View Full Version : Acura Integra
- what should i do first
- What kind of Camber Kit should I buy?
- STOLEN Integra GSR!!!!!
- Need some help pictures for this turbo integra
- Im looking to buy a Turbo Kit!!! HELP
- car idle's at 5000!!!??!!
- How can i uninstall? pls help
- HELP INTEGRA PROS
- Don't know where to post this
- transmission
- EXHAUST
- 90-93 teg trannys cant work with 94-01 starter? Holes dont line up?
- Car freaking out!
- 94-up 4door teg with accord sideskirts??
- b16a3 96 teg. pulsating idle any suggestions?
- Need help with the a/c. the compressor kicks on but no cold air.
- Stolen In Milwaukee, Wisconsin : 92-93 Integra GSR White
- so i woke up to find this missing?
- power steering help
- JDM tranny questions....
- rattle noise at low rpms from front driver side.
- DC relay wiring HELP!
- ITR Clusters...
- car starts then shuts down?
- ?gsr exhaust outer springs with type r inner springs(valves)
- GSR civic WONT START!!!HELP!!!
- cruise control clutch switch
- gsr for sale!!!!
- When taking off the head, are both the cam gears set at top dead center?
- Pulsing lights
- Jdav's 92 Integra LS build thread!
- Lowering springs question
- removing floor tar??
- Help I Have A Tail Light Related Leak On a 91 Integra RS
- Tranny Questions
- 96spec 4x114 conversion
- tell me about iacv....related problems? 2 part question
- Putting a motor into a shell
- Ac took a crap today what gives ???
- Need A Catalytic converter To Pass Georgia Emissions Test...any help???
- exhaust/header fitment
- brake help!!!
- so i'm looking at struts/springs
- what steps should i take to freshen her up?
- Car only reving to 5000rpm's?
- Bay area Auto shops
- my da wont start
- kamakaze -> stock ls cat?
- Windshield wipers dont work
- Need some expertise.
- 98 Jdm B18b fuel rail bolt size and pitch (searched)
- What's your MPG?
- 99 GSR question? Need help and ideas?
- New to H-T 95 gsr
- fuel pump problem
- honda badges
- 90-91 integra front lip
- "S" drive in automatics...
- who is runnin 2.25 or 2.5 to stock muffler
- 1992 integra sputtering/hesitating
- obd2 head
- acura integra
- need help asap...............
- how do i get
- AC RECHARGING QUESTION
- N> help on my right high beam light
- Clicking noise when turning
- changing timing belt on ls
- hytech header replica clearance
- Ignition cylinder broken. Need help.
- how to register a car in the us....
- HELP!!! PLEASE... Axle problem
- What is the FASTEST engine I could put in a Integra?
- Can some one help me with a little problem...!!!!!!!!!
- need help finding a front lip for my DA
- 1993 Integra GS-R
- ls with b16 tranny 1/4 mile?
- oil on valve grommet
- gsr throttle cable problem
- Nitrous on DC
- JDM RECARO bolt sizes??
- Need a lil help
- question about calipers
- 2000 bumper on a 96?
- 92 GS integra steering column problem?
- car not starting...no spark.
- 90 ls turbo
- Will these headers fit?
- Engine Stalled and wont start
- 5 Lug swap no e-brake light
- head lights
- honda-tech website help
- GSR block with a non v-tec head?
- trunk
- how much do u think i am able.....
- No power to clock and to radio?
- need help finding front lip for my DA
- integra mirror question
- Can I use a DC driver engine mount bracket in DA ?
- 95 Gsr m/c is going out. Will 98 m/c work?
- B20B cam question
- ACURA INTEGRA NEW ENGINE??? HELP!!!1
- NJ/Ny tuning shops
- hey, help me
- What can I expect?
- 94 OBD-1 engine into 91 DA intermediate shaft question.
- JRSC
- 97 ls valve cover fit a 93?
- coilovers
- tuning specialists
- need help with windshield weatherstripping for 94 DB
- JDM FOLDING MIRROR PROBLEM ON MY DA
- 94 LS 4dr to 5lug question
- starting troubles...
- Calling on DC2er's - Post up all your rattles inside your car
- integra tune?
- usdm>jdm, 5-speed>auto conversion help
- Cardboard marking piece for Integra Window Visor
- anyone have pics of red gt3's on red integra or civic?
- ls/vtec
- gtg
- DC2 Integra with Skunk 2 Exhaust..
- ~~fixed clutch pedal, now car wont start :/
- Goldline Springs
- ls/vtec....b18b or b18a block?
- Help me???
- WIll this fit ?
- how much is this worth.please wacth
- Front and Back Bumper
- gsr swap
- Gear So Lose....
- what to do?
- 89 acura motor
- help with major oil leak..!!
- which turbo to use?
- Bumper??????????
- help!...turn nightbeams on...headlights lit, cluster and tails out.
- I Need help with my 89 Integra
- Should I get this 93 GSR?
- rear calipers pistons - help please
- Exploded views of the B18c... where can I find some?????
- p28,p30,p13 or p72
- Need a new GSR radiator...
- how much is this worth.video
- HFP Rims
- NEED HELP ASAP
- How to tell what year you engine is
- How to take out VSS
- need help, tranny swap problem
- will a b17a fit in a gen1 integra
- CEL's after fixing FITV problem
- Will a H22A run lean with a stock GSR fuel pump
- honda badges where can i get?
- OK...how about skunk 2 struts/shocks and skunk2 coilover suspension
- Coolant system flow problem PLEASE HELP!
- Motor swap question
- v tec head
- start up idle
- Coilover Difference between 90-93 & 94-01 Integra?
- OBDII to OBDI conversion - Failed NY Emissions
- clutch help
- how much life does this clutch have left?
- ls motor
- tranny question, pros come!
- Please help me fix my crazy steering issues!!!
- WEIRD RPM's!!!!!
- abs removal help
- car keeps spinning bearings on same cylinder
- I Need pro help.
- im looking for a speedometer in Kmph
- 95 Integra RS Burning Oil . . .
- wat kind of sideskirt is this?
- SPRINGTECH COILOVERS...?????????
- Help me with ecu wiring.............pix
- very weird idle problem
- camber question
- what is this car worth
- Is this a fair price for an rs
- carb sticker...
- I miss my stock all red tail lights!!!!
- Poormans Type R smoking BAD
- deciding on cams...do i need aftermarket springs, valves and retainers?
- need help on ac electrical
- Which internals should i use for ls on boost?
- An oem 94 integra LS header has 1.625" collector only?
- Previous GSR owner didn't use premium...
- removing fitv
- 96 gsr
- LSD Tranny
- I missed a shift ( It happens...) now I have a loud valve tic and unsteady idle....
- DA Diagnosis
- thrust bearings, throw out bearings, help!!!!!
- Installing a DB8 ITR Spoiler on my Sedan... help?
- Shiftpoint Miss/Grind
- iac intechangablity??(is that a word?)
- vtec problem
- would u recomend doing ls vtec?
- stock stereo question...........
- p28 ecu for an obd1 ls?
- Engine rocks after let off throttle
- Grinding 3rd gear, oil change helped, lots of tranmission questions, PLS HELP
- any aftermarket b-pipes out there?
- Engine bay too hot? & Oil light flashing?
- New guy with 1994 integra ?s
- brake lights?
- Greddy TT
- vtec vs non vtec for turbo charging
- LS special edition hatchback BRAKE LIGHT QUESTION
- 96 integra LS with gsrTransmission Stolen (East Orlando/UCF area)
- HELP! Car wont shift in First or Reverse
- Need valvetrain advice... b18c monster
- Dash light question?
- Weird Brake problem 89 Integra. PLEASE HELP
- what would be cheaper.
- Strange bogging/stalling problem/smoke from intake.
- Quick Foglight Question
- illegal drags
- Half shafts ruined already?
- Will work for Tune.... i need some one who can tune the hondata s200.
- 94 auto tranny same as 96 auto tranny
- oil leak problem around the vtec solenoid?
- Any help would be awesome
- 93 integra runnin super rich
- GSR head
- stock 95 gsr exhaust same as stock ls??
- Need help on a B20 engine with a Integra auto tranny.
- need help removing dash
- Burning Oil!!!
- hey team! is it worth it?
- 98-01 Turn signals
- what Stage clutch for each hp
- ebay turb kit?
- value of 00 Gsr
- compression tested
- exhaust...
- burning to much oil?
- Car wont start
- wtf with the vtak!!
- Hello everyone !
- Weird ABS light problem...
- So I was wondering....
- race
- what parts do you need to boost a b18b?
- oil flow
- oil pressure
- Coillover / Suspension setup needed for me 94 Teg H22 swapped
- Need a stock GSR .bin ASAP PLEASE!!!!
- what parts do you need to build a boosted b18b??
- Valve Adjustment - Loud if too tight or too loose
- Window seal - Air leaking
