 2door and 4door DA front bumpers
- removing p/s, now what about crank pulley?
- How to launch a 95 GSR with BFG Slicks?
- how to know when its just the slave cylinder...
- hey im new
- Good mechanic/shop in North VA/DC/MD area?
- Sratching Sound from Driver-side back wheel
- K20 swappers
- Gas Mileage drop in my GS
- tq specs for motor mounts?
- B18a vs B18b...head difference?
- What do I need To make my teg have power windows and it is it hard?
- Burning fuel like crazy, HELP!!!!
- What's The Good Suspension Setup for H22 4 Door Integra??
- Will sedan integra taillights from a 95 fit into a 2000?
- generic jdm 4-1 header w/ 2.5 collector??
- EXHAUST RUST CANADA
- Distributors?
- HELP! I can get my driver's side axle out! i'm half way done :(
- JDM Integra Type RX Pedal Assembly..straight swap?
- WTB: Integra BARO sensor (black sensor box)
- camshaft marking
- P28 ecu and vafc?
- Frontend Conversion - Headlight Wiring help.
- k20 si motor or type R motor?
- Please help me find out about muffler
- '91 Integra LS exhaust
- DA Mugen Parts?
- h22 motor for 96 gsr??
- ls rods on b16 pistons
- Just finished my ls/vtec
- WANTING TO TURBO MY TEG
- What mods will i need to a gsr to be right next to Type R status?
- name of bearing/piece at the end of the axle
- Where can I get a full catback for my 98-01 integra LS
- do you need mounts for 92 integ?
- Is it possible
- idle problem?
- are all 94+ integra 4dr exhaust the same? searched...
- has anyone fabricated their blinker brackets?
- Bad to float gears?
- Honda N1 CTR Crank Pulley Belt Size Inside
- 01 GSR dipstick tube?
- 95 Integra LS opinions?
- where can i find brakets for my blinkers?
- is it OK to discard (mix) Used Man. Trans. Fluid with Used Motor Oil?
- headlights
- Pics of my 4 door LS on the juice (56k maybe)
- Stock CD player codes
- GSR Engine Loses Torque above 3500-7000 RPm. Code 43 Comes On - Help!!!!!!!!
- Will 94 RS catback exhaust fit on 2001 LS???
- Shocks Question
- LS vtec ...tranny choice ????
- Skunk2 Coilovers Question
- ep3 cd player in dc2
- how to mod a ls to perfection?
- New Integra owner with turbo Questions
- HI IM NEW
- Do 2000 and 2001 GSR's have special keys for the immoblizer?
- Is it safe to take top heat shield off?
- Exhaust help for 4dr GS-R
- How can I tell if my cars running rich/lean?
- NEED AN ANSWER TO A TURBO SETUP
- I NEED HELP ON THIS QUESTION>>ABOUT MY GSR
- header Studs
- Have GS-. put cam seal and thermostat in. NOW NO V-VTEC
- Internal Questions
- Recommend anything for car parts?
- LS-T
- HONDA Quint 5DR 1980. Is this the real 1st Gen Integra??
- new headers makeing chopper noise
- drillig noise while shifting
- Size of 90 integra rear discs
- VAFC problem on 94 gsr-help please
- da9 skunk2 mani. bogging please help
- JDM Fog Light Wiring Problem!
- help da9 products
- O2 sensor interchange... what Honda part #
- ls tranny shift at high rpm
- gsr to type r tranny worth it??????
- motor swaps
- LOOKING FOR LS TRANNY & AXLES
- 91 integra idle fluctuations!!
- LS to a GSR, really worth it?
